  3. Intergrating VL53L1x Range Finder with VOXL2
voxl-2
32 Posts 4 Posters 8.8k Views 2 Watching
  • modaltbM Offline
    modaltbM Offline
    modaltb
    Hi @Jetson-Nano our implementation is used on the applications processor (not the DSP) so you would want to use this reference:
    https://gitlab.com/voxl-public/voxl-sdk/services/qrb5165-rangefinder-server/-/tree/master
    • Jetson NanoJ Jetson Nano
      I'm using a VL53L1x rangefinder for reducing drift accumulated during VIO on a Starling system. I'm using the sensor VL53L1X, which I'm connecting to VOXL2 through J19 port where I2C communication lanes (Pins 7,8) are available.
      When I enable range finder parameters in QGC, I'm not getting any data from the rangefinder in mavlink inspector or mavlink console. As mentioned in ModalAI documentation, this sensor is directly compatable with VOXL2. Is there any specific functional parameter which is to be enabled in PX4 config seperately?
      James StrawsonJ Offline
      James Strawson
      Hi @Jetson-Nano
      The I2C port on J19 is connected to the Sensors DSP and therefore can't be accessed from the main applications processor.
      Here is a new documentation page describing how to hook up and use these sensors.
      https://docs.modalai.com/rangefinders/
      • Jetson NanoJ Offline
        Jetson Nano
        Veteran
        Thank you @modaltb @James-Strawson,
        Will check and get back. Apart from VL53L1x what are the other Rangefinder sensors which are compatible with VOXL2?
          Jetson Nano
          Veteran
          @James-Strawson @modaltb , I checked with reference to the documentation you shared, but still it was not working.
          I used the M0141 USB2 Breakout Board with the VL53L1X Rangefinder, and ran the commands that was there in the documentation.
          voxl-configure-rangefinders 1_downward_on_m0141
          And I got the similar output for the following commands
          voxl2:/$ voxl-configure-rangefinders 1_downward_on_m0141
          creating new config file for 1 downward TOF without multiplexer
          DONE
          enabling  voxl-rangefinder-server systemd service
          Done configuring voxl-rangefinder-server
          voxl2:/$ cat /etc/modalai/voxl-rangefinder-server.conf
           * Rangefinder Configuration File
           * This file is used by voxl-rangefinder-server
           * please use voxl-rangefinder-server --config {arrangement}
           * to set up this file.
           * FOV for VL53l1X TOF rangefinder is a diagonal FOV in degrees and
           * can be set between 15 and 27 degrees.
           * vl53l1x_timing_budget_ms MUST be one of 20, 33, 50, 100, 200, 500
           * 100 is default
           * vl53l1x FOV options are 15, 20, and 27 degrees
           * default is 27
           * set id_for_mavlink to a valid id (0+) to publish that sensor reading to
           * mavlink as a DOWNWARD sensor for the autopilot to use
           * set to -1 to disable this feature.
          	"i2c_bus":	1,
          	"vl53l1x_timing_budget_ms":	50,
          	"id_for_mavlink":	0,
          	"sensors":	[{
          			"enabled":	true,
          			"sensor_id":	0,
          			"type":	"TOF_VL53L1X",
          			"fov_deg":	15,
          			"range_max_m":	3,
          			"location_wrt_body":	[-0.02500000037252903, 0.019999999552965164, 0.00800000037997961],
          			"direction_wrt_body":	[0, 0, 1],
          			"is_on_mux":	false,
          			"i2c_mux_address":	112,
          			"i2c_mux_port":	0
          But the rangefinder server in not running, even after starting the server. It is enabled but not running.
          Screenshot from 2024-07-05 11-38-52.png Screenshot from 2024-07-05 11-39-05.png
          • modaltbM Offline
            modaltbM Offline
            modaltb
            Can you detect the sensor on the I2C bus, e.g https://docs.modalai.com/voxl2-linux-user-guide/#i2cdetect-usage ?
            • modaltbM modaltb
              Jetson Nano
              Veteran
              @modaltb It is not detecting any sensors, I check the sensor with another FC with PX4 which support VL53L1X and it was detected there.
              • modaltbM Offline
                modaltbM Offline
                modaltb
                what about with
                i2cdetect -r -y 1
                • modaltbM modaltb
                  what about with
                  i2cdetect -r -y 1
                  Jetson Nano
                  Veteran
                  @modaltb I tried detecting in all i2c bus, 0 to 5, it wasn't detected, I got three devices in 4, but it was UU and I think it is the cameras.
                    Jetson Nano
                    Veteran
                    @modaltb
                    • modaltbM Offline
                      modaltbM Offline
                      modaltb
                      Hi @Jetson-Nano
                      OK we'd expect something on the bus like this:
                      Can you describe your wiring setup?
                        Jetson Nano
                        Veteran
                        This is the wiring diagram of the sensor with the USB Expansion Board.
                          Jetson Nano
                          Veteran
                          @modaltb Is there any specific SDK we could check for the working of Range-Finder with?
                          modaltbM 1 Reply Last reply
                            modaltbM Offline
                            modaltbM Offline
                            modaltb
                            @Jetson-Nano are you using our M0070 board like this? https://docs.modalai.com/rangefinders/#single-rangefinder-using-m0141-expansion-board
                            Or custom? If custom check pin 5, which on our M0070 board is pulled up to 3.3VDC.
                            • modaltbM modaltb
                              Jetson Nano
                              Veteran
                              @modaltb I'm using M0141 expansion board.
                                modaltbM Offline
                                modaltbM Offline
                                modaltb
                                @Jetson-Nano what is the VL53L1X on?
                                • modaltbM modaltb
                                  Jetson Nano
                                  Veteran
                                  #17
                                  @modaltb is connected on J5 port of M0141.
                                    modaltbM Offline
                                    modaltbM Offline
                                    modaltb
                                    @Jetson-Nano can you take a picture? for example, we make a M0070 board that has this sensor on it. Are you making your own carrier board for the sensor?
                                    • modaltbM modaltb
                                      Jetson Nano
                                      Veteran
                                      @modaltb This is our setup,
                                      VinnyV 1 Reply Last reply
                                        wrote on last edited by Vinny
                                        #20
                                        HI @Jetson-Nano
                                        We have not seen that module before.
                                        Is there a product link you can share so we can investigate for voltage and signal compatibility?
                                        • VinnyV Vinny
                                          HI @Jetson-Nano
                                          Jetson Nano
                                          Veteran
                                          @Vinny @modaltb Here is the link of the product
                                          https://www.ktron.in/product/vl53l1x-laser-ranging-module-tof/
