<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[how to get H256 hires encoded imgs from sdk 1.0 ?]]></title><description><![CDATA[<p dir="auto">Hello Team,<br />
I'm trying to get encoded hires images using sdk 1.0 and camera_server v1.6.2 from a voxl2 board with configuration 6 (TOF, HIRES and Tracking). The following is the output from <code>voxl-version</code></p>
<pre><code>voxl2:~$ voxl-version
system-image: 1.6.2-M0054-14.1a-perf
kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
hw version:   M0054
voxl-suite:   1.0.0
Packages:
Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.0/binary-arm64/
Last Updated: 2023-11-12 06:55:14
List:
	libmodal-cv              0.3.2
	libmodal-exposure        0.0.8
	libmodal-journal         0.2.2
	libmodal-json            0.4.3
	libmodal-pipe            2.8.5
	libqrb5165-io            0.2.0
	libvoxl-cci-direct       0.1.5
	libvoxl-cutils           0.1.1
	mv-voxl                  0.1-r0
	qrb5165-bind             0.1-r0
	qrb5165-dfs-server       0.1.0
	qrb5165-imu-server       0.6.0
	qrb5165-slpi-test-sig    01-r0
	qrb5165-system-tweaks    0.2.2
	qrb5165-tflite           2.8.0-2
	voxl-bind-spektrum       0.1.0
	voxl-camera-calibration  0.4.0
	voxl-camera-server       1.6.2
	voxl-configurator        0.2.7
	voxl-cpu-monitor         0.4.6
	voxl-docker-support      1.2.5
	voxl-eigen3              3.4.0
	voxl-elrs                0.0.7
	voxl-esc                 1.2.2
	voxl-feature-tracker     0.2.3
	voxl-flow-server         0.3.3
	voxl-gphoto2-server      0.0.10
	voxl-jpeg-turbo          2.1.3
	voxl-lepton-server       1.1.2
	voxl-libgphoto2          0.0.4
	voxl-libuvc              1.0.7
	voxl-logger              0.3.4
	voxl-mavcam-manager      0.5.1
	voxl-mavlink             0.1.1
	voxl-mavlink-server      1.2.0
	voxl-modem               1.0.5
	voxl-mongoose            7.7.0-1
	voxl-mpa-to-ros          0.3.6
	voxl-mpa-tools           1.0.4
	voxl-opencv              4.5.5-1
	voxl-portal              0.5.9
	voxl-px4                 1.14.0-2.0.34
	voxl-px4-imu-server      0.1.2
	voxl-px4-params          0.1.8
	voxl-qvio-server         0.9.3
	voxl-remote-id           0.0.8
	voxl-slpi-uart-bridge    1.0.1
	voxl-streamer            0.7.1
	voxl-suite               1.0.0
	voxl-tag-detector        0.0.4
	voxl-tflite-server       0.3.1
	voxl-utils               1.3.1
	voxl-uvc-server          0.1.6
	voxl-vision-hub          1.6.6
	voxl2-system-image       1.6.2-r0
	voxl2-wlan               1.0-r0
<p dir="auto">I was able to get the camera-server to work with configuration 6 and the pipes are showing up in <code>voxl-inspect-cam -a</code> as shown below</p>
<pre><code>|           Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
|   hires_large_color |13271040 | 4096 | 2160 | 33.23 |  431 |      489 |     77.1  | 30.0 | 3190.0 | NV12
| hires_large_encoded |   26549 | 4096 | 2160 | 33.23 |  431 |      489 |     89.3  | 30.0 |    7.2 | H265 (P)
|    hires_large_grey | 8847360 | 4096 | 2160 | 33.23 |  431 |      489 |     71.8  | 30.0 | 2126.6 | RAW8
|   hires_small_color | 1179648 | 1024 |  768 | 33.23 |  431 |      490 |     60.6  | 30.0 |  283.5 | NV12
| hires_small_encoded |    1528 | 1024 |  768 | 33.23 |  431 |      490 |     63.0  | 30.0 |    0.5 | H265 (P)
|    hires_small_grey |  786432 | 1024 |  768 | 33.23 |  431 |      490 |     59.4  | 30.0 |  189.0 | RAW8
|      hires_snapshot |
|            tof_conf |   38528 |  224 |  172 |  0.00 |    0 |     1669 |     29.6  |  5.0 |    1.5 | RAW8
|           tof_depth |   38528 |  224 |  172 |  0.00 |    0 |     1669 |     29.3  |  5.0 |    1.5 | RAW8
|              tof_ir |   38528 |  224 |  172 |  0.00 |    0 |     1669 |     29.0  |  5.0 |    1.5 | RAW8
|            tracking |  307200 |  640 |  480 |  5.61 |  303 |    10016 |     11.6  | 30.0 |   73.7 | RAW8
<p dir="auto">However, I'm not able to see the output of the encoded hires neither in <code>voxl-portal</code> not when I subscribe to the encoded pipeline in the published topics from <code>voxl-mpa-to-ros</code>. In fact, when I try to subscribe to any encoded image topic, the node crashes immediately as shown below.</p>
<pre><code>voxl2:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
... logging to /home/root/.ros/log/c26582ac-8191-11ee-99cc-9c5322cc8a09/roslaunch-m0054-8630.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is &lt;1GB.
started roslaunch server http://m0054:43361/
SUMMARY
PARAMETERS
 * /rosdistro: melodic
 * /rosversion: 1.14.13
NODES
    voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
auto-starting new master
process[master]: started with pid [8644]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to c26582ac-8191-11ee-99cc-9c5322cc8a09
process[rosout-1]: started with pid [8655]
process[voxl_mpa_to_ros_node-2]: started with pid [8658]
MPA to ROS app is now running
Found new interface: hires_large_color
Found new interface: hires_large_encoded
Found new interface: hires_large_grey
Found new interface: hires_small_color
Found new interface: hires_small_encoded
Found new interface: hires_small_grey
Found new interface: hires_snapshot
Found new interface: tof_conf
Found new interface: tof_depth
Found new interface: tof_ir
Found new interface: tracking
Found new interface: imu_apps
Found new interface: tof_pc
Found new interface: voa_pc_out
Interface tof_depth now publishing
Interface hires_small_grey now publishing
Interface tof_depth ceasing to publish
Interface hires_large_encoded now publishing
Interface hires_small_grey ceasing to publish
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
[voxl_mpa_to_ros_node-2] process has died [pid 8658, exit code -6, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/c26582ac-8191-11ee-99cc-9c5322cc8a09/voxl_mpa_to_ros_node-2.log].
log file: /home/root/.ros/log/c26582ac-8191-11ee-99cc-9c5322cc8a09/voxl_mpa_to_ros_node-2*.log
<p dir="auto">Is there any possible solution for this issue? Please help!</p>
]]></description><link>https://forum.modalai.com/topic/2852/how-to-get-h256-hires-encoded-imgs-from-sdk-1-0</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 05:20:39 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2852.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Nov 2023 19:32:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Mon, 28 Oct 2024 10:39:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alex-kushleyev" aria-label="Profile: Alex-Kushleyev">@<bdi>Alex-Kushleyev</bdi></a> thanks - I think the voxl-streamer was enabled, but not running.<br />
Problem solved, thank you!</p>
]]></description><link>https://forum.modalai.com/post/19462</link><guid isPermaLink="true">https://forum.modalai.com/post/19462</guid><dc:creator><![CDATA[Bernhard]]></dc:creator><pubDate>Mon, 28 Oct 2024 10:39:55 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Thu, 24 Oct 2024 15:07:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bernhard" aria-label="Profile: Bernhard">@<bdi>Bernhard</bdi></a> , please follow these steps:</p>
<ul>
<li>make sure <code>voxl-camera-server</code> is running either in the background service or manually started in a terminal</li>
<li>confirm that <code>hires_small_encoded</code> stream is being generated by the camera server:
<ul>
<li><code>voxl-inspect-cam hires_small_encoded</code> should show stream statistics like FPS, frame resolution and size</li>
<li>if you do not see any stats using the inspect-cam tool, make sure the <code>small encoded</code> stream is enabled in your <code>/etc/modalai/voxl-camera-server.conf</code></li>
</ul>
</li>
<li>assuming the encoded stream is working, launch <code>voxl-streamer</code>:
<ul>
<li><code>voxl-streamer -i hires_small_encoded</code></li>
<li>it should also tell you the URL to connect to, although often the ip in the url is local (<code>127.0.0.1</code>) so you need to replace that with actual network IP address</li>
</ul>
</li>
</ul>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/19407</link><guid isPermaLink="true">https://forum.modalai.com/post/19407</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Thu, 24 Oct 2024 15:07:11 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Wed, 23 Oct 2024 12:16:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alex-kushleyev" aria-label="Profile: Alex-Kushleyev">@<bdi>Alex-Kushleyev</bdi></a> I have tried using VLC as well, that does not work.<br />
voxl-streamer is configured correctly (I think):</p>
<pre><code>"input-pipe":   "hires_small_encoded",
"bitrate":      1500000,
"rotation":     0,
"decimator":    1,
"port": 8900
<p dir="auto">But when I try to connect via rtsp://&lt;IP&gt;:8900/live nothing happens.</p>
]]></description><link>https://forum.modalai.com/post/19392</link><guid isPermaLink="true">https://forum.modalai.com/post/19392</guid><dc:creator><![CDATA[Bernhard]]></dc:creator><pubDate>Wed, 23 Oct 2024 12:16:07 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Sat, 05 Oct 2024 04:15:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bernhard" aria-label="Profile: Bernhard">@<bdi>Bernhard</bdi></a> , you may be missing a step, if you want to stream the encoded stream using RTSP protocol, please take a look at <code>voxl-streamer</code>, which is our standard package : <a href="https://docs.modalai.com/voxl-streamer/" rel="nofollow ugc">https://docs.modalai.com/voxl-streamer/</a></p>
<p dir="auto">voxl-streamer can perform the following functions:</p>
<ul>
<li>receive unencoded yuv (or raw8 monochrome) images from camera server and encode them using VOXL2's hardware encoder (using gstreamer + OMX api) and serve the encoded video as rtsp service</li>
<li>receive encoded video stream from camera server and serve the encoded video directly</li>
</ul>
<p dir="auto">To play the h264 / h265 stream you can use VLC as Zach mentioned, or ffmpeg / ffplay:</p>
<pre><code>ffplay rtsp://&lt;board-ip&gt;:port/live
<p dir="auto">port number is printed when you run <code>voxl-streamer</code> (port can be modified with a command line argument)</p>
]]></description><link>https://forum.modalai.com/post/19222</link><guid isPermaLink="true">https://forum.modalai.com/post/19222</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Sat, 05 Oct 2024 04:15:01 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Tue, 01 Oct 2024 15:48:55 GMT]]></title><description><![CDATA[<p dir="auto">Also <a class="plugin-mentions-user plugin-mentions-a" href="/user/bernhard" aria-label="Profile: Bernhard">@<bdi>Bernhard</bdi></a> - you will never be able to view the encoded stream on voxl-portal, just on VLC or something like QGC. SDK 1.0 does support h264 which is software encoding though so innately it will be slower - does this work out the gate for you?</p>
]]></description><link>https://forum.modalai.com/post/19182</link><guid isPermaLink="true">https://forum.modalai.com/post/19182</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Tue, 01 Oct 2024 15:48:55 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Tue, 01 Oct 2024 15:48:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/aashry" aria-label="Profile: aashry">@<bdi>aashry</bdi></a> voxl-camera-server with H265 support was implemented and included in an SDK past 1.0 - any reason why you are not upgrading to 1.3.3?</p>
<p dir="auto">The other option is you mix and match versions of voxl-camera-server with your current SDK version, but odds are that will have quite a bit of conflicts as it is dependent on new versions of modalpipe and such.</p>
<p dir="auto">Zach</p>
]]></description><link>https://forum.modalai.com/post/19181</link><guid isPermaLink="true">https://forum.modalai.com/post/19181</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Tue, 01 Oct 2024 15:48:00 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Fri, 20 Sep 2024 13:29:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/aashry" aria-label="Profile: aashry">@<bdi>aashry</bdi></a>, did you actually solve this problem?<br />
I am running into the same issue.</p>
<p dir="auto">Camera config is alright, stream config seems to be right as well, but I cannot get an encoded stream in either voxl-portal or vlc.</p>
<p dir="auto">Any help would be greatly appreciated.</p>
<p dir="auto">BR</p>
]]></description><link>https://forum.modalai.com/post/19076</link><guid isPermaLink="true">https://forum.modalai.com/post/19076</guid><dc:creator><![CDATA[Bernhard]]></dc:creator><pubDate>Fri, 20 Sep 2024 13:29:36 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Tue, 14 Nov 2023 21:33:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aashry" aria-label="Profile: aashry">@<bdi>aashry</bdi></a> What UAV are you flying? Is this an off the shelf one from modalai or did you assemble it yourself?</p>
<p dir="auto">Usually that error means there is a hardware issue with the cameras</p>
]]></description><link>https://forum.modalai.com/post/13220</link><guid isPermaLink="true">https://forum.modalai.com/post/13220</guid><dc:creator><![CDATA[wilkinsaf]]></dc:creator><pubDate>Tue, 14 Nov 2023 21:33:27 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Tue, 14 Nov 2023 19:32:22 GMT]]></title><description><![CDATA[<p dir="auto">Anyone can help?</p>
]]></description><link>https://forum.modalai.com/post/13215</link><guid isPermaLink="true">https://forum.modalai.com/post/13215</guid><dc:creator><![CDATA[aashry]]></dc:creator><pubDate>Tue, 14 Nov 2023 19:32:22 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Mon, 13 Nov 2023 05:56:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aashry" aria-label="Profile: aashry">@<bdi>aashry</bdi></a></p>
<p dir="auto">Edit1: Everything above applies to the <code>h264</code> encoding as well, I haven't been able to view it in the portal and it has the same problem with the ros node.</p>
]]></description><link>https://forum.modalai.com/post/13175</link><guid isPermaLink="true">https://forum.modalai.com/post/13175</guid><dc:creator><![CDATA[aashry]]></dc:creator><pubDate>Mon, 13 Nov 2023 05:56:08 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Sun, 12 Nov 2023 20:11:24 GMT]]></title><description><![CDATA[<p dir="auto">Also, it seems like <code>voxl-camera-server</code> randomly stops working. Is SDK 1.0 completely unusable so far? or Is there a workaround that we can do?</p>
<pre><code>|           Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  t
|   hires_large_color | Server Disconnected
| hires_large_encoded | Server DisconnectedMost likely the server stopped without cleaning up
Client is cleaning up pipes for the serverdMost likely the server stopped without cleaning up
ERROR in pipe_client_init_channel opening request pipe: No such device or addressing request pipe: Ns
| hires_small_encoded | Server DisconnectedERROR in pipe_client_init_channel opening request pipe: Ns
|    hires_small_grey | Server DisconnectedClient is cleaning up pipes for the server
ERROR in pipe_client_init_channel opening request pipe: No such device or address cleaning up
Most likely the server stopped without cleaning upn pipe_client_init_channel opening request pipe: Ns
Client is cleaning up pipes for the serveraning up
]]></description><link>https://forum.modalai.com/post/13172</link><guid isPermaLink="true">https://forum.modalai.com/post/13172</guid><dc:creator><![CDATA[aashry]]></dc:creator><pubDate>Sun, 12 Nov 2023 20:11:24 GMT</pubDate></item><item><title><![CDATA[Reply to how to get H256 hires encoded imgs from sdk 1.0 ? on Sun, 12 Nov 2023 19:46:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aashry" aria-label="Profile: aashry">@<bdi>aashry</bdi></a> the following is the <code>voxl-camera-server.conf</code> file as well for your reference. Should I change anything here to fix that issue? Please elaborate.</p>
<pre><code>/**
 * voxl-camera-server Configuration File
 * Each camera has configurations for up to 4 HAL3 streams:
 *    - `preview` stream for raw unprocessed images from CV cameras
 *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
 *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
 *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
 * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
 * This file is generated from default values by voxl-configure-cameras.
 * Do not expect arbitrary resolutions to work, the ISP and video compression
 * pipelines only support very specific resolutions.
 * The default video compression mode is cqp or Constant Quantization Parameter
	"version":	0.1,
	"cameras":	[{
			"type":	"pmd-tof",
			"name":	"tof",
			"enabled":	true,
			"camera_id":	0,
			"fps":	5,
			"en_preview":	true,
			"preview_width":	224,
			"preview_height":	1557,
			"pre_format":	"tof",
			"ae_mode":	"off",
			"standby_enabled":	false,
			"decimator":	5
			"type":	"imx214",
			"name":	"hires",
			"enabled":	true,
			"camera_id":	2,
			"fps":	30,
			"en_preview":	false,
			"preview_width":	640,
			"preview_height":	480,
			"pre_format":	"nv21",
			"en_small_video":	true,
			"small_video_width":	1024,
			"small_video_height":	768,
			"small_venc_mode":	"h265",
			"small_venc_br_ctrl":	"cqp",
			"small_venc_Qfixed":	30,
			"small_venc_Qmin":	15,
			"small_venc_Qmax":	40,
			"small_venc_nPframes":	9,
			"small_venc_mbps":	2,
			"en_large_video":	true,
			"large_video_width":	4096,
			"large_video_height":	2160,
			"large_venc_mode":	"h265",
			"large_venc_br_ctrl":	"cqp",
			"large_venc_Qfixed":	38,
			"large_venc_Qmin":	15,
			"large_venc_Qmax":	50,
			"large_venc_nPframes":	29,
			"large_venc_mbps":	30,
			"en_snapshot":	true,
			"en_snapshot_width":	4160,
			"en_snapshot_height":	3120,
			"ae_mode":	"isp"
			"type":	"ov7251",
			"name":	"tracking",
			"enabled":	true,
			"camera_id":	1,
			"fps":	30,
			"en_preview":	true,
			"pre_format":	"raw8",
			"ae_mode":	"lme_msv",
			"ae_desired_msv":	60,
			"ae_exposure_period":	1,
			"ae_gain_period":	1
]]></description><link>https://forum.modalai.com/post/13171</link><guid isPermaLink="true">https://forum.modalai.com/post/13171</guid><dc:creator><![CDATA[aashry]]></dc:creator><pubDate>Sun, 12 Nov 2023 19:46:33 GMT</pubDate></item></channel></rss>
