    Voxl2 Docker (Ubuntu 22) with OpenCL/Adreno
    2992
    • E
      eric
      Hello, we have a ROS2 humble autonomy stack that we we build in a CI pipeline and deploy to various platforms, including Voxl2.
      The pipeline selects an appropriate base image for respective platforms (including nvida jetson, voxl, etc), each of which is a custom docker image based on ubuntu:jammy with unique layers for platform dependencies.
      We would like to be able to utilize the Adreno GPU within our voxl2 target via OpenCL. I could use some assistance understanding how I might go about this for VOXL2. I am aware of this VOXL1 example: https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-opencl. Unfortunately, this example uses a prebuilt package for OpenCL to provide Adreno support.
      Is there any documentation that could be shared regarding how this Adreno OpenCL library was built so that we can build an equivalent library in Ubuntu 22 that supports Adreno/VOXL2?
      Any guidance would be greatly appreciated.
      Thank you,
      Eric
      • E
        eric
        For reference, I've tried downloading the adreno-opencl-sdk-2.0 from qualcomm, loaded the libraries into the docker, and run privileged while also adding devices /dev/dri and /dev/kgsl-3d0. I also added a vendor including the path to qualcomm's libOpenCL library. When I query platforms using the C++ api, the script just hangs. If I don't set the vendor, it fails with a -1001 error.
        Inside the docker, I can build all the sdk examples just fine. I just can't access Adreno.
        Thanks again for any help.
        • E
          eric @eric
          @Eric-Katzfey I know it's been a few years, but I see your name all over the voxl-docker-opencl commit history was wondering if you'd be able to share your thoughts regarding how I might approach this? Specifically, if there are any steps you'd recommend I take to get OpenCL integrated into docker for Voxl2.
          Eric
            Eric Katzfey ModalAI Team @eric
            @eric Yes, I did put that together based on some Qualcomm example code for VOXL. Not really sure how to do something similar on VOXL 2 but I'll ask around the office to see if anyone has some ideas on how to get that going.
            E 1 Reply Last reply Reply Quote 1
            • E
              eric @Eric Katzfey
              @Eric-Katzfey Really appreciate it! Thanks so much
                Alex Kushleyev ModalAI Team @eric
                @eric I will try it out, please give me a few days.
                Alex KushleyevA 1 Reply Last reply Reply Quote 1
                  Quick update, I did some testing and tried searching documentation and could not get it to work. There are posts online asking Qualcomm whether this is possible, but there is no response there.
                  I know this would be a useful feature and I will try again next week. I want to see how this worked on VOXL1 and perhaps I am missing something.
                  In my test, I am also just doing a simple device query and it works on the host VOXL2 but not inside docker, tried mapping various .so libraries and devices to the docker container and no luck yet.
                  • E
                    eric @Alex Kushleyev
                    @Alex-Kushleyev That aligns pretty well with my own experience so far. Thanks again for looking into this!
                      @eric I was able to get the GPU device query inside ubuntu 22.04 docker working using the following steps. It is possible that we can reduce the number of mapped devices and libraries to the docker container, but i am just going to give you this information right now so you can test. I will try to clean this up a bit later. I only tried the device query for now, but i figured i would let you know that there is progress..
                      #run docker
                      docker run -it --rm --privileged --device=/dev/kgsl-3d0 --device=/dev/ion -v /proc:/proc -v /firmware/image:/firmware/image -v /lib/firmware:/lib/firmware -v /sys/class:/sys/class -v /sys/bus:/sys/bus -v /sys/devices:/sys/devices -v /data:/data -v /usr/lib/liblog.so.0:/usr/lib/liblog.so.0 -v /usr/lib/libOpenCL.so:/usr/lib/libOpenCL.so -v /usr/lib/libcutils.so.0:/usr/lib/libcutils.so.0 -v /usr/lib/libllvm-qcom.so:/usr/lib/libllvm-qcom.so -v /usr/lib/libion.so.0.0.0:/usr/lib/libion.so.0.0.0 -v /usr/lib/libsync.so.0.0.0:/usr/lib/libsync.so.0.0.0 -v /usr/lib/libgsl.so:/usr/lib/libgsl.so -v /usr/lib/libCB.so:/usr/lib/libCB.so -v /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0.5600.4:/usr/lib/aarch64-linux-gnu/libglib-2.0.so.0.5600.4 -v `pwd`:/opt/code -w /opt/code arm64v8/ubuntu:22.04 bash
                      apt-get update
                      apt install --no-install-recommends -y pocl-opencl-icd
                      then run your test app to query the device..
                      • E
                        @Alex-Kushleyev 🙇
                          OK, a little more clean-up, it seems this is the minimal set of libraries /devices needed:
                          docker run -it --rm --privileged \
                          	-v /usr/lib/libOpenCL.so:/usr/lib/libOpenCL.so \
                          	-v /usr/lib/libCB.so:/usr/lib/libCB.so \
                          	-v /usr/lib/libgsl.so:/usr/lib/libgsl.so \
                          	-v /usr/lib/liblog.so.0:/usr/lib/liblog.so.0 \
                          	-v /usr/lib/libcutils.so.0:/usr/lib/libcutils.so.0 \
                          	-v /usr/lib/libsync.so.0.0.0:/usr/lib/libsync.so.0.0.0 \
                          	-v /usr/lib/libion.so.0.0.0:/usr/lib/libion.so.0.0.0 \
                          	-v /usr/lib/libllvm-qcom.so:/usr/lib/libllvm-qcom.so \
                          	-v /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0.5600.4:/usr/lib/aarch64-linux-gnu/libglib-2.0.so.0.5600.4 \
                          	-v `pwd`:/opt/code -w /opt/code \
                          (--privileged mode maps all the needed devices to the docker container)
                          Then install some more packages (not sure if this can be reduced, not clear exactly what is missing):
                          apt-get update
                          Maybe we can figure out what lib is still missing so that pocl-opencl-icd does not have to be installed.. At least the issue was the a missing library, not a mapped device
                          For testing, I used a device query script from here:
                          root@733a6d4d5fdb:/opt/code# ./simple_query
                          1. Device: QUALCOMM Adreno(TM)
                           1.1 Hardware version: OpenCL 2.0 Adreno(TM) 650
                           1.2 Software version: OpenCL 2.0 QUALCOMM build: commit # changeid # Date: 11/10/21 Wed Local Branch:  Remote Branch:  Compiler E031.37.12.01
                           1.3 OpenCL C version: OpenCL C 2.0 Adreno(TM) 650
                           1.4 Parallel compute units: 3
                          I also verified that a simple matrix multiplication app also worked (not provided here)
                          @eric , can you please let me know if this works for you?
                          • E
                            OMG IT WORKS!!
                            I was able to extract all these libraries from the host and directly install them inside the docker, and now the pcol-opencl-icd installation isn't needed.
                            This is really important for us, since it allows us to build external dependencies that rely on OpenCL in our pipeline directly without bind mounts (outside the host environment).
                            Really, really appreciate all your help!
                            FROM arm64v8/ubuntu:22.04
                            # Install necessary dependencies
                            RUN apt-get update && \
                                apt-get install -y \
                                cmake \
                                build-essential \
                                libglib2.0-0
                            # Copy Adreno GPU dependencies
                            # - libcutils0_0-r1_arm64.deb
                            # - libsync_1.0-r1_arm64.deb
                            # - qti-libion_0-r1_arm64.deb
                            # - liblog0_1.0-r1_arm64.deb
                            # - qti-adreno_1.0-r0_arm64.deb
                            COPY dep /root/dep
                            # Create required directory for qti-adreno install
                            RUN mkdir /usr/include/KHR && dpkg -i /root/dep/*.deb
                            # Copy and build test script
                            COPY ./hellocl /root/hellocl
                            RUN cd /root/hellocl && mkdir build && cd build && cmake .. && make
                            CMD ["bash"]
                            voxl2:~/opencl$ docker run -it --rm --privileged opencl:latest ./root/hellocl/build/hellocl
                            Platform Information:
                            Platform Name: QUALCOMM Snapdragon(TM)
                            Platform Vendor: QUALCOMM
                            Platform Version: OpenCL 2.0 QUALCOMM build: commit # changeid # Date: 11/10/21 Wed Local Branch:  Remote Branch:
                            Platform Profile: FULL_PROFILE
                            Platform Extensions:
                            Device Information:
                            Device Name: QUALCOMM Adreno(TM)
                            Device Vendor: QUALCOMM
                            Driver Version: OpenCL 2.0 QUALCOMM build: commit # changeid # Date: 11/10/21 Wed Local Branch:  Remote Branch:  Compiler E031.37.12.01
                            Device Version: OpenCL 2.0 Adreno(TM) 650
                            Device OpenCL C Version: OpenCL C 2.0 Adreno(TM) 650
                            Device Max Compute Units: 3
                            This should be three: 3
                              hi @eric ,
                              Nice! very clean.
                              Did you use dpkg-repack to create debs of installed packages, such as:
                              apt-get install dpkg-repack
                              dpkg-repack qti-adreno
                              Cool trick!
                              I will test this out and add to our docs.
                              • E
                                @Alex-Kushleyev Yes, dpkg -S <file path> to figure out which debs installed which libraries (ie, dpkg -S /usr/lib/libOpenCL.so), apt-cache show to see the source (ubuntu ppa vs modalai), then dpkg-repack to repack the modalai debs.
                                Thanks again!
                                  @eric , thanks again for your input on this, i have posted a complete tutorial how to enable OpenCL in Docker on VOXL2 : https://docs.modalai.com/voxl-2-opencl-in-docker/
                                  • E
                                    @Alex-Kushleyev Awesome! Thanks again for all your help with this!
                                    Peter MilaniP 1 Reply Last reply Reply Quote 0
                                    • Peter MilaniP
                                      Peter Milani @eric
                                      @Alex-Kushleyev @eric I've implemented your solution and get the same result.
                                      I did get a bit confused as running clinfo only returned a single device of type CPU and without the name "Adreno".
                                      However I added to your test script a query on the device_type and it returned GPU so I guess its only finding the GPU. I would have expected it to return a few more devices as the [Qualcomm OpenCL guide] (https://docs.qualcomm.com/bundle/publicresource/80-NB295-11_REV_C_Qualcomm_Snapdragon_Mobile_Platform_Opencl_General_Programming_and_Optimization.pdf) suggests that the dsp and CPU could have been returned as well, so I'm not sure what is happening there. I didn't have to link devices only shared the volumes to the relevant libraries. I would have expected the CPU to be returned a a matter of course as that is what happens with the intel implementation.
                                      My additional lines to the script (given for info is):
                                        cl_device_type device_type;
                                        clGetDeviceInfo(devices[j], CL_DEVICE_TYPE, sizeof(cl_device_type), &device_type, NULL);
                                        printf("Device type: ");
                                        if (device_type & CL_DEVICE_TYPE_CPU)
                                            printf("CPU ");
                                        if (device_type & CL_DEVICE_TYPE_GPU)
                                            printf("GPU ");
                                        if (device_type & CL_DEVICE_TYPE_ACCELERATOR)
                                            printf("ACCELERATOR ");
                                        if (device_type & CL_DEVICE_TYPE_DEFAULT)
                                            printf("DEFAULT ");
                                        printf("\n");
                                      Which returns
                                      OpenCL platform count: 1
                                      OpenCL device count: 1
                                      Device type: GPU
                                        Alex Kushleyev ModalAI Team @Peter Milani
                                        @Peter-Milani , it looks like Qualcomm CPU device is not supported by OpenCL library from Qualcomm.
                                        clinfo may be confused, but installing and running clinfo natively on voxl2 does not return any platforms - the opencl libraries that may get installed by apt are most likely not compatible with the VOXL2 GPU.
                                        • Peter MilaniP
                                          Peter Milani @Alex Kushleyev
                                          @Alex-Kushleyev I was able to get the following when running opencl within the docker instance:
                                           clinfo
                                          Number of platforms                               1
                                            Platform Name                                   Portable Computing Language
                                            Platform Vendor                                 The pocl project
                                            Platform Version                                OpenCL 1.2 pocl 1.4, None+Asserts, LLVM 9.0.1, RELOC, SLEEF, POCL_DEBUG
                                            Platform Profile                                FULL_PROFILE
                                            Platform Extensions                             cl_khr_icd
                                            Platform Extensions function suffix             POCL
                                          Number of devices                                 1
                                            Device Name                                     pthread-0x805
                                            Device Vendor                                   Qualcomm
                                            Device Vendor ID                                0x13b5
                                            Device Version                                  OpenCL 1.2 pocl HSTR: pthread-aarch64-unknown-linux-gnu-GENERIC
                                            Driver Version                                  1.4
                                            Device OpenCL C Version                         OpenCL C 1.2 pocl
                                            Device Type                                     CPU
                                            Device Profile                                  FULL_PROFILE
                                            Device Available                                Yes
                                            Compiler Available                              Yes
                                            Linker Available                                Yes
                                            Max compute units                               8
                                            Max clock frequency                             1804MHz
                                            Device Partition                                (core)
                                              Max number of sub-devices                     8
                                              Supported partition types                     equally, by counts
                                              Supported affinity domains                    (n/a)
                                            Max work item dimensions                        3
                                            Max work item sizes                             4096x4096x4096
                                            Max work group size                             4096
                                            Preferred work group size multiple              8
                                            Preferred / native vector sizes
                                              char                                                16 / 16
                                              short                                                8 / 8
                                              int                                                  4 / 4
                                              long                                                 2 / 2
                                              half                                                 0 / 0        (n/a)
                                              float                                                4 / 4
                                              double                                               2 / 2        (cl_khr_fp64)
                                            Half-precision Floating-point support           (n/a)
                                            Single-precision Floating-point support         (core)
                                              Denormals                                     No
                                              Infinity and NANs                             Yes
                                              Round to nearest                              Yes
                                              Round to zero                                 No
                                              Round to infinity                             No
                                              IEEE754-2008 fused multiply-add               No
                                              Support is emulated in software               No
                                              Correctly-rounded divide and sqrt operations  No
                                            Double-precision Floating-point support         (cl_khr_fp64)
                                              Denormals                                     Yes
                                              Round to zero                                 Yes
                                              Round to infinity                             Yes
                                              IEEE754-2008 fused multiply-add               Yes
                                            Address bits                                    64, Little-Endian
                                            Global memory size                              5896568832 (5.492GiB)
                                            Error Correction support                        No
                                            Max memory allocation                           2147483648 (2GiB)
                                            Unified memory for Host and Device              Yes
                                            Minimum alignment for any data type             128 bytes
                                            Alignment of base address                       1024 bits (128 bytes)
                                            Global Memory cache type                        None
                                            Image support                                   Yes
                                              Max number of samplers per kernel             16
                                              Max size for 1D images from buffer            134217728 pixels
                                              Max 1D or 2D image array size                 2048 images
                                              Max 2D image size                             8192x8192 pixels
                                              Max 3D image size                             2048x2048x2048 pixels
                                              Max number of read image args                 128
                                              Max number of write image args                128
                                            Local memory type                               Global
                                            Local memory size                               33554432 (32MiB)
                                            Max number of constant args                     8
                                            Max constant buffer size                        33554432 (32MiB)
                                            Max size of kernel argument                     1024
                                            Queue properties
                                              Out-of-order execution                        Yes
                                              Profiling                                     Yes
                                            Prefer user sync for interop                    Yes
                                            Profiling timer resolution                      1ns
                                            Execution capabilities
                                              Run OpenCL kernels                            Yes
                                              Run native kernels                            Yes
                                            printf() buffer size                            16777216 (16MiB)
                                            Built-in kernels                                (n/a)
                                            Device Extensions                               cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr_fp64
                                          NULL platform behavior
                                            clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  Portable Computing Language
                                            clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [POCL]
                                            clCreateContext(NULL, ...) [default]            Success [POCL]
                                            clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
                                            clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  Success (1)
                                            clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No devices found in platform
                                            clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
                                            clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
                                            clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
                                          ICD loader properties
                                            ICD loader Name                                 OpenCL ICD Loader
                                            ICD loader Vendor                               OCL Icd free software
                                            ICD loader Version                              2.2.11
                                            ICD loader Profile                              OpenCL 2.1
                                          but after installing:
                                          apt install -y -qq pocl-opencl-icd;
                                            @Peter-Milani , I see. this looks like a generic implementation of OpenCL for ARM from 3rd party (not Qualcomm), and i think it also overwrites the proprietary opencl libraries, disabling the GPU opencl support. However, you could make two separate docker images, one for each use case (cpu and gpu)
