  3. Tracking camera calibration not progressing
voxl-cam
23 Posts 5 Posters 12.7k Views 3 Watching
  • P plub
    @Alex-Kushleyev Thanks. Now calibration is starting. Solution is to use 5x6 checkerboard with trimmed in half squares on edges. But even we can do full calibration, it says failed in the end. Re-projection error for stereo calibration ( standalone cameras calibrate fine ) is very high. Any solutions for this?
    @plub , could you please clarify which cameras you are using in the stereo configuration? OV7251?
    If the larger pattern was still detected by the procedure but was not accepted as a sample, this means that the pattern took up too little space of the desired area. You need to fill the desired area in each step almost completely, so that the sample is accepted.
    Also, is your checkerboard printed on paper and attached to a very flat surface without wrinkles? A poor calibration pattern can lead to poor results.
    Can you please post the result of the calibration? intrinsic and extrinsic parameters that are generated by the calibration procedure, even though it fails. Also please share the reprojection errors.
    • KnightHawk06K Offline
      KnightHawk06
      Hello, I'm having the same issue with the dual AR0144 1 MP tracking image sensors not progressing in the calibration sequence. I see some dark obscurations in the tracking rectangle and I am able to see the corners being counted but the calibration sequence never progresses.
      camera_calibrator_overlay_1744926606.png camera_calibrator_overlay_1744927851.png Media.jpg
      voxl2:~$ voxl-calibrate-camera tracking_down -s 6x9 -l 0.0254 -d
      Waiting for valid pipe...
      Please open voxl-portal in a web browser to view the camera calibrator overlay stream
      ^C
      received SIGINT Ctrl-C
      done sampling
      Exiting Cleanly
      waiting to join consumer thread
      Alex KushleyevA tomT 2 Replies Last reply
      • KnightHawk06K KnightHawk06
        ^C
        done sampling
        Exiting Cleanly
        Hello @KnightHawk06,
        This can happen because of lens shading on the AR0144 camera lens causing the thresholding (in camera calibration app) to not work as expected.
        Depending on the version of VOXL2 SDK you are using, there may be also tracking_down_misp_grey camera stream available, which is the lens shading compensated output for this camera. I believe it should work better for calibration purposes.
        Can you please try? If that does not help, I can suggest a few other tweaks, but those will require rebuilding the voxl-camera-calibration app.
        KnightHawk06K 1 Reply Last reply
          ^C
          done sampling
          Exiting Cleanly
          @KnightHawk06 You'll also want to add a -f to your voxl-calibrate-camera call for "fisheye"
            KnightHawk06
            wrote on last edited by KnightHawk06
            #11
            Thanks for the suggestion. I have en_misp enabled and I can see the misp_grey view in the voxl-portal, How do I command voxl-calibrate-camera to use the misp_grey view?
            kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
            hw platform:  M0054
            mach.var:     1.0.1
            voxl-suite:   1.4.3
                                                     "type": "ar0144",
                                                     "name": "tracking_down",
                                                     "enabled":      true,
                                                     "camera_id":    3,
                                                     "fps":  30,
                                                     "en_rotate":    false,
                                                     "en_preview":   true,
                                                     "preview_width":        1280,
                                                     "preview_height":       800,
                                                     "en_raw_preview":       true,
                                                     "en_misp":      true,
                                                     "misp_width":   1280,
                                                     "misp_height":  800,
                                                     "misp_venc_enable":     false,
                                                     "misp_venc_mode":       "h264",
                                                     "misp_venc_br_ctrl":    "cqp",
                                                     "misp_venc_Qfixed":     30,
                                                     "misp_venc_Qmin":       15,
                                                     "misp_venc_Qmax":       50,
                                                     "misp_venc_nPframes":   29,
                                                     "misp_venc_mbps":       2,
                                                     "misp_venc_osd":        false,
                                                     "misp_awb":     "auto",
                                                     "misp_gamma":   1,
                                                     "ae_mode":      "lme_msv",
                                                     "gain_min":     54,
                                                     "gain_max":     8000,
                                                     "ae_desired_msv":       60,
                                                     "exposure_min_us":      20,
                                                     "exposure_max_us":      12000,
                                                     "exposure_soft_min_us": 5000,
                                                     "ae_filter_alpha":      0.600000023841858,
                                                     "ae_ignore_fraction":   0.20000000298023224,
                                                     "ae_slope":     0.05000000074505806,
                                                     "ae_exposure_period":   1,
                                                     "ae_gain_period":       1
              hw platform:  M0054
              mach.var:     1.0.1
              voxl-suite:   1.4.3
                                                       "type": "ar0144",
                                                       "enabled":      true,
                                                       "camera_id":    3,
                                                       "fps":  30,
                                                       "en_rotate":    false,
                                                       "en_preview":   true,
                                                       "en_misp":      true,
                                                       "misp_width":   1280,
                                                       "misp_height":  800,
                                                       "misp_awb":     "auto",
                                                       "misp_gamma":   1,
                                                       "gain_min":     54,
                                                       "gain_max":     8000,
                                                       "ae_gain_period":       1
              @KnightHawk06 , use voxl-calibrare-camera tracking_down_misp_grey <remaining options>
                KnightHawk06
                @Alex-Kushleyev Thanks! I was able to get to the 2nd calibration panel with the command below but the process became unresponsive a couple times and I had to reboot, I eventually was able to detect the corners in the 2nd panel but am unable to progress.
                voxl-calibrate-camera tracking_down_misp_grey -f -s 6x9 -l 0.0254
                  @KnightHawk06 , thanks for the details. I am not aware of the calibration app becoming unresponsive - do you have any details about that (at which point did it become unresponsive?). Any info you have on this would help. thank you!
                  KnightHawk06K 2 Replies Last reply
                    KnightHawk06
                    @Alex-Kushleyev The calibration image froze and I was unable to view any camera data in the VOXL portal, I also was unable to ping the device from my desktop until rebooting the device.
                    I'm still unable to complete the calibration process, are there any logs that I can review to see what's happening? Any other ideas of how I can proceed?
                      KnightHawk06
                      @Alex-Kushleyev You had mentioned there are some other things to try that will require rebuilding the voxl-camera-calibration app? I tried increasing ae_desired_msv and misp_gamma to help with the lens shading but I was not able to progress any further through calibration.
                        KnightHawk06
                        @Alex-Kushleyev Here is some more information on the calibration process freezing, the camera feed stops updating in the voxl portal.
                          #18
                          @KnightHawk06 , Please try building the calibration app from this branch : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-camera-calibration/-/tree/fisheye-stereo?ref_type=heads
                          Some time ago i fixed it up to work with fisheye stereo calibration, but also changed one parameter in thresholding to make it more smooth : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-camera-calibration/-/commit/0bce9a25c67e64a229cfcbad4b6ace3a5837ee1b#f221083d30a7ca966318f904682ecf4970341657 -- in threshold.cpp change the number of tiles from 3 to 5, so that the image thresholding is more smooth across the image (even a larger number like 7 should work even better, but i am not sure if i tried).
                          In the same branch I also slightly reduced the percentage of the windows that needs to be filled up with the checkerboard pattern, so that it is easier to have the calibration accept the pattern.
                          Another thing to try, to just reduce the cpu load, just temporarily drop the FPS to 15, so that there are not so many frames to process (you can change it in voxl-camera-server.conf)
                          I am going to take a look again at this soon and potentially integrate these fixes as options to camera calibration app (number of tiles, frame skip, etc)
                            KnightHawk06
                            @Alex-Kushleyev Thanks, this is very helpful. I checked out the fisheye-stereo branch and built and deployed it to the voxl2. I tried both 5 and 7 max tiles and also decreased fps to 15. The image is freezing less often during calibration and it is successfully counting the corners but does not progress past 0%. The 2 cameras are 4.5 cm apart, is that ok? Are there any debug logs that I can turn on to inspect why the calibration is not moving forward?
                            ~/git/voxl-camera-calibration$ ./deploy_to_voxl.sh
                            searching for ADB device
                            checking VOXL for dpkg/opkg
                            dpkg detected
                            voxl-camera-calibration_0.5.9_arm64.deb: 1 file pushed, 0 skipped. 417.9 MB/s (177172 bytes in 0.000s)
                            (Reading database ... 105707 files and directories currently installed.)
                            Preparing to unpack .../voxl-camera-calibration_0.5.9_arm64.deb ...
                            Unpacking voxl-camera-calibration (0.5.9) over (0.5.9) ...
                            Setting up voxl-camera-calibration (0.5.9) ...
                            Postinst script completed.
                            DONE
                              dpkg detected
                              DONE
                              @KnightHawk06 ,
                              Oh i understand now.. The red box in the overlay defines the region where you need the calibration pattern to be located, HOWEVER there is also a requirement for the area within that red box that the pattern must fill. So, in your case, the detected pattern is too small within the red box, so you need to bring the pattern closer to the camera.
                              In calibrator.cpp, look for the following:
                              //Each item represents a desired square in percentages of the image {x1,y1,x2,y2, fill threshold, #samples} from top left
                              On that fisheye stereo branch i lowered the thresholds for Fisheye patterns, but not FisheyeWide patterns, so you are still having issues (after trying to bring the pattern closer), you would want to slightly lower the fill thresholds here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-camera-calibration/-/blob/0bce9a25c67e64a229cfcbad4b6ace3a5837ee1b/src/calibrator.cpp#L272 (maybe from 40 to 35 and from 45 to 30).
                                @KnightHawk06 ,
                                KnightHawk06
                                #21
                                @Alex-Kushleyev Thanks, that definitely helped. I was able to get through calibration but I was moving the camera to track the board so I think there was too much motion, I tried again by keeping the camera stationary and moving the board but I was only able to get through 2 of the squares.
                                This one looks like it should have advanced?
                                voxl2:~$ voxl-calibrate-camera tracking_down_misp_grey -f -s 6x9 -l 0.0254
                                Running Calibration...
                                Matrix
                                [467.7722718958223, 0, 643.0951201881879;
                                0, 465.4675015580457, 407.219312862067;
                                0, 0, 1]
                                Distortion
                                [0.06879494760256116;
                                -0.06189410980661297;
                                0.09295232529748904;
                                -0.03719414450439851]
                                distortion_model: fisheye
                                Re-projection error reported by calibrateCamera: 1.55185
                                Calibration Failed
                                Max reprojection error: 0.60
                                This is most likely due to motion blur, please try again.
                                Exiting Cleanly
                                I went down to 30,25 % fill and was able to complete the calibration but I'm still getting the motion blur error.
                                Matrix
                                [469.8268457990205, 0, 645.2242591682075;
                                0, 468.3299010304277, 405.5249057705095;
                                0, 0, 1]
                                Distortion
                                [0.04544429816970399;
                                -0.02133881952988525;
                                0.08318821819789667;
                                -0.04616442017968726]
                                Re-projection error reported by calibrateCamera: 1.26416
                                Calibration Failed
                                Exiting Cleanly
                                  Matrix
                                  0, 0, 1]
                                  Distortion
                                  Calibration Failed
                                  Exiting Cleanly
                                  Matrix
                                  0, 0, 1]
                                  Distortion
                                  Calibration Failed
                                  Exiting Cleanly
                                  @KnightHawk06 ,
                                  You should double check something - is your calibration pattern perfectly flat?
                                  When I perform camera calibration, I use an LCD screen to display the pattern whenever possible, because the screes are typically very flat.
                                  In order to avoid blurring, you could (temporarily) limit the upper end of the exposure range in volx-camera-server.conf to something like 5ms and that should help. This will cause the gain to be increased (automatically) to achieve the same i mage brightness, which will result in a bit more noise, but it should be ok. After calibration, you can set the upper exposure back. Alternatively, you can set the exposure / gain from voxl2 command line like so:
                                  voxl-send-command tracking_down set_exp_gain 5.0 400
                                  (this should override the automatic exposure / gain control and set the exposure to 5ms and gain to 400 (4.0x analog gain).
                                  If you are still using the printed pattern, increasing the illumination in the room should also help make the image brighter and drive the exposure down, reducing the blur.
                                    @KnightHawk06 ,
                                    KnightHawk06
                                    @Alex-Kushleyev I initially tried using an LCD screen for the checkerboard, but the camera wasn't detecting it. Should I move the camera around when transitioning between boxes on the LCD screen?
                                    Afterward, I reverted to the physical checkerboard and moved slowly during calibration. Additionally, I switched to the stereo camera configuration (https://docs.modalai.com/voxl2-camera-configs/#c-10-front-stereo-only-ov7251). Calibration completed successfully, and I was able to start the voxl-dfs-server (after renaming the intrinsics/extrinsics files to match the DFS configuration).
                                    However, I'm still not seeing valid output data in the VOXL Portal. Both the DFS server status and journal logs appear normal. Any idea what might be causing this?
                                    The orientation was labeled vertical in the extrinsics file, I updated it to horizontal since the cameras are mounted in that direction, I tried both.
                                    voxl2:~$ voxl-calibrate-camera stereo -s 6x9 -l 0.0254
                                    Calibrating Left Camera
                                    using intrinsics guess for ov7251 stereo cam
                                    Matrix
                                    [512.0490656858071, 0, 317.943082105687;
                                     0, 512.9677676044445, 249.1010817824914;
                                     0, 0, 1]
                                    Distortion
                                    [-0.2223760024137635;
                                     0.2834698825913266;
                                     0.006375005556120415;
                                     0.001380405690556171;
                                     -0.3234049381178579]
                                    distortion_model: plumb_bob
                                    Re-projection error reported by calibrateCamera: 0.618295
                                    Calibration Succeded!
                                    Calibrating Right Camera
                                    Matrix
                                    [499.9941123870856, 0, 302.2300515222531;
                                     0, 500.0159138740167, 197.2845691878148;
                                     0, 0, 1]
                                    Distortion
                                    [-0.1920328131645855;
                                     0.1661211129668493;
                                     -9.2603546772169e-06;
                                     -0.0005742159007090549;
                                     -0.1386842520292771]
                                    Re-projection error reported by calibrateCamera: 0.654897
                                    Calibrating Extrinsics
                                    7 frames will be processed
                                    Processing non-fisheye stereo
                                    R
                                    [0.9998717783469182, -0.01301971984148091, 0.009322754990917012;
                                     0.01315096821001574, 0.9998132816974246, -0.01415816995820597;
                                     -0.009136678855605861, 0.01427895782876463, 0.9998563059074108]
                                    T
                                    [-0.09106229154044132;
                                     0.0003557888497092847;
                                     -0.01247277836064075]
                                    Re-projection error reported by stereoCalibrate: 0.921971
                                    Detected horizontal stereo pair
                                    Distance between cameras: 0.0911
                                    Extrinsics Calibration Succeded!
                                    Saved intrinsics to: /data/modalai/opencv_stereo_intrinsics.yml
                                    Saved extrinsics to: /data/modalai/opencv_stereo_extrinsics.yml
                                    Exiting Cleanly
                                    cat opencv_stereo_front_extrinsics.yml
                                    %YAML:1.0
                                    R: !!opencv-matrix
                                       rows: 3
                                       cols: 3
                                       dt: d
                                       data: [ 9.9987177834691821e-01, -1.3019719841480912e-02,
                                           9.3227549909170124e-03, 1.3150968210015740e-02,
                                           9.9981328169742456e-01, -1.4158169958205966e-02,
                                           -9.1366788556058610e-03, 1.4278957828764632e-02,
                                           9.9985630590741081e-01 ]
                                    T: !!opencv-matrix
                                       rows: 3
                                       cols: 1
                                       dt: d
                                       data: [ -9.1062291540441320e-02, 3.5578884970928471e-04,
                                           -1.2472778360640750e-02 ]
                                    reprojection_error: 9.2197082833254862e-01
                                    orientation: vertical
                                    calibration_time: "2025-04-29 21:24:04"
                                    cat opencv_stereo_front_intrinsics.yml
                                    %YAML:1.0
                                    M1: !!opencv-matrix
                                       rows: 3
                                       cols: 3
                                       dt: d
                                       data: [ 5.1204906568580714e+02, 0., 3.1794308210568698e+02, 0.,
                                           5.1296776760444448e+02, 2.4910108178249143e+02, 0., 0., 1. ]
                                    D1: !!opencv-matrix
                                       rows: 5
                                       cols: 1
                                       dt: d
                                       data: [ -2.2237600241376348e-01, 2.8346988259132661e-01,
                                           6.3750055561204149e-03, 1.3804056905561710e-03,
                                           -3.2340493811785792e-01 ]
                                    reprojection_error1: 6.1829492384868989e-01
                                    M2: !!opencv-matrix
                                       rows: 3
                                       cols: 3
                                       dt: d
                                       data: [ 4.9999411238708558e+02, 0., 3.0223005152225312e+02, 0.,
                                           5.0001591387401669e+02, 1.9728456918781478e+02, 0., 0., 1. ]
                                    D2: !!opencv-matrix
                                       rows: 5
                                       cols: 1
                                       dt: d
                                       data: [ -1.9203281316458551e-01, 1.6612111296684931e-01,
                                           -9.2603546772168998e-06, -5.7421590070905486e-04,
                                           -1.3868425202927714e-01 ]
                                    reprojection_error2: 6.5489679777844001e-01
                                    width: 640
                                    height: 480
