  3. Hires cam not working with voxl2
voxl-2
14 Posts 2 Posters 2.4k Views 1 Watching
  • voxl-phoenixV voxl-phoenix
    @Alex-Kushleyev Thank you for the advise , I have been using the kernal image which includes M0173 breakout board.
    voxl2:~$ voxl-camera-server -l
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0030, Sensor Id: 0x0356
    DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x007A, Sensor Id: 0x2975
    DEBUG:   Number of cameras: 2
    Stats for camera: 0
    1280 x  800
    1280 x  800
    1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x  800 HAL_PIXEL_FORMAT_BLOB
    1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x  768 HAL_PIXEL_FORMAT_BLOB
    1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x  720 HAL_PIXEL_FORMAT_BLOB
    1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
    1024 x  738 HAL_PIXEL_FORMAT_BLOB
    1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
    1024 x  768 HAL_PIXEL_FORMAT_BLOB
     864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
     864 x  480 HAL_PIXEL_FORMAT_BLOB
     800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
     800 x  600 HAL_PIXEL_FORMAT_BLOB
     800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
     800 x  480 HAL_PIXEL_FORMAT_BLOB
     720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
     720 x  480 HAL_PIXEL_FORMAT_BLOB
     640 x  512 HAL_PIXEL_FORMAT_YCbCr_420_888
     640 x  512 HAL_PIXEL_FORMAT_BLOB
    1280 x  800 HAL_PIXEL_FORMAT_RAW10
    1280 x  800 HAL_PIXEL_FORMAT_RAW12
    1280 x  800 HAL_PIXEL_FORMAT_RAW16
    1280 x  800 HAL_PIXEL_FORMAT_RAW_OPAQUE
    	min = 54
    	max = 1596
    	1596
    	min = 0ns
    	max = 1318629735ns
    Stats for camera: 1
     240 x 1629
     240 x 1629 HAL_PIXEL_FORMAT_RAW10
     240 x 1629 HAL_PIXEL_FORMAT_RAW12
     240 x 1629 HAL_PIXEL_FORMAT_RAW16
     240 x 1629 HAL_PIXEL_FORMAT_RAW_OPAQUE
    	min = 54
    	max = 0
    	min = 0ns
    	max = 0ns
    Number of cameras detected: 2
    voxl2:~$ voxl-version | grep mach
    mach.var:     1.0.1
    voxl2:~$
    I have TOF, tracking and Hires connected to the board it worked fine as soon as connected for first time than I can see no response from Hires but Tracking and TOF are working properly.
    @voxl-phoenix please make sure the cameras are connected as shown in C26 configuration https://docs.modalai.com/voxl2-coax-camera-bundles/
    voxl-phoenixV 1 Reply Last reply
      voxl-phoenixV Offline
      voxl-phoenix
      Yeah I did follow the exact camera connections given on C26 configuration except that I don't have a down tracking camera. everything else is same. It's weird that it worked at start and than no response at all.
        Can you please list
        /usr/lib/camera/*sensormodule*
          Can you please list
          voxl-phoenix
          wrote on last edited by voxl-phoenix
          sorry for the trouble, but I can't get my head around why this is happening,
          voxl2:~$ ls /usr/lib/camera/*sensormodule*
          /usr/lib/camera/com.qti.sensormodule.ar0144_combo_0.bin
          /usr/lib/camera/com.qti.sensormodule.ar0144_combo_6.bin
          /usr/lib/camera/com.qti.sensormodule.imx412_fpv_1.bin
          /usr/lib/camera/com.qti.sensormodule.irs2975c_3.bin
          voxl2:~$
          is there any chance my SDK installation might be corrupt. I have tried using 1.4.1 and 1.4.0.
            voxl2:~$
            @voxl-phoenix , can you please confirm something - did you mention that this exact hardware setup was previously working with 4 cameras and now two cameras are no longer detected?
            Regarding camera calibration, it seems the issue is that the calibrator is attempting to calibrate extrinsics (which is only done for a stereo camera setup), but you are only calibrating one camera. Let me look into that.
              voxl-phoenix
              #9
              @Alex-Kushleyev I have only three cameras one TOF, Tracking, Hires each. TOF and Tracking are working properly.
              for calibration I',m just calibrating Tracking camera with fish eye
              voxl-calibrate-cameras -f -s 8x5 -l 0.029
              it is trying to calibrate extrinsics automatically.
                @voxl-phoenix ,
                Ohh, sorry for the confusion. I misread your original post and thought that you have 4 cameras connected, like C26 configuration.
                Can you please disconnect your M0173 from VOXL2 and take a picture showing the connectors on M0173 and where each camera is connected? just to double check.
                  @voxl-phoenix ,
                  voxl-phoenix
                  #11
                  Thank you @Alex-Kushleyev
                  This is the output from my voxl-inspect-cam -a
                  |                Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |lt
                  |                 tof_conf |   43200 |  180 |  240 |  2.70 |    0 |     2824 | 8
                  |                tof_depth |   43200 |  180 |  240 |  2.70 |    0 |     2824 | 8
                  |                   tof_ir |   43200 |  180 |  240 |  2.70 |    0 |     2824 | 8
                  |           tracking_front | 1024000 | 1280 |  800 | 12.00 | 1596 |     8926 | 8
                  |     tracking_front_bayer | 1024000 | 1280 |  800 | 12.00 | 1596 |     8926 | 8
                  | tracking_front_misp_grey | 1024000 | 1280 |  800 | 12.00 | 1596 |     8926 | 8
                  | tracking_front_misp_norm | 1024000 | 1280 |  800 | 12.00 | 1596 |     8926 | 8
                  This is the output when I run voxl-camera-server.
                  voxl-camera-server
                  MISP awb str: auto
                  Setting MISP AWB to Autodetected system image 1.8.2
                  using new imx412 defaults
                  MISP awb str: auto
                  Setting MISP AWB to Auto=================================================================
                  configuration for 4 cameras:
                  cam #0
                      sensor type:         ar0144
                      isEnabled:           1
                      camId:               0
                      camId2:              -1
                      fps:                 30
                      en_rotate:           1
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           1280
                      pre_height:          800
                      en_raw_preview:      1
                      en_small_video:      0
                      small_video_width:   -1
                      small_video_height:  -1
                      en_large_video:      0
                      large_video_width:   -1
                      large_video_height:  -1
                      en_misp:             1
                      misp_width:          1280
                      misp_height:         800
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      exif_focal_length:   0.000000
                      exif_focal_len_35mm_format:0
                      exif_fnumber:        0.000000
                      ae_mode:             lme_msv
                      msv_exposure_min_us: 20
                      msv_exposure_max_us: 12000
                      gain_min           : 54
                      gain_max           : 8000
                      standby_enabled:     0
                      decimator:           1
                      independent_exposure:0
                  cam #1
                      sensor type:         imx412
                      isEnabled:           1
                      camId:               1
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          0
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      0
                      en_small_video:      1
                      small_video_width:   1024
                      small_video_height:  768
                      en_large_video:      1
                      large_video_width:   4056
                      large_video_height:  3040
                      en_misp:             0
                      misp_width:          -1
                      misp_height:         -1
                      en_snapshot:         1
                      snap_width:          4056
                      snap_height:         3040
                      exif_focal_length:   3.100000
                      exif_focal_len_35mm_format:17
                      exif_fnumber:        1.240000
                      ae_mode:             isp
                      msv_exposure_max_us: 33000
                      gain_min           : 54
                      gain_max           : 8000
                      standby_enabled:     0
                      decimator:           1
                  cam #2
                      sensor type:         pmd-tof-liow2
                      isEnabled:           1
                      camId:               2
                      camId2:              -1
                      fps:                 10
                      en_rotate:           1
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           240
                      pre_height:          1629
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_misp:             0
                      misp_width:          -1
                      misp_height:         -1
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             off
                      msv_exposure_min_us: 0
                      msv_exposure_max_us: 6000
                      gain_min           : 0
                      gain_max           : 0
                      standby_enabled:     0
                      decimator:           5
                  cam #3
                      sensor type:         ar0144
                      isEnabled:           1
                      camId:               3
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           1280
                      pre_height:          800
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_misp:             1
                      misp_width:          1280
                      misp_height:         800
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             lme_msv
                      gain_min           : 54
                      gain_max           : 8000
                      standby_enabled:     0
                      decimator:           1
                  fsync_en:            1
                  fsync_gpio:          109
                  connected to mavlink pipe
                  Connected to cpu-monitor
                  Starting Camera: tracking_front (id #0)
                  MISP Initializing!!!
                   Detected 1 platform(s)
                   Detected 1 GPU device(s)
                  Starting Camera: hires (id #1)
                  ERROR:   Camera 1 failed to find supported stream config: 1024x768
                  WARNING: Failed to start cam hires due to invalid resolution
                  WARNING: assuming cam is missing and trying to compensate
                  Starting Camera: tof (originally id #2) with id offset: 1
                  Starting Camera: tracking_down (originally id #3) with id offset: 1
                  WARNING: cam tracking_down (id 2) does not seem to be alive
                  ------ voxl-camera-server: Started 2 of 4 cameras
                  camera tracking_front frame size: 1024000 (1540096 alloc).. raw bpp: 8
                  WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 10223 frame(s).
                  WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 10223 frames dropped, FC 0 frames dropped, 9 frames delivered.
                  WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 9 frame(s).
                  WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 9 frames dropped, FC 0 frames dropped, 81 frames delivered.
                  ^C
                  received SIGINT Ctrl-C
                  ------ voxl-camera-server: Camera server is now stopping
                  WARNING: Deleting buffers: 6 of 16 still in use
                  ------ voxl-camera-server: Camera server exited gracefully, returning 0
                  this is my voxl sdk info
                  kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
                  hw platform:  M0054
                  mach.var:     1.0.1
                  voxl-suite:   1.4.3
                  Packages:
                  Thank you for help.
                    voxl-camera-server
                    MISP awb str: auto
                    MISP awb str: auto
                    cam #0
                        sensor type:         ar0144
                        isEnabled:           1
                        camId:               0
                        camId2:              -1
                        fps:                 30
                        en_rotate:           1
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_misp:             1
                        misp_width:          1280
                        misp_height:         800
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        gain_min           : 54
                        gain_max           : 8000
                        standby_enabled:     0
                        decimator:           1
                    cam #1
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               1
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      1
                        en_misp:             0
                        misp_width:          -1
                        misp_height:         -1
                        en_snapshot:         1
                        snap_width:          4056
                        snap_height:         3040
                        ae_mode:             isp
                        gain_min           : 54
                        gain_max           : 8000
                        standby_enabled:     0
                        decimator:           1
                    cam #2
                        isEnabled:           1
                        camId:               2
                        camId2:              -1
                        fps:                 10
                        en_rotate:           1
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           240
                        pre_height:          1629
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_misp:             0
                        misp_width:          -1
                        misp_height:         -1
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             off
                        gain_min           : 0
                        gain_max           : 0
                        standby_enabled:     0
                        decimator:           5
                    cam #3
                        sensor type:         ar0144
                        isEnabled:           1
                        camId:               3
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_misp:             1
                        misp_width:          1280
                        misp_height:         800
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        gain_min           : 54
                        gain_max           : 8000
                        standby_enabled:     0
                        decimator:           1
                    fsync_en:            1
                    fsync_gpio:          109
                    ^C
                    hw platform:  M0054
                    mach.var:     1.0.1
                    voxl-suite:   1.4.3
                    Packages:
                    Thank you for help.
                    @voxl-phoenix , the connections look correct. Can you please clarify whether this setup was working (hires camera was working) and then suddenly stopped working? Or what changed between the time when it was working and now.
                      voxl-phoenix
                      @Alex-Kushleyev I have got this camera two days back and I have connected it and tested them both they, worked fine. I had to unbrick my board so I unbricked it and installed new SDK 1.4.1.
                      It was working fine before and after installation. I have just disconnected the camera and conected it again, because I was installing it in the holder that I 3D printed, just before installing I have tested it once, it is not working since than. only once I have disconnected the cable and connected it again, it stopped working. I have checked there is no damage to cables or board. I have handled them properly.
                        @voxl-phoenix , I think you also mentioned that you tried swapping the cables between tracking and imx412 camera, right? If so, it seems something got damaged in the IMX412 camera during connecting / disconnecting. For disconnecting the cables, we suggest using a special tool, please see https://docs.modalai.com/micro-coax-user-guide/#-proper-cable-and-adapter-handling- .
                        Also, it is hard to say for sure where exactly the issue is - M0173 board or IMX412 camera. the only good way find the cause is to replace components one at a time.
                        Just to elaborate on the symptoms that you are seeing : voxl-camera-server -l command essentially probes all the cameras (based on the sensormodule files located in /usr/lib/camera). Probing involves turning the camera on via the reset GPIO and attempting to talk to the camera via I2c interface. If the camera responds, the probe is successful, otherwise failed. In your case, the probe of IMX412 failed, which means either the camera could not be turned on for various reasons or the i2c communication was not working.
                        If you have another tracking camera AR0144, you could connect it instead of the IMX412 and see if the probe succeeds. You would need to add /usr/share/modalai/chi-cdk/ar0144/com.qti.sensormodule.ar0144_1.bin file to /usr/lib/camera (which is the AR0144 sensormodule for the camera slot 1, where the IMX412 is currently connected). Then if you run voxl-camera-server -l and detect two AR0144 cameras (3 cameras total) then i2c communication and power should be working).
