  3. NACK Received when updating voxl esc
esc
6 Posts 2 Posters 1.3k Views 1 Watching
  • wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    I am getting a "NACK Received" when I am trying to update the firmware on my voxl esc. I get to about 4% and then I get this error
    Here is a video explaining it in closer detail
    https://www.loom.com/share/f016b3a706a242c2a2235107f2faabb0
    • wilkinsafW wilkinsaf
      @wilkinsaf , you have a M0117 ESC, this can be seen @ 0:32 of your video (and other parts), but you are trying to install firmware for M0138 ESC.
      Also, three of your ESC channels have ESC version 39 (ids 0,1,2) and id 3 has firmware version 36.
      In any case, you can use the following script to auto detect the ESC (and pick correct firmware) and install it :
      ./voxl-esc-upload-firmware-all.sh
      This should update firmware for all all 4 ESCs.
      Then you will need to install the desired ESC params to your ESC. Please note that IDs 0 and 3 are missing params (that is why they are defaulting to 57600 baud rate), but the voxl-esc-upload-params.py script should take care of it. You can always force the update params script to use specific baud rate (such as 57600).
      wilkinsafW 1 Reply Last reply
        wilkinsafW Offline
        wilkinsafW Offline
        wilkinsaf
        Yes, whenever I try to have the auto-update for the firmware I get this
        VOXL Platform: M0054
        INFO: ESC(s) detected: [1, 2]
        WARNING: Specified ESC ID not detected; perform manual power cycle now
        Updated baud rate to 230400
        INFO: Installing firmware to ESC ID 0 : /usr/share/modalai/voxl-esc-tools/firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
        ERROR: An error occured during the write process.
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          When I try and update the parameters I get
          voxl2:/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-upload-params.py --params-file ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
          [GCC 8.4.0]
          dpkg-query: no packages found matching voxl-esc-board-detect.py
          dpkg-query: no packages found matching voxl-esc-calibrate.py
          dpkg-query: no packages found matching voxl-esc-led.py
          dpkg-query: no packages found matching voxl-esc-neopixel-test.py
          dpkg-query: no packages found matching voxl-esc-scan.py
          dpkg-query: no packages found matching voxl-esc-spin-helper.sh
          dpkg-query: no packages found matching voxl-esc-spin-sine.py
          dpkg-query: no packages found matching voxl-esc-spin-step.py
          dpkg-query: no packages found matching voxl-esc-spin.py
          dpkg-query: no packages found matching voxl-esc-tools-bin
          dpkg-query: no packages found matching voxl-esc-upload-firmware-all.sh
          dpkg-query: no packages found matching voxl-esc-upload-firmware.py
          dpkg-query: no packages found matching voxl-esc-upload-params.py
          dpkg-query: no packages found matching voxl-esc-verify-params.py
          dpkg-query: no packages found matching voxl_esc_setup_paths.py
          dpkg-query: no packages found matching voxl_serial.py
          Found voxl-esc tools bin version: 1.6
          INFO: Params file name : ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
          INFO: Params file size : 7507 bytes
          INFO: ESCs detected:
          INFO: ---------------------
          ID: 1, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
          ID: 2, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
          INFO: Loading XML config file...
          INFO: Uploading params for ESC ID 255...
          -- board config
          -- id config
          -- uart config
          -- tune config
              DONE
          INFO: Resetting ESCs...
              DONE
          INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
          ERROR: No ESC(s) detected
          INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
          INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 57600
          ID: 0, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
          ID: 3, SW: 36, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
          ERROR: ESC firmware version 36 is incompatible with params supported by this utility
                 Acceptable ESC firmware versions are:  [38, 39]
          I have tried a parameter set in the "old" parameter folder with similar results
            [GCC 8.4.0]
            -- board config
            -- id config
            -- uart config
            -- tune config
                DONE
                DONE
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            Ok, Here is how I solved it.
            1. Installed old firmware: ./voxl-esc-upload-firmware.py --firmware-baud-rate 57600 -f firmware/old/modalai_esc_firmware_m0117_1_v0_36_f75f1fdb.bin --id 0
            2. Installed newer firmware: ./voxl-esc-upload-firmware.py --firmware-baud-rate 250000 -f firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin --id 0
            I was loading a custom SDK on this vehicle so I am theorizing that there is somehting custom/funky going on with voxl-esc
              @wilkinsaf , yes, you got it. By the way, you did not have to restore the old firmware, you could have just done this:
              ./voxl-esc-upload-firmware.py --firmware-baud-rate 57600 -f firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin --id 0
              The following note does not really help, if you also have power connected to VOXL2..
              However, if the ESC is connected to a PC, you can just power cycle the ESC and the the bootloader will start up and firmware update will being.
