  3. Intergrating VL53L1x Range Finder with VOXL2
voxl-2
32 Posts 4 Posters 9.1k Views 2 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    I'm using a VL53L1x rangefinder for reducing drift accumulated during VIO on a Starling system. I'm using the sensor VL53L1X, which I'm connecting to VOXL2 through J19 port where I2C communication lanes (Pins 7,8) are available.
    When I enable range finder parameters in QGC, I'm not getting any data from the rangefinder in mavlink inspector or mavlink console. As mentioned in ModalAI documentation, this sensor is directly compatable with VOXL2. Is there any specific functional parameter which is to be enabled in PX4 config seperately?
    James StrawsonJ 1 Reply Last reply
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @Jetson-Nano our implementation is used on the applications processor (not the DSP) so you would want to use this reference:
      https://gitlab.com/voxl-public/voxl-sdk/services/qrb5165-rangefinder-server/-/tree/master
      • Jetson NanoJ Jetson Nano
        James StrawsonJ Offline
        James Strawson
        Hi @Jetson-Nano
        The I2C port on J19 is connected to the Sensors DSP and therefore can't be accessed from the main applications processor.
        Here is a new documentation page describing how to hook up and use these sensors.
        https://docs.modalai.com/rangefinders/
          Jetson Nano
          Veteran
          Thank you @modaltb @James-Strawson,
          Will check and get back. Apart from VL53L1x what are the other Rangefinder sensors which are compatible with VOXL2?
            Jetson Nano
            Veteran
            @James-Strawson @modaltb , I checked with reference to the documentation you shared, but still it was not working.
            I used the M0141 USB2 Breakout Board with the VL53L1X Rangefinder, and ran the commands that was there in the documentation.
            voxl-configure-rangefinders 1_downward_on_m0141
            And I got the similar output for the following commands
            voxl2:/$ voxl-configure-rangefinders 1_downward_on_m0141
            creating new config file for 1 downward TOF without multiplexer
            DONE
            enabling  voxl-rangefinder-server systemd service
            Done configuring voxl-rangefinder-server
            voxl2:/$ cat /etc/modalai/voxl-rangefinder-server.conf
             * Rangefinder Configuration File
             * This file is used by voxl-rangefinder-server
             * please use voxl-rangefinder-server --config {arrangement}
             * to set up this file.
             * FOV for VL53l1X TOF rangefinder is a diagonal FOV in degrees and
             * can be set between 15 and 27 degrees.
             * vl53l1x_timing_budget_ms MUST be one of 20, 33, 50, 100, 200, 500
             * 100 is default
             * vl53l1x FOV options are 15, 20, and 27 degrees
             * default is 27
             * set id_for_mavlink to a valid id (0+) to publish that sensor reading to
             * mavlink as a DOWNWARD sensor for the autopilot to use
             * set to -1 to disable this feature.
            	"i2c_bus":	1,
            	"vl53l1x_timing_budget_ms":	50,
            	"id_for_mavlink":	0,
            	"sensors":	[{
            			"enabled":	true,
            			"sensor_id":	0,
            			"type":	"TOF_VL53L1X",
            			"fov_deg":	15,
            			"range_max_m":	3,
            			"location_wrt_body":	[-0.02500000037252903, 0.019999999552965164, 0.00800000037997961],
            			"direction_wrt_body":	[0, 0, 1],
            			"is_on_mux":	false,
            			"i2c_mux_address":	112,
            			"i2c_mux_port":	0
            But the rangefinder server in not running, even after starting the server. It is enabled but not running.
            Screenshot from 2024-07-05 11-38-52.png Screenshot from 2024-07-05 11-39-05.png
            • modaltbM Offline
              modaltbM Offline
              modaltb
              Can you detect the sensor on the I2C bus, e.g https://docs.modalai.com/voxl2-linux-user-guide/#i2cdetect-usage ?
              • modaltbM modaltb
                Jetson Nano
                Veteran
                @modaltb It is not detecting any sensors, I check the sensor with another FC with PX4 which support VL53L1X and it was detected there.
                • modaltbM Offline
                  modaltbM Offline
                  modaltb
                  what about with
                  i2cdetect -r -y 1
                  • modaltbM modaltb
                    what about with
                    i2cdetect -r -y 1
                    Jetson Nano
                    Veteran
                    @modaltb I tried detecting in all i2c bus, 0 to 5, it wasn't detected, I got three devices in 4, but it was UU and I think it is the cameras.
                      Jetson Nano
                      Veteran
                      @modaltb
                      • modaltbM Offline
                        modaltbM Offline
                        modaltb
                        Hi @Jetson-Nano
                        OK we'd expect something on the bus like this:
                        Can you describe your wiring setup?
                          Jetson Nano
                          Veteran
                          This is the wiring diagram of the sensor with the USB Expansion Board.
                            Jetson Nano
                            Veteran
                            @modaltb Is there any specific SDK we could check for the working of Range-Finder with?
                            modaltbM 1 Reply Last reply
                              modaltbM Offline
                              modaltbM Offline
                              modaltb
                              @Jetson-Nano are you using our M0070 board like this? https://docs.modalai.com/rangefinders/#single-rangefinder-using-m0141-expansion-board
                              Or custom? If custom check pin 5, which on our M0070 board is pulled up to 3.3VDC.
                              • modaltbM modaltb
                                Jetson Nano
                                Veteran
                                @modaltb I'm using M0141 expansion board.
                                  modaltbM Offline
                                  modaltbM Offline
                                  modaltb
                                  @Jetson-Nano what is the VL53L1X on?
                                  • modaltbM modaltb
                                    Jetson Nano
                                    Veteran
                                    #17
                                    @modaltb is connected on J5 port of M0141.
                                      modaltbM Offline
                                      modaltbM Offline
                                      modaltb
                                      @Jetson-Nano can you take a picture? for example, we make a M0070 board that has this sensor on it. Are you making your own carrier board for the sensor?
                                      • modaltbM modaltb
                                        Jetson Nano
                                        Veteran
                                        @modaltb This is our setup,
                                        VinnyV 1 Reply Last reply
                                          wrote on last edited by Vinny
                                          #20
                                          HI @Jetson-Nano
                                          We have not seen that module before.
                                          Is there a product link you can share so we can investigate for voltage and signal compatibility?
