  3. Starling 2 Max with Ublox F9P Ultralight
starling
7 Posts 3 Posters 1.7k Views 1 Watching
  • Sam KileyS Offline
    Sam KileyS Offline
    Sam Kiley
    wrote on last edited by Sam Kiley
    I am using the Holybro F9P Ultralight with the starling 2 max but am not able to get gps data from the F9P. This is in relation to this post, trying to get around the self-jamming gps issue on the voxl2 with modem stack:
    https://forum.modalai.com/topic/4226/starling-2-max-no-gps-data/44
    I have voxl-px4.conf GPS set to auto, so then it runs px4-qshell gps start.
    When I look at the px4 logs, I see this being repeated:
    May 02 20:57:54 m0054 voxl-px4[1746]: INFO [muorb] SLPI: u-blox firmware version: HPG 1.51
    May 02 20:57:54 m0054 voxl-px4[1746]: INFO [muorb] SLPI: u-blox protocol version: 27.50
    May 02 20:57:54 m0054 voxl-px4[1746]: INFO [muorb] SLPI: u-blox module: ZED-F9P
    May 02 20:57:54 m0054 voxl-px4[1746]: INFO [muorb] SLPI: GPS UART baudrate set to 115200
    May 02 20:57:54 m0054 voxl-px4[1746]: INFO [muorb] SLPI: Got ack to initial CFG_VALSET!
    There is never outputted this line: (Which form other forum posts seems to indicate a real successful connection):
    INFO [uORB] Advertising remote topic sensor_gps
    Also, my px4-listener sensor_gps says:
    voxl2:/$ px4-listener sensor_gps
    never published
    and then px4-qshell gps status outputs in the logs:
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: qshell gotten: gps status
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: arg0 = 'gps'
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: arg1 = 'status'
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: Main GPS
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: protocol: UBX
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: status: NOT OK, port: 6, baudrate: 115200
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: sat info: enabled
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: rate reading: 0 B/s
    May 02 20:57:33 m0054 voxl-px4[1746]: INFO [muorb] SLPI: Ok executing command: gps status
    I also went into the u-center with the F9P and made sure that ubx was a protocol for in/out.
    voxl-ardupilot doesn't have any issues connecting, so wondering if this is just a px4 gps driver issue specific to the voxl setup. I am on voxl-suite 1.4.1
    Any advice on this? Thanks for any info
    • Sam KileyS Sam Kiley
      never published
      @Sam-Kiley Not sure, we haven't tried that one yet. Since it works with voxl-ardupilot that pretty much confirms that it is wired up properly. You could try with a mainline build such as: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mainline-px4_1.16.0-1.0.2-202505070835_arm64.deb
        Sam KileyS Offline
        Sam Kiley
        Eric, Thanks, yeah I suspected that it was some sort of version thing with px4 where they support it now.
        Could you explain what the difference between mainline px4 and what I probably have loaded? or is it just because the VOXL SDK 1.4.1 is slightly behind?
          @Sam-Kiley our fork is based on pre-1.14.0 PX4. But mainline PX4 now runs on VOXL 2 at (almost) feature parity so the voxl-mainline-px4 package bundles up a mainline version (in this case v1.16.0-rc1).
            Sam KileyS Offline
            Sam Kiley
            I did wget from the voxl2 over wifi to get the package in / directory. dpkg -i on that results in this error:
            voxl2:/$ dpkg -i voxl-mainline-px4_1.16.0-1.0.2-202505070835_arm64.deb
            Selecting previously unselected package voxl-mainline-px4.
            (Reading database ... 105523 files and directories currently installed.)
            Preparing to unpack voxl-mainline-px4_1.16.0-1.0.2-202505070835_arm64.deb ...
            Unpacking voxl-mainline-px4 (1.16.0-1.0.2-202505070835) ...
            dpkg: error processing archive voxl-mainline-px4_1.16.0-1.0.2-202505070835_arm64.deb (--install):
            trying to overwrite '/data/px4/etc/extras/actuators.json.xz', which is also in package voxl-px4 1.14.0-2.0.94
            dpkg-deb (subprocess): decompressing archive member: lzma write error: Broken pipe
            dpkg-deb (subprocess): cannot copy archive member from 'voxl-mainline-px4_1.16.0-1.0.2-202505070835_arm64.deb' to decompressor pipe: failed to write (Broken pipe)
            dpkg-deb: error: <decompress> subprocess returned error exit status 2
            Errors were encountered while processing:
            I currently have voxl-ardupilot and voxl-px4 stopped and disabled.
            Any ideas on this?
              Any ideas on this?
              @Sam-Kiley Yeah, try dpkg --force-all -i <package-name>
              • S Offline
                S Offline
                shawn_ricardo
                wrote on last edited by shawn_ricardo
                Just wanted to share: Using this approach, I was able to integrate CubePilot Here4
                • Eric KatzfeyE Eric Katzfey referenced this topic on
