  3. Quectel 5G-Modem doesn't work at all
cellular
25 Posts 3 Posters 8.4k Views 2 Watching
  • Jerry LinJ Offline
    Jerry LinJ Offline
    Jerry Lin
    wrote on last edited by Jerry Lin
    Hi, I followed 5G Modem User Guide
    voxl2:/$ voxl-configure-modem
    Starting interactive mode
    What type of modem are you using?
    1) v2	      3) dtc	    5) quectel
    2) microhard  4) doodle	    6) em9191
    #? 5
    Are you attempting to connect to ModalLink? (not common)
    1) yes
    2) no
    #? 2
    Which APN is correct for your SIM card?
    AT&T - IoT device - APN: m2m.com.attz
    AT&T - Laptop or Tablet - APN: broadband
    AT&T - Smartphone - APN: phone
    T-Mobile - APN: fast.t-mobile.com
    Verizon - APN: vzwinternet
    Google Fi - APN: h2g2
    1) m2m.com.attz	      4) fast.t-mobile.com  7) Custom
    2) broadband	      5) vzwinternet
    3) phone	      6) googlefi
    #? 7
    Please enter a custom APN
    nxtgenphone
    Select modem region:
    1) Americas
    2) Europe/Middle-East/Asia
    #? 1
    qrb5165 based device detected
    reloading systemd services
    enabling voxl-modem systemd service
    starting voxl-modem systemd service
    DONE configuring voxl-modem
    and it always failed with:
    voxl2:/$ systemctl status -l voxl-modem
    ● voxl-modem.service - Modem Initialization
       Loaded: loaded (/etc/systemd/system/voxl-modem.service; enabled; vendor preset: enabled)
       Active: active (running) since Sun 2024-09-08 07:03:55 UTC; 14s ago
      Process: 3019 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
     Main PID: 3020 (voxl-modem-star)
        Tasks: 2 (limit: 4915)
       CGroup: /system.slice/voxl-modem.service
               └─3020 /bin/bash /usr/bin/voxl-modem-start
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:955] qmidevice_detect failed
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:956] Quectel_QConnectManager_Linux_V1.6.0.24
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:957] network interface '' or qmidev '' is not exist
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:957] qmidevice_detect failed
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:961] Quectel_QConnectManager_Linux_V1.6.0.24
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:961] network interface '' or qmidev '' is not exist
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:961] qmidevice_detect failed
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:963] Quectel_QConnectManager_Linux_V1.6.0.24
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:963] network interface '' or qmidev '' is not exist
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:963] qmidevice_detect failed
    I checked this forum and tried the following command
    $ quectel-CM -s nxtgenphone
    [09-08_07:06:58:832] Quectel_QConnectManager_Linux_V1.6.0.24
    [09-08_07:06:58:832] network interface '' or qmidev '' is not exist
    [09-08_07:06:58:832] qmidevice_detect failed
    [09-08_07:06:58:833] qmidevice_detect failed
    The result was still the same.
    I tried the latest voxl-modem and still no luck.
    I purchased Sentinel with 5G LTE modem without touching anything. I double checked the Quectel modem after inserting the SIM and confirmed it is secured as before.
    Can anybody help resolve this issue?
    • Jerry LinJ Jerry Lin
      #? 5
      1) yes
      2) no
      #? 2
      #? 7
      nxtgenphone
      1) Americas
      #? 1
      @Jerry-Lin What do you see with lsusb and lsusb -t?
      Jerry LinJ 1 Reply Last reply
        Jerry LinJ Offline
        Jerry LinJ Offline
        Jerry Lin
        Hi @tom, here are the outputs:
        voxl2:/$ lsusb
        voxl2:/$ lsusb -t
        /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 10000M
        /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
          voxl2:/$ lsusb
          voxl2:/$ lsusb -t
          Jerry LinJ Offline
          Jerry LinJ Offline
          Jerry Lin
            Jerry LinJ Offline
            Jerry Lin
            The weird thing is every time I insert the SIM card, my WiFi will be gone without even the blue flash light from the WiFi module.
            Then, it took me long to get WiFi back by reconnecting the wire, touching around Quectel module, restarting dhcpcd and disabling voxl-modem, anything I can think of related to wlan0.
            After having WiFi, lsusb would output:
            Bus 002 Device 002: ID 0424:5744 Standard Microsystems Corp.
            Bus 001 Device 004: ID 0424:2740 Standard Microsystems Corp.
            Bus 001 Device 003: ID 0bda:0811 Realtek Semiconductor Corp.
            Bus 001 Device 002: ID 0424:2744 Standard Microsystems Corp.
            While having more USB devices, I tried voxl-configure-modem without the SIM card, I still got
              @Jerry-Lin Yeah it doesn't seem as though the quectel modem is being detected at all. Can you post a picture of your setup as a sanity check?
                Jerry LinJ Offline
                Jerry Lin
                Sure,
                I didn't touch anything except for opening the cover, unscrewing the nuts and inserting the SIM card.
                  Sure,
                  @Jerry-Lin Are you sure that the add-on board is fully seated onto the VOXL 2? There are two connectors that need to be fully seated
                    Jerry LinJ Offline
                    Jerry LinJ Offline
                    Jerry Lin
                    Hi @tom I am not sure and don't know how.
                    Can you show me some pictures so I can have the clue which modules are needed take apart for checking and making sure.
                      @Jerry-Lin If you looks at the diagram here: https://docs.modalai.com/5G-Modem-datasheet/#block-diagrams
                      both J4 and J2 need to fully inserted into J5 and J3 of VOXL 2, seen here: https://docs.modalai.com/voxl2-connectors/#connector-callouts
                        Jerry LinJ Offline
                        Jerry Lin
                        Super cool, after all unscrewed and the modem taken out, I saw the connectors. Knowing how they connect, I pressed hard to make sure fully seated and the qmidevice_detect failed went away with the WiFi working!!!
                        The output of lsusb looks more devices now:
                        voxl2:~$ lsusb
                        Bus 002 Device 003: ID 2c7c:0800
                        The output of quectel-CM is now totally different:
                        voxl2:~$ quectel-CM -s nxtgenphone
                        [09-10_01:27:54:793] Quectel_QConnectManager_Linux_V1.6.0.24
                        [09-10_01:27:54:795] Find /sys/bus/usb/devices/2-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x002, dev=0x003
                        [09-10_01:27:54:795] Auto find qmichannel = /dev/cdc-wdm0
                        [09-10_01:27:54:795] Auto find usbnet_adapter = wwan0
                        [09-10_01:27:54:795] netcard driver = qmi_wwan, driver version = 22-Aug-2005
                        [09-10_01:27:54:796] Modem works in QMI mode
                        [09-10_01:27:54:828] /proc/3149/fd/7 -> /dev/cdc-wdm0
                        [09-10_01:27:54:828] /proc/3149/exe -> /usr/bin/quectel-CM
                        [09-10_01:27:56:830] cdc_wdm_fd = 7
                        [09-10_01:27:56:905] Get clientWDS = 1
                        [09-10_01:28:26:908] QmiWwanGetClientID message timeout
                        [09-10_01:28:26:921] Get clientNAS = 4
                        [09-10_01:28:26:953] Get clientUIM = 1
                        [09-10_01:28:26:985] Get clientWDA = 1
                        [09-10_01:28:26:985] QMIType 2 has no clientID
                        [09-10_01:28:26:985] requestBaseBandVersion err = -19
                        [09-10_01:28:41:321] QmiWwanThread read=-1 errno: 2 (No such file or directory)
                        [09-10_01:28:56:987] requestSetEthMode message timeout
                        [09-10_01:28:56:987] requestSetEthMode err = 110
                        [09-10_01:29:26:989] requestGetSIMStatus message timeout
                        [09-10_01:29:26:990] requestGetSIMStatus err = 110
                        [09-10_01:29:26:990] requestSetProfile[1] nxtgenphone///0
                        [09-10_01:29:27:081] QmiWwanThread read=-1 errno: 2 (No such file or directory)
                        [09-10_01:29:57:051] requestGetProfile message timeout
                        [09-10_01:29:57:051] requestGetProfile err = 110
                        [09-10_01:29:57:064] QmiWwanThread read=-1 errno: 2 (No such file or directory)
                        [09-10_01:30:27:054] requestRegistrationState2 message timeout
                        [09-10_01:30:27:055] requestRegistrationState2 err = 110
                        [09-10_01:30:57:056] requestQueryDataCall message timeout
                        [09-10_01:30:57:057] requestQueryDataCall err = 110
                        [09-10_01:30:57:057] ifconfig wwan0 0.0.0.0
                        [09-10_01:30:57:083] ifconfig wwan0 down
                        [09-10_01:30:57:129] requestRegistrationState2 MCC: 310, MNC: 410, PS: Attached, DataCap: LTE
                        [09-10_01:32:57:130] requestSetupDataCall message timeout
                        [09-10_01:32:57:130] requestSetupDataCall err = 110
                        [09-10_01:32:57:130] try to requestSetupDataCall 5 second later
                        [09-10_01:35:02:132] requestSetupDataCall message timeout
                        [09-10_01:35:02:133] requestSetupDataCall err = 110
                        [09-10_01:35:02:133] try to requestSetupDataCall 10 second later
                        [09-10_01:35:12:170] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
                        [09-10_01:35:12:170] try to requestSetupDataCall 20 second later
                        [09-10_01:35:32:200] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
                        [09-10_01:35:32:200] try to requestSetupDataCall 40 second later
                        [09-10_01:38:12:226] requestSetupDataCall message timeout
                        [09-10_01:38:12:228] requestSetupDataCall err = 110
                        [09-10_01:38:12:228] try to requestSetupDataCall 60 second later
                        [09-10_01:41:12:274] requestSetupDataCall message timeout
                        [09-10_01:41:12:277] requestSetupDataCall err = 110
                        [09-10_01:41:12:277] try to requestSetupDataCall 60 second later
                        [09-10_01:44:12:304] requestSetupDataCall message timeout
                        [09-10_01:44:12:304] requestSetupDataCall err = 110
                        [09-10_01:44:12:304] try to requestSetupDataCall 60 second later
                        [09-10_01:45:12:357] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
                        [09-10_01:45:12:357] try to requestSetupDataCall 60 second later
                        [09-10_01:46:12:424] QmiWwanThread read=-1 errno: 2 (No such file or directory)
                        [09-10_01:48:12:391] requestSetupDataCall message timeout
                        [09-10_01:48:12:391] requestSetupDataCall err = 110
                        [09-10_01:48:12:392] try to requestSetupDataCall 60 second later
                        [09-10_01:49:12:454] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
                        [09-10_01:49:12:454] try to requestSetupDataCall 60 second later
                        [09-10_01:52:12:486] requestSetupDataCall message timeout
                        [09-10_01:52:12:486] requestSetupDataCall err = 110
                        [09-10_01:52:12:486] try to requestSetupDataCall 60 second later
                        [09-10_01:55:12:530] requestSetupDataCall message timeout
                        [09-10_01:55:12:533] requestSetupDataCall err = 110
                        [09-10_01:55:12:533] try to requestSetupDataCall 60 second later
                        [09-10_01:56:12:582] QmiWwanThread read=-1 errno: 2 (No such file or directory)
                        [09-10_01:58:12:576] requestSetupDataCall message timeout
                        [09-10_01:58:12:576] requestSetupDataCall err = 110
                        [09-10_01:58:12:576] try to requestSetupDataCall 60 second later
                        [09-10_01:59:12:615] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
                        [09-10_01:59:12:615] try to requestSetupDataCall 60 second later
                        However, it takes forever to finish. I googled around my AT&T APN, it looks right using nxtgenphone:
                        If you have an:
                        LTE device: Set your settings to NXTGENPHONE
                        Data device: Set your settings to Broadband
                        5G Smartphone: Set your settings to ENHANCEDPHONE
                        Not sure what is going wrong this time.
                        VinnyV tomT 2 Replies Last reply
                          voxl2:~$ lsusb
                          If you have an:
                          Hi @Jerry-Lin
                          Glad Tom was able to help you and you are making progress.
                          For future note, please re-install the nut hardware on these screws or the boards can become separated again leading to more failures.
                          Please be careful to ensure they do not contact any of the circuit components on the PCB.
                            voxl2:~$ lsusb
                            If you have an:
                            @Jerry-Lin Awesome seems as though the hardware is working as expected now. I can't tell you what the correct APN is for your network, it very much depends on your plan, provider, etc. It's possible you need a SIM card specifically for IOT devices from your carrier
                              Jerry LinJ Offline
                              Jerry Lin
                              Sure, will do.
                              Sorry that I was trying to insert the SIM card and realized unable to do it unless lifting the modem module. After inserting the SIM card, I didn't push hard worrying breaking anything because the drone is super expensive.
                              Thanks to Tom for helping me understand how the modules are connected. I think inserting the SIM card is a very frequent activity and it would be nice to make it very accessible by a hole like others on the side. It took me hours to figure out how to access the SIM card socket. Anyway, now I learned how to secure the connections and not a problem for me anymore.
                              BTW, any idea about my last "timeout and trying forever" issue? I have tried two SIM cards without a success.
                                Jerry LinJ Offline
                                Jerry Lin
                                @tom said in Quectel 5G-Modem doesn't work at all:
                                So, did you mean normal phone SIM cards are not compatible with the Quectel modem and the "5G LTE" is not the same protocol our phones use as advertised "Connectivity: 4G/5G"?
                                Then, what are requirements should I provide to my carrier (located in Pennsylvania, USA) for this kind of SIM card to get the drone Internet access?
                                  @Jerry-Lin They can be, it just depends on the carrier. We always test here with Google Fi IoT SIM cards, they're super easy to setup and cheap
                                    Jerry LinJ Offline
                                    Jerry Lin
                                    #17
                                    Cool, my carriers are AT&T and Xfinity Mobile. What I should I mention to them for my application? Just IoT or any specs that you know about?
                                    So, the log:
                                    looks a SIM card issue to you? Or what else (e.g. commands or wiring) can I try to get 5G connected?
                                      So, the log:
                                      @Jerry-Lin I would mention IOT as well as the modem you're using "Quectel RM502Q-AE". I know when I was first working with this modem that some carriers didn't yet support but that was a long time ago so I'm guessing that has changed
                                        Jerry LinJ Offline
                                        Jerry Lin
                                        OK, will get to carries to see if I can move forward with the existing SIM cards. If not, will try Google Fi IoT SIM cards.
                                        Thanks for the advice!!!
                                          Jerry LinJ Offline
                                          Jerry Lin
                                          I
                                          • checked with an AT&T store and they provide SIM card for phone only.
                                          • then googled around and found several attempts using Quectel MODEM with AT&T SIM card and AT commands were used for debugging.
                                          • searched in ModalAI Forum and found some AT commands for the model.
                                          • tried but got only ERROR
                                            voxl2:~$ echo -ne "AT+QNWPREFCFG="mode_pref",LTE:NR5G\r" | busybox microcom /dev/ttyUSB2
                                            AT+QNWPREFCFG=mode_pref,LTE:NR5G
                                            ERROR
                                          • did voxl-configure-modem again to see if AT commands can be used and found the same command:
                                            Sep 25 02:41:22 m0054 voxl-modem-start[8392]: qrb5165 based hardware detected...
                                            Sep 25 02:41:22 m0054 voxl-modem-start[8392]: \Setting mode preference to LTE / 5G
                                            Sep 25 02:41:22 m0054 voxl-modem-start[8392]: AT+QNWPREFCFG="mode_pref",LTE:NR5G
                                            Sep 25 02:41:22 m0054 voxl-modem-start[8392]: OK
                                            Sep 25 02:41:23 m0054 voxl-modem-start[8392]: Initalizing cellular connection...
                                          • After 7 minutes I saw: no lease, failing. Well, at least, it tried to lease.
                                            Sep 25 02:48:49 m0054 voxl-modem-start[8392]: udhcpc: started, v1.27.2
                                            Sep 25 02:48:49 m0054 voxl-modem-start[8392]: No resolv.conf for interface wwan0.udhcpc
                                            Sep 25 02:48:49 m0054 voxl-modem-start[8392]: udhcpc: sending discover
                                            Sep 25 02:48:52 m0054 voxl-modem-start[8392]: udhcpc: sending discover
                                            Sep 25 02:48:55 m0054 voxl-modem-start[8392]: udhcpc: sending discover
                                            Sep 25 02:48:58 m0054 voxl-modem-start[8392]: udhcpc: sending discover
                                            Sep 25 02:49:01 m0054 voxl-modem-start[8392]: udhcpc: sending discover
                                            Sep 25 02:49:04 m0054 udhcpc[10399]: wwan0: configuration failed: leasefail:
                                            Sep 25 02:49:04 m0054 voxl-modem-start[8392]: udhcpc: no lease, failing
                                          • All of sudden, I saw lease obtained with an IP provided:
                                            Sep 25 02:49:04 m0054 voxl-modem-start[8392]: udhcpc: started, v1.27.2
                                            Sep 25 02:49:05 m0054 voxl-modem-start[8392]: No resolv.conf for interface wwan0.udhcpc
                                            Sep 25 02:49:05 m0054 voxl-modem-start[8392]: udhcpc: sending discover
                                            Sep 25 02:49:05 m0054 voxl-modem-start[8392]: udhcpc: sending select for 10.194.135.84
                                            Sep 25 02:49:05 m0054 voxl-modem-start[8392]: udhcpc: lease of 10.194.135.84 obtained, lease time 7200
                                            Sep 25 02:49:05 m0054 voxl-modem-start[8392]: Too few arguments.
                                          • I was not sure about the impact of Too few arguments error, though.
                                          Well, with an IP address, I tried to:
                                          • ping
                                          • ssh
                                          Unfortunately only responded with timeout messages.
                                          Wondering if I really have the Internet access, I did ifconfig wlan0 down and the ping google.com from voxl. It was still responded !!!
                                          Hmm, how about continue Connecting to QGC over 5G instructions?
                                          • With Tailscale VPN installed, I was able to ssh to the drone using the VPN IP address!!!
                                          • With QGroundControl setup, I was able to see the drone statuses and statistics using the VPN IP address!!!
                                          That means I can control the drone even it is hundreds of miles away!!!
                                          Millions of thanks for great help @tom and @Vinny !!!!!!!!!!!
                                          Still with Too few arguments error, I am not sure how good the 4G/5G connection would be. Will experiment more to figure out. However, if you guys know anything can be improved, please let me know.
