  2. VOXL Dev Drones
  3. Starling & Starling 2
  4. GPS not connecting
GPS not connecting
5 Posts 4 Posters 972 Views 2 Watching
  • john 0J Offline
    john 0J Offline
    john 0
    I have a starling 2 with the default GPS. When I write "px4-listener sensor_gps" I receive: "never published". When I looked at the startup log I see that it is searching and not connecting to any gps, constantly printing the following lines:
    GPS UART baudrate set to 115200
    Dec 12 10:19:56 m0054 voxl-px4[22983]: INFO [muorb] SLPI: GPS UART baudrate set to 9600
    Dec 12 10:19:56 m0054 voxl-px4[22983]: INFO [muorb] SLPI: GPS UART baudrate set to 38400
    Dec 12 10:19:56 m0054 voxl-px4[22983]: INFO [muorb] SLPI: GPS UART baudrate set to 57600
    when I run the gps status command I see in the log:
    Dec 12 10:36:46 m0054 voxl-px4[1942]: INFO [muorb] SLPI: Main GPS
    Dec 12 10:36:46 m0054 voxl-px4[1942]: INFO [muorb] SLPI: protocol: UBX
    Dec 12 10:36:46 m0054 voxl-px4[1942]: INFO [muorb] SLPI: status: NOT OK, port: 6, baudrate: 0
    Dec 12 10:36:46 m0054 voxl-px4[1942]: INFO [muorb] SLPI: sat info: disabled
    Dec 12 10:36:46 m0054 voxl-px4[1942]: INFO [muorb] SLPI: rate reading: 0 B/s
    Dec 12 10:36:46 m0054 voxl-px4[1942]: INFO [muorb] SLPI: Ok executing command: gps status
    • john 0J john 0
      Hi @john-0,
      You are trying the right commands, so this could be a hardware issue. Can you please inspect the cables that go into the GPS unit and J19 connector on VOXL2?
      Do you have any other GPS unit you could plug into J19 for a quick test instead of the one installed on your vehicle?
      Also, which VOXL2 SDK are you using?
      Meytal LempelM 1 Reply Last reply
        Hi @john-0,
        Meytal LempelM Offline
        Meytal Lempel
        Hi @Alex-Kushleyev, (I am from the same team as John's)
        Our VOXL2 SDK is "voxl-suite 1.3.1".
        We did try to connect the cable that goes into the sensor to another "taoglas CGGBP 18.4.A.02" and recieved GPS messages.
        Our Starling2 came out of the box like that, should we change the sensor's configuration or is it a hardware malfunction?
        Thank you!
        • Meytal LempelM Meytal Lempel
          Thank you!
          @Meytal-Lempel On your device what does /etc/modalai/voxl-px4.conf look like?
            Meytal Lempel
            Hi @tom , here is my /etc/modalai/voxl-px4.conf:
            #!/bin/bash
            # voxl-px4 Configuration File
            # GPS:
            #     Tell PX4 which GPS to use. If there is no GPS unit use NONE. Otherwise
            #     choose AUTODETECT and the startup script will attempt to automatically
            #     configure the GPS, magnetometer, and status LED
            #     Options include: [NONE, AUTODETECT]
            # RC:
            #     Tell PX4 which RC transmitter to use.
            #     Use EXTERNAL when getting RC control from external Mavlink messages (e.g Via QGC)
            #     Options include: [SPEKTRUM, CRSF_MAV, CRSF_RAW, M0065_SBUS, EXTERNAL, FAKE_RC_INPUT]
            # ESC:
            #     Tell PX4 which type of ESC to use.
            #     Options include: [VOXL_ESC, VOXL2_IO_PWM_ESC]
            # POWER_MANAGER:
            #     Tell PX4 which power manager to use.
            #     Use NONE for ModalAI Mini-ESC since the ESC driver handles PM.
            #     Use EXTERNAL when not using the ModalAI APM power manager to power the board
            #       This also just disables the voxlpm driver, same as the NONE option
            #     Options include: [VOXLPM, EXTERNAL, NONE]
            # DISTANCE_SENSOR:
            #     Tell PX4 which distance sensor peripheral to use.
            #     Note: The sensor will be started on the RC port so it is only
            #           really possible to use it when using external RC.
            #     Options include: [NONE, LIGHTWARE_SF000]
            # OSD:
            #     Tell PX4 whether to enable OSD (on-screen display).
            #     Options include: [ENABLE, DISABLE]
            # DAEMON_MODE:
            #     Tell PX4 whether to enable daemon mode.
            # SENSOR_CAL:
            #     Tell PX4 where to source sensor calibration information.
            #     Options include: [ACTUAL, FAKE]
            # ARTIFACT_MODE:
            #     Do not allow artifacts to be saved to disk. Will not start the logging
            #     module, will delete any current log files, and will delete the data manager file.
            # EXTRA_STEPS:
            #     Optional field that allows a user to define custom commands to be run by PX4 on boot.
            #     Must be a valid bash array as seen below
            #     Example: EXTRA_STEPS=( "qshell gps start" "qshell commander mode manual" )
            GPS=AUTODETECT
            RC=GHST
            ESC=VOXL_ESC
            POWER_MANAGER=VOXLPM
            DISTANCE_SENSOR=NONE
            OSD=DISABLE
            DAEMON_MODE=ENABLE
            SENSOR_CAL=ACTUAL
            ARTIFACT_MODE=DISABLE
            EXTRA_STEPS=()
