  2. VOXL SDK and Software
  3. Lepton Thermal Camera for Object detection
voxl-sdk
4 Posts 2 Posters 757 Views
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hello @Eric-Katzfey @tom ,
    I had a doubt regarding the thermal camera pipeline(i.e. voxl-lepton-server). Can the output from the thermal camera be used for object detection on the voxl-tflite-server instead of using the RGB Hires camera as usual.
    I am using Lepton thermal camera on VOXL 2 compute.
    • Jetson NanoJ Jetson Nano
      Jetson Nano
      Veteran
      Could you please share some updates on this?
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        @Jetson-Nano if you plan on using object detection in tflite server, then you can use yolov5 or yolov8 - I am unsure if you can pipe in that data into tflite with it working as that code base is meant to ingest generic raw and nv frames (RAW8/16 or NV12/21) so streaming in a different frame format might cause issue - if this doesnt fail and it works with the pipe, then it is up to you to train your own model based on the thermal camera feed.
          Jetson Nano
          Veteran
          @Zachary-Lowell-0 Thank you for your reply. I will test it out and let you of any developments.
