  3. Vision sensors not detected in VOXL2
image-sensor
17 Posts 4 Posters 3.2k Views 2 Watching
  • Jetson NanoJ Jetson Nano
    Hey @modaltb @Alex-Kushleyev @James-Strawson
    I'm using a Starling drone setup on a custom airframe. The sensor suite is the same as in Starling drone. Recently, during ground test, every vision sensor on the drone worked fine. But during flight we noticed that Tracking Camera(ov9281 fisheye lens) was'nt detected and the error message of CAM_INSTALLED_MISSING appeared on screen and ToF also stopped publishing depth data.
    I tried reflashing the system with SDK 1.1.1 again. But concurrently the ToF now stopped from being detected by the VOXL-CAMERA_SERVER and VOXL_VISION_HUB.
    Current SDK being used on the system is 1.1.1.
    To troubleshoot, tried
    1. removing the cable connectors and attaching again, but still particularly the ToF is'nt getting detetcted.
    2. tried adding only the individual sensors including tracking and checking if camera server and vision server detects and services are functioning, but still ToF dint show up on sensors being detected.
    3. Is there any debugger command to check and troubleshoot ToF sensor in voxl-camera-server pipeline?
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    I'm getting following output when running the command, voxl-camera-server -l
    voxl2:/$ voxl-camera-server -l
    DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x0020, Sensor Id: 0x0214
    DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x00C0, Sensor Id: 0x7750
    DEBUG:   Number of cameras: 2
    Stats for camera: 0:
    	4208x3120, 4096x2160, 2104x1560, 1920x1080, 1280x 720,
    ANDROID_SCALER_AVAILABLE_PROCESSED_SIZES:
    ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS_OUTPUT:
    ANDROID_SCALER_AVAILABLE_JPEG_SIZES:
    	min = 54
    	max = 431
    	431
    	min = 15723ns
    	max = 683714540ns
    Stats for camera: 1:
    	 640x 480,  640x 480,  640x 480,
    	min = 54
    	max = 431
    	431
    	min = 0ns
    	max = 17942880ns
    ToF is not being detected here either. Even though High-res and Tracking ov7251 is detected, still there is no output stream which could be observed on voxl-portal.
    modaltbM 1 Reply Last reply
      	min = 54
      	max = 431
      	431
      	min = 15723ns
      	max = 683714540ns
      	min = 54
      	max = 431
      	431
      	min = 0ns
      	max = 17942880ns
      modaltbM Offline
      modaltbM Offline
      modaltb
      @Jetson-Nano If you've reverted back to original config, run voxl-configure-cameras and select the D0005 Starling option.
      When you want to use ov9782, you need to copy the correct binary into /usr/lib/camera and also update config file?
      A high level helper is here:
      https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/master/misc_files/usr/share/modalai/voxl-camera-server/custom_camera_config.txt?ref_type=heads
      You can then use voxl-configure-cameras -c to use custom setup, after you've setup the above file into correct place (see top of the file for direction).
      see this for logic of setting up proper bins:
      https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/master/scripts/qrb5165-configure-cameras
      see https://docs.modalai.com/voxl2-image-sensors/ for more info, but since we support a lot of different configs and, because of I2C clashes if we have all binaries in /usr/lib/camera, we copy bins into place using camera-server wizard.
      • modaltbM modaltb
        Jetson Nano
        Veteran
        @modaltb Thanks for reverting. I have a doubt. Generally I don'nt copy any binaries while setting up camera servers. Also, I'm following D0005 Starling camera config only.
        1. If binaries are to copied, from where do I get the binaries from?
        2. How do I update the config file?
        My h/w config is similar to this,
          Jetson Nano
          Veteran
          @modaltb , sorry there was a mistake in my first post. I am not using a different sensor, I am using the same sensor which I got with Starling which is ov7251 (fisheye lens). Initially when I was testing, everything was fine with SDK 1.1.1. And all of sudden with no hardware or software changes, the voxl-camera-server was not running. If I run using
          voxl-camera-server -d 0
          all the camera runs and I can see them in the portal, but it'll abort after some time (Approx 5 sec). I tried disabling and enabling, restarting, rebooting but it was the same.
          voxl2:~$ voxl-camera-server -l
          DEBUG:   ----------- Number of cameras: 5
          DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x007A, Sensor Id: 0x003D
          DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x0020, Sensor Id: 0x0214
          DEBUG:   Cam idx: 2, Cam slot: 3, Slave Address: 0x00E2, Sensor Id: 0x7750
          DEBUG:   Cam idx: 3, Cam slot: 4, Slave Address: 0x00E2, Sensor Id: 0x7750
          DEBUG:   Cam idx: 4, Cam slot: 5, Slave Address: 0x00E4, Sensor Id: 0x7750
          DEBUG:   Number of cameras: 5
          Stats for camera: 0
           224 x 1557
           224 x 1557 HAL_PIXEL_FORMAT_RAW10
           224 x 1557 HAL_PIXEL_FORMAT_RAW12
           224 x 1557 HAL_PIXEL_FORMAT_RAW16
           224 x 1557 HAL_PIXEL_FORMAT_RAW_OPAQUE
          	min = 54
          	max = 0
          	min = 0ns
          	max = 0ns
          Stats for camera: 1
          4208 x 3120
          3840 x 2160
          1920 x 1080
          1920 x 1080
          4208 x 3120 HAL_PIXEL_FORMAT_YCbCr_420_888
          4208 x 3120 HAL_PIXEL_FORMAT_BLOB
          4160 x 3120 HAL_PIXEL_FORMAT_YCbCr_420_888
          4160 x 3120 HAL_PIXEL_FORMAT_BLOB
          4096 x 2304 HAL_PIXEL_FORMAT_YCbCr_420_888
          4096 x 2304 HAL_PIXEL_FORMAT_BLOB
          4096 x 2160 HAL_PIXEL_FORMAT_YCbCr_420_888
          4096 x 2160 HAL_PIXEL_FORMAT_BLOB
          1280 x  960 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  960 HAL_PIXEL_FORMAT_BLOB
          1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  800 HAL_PIXEL_FORMAT_BLOB
          1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  768 HAL_PIXEL_FORMAT_BLOB
          1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  720 HAL_PIXEL_FORMAT_BLOB
          1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
          1024 x  738 HAL_PIXEL_FORMAT_BLOB
          1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
          1024 x  768 HAL_PIXEL_FORMAT_BLOB
           864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           864 x  480 HAL_PIXEL_FORMAT_BLOB
           800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
           800 x  600 HAL_PIXEL_FORMAT_BLOB
           800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           800 x  480 HAL_PIXEL_FORMAT_BLOB
           720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           720 x  480 HAL_PIXEL_FORMAT_BLOB
          4208 x 3120 HAL_PIXEL_FORMAT_RAW10
          4208 x 3120 HAL_PIXEL_FORMAT_RAW12
          4208 x 3120 HAL_PIXEL_FORMAT_RAW16
          4208 x 3120 HAL_PIXEL_FORMAT_RAW_OPAQUE
          	min = 54
          	max = 431
          	431
          	min = 10449ns
          	max = 683714540ns
          Stats for camera: 2
           640 x  480
           640 x  480
           640 x  480
           640 x  480 HAL_PIXEL_FORMAT_RAW10
           640 x  480 HAL_PIXEL_FORMAT_RAW12
           640 x  480 HAL_PIXEL_FORMAT_RAW16
           640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
          	min = 54
          	max = 3451
          	3451
          	min = 0ns
          	max = 1266732525ns
          Stats for camera: 3
           640 x  480
          	min = 54
          	max = 3451
          	3451
          	min = 0ns
          	max = 1266732525ns
          Stats for camera: 4
           640 x  480
          	min = 54
          	max = 3451
          	3451
          	min = 0ns
          	max = 1266732525ns
          Number of cameras detected: 5
          voxl2:~$ voxl-camera-server -s
          Assuming type: PMD_TOF for camera 0
          Assuming type: IMX214 for camera 1
          detected system image 1.7.6
          using new imx214 defaults
          Assuming type: OV7251 for camera 2
          Assuming type: OV7251 for camera 3
          Assuming type: OV7251 for camera 4
          connected to GPS mavlink pipe
          Starting Camera: cam0 (id #0)
          Connected to cpu-monitor
          Starting Camera: cam1 (id #1)
          Using gain limits min: 54 max: 431
          WARNING: Port Def 0:
          	Count Min: 8
          	Count Actual: 16
          	Buffers Contiguous: Yes
          	Buffer Alignment: 0
          WARNING: Port Def 1:
          	Count Min: 4
          	Count Actual: 16
          	Buffers Contiguous: No
          	Buffer Alignment: 0
          	Count Min: 8
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 4
          	Count Actual: 16
          	Buffer Alignment: 0
          Starting Camera: cam2 (id #2)
          Using gain limits min: 54 max: 3451
          setting ov7251 BLC register for cam id 2
          Starting Camera: cam3 (id #3)
          ERROR:   Royale startCapture! 1024
          setting ov7251 BLC register for cam id 3
          Starting Camera: cam4 (id #4)
          setting ov7251 BLC register for cam id 4
          ------ voxl-camera-server: Started 5 of 5 cameras
          Aborted
          	Count Min: 8
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 4
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 8
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 4
          	Count Actual: 16
          	Buffer Alignment: 0
          ERROR:   [ERROR] in _sensor_ioctl, ioctl failed: Connection timed out
          ERROR:   [ERROR] in voxl_cci_write_word_array, Failed ioctl call
          ERROR:   Failed CCI read
          Aborted
          Later when we changed SDK and checked, the cameras weren't working. I have another starling drone, from which I checked the files in /usr/lib/camera and it was the same, and also I tried copying the files from starling's /camera directory and pasted it to the setup I am using and still it is not working. When I tried with different SDK (1.1.0), TOF works, but the tracking and high res doesn't. I tried changing the ports of the cameras also, but it is still the same.
          In 1.1.1 the tracking is working fine, the TOF is not being detected and the highres is being detected but not sending any video feed in portal.
          I tried configuring individual cameras one after another and still it is the same. I tried custom config and still the issue remains.
          DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x00E2, Sensor Id: 0x7750
          Stats for camera: 0
          4208 x 3120
          3840 x 2160
          1920 x 1080
          1920 x 1080
          	min = 54
          	max = 431
          	431
          	min = 10449ns
          	max = 683714540ns
          Stats for camera: 1
           640 x  480
           640 x  480
           640 x  480
          	min = 54
          	max = 3451
          	3451
          	min = 0ns
          	max = 1266732525ns
          Number of cameras detected: 2
          detected system image 1.7.8
          configuration for 3 cameras:
          cam #0
              sensor type:         pmd-tof
              isEnabled:           1
              camId:               0
              camId2:              -1
              fps:                 5
              en_rotate:           1
              en_rotate2:          0
              en_preview:          1
              pre_width:           224
              pre_height:          1557
              en_raw_preview:      1
              en_small_video:      0
              small_video_width:   -1
              small_video_height:  -1
              en_large_video:      0
              large_video_width:   -1
              large_video_height:  -1
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              msv_exposure_min_us: 20
              msv_exposure_max_us: 33000
              standby_enabled:     0
              decimator:           5
              independent_exposure:0
          cam #1
              sensor type:         imx214
              isEnabled:           1
              camId:               1
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          0
              pre_width:           640
              pre_height:          480
              en_raw_preview:      0
              en_small_video:      1
              small_video_width:   1024
              small_video_height:  768
              en_large_video:      1
              large_video_width:   4208
              large_video_height:  3120
              en_snapshot:         1
              snap_width:          4208
              snap_height:         3120
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
          cam #2
              sensor type:         ov7251
              isEnabled:           1
              camId:               2
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           640
              pre_height:          480
              en_raw_preview:      1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
          fsync_en:            0
          fsync_gpio:          109
          Starting Camera: tof (id #0)
          ERROR:   Camera 0 failed to find supported preview config: 224x1557
          WARNING: Failed to start cam tof due to invalid resolution
          WARNING: assuming cam is missing and trying to compensate
          Starting Camera: hires (originally id #1) with id offset: 1
          Starting Camera: tracking (originally id #2) with id offset: 1
          setting ov7251 BLC register for cam id 1
          ------ voxl-camera-server: Started 2 of 3 cameras
            Stats for camera: 0
             224 x 1557
            	min = 54
            	max = 0
            	min = 0ns
            	max = 0ns
            Stats for camera: 1
            4208 x 3120
            3840 x 2160
            1920 x 1080
            1920 x 1080
            	min = 54
            	max = 431
            	431
            	min = 10449ns
            	max = 683714540ns
            Stats for camera: 2
             640 x  480
             640 x  480
             640 x  480
            	min = 54
            	max = 3451
            	3451
            	min = 0ns
            	max = 1266732525ns
            Stats for camera: 3
             640 x  480
            	min = 54
            	max = 3451
            	3451
            	min = 0ns
            	max = 1266732525ns
            Stats for camera: 4
             640 x  480
            	min = 54
            	max = 3451
            	3451
            	min = 0ns
            	max = 1266732525ns
            	Count Min: 8
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 4
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 8
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 4
            	Count Actual: 16
            	Buffer Alignment: 0
            Aborted
            	Count Min: 8
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 4
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 8
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 4
            	Count Actual: 16
            	Buffer Alignment: 0
            Aborted
            Stats for camera: 0
            4208 x 3120
            3840 x 2160
            1920 x 1080
            1920 x 1080
            	min = 54
            	max = 431
            	431
            	min = 10449ns
            	max = 683714540ns
            Stats for camera: 1
             640 x  480
             640 x  480
             640 x  480
            	min = 54
            	max = 3451
            	3451
            	min = 0ns
            	max = 1266732525ns
            cam #0
                isEnabled:           1
                camId:               0
                camId2:              -1
                fps:                 5
                en_rotate:           1
                en_rotate2:          0
                en_preview:          1
                pre_width:           224
                pre_height:          1557
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             off
                standby_enabled:     0
                decimator:           5
            cam #1
                sensor type:         imx214
                isEnabled:           1
                camId:               1
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          0
                pre_width:           640
                pre_height:          480
                en_raw_preview:      0
                en_small_video:      1
                en_large_video:      1
                en_snapshot:         1
                snap_width:          4208
                snap_height:         3120
                ae_mode:             isp
                standby_enabled:     0
                decimator:           1
            cam #2
                sensor type:         ov7251
                isEnabled:           1
                camId:               2
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           640
                pre_height:          480
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                standby_enabled:     0
                decimator:           1
            fsync_en:            0
            fsync_gpio:          109
            Jetson Nano
            Veteran
            @modaltb @Alex-Kushleyev @Chad-Sweet Some help in this would be really appreciated.
            • Jetson NanoJ Jetson Nano referenced this topic on
              @Jetson-Nano , sorry for the delay.
              I have noticed that you are running the hires camera (IMX214) at full resolution 4208x3120@30fps (large video). We recently found that in some cases, this can cause the camera server to abort. Just to test the theory, can you please try reducing the FPS of hires camera from 30 to 25 and see if the issue goes away. If it does not go away, please try to disable the cameras one by one in voxl-camera-server.conf to try to isolate which one is causing the issue.
                Jetson Nano
                Veteran
                @Alex-Kushleyev I'll test the solution what you told for High res and get back, what about the ToF?
                  @Jetson-Nano , I guess I am a little confused whether you have one or more issues right now.
                  Let's focus on the TOF sensor. if you simply unplug all the sensors except for TOF and set up your voxl-camera-server.conf to only have TOF streaming enabled, does TOF work? If not, do you have more than one TOF sensor to check?
                    Jetson Nano
                    Veteran
                    @Alex-Kushleyev In my current system I have a Tracking(ov7251), Highres(imx214) and a pmd-tof. I have removed and tracking and highres and had only only ToF connected.
                    I setup the camera config for ToF only. The ToF was connected to J6 Lower through interposer to Voxl2. Using the command
                    voxl-inspect-cam -a
                    I'm not able to see the details of ToF connected.
                    In the same setup I use another ToF sensor and check, initially it doesn't get detected but upon running the camera config config couple of times and after few mins post starting the voxl-camera-server through terminal, I get the ToF feed in VOXL portal.
                      voxl-inspect-cam -a
                      @Jetson-Nano , please note that when you attach a new TOF V1 sensor to VOXL2, the first time you run voxl-camera-server, it will try to see if there is a calibration file downloaded from the TOF sensor and stored on VOXL2. This calibration file contains device-specific information (lens calibration, etc) that is used by the TOF software library to process the raw data and create the point clouds. If the calibration file is not present on VOXL2 (it is checked by the serial number of the TOF device), the calibration file will be downloaded from the TOF sensor by voxl-camera-server. This download process takes about 1 minute to complete and it may seem like the camera server / TOF is not working at that time (it will just sit quietly, unless you run voxl-camera-server -d 0 to enable the debug messages).
                      I believe that this may be an issue you saw then you used "another ToF sensor" - perhaps you did not initially wait long enough for the calibration file to be downloaded by voxl-camera-server. But after the calibration file has been downloaded, the TOF sensor started working.
                        Jetson Nano
                        Veteran
                        @Alex-Kushleyev Thanks for reverting. Where is the calibration file saved in VOXL2?
                        ModeratorM 1 Reply Last reply
                          @Jetson-Nano you can see in the docs the calibration is stored in /data/modalai https://docs.modalai.com/calibrate-cameras/
                          • ModeratorM Moderator
                            Jetson Nano
                            Veteran
                            #14
                            @Moderator I meant to ask, where are calibration files of ToF is located?
                              @Jetson-Nano , for TOF V1, the calibration should be downloaded from the sensor when the camera server sees it for the very first time. The location should be /data/misc/camera/<sensor_serial_number>.
                              TOF V2 does not store the data on VOXL2, instead the calibration data is downloaded every time and is used by the TOF processing library to generate the point clouds.
                                Jetson Nano
                                Veteran
                                @Alex-Kushleyev Thanks for reverting. But not always I have compute compute connected to internet in station mode, rather it stays in softap. In the case of latter, when I reconfigure the voxl-camera-server how will calib files be downloaded?
                                  @Jetson-Nano , the ToF V1 calibration file is downloaded from the sensor itself via i2c . No internet connection is required.
