  3. how to get H256 hires encoded imgs from sdk 1.0 ?
13 Posts 5 Posters 2.5k Views 1 Watching
  • A aashry
    Hello Team,
    I'm trying to get encoded hires images using sdk 1.0 and camera_server v1.6.2 from a voxl2 board with configuration 6 (TOF, HIRES and Tracking). The following is the output from voxl-version
    voxl2:~$ voxl-version
    system-image: 1.6.2-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   1.0.0
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.0/binary-arm64/
    Last Updated: 2023-11-12 06:55:14
    List:
    	libmodal-cv              0.3.2
    	libmodal-exposure        0.0.8
    	libmodal-journal         0.2.2
    	libmodal-json            0.4.3
    	libmodal-pipe            2.8.5
    	libqrb5165-io            0.2.0
    	libvoxl-cci-direct       0.1.5
    	libvoxl-cutils           0.1.1
    	mv-voxl                  0.1-r0
    	qrb5165-bind             0.1-r0
    	qrb5165-dfs-server       0.1.0
    	qrb5165-imu-server       0.6.0
    	qrb5165-slpi-test-sig    01-r0
    	qrb5165-system-tweaks    0.2.2
    	qrb5165-tflite           2.8.0-2
    	voxl-bind-spektrum       0.1.0
    	voxl-camera-calibration  0.4.0
    	voxl-camera-server       1.6.2
    	voxl-configurator        0.2.7
    	voxl-cpu-monitor         0.4.6
    	voxl-docker-support      1.2.5
    	voxl-eigen3              3.4.0
    	voxl-elrs                0.0.7
    	voxl-esc                 1.2.2
    	voxl-feature-tracker     0.2.3
    	voxl-flow-server         0.3.3
    	voxl-gphoto2-server      0.0.10
    	voxl-jpeg-turbo          2.1.3
    	voxl-lepton-server       1.1.2
    	voxl-libgphoto2          0.0.4
    	voxl-libuvc              1.0.7
    	voxl-logger              0.3.4
    	voxl-mavcam-manager      0.5.1
    	voxl-mavlink             0.1.1
    	voxl-mavlink-server      1.2.0
    	voxl-modem               1.0.5
    	voxl-mongoose            7.7.0-1
    	voxl-mpa-to-ros          0.3.6
    	voxl-mpa-tools           1.0.4
    	voxl-opencv              4.5.5-1
    	voxl-portal              0.5.9
    	voxl-px4                 1.14.0-2.0.34
    	voxl-px4-imu-server      0.1.2
    	voxl-px4-params          0.1.8
    	voxl-qvio-server         0.9.3
    	voxl-remote-id           0.0.8
    	voxl-slpi-uart-bridge    1.0.1
    	voxl-streamer            0.7.1
    	voxl-suite               1.0.0
    	voxl-tag-detector        0.0.4
    	voxl-tflite-server       0.3.1
    	voxl-utils               1.3.1
    	voxl-uvc-server          0.1.6
    	voxl-vision-hub          1.6.6
    	voxl2-system-image       1.6.2-r0
    	voxl2-wlan               1.0-r0
    I was able to get the camera-server to work with configuration 6 and the pipes are showing up in voxl-inspect-cam -a as shown below
    |           Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
    |   hires_large_color |13271040 | 4096 | 2160 | 33.23 |  431 |      489 |     77.1  | 30.0 | 3190.0 | NV12
    | hires_large_encoded |   26549 | 4096 | 2160 | 33.23 |  431 |      489 |     89.3  | 30.0 |    7.2 | H265 (P)
    |    hires_large_grey | 8847360 | 4096 | 2160 | 33.23 |  431 |      489 |     71.8  | 30.0 | 2126.6 | RAW8
    |   hires_small_color | 1179648 | 1024 |  768 | 33.23 |  431 |      490 |     60.6  | 30.0 |  283.5 | NV12
    | hires_small_encoded |    1528 | 1024 |  768 | 33.23 |  431 |      490 |     63.0  | 30.0 |    0.5 | H265 (P)
    |    hires_small_grey |  786432 | 1024 |  768 | 33.23 |  431 |      490 |     59.4  | 30.0 |  189.0 | RAW8
    |      hires_snapshot |
    |            tof_conf |   38528 |  224 |  172 |  0.00 |    0 |     1669 |     29.6  |  5.0 |    1.5 | RAW8
    |           tof_depth |   38528 |  224 |  172 |  0.00 |    0 |     1669 |     29.3  |  5.0 |    1.5 | RAW8
    |              tof_ir |   38528 |  224 |  172 |  0.00 |    0 |     1669 |     29.0  |  5.0 |    1.5 | RAW8
    |            tracking |  307200 |  640 |  480 |  5.61 |  303 |    10016 |     11.6  | 30.0 |   73.7 | RAW8
    However, I'm not able to see the output of the encoded hires neither in voxl-portal not when I subscribe to the encoded pipeline in the published topics from voxl-mpa-to-ros. In fact, when I try to subscribe to any encoded image topic, the node crashes immediately as shown below.
    voxl2:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    ... logging to /home/root/.ros/log/c26582ac-8191-11ee-99cc-9c5322cc8a09/roslaunch-m0054-8630.log
    Checking log directory for disk usage. This may take a while.
    Press Ctrl-C to interrupt
    Done checking log file disk usage. Usage is <1GB.
    started roslaunch server http://m0054:43361/
    SUMMARY
    PARAMETERS
     * /rosdistro: melodic
     * /rosversion: 1.14.13
    NODES
        voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
    auto-starting new master
    process[master]: started with pid [8644]
    ROS_MASTER_URI=http://localhost:11311
    setting /run_id to c26582ac-8191-11ee-99cc-9c5322cc8a09
    process[rosout-1]: started with pid [8655]
    started core service [/rosout]
    process[voxl_mpa_to_ros_node-2]: started with pid [8658]
    MPA to ROS app is now running
    Found new interface: hires_large_color
    Found new interface: hires_large_encoded
    Found new interface: hires_large_grey
    Found new interface: hires_small_color
    Found new interface: hires_small_encoded
    Found new interface: hires_small_grey
    Found new interface: hires_snapshot
    Found new interface: tof_conf
    Found new interface: tof_depth
    Found new interface: tof_ir
    Found new interface: tracking
    Found new interface: imu_apps
    Found new interface: tof_pc
    Found new interface: voa_pc_out
    Interface tof_depth now publishing
    Interface hires_small_grey now publishing
    Interface tof_depth ceasing to publish
    Interface hires_large_encoded now publishing
    Interface hires_small_grey ceasing to publish
    terminate called after throwing an instance of 'std::bad_alloc'
      what():  std::bad_alloc
    [voxl_mpa_to_ros_node-2] process has died [pid 8658, exit code -6, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/c26582ac-8191-11ee-99cc-9c5322cc8a09/voxl_mpa_to_ros_node-2.log].
    log file: /home/root/.ros/log/c26582ac-8191-11ee-99cc-9c5322cc8a09/voxl_mpa_to_ros_node-2*.log
    Is there any possible solution for this issue? Please help!
    aashry
    @aashry the following is the voxl-camera-server.conf file as well for your reference. Should I change anything here to fix that issue? Please elaborate.
     * voxl-camera-server Configuration File
     * Each camera has configurations for up to 4 HAL3 streams:
     *    - `preview` stream for raw unprocessed images from CV cameras
     *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
     *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
     *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
     * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
     * This file is generated from default values by voxl-configure-cameras.
     * Do not expect arbitrary resolutions to work, the ISP and video compression
     * pipelines only support very specific resolutions.
     * The default video compression mode is cqp or Constant Quantization Parameter
    	"version":	0.1,
    	"cameras":	[{
    			"type":	"pmd-tof",
    			"name":	"tof",
    			"enabled":	true,
    			"camera_id":	0,
    			"fps":	5,
    			"en_preview":	true,
    			"preview_width":	224,
    			"preview_height":	1557,
    			"pre_format":	"tof",
    			"ae_mode":	"off",
    			"standby_enabled":	false,
    			"decimator":	5
    			"type":	"imx214",
    			"name":	"hires",
    			"enabled":	true,
    			"camera_id":	2,
    			"fps":	30,
    			"en_preview":	false,
    			"preview_width":	640,
    			"preview_height":	480,
    			"pre_format":	"nv21",
    			"en_small_video":	true,
    			"small_video_width":	1024,
    			"small_video_height":	768,
    			"small_venc_mode":	"h265",
    			"small_venc_br_ctrl":	"cqp",
    			"small_venc_Qfixed":	30,
    			"small_venc_Qmin":	15,
    			"small_venc_Qmax":	40,
    			"small_venc_nPframes":	9,
    			"small_venc_mbps":	2,
    			"en_large_video":	true,
    			"large_video_width":	4096,
    			"large_video_height":	2160,
    			"large_venc_mode":	"h265",
    			"large_venc_br_ctrl":	"cqp",
    			"large_venc_Qfixed":	38,
    			"large_venc_Qmin":	15,
    			"large_venc_Qmax":	50,
    			"large_venc_nPframes":	29,
    			"large_venc_mbps":	30,
    			"en_snapshot":	true,
    			"en_snapshot_width":	4160,
    			"en_snapshot_height":	3120,
    			"ae_mode":	"isp"
    			"type":	"ov7251",
    			"name":	"tracking",
    			"enabled":	true,
    			"camera_id":	1,
    			"fps":	30,
    			"en_preview":	true,
    			"pre_format":	"raw8",
    			"ae_mode":	"lme_msv",
    			"ae_desired_msv":	60,
    			"ae_filter_alpha":	0.600000023841858,
    			"ae_ignore_fraction":	0.20000000298023224,
    			"ae_slope":	0.05000000074505806,
    			"ae_exposure_period":	1,
    			"ae_gain_period":	1
    A 1 Reply Last reply
    • A aashry
      	"version":	0.1,
      	"cameras":	[{
      			"type":	"pmd-tof",
      			"name":	"tof",
      			"enabled":	true,
      			"camera_id":	0,
      			"fps":	5,
      			"en_preview":	true,
      			"ae_mode":	"off",
      			"decimator":	5
      			"type":	"imx214",
      			"name":	"hires",
      			"enabled":	true,
      			"camera_id":	2,
      			"fps":	30,
      			"ae_mode":	"isp"
      			"type":	"ov7251",
      			"name":	"tracking",
      			"enabled":	true,
      			"camera_id":	1,
      			"fps":	30,
      			"en_preview":	true,
      			"ae_gain_period":	1
      aashry
      wrote on last edited by aashry
      Also, it seems like voxl-camera-server randomly stops working. Is SDK 1.0 completely unusable so far? or Is there a workaround that we can do?
      |           Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  t
      |   hires_large_color | Server Disconnected
      | hires_large_encoded | Server DisconnectedMost likely the server stopped without cleaning up
      Client is cleaning up pipes for the serverdMost likely the server stopped without cleaning up
      ERROR in pipe_client_init_channel opening request pipe: No such device or addressing request pipe: Ns
      | hires_small_encoded | Server DisconnectedERROR in pipe_client_init_channel opening request pipe: Ns
      |    hires_small_grey | Server DisconnectedClient is cleaning up pipes for the server
      ERROR in pipe_client_init_channel opening request pipe: No such device or address cleaning up
      Most likely the server stopped without cleaning upn pipe_client_init_channel opening request pipe: Ns
      Client is cleaning up pipes for the serveraning up
      • A aashry
        aashry
        @aashry
        Edit1: Everything above applies to the h264 encoding as well, I haven't been able to view it in the portal and it has the same problem with the ros node.
        • A aashry
          @aashry
          aashry
          Anyone can help?
          wilkinsafW 1 Reply Last reply
          • A aashry
            Anyone can help?
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            @aashry What UAV are you flying? Is this an off the shelf one from modalai or did you assemble it yourself?
            Usually that error means there is a hardware issue with the cameras
            • B Offline
              B Offline
              Bernhard
              Hi @aashry, did you actually solve this problem?
              I am running into the same issue.
              Camera config is alright, stream config seems to be right as well, but I cannot get an encoded stream in either voxl-portal or vlc.
              Any help would be greatly appreciated.
              BR
              • Zachary Lowell 0Z Offline
                Zachary Lowell 0
                Hi @aashry voxl-camera-server with H265 support was implemented and included in an SDK past 1.0 - any reason why you are not upgrading to 1.3.3?
                The other option is you mix and match versions of voxl-camera-server with your current SDK version, but odds are that will have quite a bit of conflicts as it is dependent on new versions of modalpipe and such.
                Zach
                  Zachary Lowell 0
                  Also @Bernhard - you will never be able to view the encoded stream on voxl-portal, just on VLC or something like QGC. SDK 1.0 does support h264 which is software encoding though so innately it will be slower - does this work out the gate for you?
                  • B Bernhard
                    BR
                    #10
                    @Bernhard , you may be missing a step, if you want to stream the encoded stream using RTSP protocol, please take a look at voxl-streamer, which is our standard package : https://docs.modalai.com/voxl-streamer/
                    voxl-streamer can perform the following functions:
                    • receive unencoded yuv (or raw8 monochrome) images from camera server and encode them using VOXL2's hardware encoder (using gstreamer + OMX api) and serve the encoded video as rtsp service
                    • receive encoded video stream from camera server and serve the encoded video directly
                    To play the h264 / h265 stream you can use VLC as Zach mentioned, or ffmpeg / ffplay:
                    ffplay rtsp://<board-ip>:port/live
                    port number is printed when you run voxl-streamer (port can be modified with a command line argument)
                    B 1 Reply Last reply
                      B Offline
                      B Offline
                      Bernhard
                      @Alex-Kushleyev I have tried using VLC as well, that does not work.
                      voxl-streamer is configured correctly (I think):
                      "input-pipe":   "hires_small_encoded",
                      "bitrate":      1500000,
                      "rotation":     0,
                      "decimator":    1,
                      "port": 8900
                      But when I try to connect via rtsp://<IP>:8900/live nothing happens.
                      • B Bernhard
                        "bitrate":      1500000,
                        "rotation":     0,
                        "decimator":    1,
                        "port": 8900
                        @Bernhard , please follow these steps:
                        • make sure voxl-camera-server is running either in the background service or manually started in a terminal
                        • confirm that hires_small_encoded stream is being generated by the camera server:
                          • voxl-inspect-cam hires_small_encoded should show stream statistics like FPS, frame resolution and size
                          • if you do not see any stats using the inspect-cam tool, make sure the small encoded stream is enabled in your /etc/modalai/voxl-camera-server.conf
                        • assuming the encoded stream is working, launch voxl-streamer:
                          • voxl-streamer -i hires_small_encoded
                          • it should also tell you the URL to connect to, although often the ip in the url is local (127.0.0.1) so you need to replace that with actual network IP address
                          B Offline
                          B Offline
                          Bernhard
                          @Alex-Kushleyev thanks - I think the voxl-streamer was enabled, but not running.
                          Problem solved, thank you!
