    Lepton Thermal Camera for Object detection
    VOXL SDK
    • Jetson NanoJ
      Jetson Nano
      Hello @Eric-Katzfey @tom ,
      I had a doubt regarding the thermal camera pipeline(i.e. voxl-lepton-server). Can the output from the thermal camera be used for object detection on the voxl-tflite-server instead of using the RGB Hires camera as usual.
      I am using Lepton thermal camera on VOXL 2 compute.
      Jetson NanoJ 1 Reply Last reply Reply Quote 0
      • Jetson NanoJ
        Jetson Nano @Jetson Nano
        Could you please share some updates on this?
        • Zachary Lowell 0Z
          Zachary Lowell 0 ModalAI Team
          @Jetson-Nano if you plan on using object detection in tflite server, then you can use yolov5 or yolov8 - I am unsure if you can pipe in that data into tflite with it working as that code base is meant to ingest generic raw and nv frames (RAW8/16 or NV12/21) so streaming in a different frame format might cause issue - if this doesnt fail and it works with the pipe, then it is up to you to train your own model based on the thermal camera feed.
          • Jetson NanoJ
            Jetson Nano @Zachary Lowell 0
            @Zachary-Lowell-0 Thank you for your reply. I will test it out and let you of any developments.
