    PX4 stops running
    Starling & Starling 2
    879
    • kestrelsystemsbpK
      kestrelsystemsbp
      We are using two starling 2 drones for our project. On the first drone voxl-px4 starts automatically at boot and runs without problems, but on the second drone px4 needs to be manually set to run. This would not be a huge problem in itself, but px4 always end up stopping after a few minutes. I have looked into the logfile of px4 and it shows that on February 27th px4 was stopped, but what was done that day in particular is difficult to remember in hinsight
        Eric Katzfey ModalAI Team @kestrelsystemsbp
        @kestrelsystemsbp Can you disable the px4 autostart (e.g. systemctl disable voxl-px4) and then reboot the drone? Then start voxl-px4 from the command line and capture it's output (e.g. voxl-px4 -d)?
        kestrelsystemsbpK 1 Reply Last reply Reply Quote 0
        • kestrelsystemsbpK
          kestrelsystemsbp @Eric Katzfey
          This is what I get when I try to start PX4 back up again.
          Eric KatzfeyE tomT 2 Replies Last reply Reply Quote 0
            @kestrelsystemsbp That's the entire output from voxl-px4 -d? What version of the VOXL SDK is installed? Have you made any modifications to /usr/bin/voxl-px4-start or /etc/modalai/voxl-px4.conf? Have you made any modifications to the software on the Starling 2?
            kestrelsystemsbpK Eric KatzfeyE 2 Replies Last reply Reply Quote 0
              tom admin @kestrelsystemsbp
              @kestrelsystemsbp Can you post the contents of /etc/modalai/voxl-px4.conf
              • kestrelsystemsbpK
                kestrelsystemsbp @tom
                • kestrelsystemsbpK
                  @Eric-Katzfey Have not done any modifications to the software other than basic setup stuff for QGC.
                    Eric Katzfey ModalAI Team @Eric Katzfey
                    @Eric-Katzfey said in PX4 stops running:
                      @kestrelsystemsbp said in PX4 stops running:
                      What changes were made for that?
                        @kestrelsystemsbp Would also be helpful to see the contents of /usr/bin/voxl-px4-start
                        • kestrelsystemsbpK
                          #!/bin/sh
                          PX4 commands need the 'px4-' prefix in bash.
                          (px4-alias.sh is expected to be in the PATH)
                          . px4-alias.sh
                          echo -e "\n*************************"
                          echo "AIRFRAME: $AIRFRAME"
                          echo "GPS: $GPS"
                          echo "RC: $RC"
                          echo "ESC: $ESC"
                          echo "POWER MANAGER: $POWER_MANAGER"
                          echo "AIRSPEED SENSOR: $AIRSPEED_SENSOR"
                          echo "DISTANCE SENSOR: $DISTANCE_SENSOR"
                          echo "OSD: $OSD"
                          echo "ARTIFACT_MODE: $ARTIFACT_MODE"
                          echo "EXTRA STEPS:"
                          for i in "${EXTRA_STEPS[@]}"
                          do
                          echo -e "\t$i"
                          done
                          echo -e "*************************\n"
                          In order to just exit after starting the uorb / muorb modules define
                          the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
                          This is useful for testing / debug where you may want to start drivers
                          and modules manually from the px4 command shell
                          if [ ! -z $MINIMAL_PX4 ]; then
                          /bin/echo "Running minimal script"
                          exit 0
                          fi
                          Figure out what platform we are running on.
                          PLATFORM=/usr/bin/voxl-platform 2> /dev/null
                          RETURNCODE=$?
                          if [ $RETURNCODE -ne 0 ]; then
                          # If we couldn't get the platform from the voxl-platform utility then check
                          # /etc/version to see if there is an M0052 substring in the version string. If so,
                          # then we assume that we are on M0052.
                          VERSIONSTRING=$(</etc/version)
                          M0052SUBSTRING="M0052"
                          if [[ "$VERSIONSTRING" == "$M0052SUBSTRING" ]]; then
                          PLATFORM="M0052"
                          fi
                          fi
                          We can only run on M0052, M0054, or M0104 so exit with error if that is not the case
                          if [ $PLATFORM = "M0052" ]; then
                          /bin/echo "Running on M0052"
                          elif [ $PLATFORM = "M0054" ]; then
                          /bin/echo "Running on M0054"
                          elif [ $PLATFORM = "M0104" ]; then
                          /bin/echo "Running on M0104"
                          else
                          /bin/echo "Error, cannot determine platform!"
                          exit 0
                          fi
                          Sleep a little here. A lot happens when the uorb and muorb start
                          and we need to make sure that it all completes successfully to avoid
                          any possible race conditions.
                          /bin/sleep 1
                          param select /data/px4/param/parameters
                          Load in all of the parameters that have been saved in the file
                          param load
                          if [ "$ARTIFACT_MODE" == "ENABLE" ]; then
                          # Do not start the logger module if we are in artifact mode. Logging
                          # produces a log artifact. If there are currently any saved logs make
                          # sure to delete them now.
                          # Also remove the data manager file that may have saved GPS waypoint information
                          # in it.
                          # Use shred to remove all files so that they cannot be recovered.
                          # shred should be effective on the /data partition since it has this configuration:
                          # /dev/sda8 /data ext4 rw,nosuid,nodev,noatime,discard,noauto_da_alloc,data=ordered 0 0
                          /usr/bin/find /data/px4/log -name "*.ulg" -exec /usr/bin/shred -u -n 7 {} ;
                          /bin/rm -fR /data/px4/log
                          /usr/bin/shred -u -n 7 /data/px4/dataman
                          /bin/echo "Artifact mode has been enabled"
                          else
                          # Start logging and use timestamps for log files when possible.
                          # Add the "-e" option to start logging immediately. Default is
                          # to log only when armed. Caution must be used with the "-e" option
                          # because if power is removed without stopping the logger gracefully then
                          # the log file may be corrupted.
                          logger start -t
                          fi
                          IMU (accelerometer / gyroscope)
                          if [ "$PLATFORM" == "M0104" ]; then
                          /bin/echo "Starting IMU driver with rotation 12"
                          qshell icm42688p start -s -R 12
                          else
                          /bin/echo "Starting IMU driver with no rotation"
                          fi
                          Start Invensense ICP 101xx barometer built on to VOXL 2
                          qshell icp101xx start -I -b 5
                          Auto detect the magnetometer. If one or both of these devices
                          are not connected it will fail but not cause any harm.
                          /bin/echo "Looking for qmc5883l magnetometer"
                          /bin/echo "Looking for ist8310 magnetometer"
                          GPS and magnetometer
                          if [ "$GPS" != "NONE" ]; then
                          # On M0052 the GPS driver runs on the apps processor
                          gps start -d /dev/ttyHS2
                          # On M0054 and M0104 the GPS driver runs on SLPI DSP
                          else
                          qshell gps start
                          fi
                          fi
                          Auto detect an ncp5623c i2c RGB LED. If one isn't connected this will
                          /bin/echo "Looking for ncp5623c RGB LED"
                          qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                          We do not change the following parameters but QGC will complain if they aren't
                          being reported as "used" by px4. "Touching" them accomplishes that.
                          param touch SYS_AUTOCONFIG
                          param touch SDLOG_MODE
                          ESC driver
                          if [ "$ESC" == "VOXL_ESC" ]; then
                          /bin/echo "Starting VOXL ESC driver"
                          qshell voxl_esc start
                          elif [ "$ESC" == "VOXL2_IO_PWM_ESC" ]; then
                          if [ "$RC" == "M0065_SBUS" ]; then
                          /bin/echo "Starting VOXL IO for PWM ESC with SBUS RC"
                          qshell voxl2_io start
                          else
                          /bin/echo "Starting VOXL IO for PWM ESC without SBUS RC"
                          qshell voxl2_io start -e
                          fi
                          else
                          /bin/echo "No ESC type specified, not starting an ESC driver"
                          fi
                          RC driver
                          if [ "$RC" == "FAKE_RC_INPUT" ]; then
                          /bin/echo "Starting fake RC driver"
                          qshell rc_controller start
                          elif [ "$RC" == "CRSF_RAW" ]; then
                          /bin/echo "Starting CRSF RC driver"
                          qshell crsf_rc start -d 7
                          elif [ "$RC" == "CRSF_MAV" ]; then
                          /bin/echo "Starting TBS crossfire RC - MAV Mode"
                          qshell mavlink_rc_in start -m -p 7 -b 115200
                          elif [ "$RC" == "SPEKTRUM" ]; then
                          /bin/echo "Starting Spektrum RC"
                          # On M0052 the RC driver runs on the apps processor
                          rc_input start -d /dev/ttyHS1
                          # On M0054 and M0104 the RC driver runs on SLPI DSP
                          else
                          qshell spektrum_rc start
                          fi
                          elif [ "$RC" == "GHST" ]; then
                          /bin/echo "Starting GHST RC driver"
                          qshell ghst_rc start -d 7
                          elif [ "$RC" == "M0065_SBUS" ]; then
                          apps_sbus start
                          elif [ "$ESC" != "VOXL2_IO_PWM_ESC" ]; then
                          /bin/echo "Attempting to start M0065 SBUS RC driver for original M0065 FW"
                          qshell dsp_sbus start
                          retVal=$?
                          if [ $retVal -ne 0 ]; then
                          /bin/echo "Starting M0065 SBUS RC driver for original M0065 FW failed"
                          /bin/echo "Attempting to start M0065 SBUS RC driver for new M0065 FW"
                          qshell voxl2_io start -d -p 7
                          fi
                          else
                          /bin/echo "M0065 SBUS RC driver already started with PWM ESC start"
                          fi
                          fi
                          if [ "$DISTANCE_SENSOR" == "LIGHTWARE_SF000" ]; then
                          # Make sure to set the parameter SENS_EN_SF0X to 8 for sf000/b sensor
                          qshell lightware_laser_serial start -d 7
                          fi
                          if [ "$POWER_MANAGER" == "VOXLPM" ]; then
                          # APM power monitor
                          qshell voxlpm start -X -b 2
                          fi
                          if [ "$AIRSPEED_SENSOR" == "MS4525DO" ]; then
                          qshell ms4525do start -X -b 4
                          fi
                          Optional distance sensor on spare i2c
                          qshell vl53l0x start -X -b 4
                          qshell vl53l1x start -X -b 4
                          Start all of the processing modules on DSP
                          qshell sensors start
                          qshell ekf2 start
                          if [ "$AIRFRAME" == "FIXED_WING" ]; then
                          qshell fw_pos_control start
                          qshell fw_att_control start
                          qshell fw_rate_control start
                          qshell airspeed_selector start
                          qshell fw_autotune_attitude_control start
                          qshell land_detector start fixedwing
                          elif [ $AIRFRAME = "MULTICOPTER" ]; then
                          qshell mc_pos_control start
                          qshell mc_att_control start
                          qshell mc_rate_control start
                          qshell mc_hover_thrust_estimator start
                          qshell mc_autotune_attitude_control start
                          qshell land_detector start multicopter
                          fi
                          qshell manual_control start
                          qshell control_allocator start
                          qshell load_mon start
                          Only start the rc_update module if an actual RC driver
                          is publishing input_rc topics. Otherwise for external RC
                          over Mavlink this isn't needed.
                          if [ "$RC" != "EXTERNAL" ]; then
                          qshell rc_update start
                          fi
                          qshell commander start
                          This is needed for altitude and position hold modes
                          qshell flight_mode_manager start
                          Start all of the processing modules on the applications processor
                          dataman start
                          navigator start
                          load_mon start
                          This bridge allows raw data packets to be sent over UART to the ESC
                          modal_io_bridge start
                          Start microdds_client for ros2 offboard messages from agent over localhost
                          microdds_client start -t udp -h 127.0.0.1 -p 8888
                          On M0052 there is only one IMU. So, PX4 needs to
                          publish IMU samples externally for VIO to use.
                          imu_server start
                          fi
                          start the onboard fast link to connect to voxl-mavlink-server
                          mavlink start -x -u 14556 -o 14557 -r 100000 -n lo -m onboard
                          slow down some of the fastest streams
                          mavlink stream -u 14556 -s HIGHRES_IMU -r 10
                          mavlink stream -u 14556 -s ATTITUDE -r 10
                          mavlink stream -u 14556 -s ATTITUDE_QUATERNION -r 10
                          mavlink stream -u 14556 -s GLOBAL_POSITION_INT -r 30
                          mavlink stream -u 14556 -s SCALED_PRESSURE -r 10
                          start the slow normal mode for voxl-mavlink-server to forward to GCS
                          mavlink start -x -u 14558 -o 14559 -r 100000 -n lo
                          mavlink boot_complete
                          Optional MSP OSD driver for DJI or HDZero goggles
                          This is only supported on M0054 (with M0125 accessory board)
                          if [ "$OSD" == "ENABLE" ] || [ "$OSD" == "DJI" ]; then
                          /bin/echo "Starting DJI OSD driver"
                          msp_osd start -d /dev/ttyHS1
                          elif [ "$PLATFORM" == "M0054" ] && [ "$OSD" == "HDZERO" ] || [ "$OSD" == "DJI_MSP_DP" ]; then
                          /bin/echo "Starting $OSD OSD driver for $PLATFORM"
                          msp_dp_osd start -d /dev/ttyHS1
                          elif [ "$PLATFORM" == "M0104" ] && [ "$OSD" == "HDZERO" ] || [ "$OSD" == "DJI_MSP_DP" ] ; then
                          msp_dp_osd start -d /dev/ttyHS0
                          fi
                          Start optional EXTRA_STEPS
                          do
                          $i
                          done
                          • kestrelsystemsbpK
                              @kestrelsystemsbp Perhaps you can do a fresh installation on 1.3.5 and see if the problem goes away? v1.3.5 has a lot of test time on it and nothing like the issue you are seeing has been encountered by us or any of our customers so this is a bit of a mystery. I would try the fresh install and, without making any modifications at all, see if it comes up and stays up. If so you can start introducing any configuration changes you need one by one to see if any of them are causing the issue.
                              • kestrelsystemsbpK
                                @Eric-Katzfey How do I do that?
                                  @kestrelsystemsbp You can download the SDK from downloads.modalai.com,
                                  Untar it with tar -xzvf voxl2_SDK_1.3.5.tar.gz
                                  cd voxl2_SDK_1.3.5
                                  Install it with ./install.sh
                                  Although if there isn't a specific reason you're on 1.3.5, I would recommend updating to 1.4.1
                                  • kestrelsystemsbpK
                                    @tom That did the trick, thanks for the help!
