    Hires cam not working with voxl2
    1143
    • voxl-phoenixV
      voxl-phoenix
      I'm using a VOXL 2 flight controller with an M0173 Starling 2 Front End. The setup includes tracking camera, PMD TOF and a high-resolution (hires) IMX412 camera. While the tracking cameras and TOF are detected and functioning, I'm unable to get any response from the hires camera.
      I have tried reconnnecting camera again and reinstalled SDK. and downgraded to SDK 1.4.0.
      when I connected them first it worked properly and I havr disconnected the cable and connected again , it is not showing at all. I have checked reconnecting the cable properly multiple times. I even tried swapping Tracking cable to Hires but no use.
      Error I have got from voxl-camera-server
      fsync_en:            1
      fsync_gpio:          109
      connected to mavlink pipe
      Connected to cpu-monitor
      Starting Camera: tracking_front (id #0)
      MISP Initializing!!!
       Detected 1 platform(s)
       Detected 1 GPU device(s)
      Starting Camera: hires (id #1)
      ERROR:   Camera 1 failed to find supported stream config: 1024x768
      WARNING: Failed to start cam hires due to invalid resolution
      WARNING: assuming cam is missing and trying to compensate
      Starting Camera: tof (originally id #2) with id offset: 1
      Starting Camera: tracking_down (originally id #3) with id offset: 1
      WARNING: cam tracking_down (id 2) does not seem to be alive
      ------ voxl-camera-server: Started 2 of 4 cameras
      please suggest me any fixes for this.
      My SKU is :
      family code: MCCA-M0054 (voxl2-board-only)
      compute board: 4 (voxl2)
      hw version: 1
      cam config: 26
      modem config: ()
      tx config: ()
      extras config: ()
      SKU: MCCA-M0054-C26-T0-M0-X0
      this is my voxl-camera-server.config file
      cat /etc/modalai/voxl-camera-server.conf
       * voxl-camera-server Configuration File
       * Each camera has configurations for up to 4 HAL3 streams:
       *    - `preview` stream for raw unprocessed images from CV cameras
       *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
       *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
       *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
       * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
       * This file is generated from default values by voxl-configure-cameras.
       * Do not expect arbitrary resolutions to work, the ISP and video compression
       * pipelines only support very specific resolutions.
       * The default video compression mode is cqp or Constant Quantization Parameter
      	"version":	0.1,
      	"fsync_en":	true,
      	"fsync_gpio":	109,
      	"cameras":	[{
      			"type":	"ar0144",
      			"name":	"tracking_front",
      			"enabled":	true,
      			"camera_id":	0,
      			"fps":	30,
      			"en_rotate":	true,
      			"en_preview":	true,
      			"preview_width":	1280,
      			"preview_height":	800,
      			"en_raw_preview":	true,
      			"en_misp":	true,
      			"misp_width":	1280,
      			"misp_height":	800,
      			"misp_venc_enable":	false,
      			"misp_venc_mode":	"h264",
      			"misp_venc_br_ctrl":	"cqp",
      			"misp_venc_Qfixed":	30,
      			"misp_venc_Qmin":	15,
      			"misp_venc_Qmax":	50,
      			"misp_venc_nPframes":	29,
      			"misp_venc_mbps":	2,
      			"misp_venc_osd":	false,
      			"misp_awb":	"auto",
      			"ae_mode":	"lme_msv",
      			"gain_min":	54,
      			"gain_max":	8000,
      			"ae_desired_msv":	60,
      			"exposure_min_us":	20,
      			"exposure_max_us":	12000,
      			"exposure_soft_min_us":	5000,
      			"ae_filter_alpha":	0.600000023841858,
      			"ae_ignore_fraction":	0.20000000298023224,
      			"ae_slope":	0.05000000074505806,
      			"ae_exposure_period":	1,
      			"ae_gain_period":	1
      			"type":	"imx412",
      			"name":	"hires",
      			"enabled":	true,
      			"camera_id":	1,
      			"fps":	30,
      			"en_preview":	false,
      			"preview_width":	640,
      			"preview_height":	480,
      			"en_raw_preview":	false,
      			"en_small_video":	true,
      			"small_video_width":	1024,
      			"small_video_height":	768,
      			"small_venc_mode":	"h264",
      			"small_venc_br_ctrl":	"cqp",
      			"small_venc_Qfixed":	30,
      			"small_venc_Qmin":	15,
      			"small_venc_Qmax":	40,
      			"small_venc_nPframes":	9,
      			"small_venc_mbps":	2,
      			"small_venc_osd":	false,
      			"en_large_video":	true,
      			"large_video_width":	4056,
      			"large_video_height":	3040,
      			"large_venc_mode":	"h264",
      			"large_venc_br_ctrl":	"cqp",
      			"large_venc_Qfixed":	40,
      			"large_venc_Qmin":	15,
      			"large_venc_Qmax":	50,
      			"large_venc_nPframes":	29,
      			"large_venc_mbps":	40,
      			"large_venc_osd":	false,
      			"en_snapshot":	true,
      			"en_snapshot_width":	4056,
      			"en_snapshot_height":	3040,
      			"exif_focal_length":	3.0999999046325684,
      			"exif_focal_length_in_35mm_format":	17,
      			"exif_fnumber":	1.2400000095367432,
      			"ae_mode":	"isp",
      			"gain_min":	54,
      			"gain_max":	8000
      			"type":	"pmd-tof-liow2",
      			"name":	"tof",
      			"enabled":	true,
      			"camera_id":	2,
      			"fps":	10,
      			"en_rotate":	true,
      			"ae_mode":	"off",
      			"gain_min":	0,
      			"gain_max":	0,
      			"exposure_max_us":	6000,
      			"standby_enabled":	false,
      			"decimator":	5
      			"type":	"ar0144",
      			"name":	"tracking_down",
      			"enabled":	true,
      			"camera_id":	3,
      			"fps":	30,
      			"en_rotate":	false,
      			"en_preview":	true,
      			"en_misp":	true,
      			"misp_width":	1280,
      			"misp_height":	800,
      			"misp_awb":	"auto",
      			"gain_min":	54,
      			"gain_max":	8000,
      			"ae_gain_period":	1
        Alex Kushleyev ModalAI Team @voxl-phoenix
        @voxl-phoenix , if you use VOXL2 with the M0173 camera front-end, when you install the VOXL2 SDK, you need to select the option 2, which enables M0173:
        PLEASE SELECT WHICH KERNEL TO FLASH
        1. M0054-1 -> QRB5165M, Starling (D0005), Sentinel (D0006), FPV (D0008), D0010, PX4 Dev Kit (D0011)
        2. M0054-1 -> QRB5165M w/ M0173 Camera Breakout Board, Starling 2 Max (D0012), Starling 2 (D0014)
        The reason for this is the M0173 has different mapping of various GPIO that controls camera functions (including on/off). The camera GPIO control is done from the Kernel, so that is why a different kernel needs to be loaded if you use M0173.
        If you don't want to re-install the whole SDK, you can update the kernel manually:
        Test the new kernel without overwriting (will not persist after reboot):
        adb reboot bootloader
        fastboot boot m0054-1-var00.1-kernel.img
        Then you can adb into the board and do a quick test to see if all cameras are detected : voxl-camera-server -l will print at the top all detected cameras (in your case should be 4 cameras).
        To permanently flash the new kernel:
        fastboot flash boot_a m0054-1-var00.1-kernel.img
        fastboot flash boot_b m0054-1-var00.1-kernel.img
        fastboot reboot
        (in order to flash the standard kernel, use m0054-1-var00.0-kernel.img)
        In order to check which kernel variant you are currently running:
        voxl2:/$ voxl-version | grep mach
        mach.var:     1.0.0
        # this is the default kernel, not for use with M0173
        or
        mach.var:     1.0.1
        # this is the kernel for use with M0173
        If you are using M0154 (not M0054), It uses the same kernel as M0054, and will be detected as such.
        Hopefully this solves your issue.
        • voxl-phoenixV
          voxl-phoenix
          @Alex-Kushleyev Thank you for the advise , I have been using the kernal image which includes M0173 breakout board.
          voxl2:~$ voxl-camera-server -l
          DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0030, Sensor Id: 0x0356
          DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x007A, Sensor Id: 0x2975
          DEBUG:   Number of cameras: 2
          Stats for camera: 0
          1280 x  800
          1280 x  800
          1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  800 HAL_PIXEL_FORMAT_BLOB
          1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  768 HAL_PIXEL_FORMAT_BLOB
          1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  720 HAL_PIXEL_FORMAT_BLOB
          1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
          1024 x  738 HAL_PIXEL_FORMAT_BLOB
          1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
          1024 x  768 HAL_PIXEL_FORMAT_BLOB
           864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           864 x  480 HAL_PIXEL_FORMAT_BLOB
           800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
           800 x  600 HAL_PIXEL_FORMAT_BLOB
           800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           800 x  480 HAL_PIXEL_FORMAT_BLOB
           720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           720 x  480 HAL_PIXEL_FORMAT_BLOB
           640 x  512 HAL_PIXEL_FORMAT_YCbCr_420_888
           640 x  512 HAL_PIXEL_FORMAT_BLOB
          1280 x  800 HAL_PIXEL_FORMAT_RAW10
          1280 x  800 HAL_PIXEL_FORMAT_RAW12
          1280 x  800 HAL_PIXEL_FORMAT_RAW16
          1280 x  800 HAL_PIXEL_FORMAT_RAW_OPAQUE
          	min = 54
          	max = 1596
          	1596
          	min = 0ns
          	max = 1318629735ns
          Stats for camera: 1
           240 x 1629
           240 x 1629 HAL_PIXEL_FORMAT_RAW10
           240 x 1629 HAL_PIXEL_FORMAT_RAW12
           240 x 1629 HAL_PIXEL_FORMAT_RAW16
           240 x 1629 HAL_PIXEL_FORMAT_RAW_OPAQUE
          	min = 54
          	max = 0
          	min = 0ns
          	max = 0ns
          Number of cameras detected: 2
          voxl2:~$ voxl-version | grep mach
          mach.var:     1.0.1
          voxl2:~$
          I have TOF, tracking and Hires connected to the board it worked fine as soon as connected for first time than I can see no response from Hires but Tracking and TOF are working properly.
            @voxl-phoenix please make sure the cameras are connected as shown in C26 configuration https://docs.modalai.com/voxl2-coax-camera-bundles/
            voxl-phoenixV 1 Reply Last reply Reply Quote 0
            • voxl-phoenixV
              voxl-phoenix @Alex Kushleyev
              Yeah I did follow the exact camera connections given on C26 configuration except that I don't have a down tracking camera. everything else is same. It's weird that it worked at start and than no response at all.
                Can you please list
                /usr/lib/camera/*sensormodule*
                • voxl-phoenixV
                  sorry for the trouble, but I can't get my head around why this is happening,
                  voxl2:~$ ls /usr/lib/camera/*sensormodule*
                  /usr/lib/camera/com.qti.sensormodule.ar0144_combo_0.bin
                  /usr/lib/camera/com.qti.sensormodule.ar0144_combo_6.bin
                  /usr/lib/camera/com.qti.sensormodule.imx412_fpv_1.bin
                  /usr/lib/camera/com.qti.sensormodule.irs2975c_3.bin
                  voxl2:~$
                  is there any chance my SDK installation might be corrupt. I have tried using 1.4.1 and 1.4.0.
                    @voxl-phoenix , can you please confirm something - did you mention that this exact hardware setup was previously working with 4 cameras and now two cameras are no longer detected?
                    Regarding camera calibration, it seems the issue is that the calibrator is attempting to calibrate extrinsics (which is only done for a stereo camera setup), but you are only calibrating one camera. Let me look into that.
                    • voxl-phoenixV
                      @Alex-Kushleyev I have only three cameras one TOF, Tracking, Hires each. TOF and Tracking are working properly.
                      for calibration I',m just calibrating Tracking camera with fish eye
                      voxl-calibrate-cameras -f -s 8x5 -l 0.029
                      it is trying to calibrate extrinsics automatically.
                        @voxl-phoenix ,
                        Ohh, sorry for the confusion. I misread your original post and thought that you have 4 cameras connected, like C26 configuration.
                        Can you please disconnect your M0173 from VOXL2 and take a picture showing the connectors on M0173 and where each camera is connected? just to double check.
                        • voxl-phoenixV
                          Thank you @Alex-Kushleyev
                          This is the output from my voxl-inspect-cam -a
                          |                Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |lt
                          |                 tof_conf |   43200 |  180 |  240 |  2.70 |    0 |     2824 | 8
                          |                tof_depth |   43200 |  180 |  240 |  2.70 |    0 |     2824 | 8
                          |                   tof_ir |   43200 |  180 |  240 |  2.70 |    0 |     2824 | 8
                          |           tracking_front | 1024000 | 1280 |  800 | 12.00 | 1596 |     8926 | 8
                          |     tracking_front_bayer | 1024000 | 1280 |  800 | 12.00 | 1596 |     8926 | 8
                          | tracking_front_misp_grey | 1024000 | 1280 |  800 | 12.00 | 1596 |     8926 | 8
                          | tracking_front_misp_norm | 1024000 | 1280 |  800 | 12.00 | 1596 |     8926 | 8
                          This is the output when I run voxl-camera-server.
                          voxl-camera-server
                          MISP awb str: auto
                          Setting MISP AWB to Autodetected system image 1.8.2
                          using new imx412 defaults
                          MISP awb str: auto
                          Setting MISP AWB to Auto=================================================================
                          configuration for 4 cameras:
                          cam #0
                              sensor type:         ar0144
                              isEnabled:           1
                              camId:               0
                              camId2:              -1
                              fps:                 30
                              en_rotate:           1
                              en_rotate2:          0
                              en_preview:          1
                              pre_width:           1280
                              pre_height:          800
                              en_raw_preview:      1
                              en_small_video:      0
                              small_video_width:   -1
                              small_video_height:  -1
                              en_large_video:      0
                              large_video_width:   -1
                              large_video_height:  -1
                              en_misp:             1
                              misp_width:          1280
                              misp_height:         800
                              en_snapshot:         0
                              snap_width:          -1
                              snap_height:         -1
                              exif_focal_length:   0.000000
                              exif_focal_len_35mm_format:0
                              exif_fnumber:        0.000000
                              ae_mode:             lme_msv
                              msv_exposure_min_us: 20
                              msv_exposure_max_us: 12000
                              gain_min           : 54
                              gain_max           : 8000
                              standby_enabled:     0
                              decimator:           1
                              independent_exposure:0
                          cam #1
                              sensor type:         imx412
                              isEnabled:           1
                              camId:               1
                              camId2:              -1
                              fps:                 30
                              en_rotate:           0
                              en_rotate2:          0
                              en_preview:          0
                              pre_width:           640
                              pre_height:          480
                              en_raw_preview:      0
                              en_small_video:      1
                              small_video_width:   1024
                              small_video_height:  768
                              en_large_video:      1
                              large_video_width:   4056
                              large_video_height:  3040
                              en_misp:             0
                              misp_width:          -1
                              misp_height:         -1
                              en_snapshot:         1
                              snap_width:          4056
                              snap_height:         3040
                              exif_focal_length:   3.100000
                              exif_focal_len_35mm_format:17
                              exif_fnumber:        1.240000
                              ae_mode:             isp
                              msv_exposure_max_us: 33000
                              gain_min           : 54
                              gain_max           : 8000
                              standby_enabled:     0
                              decimator:           1
                          cam #2
                              sensor type:         pmd-tof-liow2
                              isEnabled:           1
                              camId:               2
                              camId2:              -1
                              fps:                 10
                              en_rotate:           1
                              en_rotate2:          0
                              en_preview:          1
                              pre_width:           240
                              pre_height:          1629
                              en_raw_preview:      1
                              en_small_video:      0
                              en_large_video:      0
                              en_misp:             0
                              misp_width:          -1
                              misp_height:         -1
                              en_snapshot:         0
                              snap_width:          -1
                              snap_height:         -1
                              ae_mode:             off
                              msv_exposure_min_us: 0
                              msv_exposure_max_us: 6000
                              gain_min           : 0
                              gain_max           : 0
                              standby_enabled:     0
                              decimator:           5
                          cam #3
                              sensor type:         ar0144
                              isEnabled:           1
                              camId:               3
                              camId2:              -1
                              fps:                 30
                              en_rotate:           0
                              en_rotate2:          0
                              en_preview:          1
                              pre_width:           1280
                              pre_height:          800
                              en_raw_preview:      1
                              en_small_video:      0
                              en_large_video:      0
                              en_misp:             1
                              misp_width:          1280
                              misp_height:         800
                              en_snapshot:         0
                              snap_width:          -1
                              snap_height:         -1
                              ae_mode:             lme_msv
                              gain_min           : 54
                              gain_max           : 8000
                              standby_enabled:     0
                              decimator:           1
                          fsync_en:            1
                          fsync_gpio:          109
                          camera tracking_front frame size: 1024000 (1540096 alloc).. raw bpp: 8
                          WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 10223 frame(s).
                          WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 10223 frames dropped, FC 0 frames dropped, 9 frames delivered.
                          WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 9 frame(s).
                          WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 9 frames dropped, FC 0 frames dropped, 81 frames delivered.
                          ^C
                          received SIGINT Ctrl-C
                          ------ voxl-camera-server: Camera server is now stopping
                          WARNING: Deleting buffers: 6 of 16 still in use
                          ------ voxl-camera-server: Camera server exited gracefully, returning 0
                          this is my voxl sdk info
                          kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
                          hw platform:  M0054
                          mach.var:     1.0.1
                          voxl-suite:   1.4.3
                          Packages:
                          Thank you for help.
                            @voxl-phoenix , the connections look correct. Can you please clarify whether this setup was working (hires camera was working) and then suddenly stopped working? Or what changed between the time when it was working and now.
                            • voxl-phoenixV
                              @Alex-Kushleyev I have got this camera two days back and I have connected it and tested them both they, worked fine. I had to unbrick my board so I unbricked it and installed new SDK 1.4.1.
                              It was working fine before and after installation. I have just disconnected the camera and conected it again, because I was installing it in the holder that I 3D printed, just before installing I have tested it once, it is not working since than. only once I have disconnected the cable and connected it again, it stopped working. I have checked there is no damage to cables or board. I have handled them properly.
                                @voxl-phoenix , I think you also mentioned that you tried swapping the cables between tracking and imx412 camera, right? If so, it seems something got damaged in the IMX412 camera during connecting / disconnecting. For disconnecting the cables, we suggest using a special tool, please see https://docs.modalai.com/micro-coax-user-guide/#-proper-cable-and-adapter-handling- .
                                Also, it is hard to say for sure where exactly the issue is - M0173 board or IMX412 camera. the only good way find the cause is to replace components one at a time.
                                Just to elaborate on the symptoms that you are seeing : voxl-camera-server -l command essentially probes all the cameras (based on the sensormodule files located in /usr/lib/camera). Probing involves turning the camera on via the reset GPIO and attempting to talk to the camera via I2c interface. If the camera responds, the probe is successful, otherwise failed. In your case, the probe of IMX412 failed, which means either the camera could not be turned on for various reasons or the i2c communication was not working.
                                If you have another tracking camera AR0144, you could connect it instead of the IMX412 and see if the probe succeeds. You would need to add /usr/share/modalai/chi-cdk/ar0144/com.qti.sensormodule.ar0144_1.bin file to /usr/lib/camera (which is the AR0144 sensormodule for the camera slot 1, where the IMX412 is currently connected). Then if you run voxl-camera-server -l and detect two AR0144 cameras (3 cameras total) then i2c communication and power should be working).
