  3. Voxl2 Docker (Ubuntu 22) with OpenCL/Adreno
20 Posts 4 Posters 5.2k Views 3 Watching
  • E eric
    @Alex-Kushleyev That aligns pretty well with my own experience so far. Thanks again for looking into this!
    @eric I was able to get the GPU device query inside ubuntu 22.04 docker working using the following steps. It is possible that we can reduce the number of mapped devices and libraries to the docker container, but i am just going to give you this information right now so you can test. I will try to clean this up a bit later. I only tried the device query for now, but i figured i would let you know that there is progress..
    #run docker
    docker run -it --rm --privileged --device=/dev/kgsl-3d0 --device=/dev/ion -v /proc:/proc -v /firmware/image:/firmware/image -v /lib/firmware:/lib/firmware -v /sys/class:/sys/class -v /sys/bus:/sys/bus -v /sys/devices:/sys/devices -v /data:/data -v /usr/lib/liblog.so.0:/usr/lib/liblog.so.0 -v /usr/lib/libOpenCL.so:/usr/lib/libOpenCL.so -v /usr/lib/libcutils.so.0:/usr/lib/libcutils.so.0 -v /usr/lib/libllvm-qcom.so:/usr/lib/libllvm-qcom.so -v /usr/lib/libion.so.0.0.0:/usr/lib/libion.so.0.0.0 -v /usr/lib/libsync.so.0.0.0:/usr/lib/libsync.so.0.0.0 -v /usr/lib/libgsl.so:/usr/lib/libgsl.so -v /usr/lib/libCB.so:/usr/lib/libCB.so -v /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0.5600.4:/usr/lib/aarch64-linux-gnu/libglib-2.0.so.0.5600.4 -v `pwd`:/opt/code -w /opt/code arm64v8/ubuntu:22.04 bash
    apt-get update
    apt install --no-install-recommends -y pocl-opencl-icd
    then run your test app to query the device..
    E 1 Reply Last reply
      #run docker
      apt-get update
      E Offline
      E Offline
      eric
      @Alex-Kushleyev 🙇
      • E eric
        @Alex-Kushleyev 🙇
        #11
        OK, a little more clean-up, it seems this is the minimal set of libraries /devices needed:
        docker run -it --rm --privileged \
        	-v /usr/lib/libOpenCL.so:/usr/lib/libOpenCL.so \
        	-v /usr/lib/libCB.so:/usr/lib/libCB.so \
        	-v /usr/lib/libgsl.so:/usr/lib/libgsl.so \
        	-v /usr/lib/liblog.so.0:/usr/lib/liblog.so.0 \
        	-v /usr/lib/libcutils.so.0:/usr/lib/libcutils.so.0 \
        	-v /usr/lib/libsync.so.0.0.0:/usr/lib/libsync.so.0.0.0 \
        	-v /usr/lib/libion.so.0.0.0:/usr/lib/libion.so.0.0.0 \
        	-v /usr/lib/libllvm-qcom.so:/usr/lib/libllvm-qcom.so \
        	-v /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0.5600.4:/usr/lib/aarch64-linux-gnu/libglib-2.0.so.0.5600.4 \
        	-v `pwd`:/opt/code -w /opt/code \
        (--privileged mode maps all the needed devices to the docker container)
        Then install some more packages (not sure if this can be reduced, not clear exactly what is missing):
        apt-get update
        Maybe we can figure out what lib is still missing so that pocl-opencl-icd does not have to be installed.. At least the issue was the a missing library, not a mapped device
        For testing, I used a device query script from here:
        root@733a6d4d5fdb:/opt/code# ./simple_query
        1. Device: QUALCOMM Adreno(TM)
         1.1 Hardware version: OpenCL 2.0 Adreno(TM) 650
         1.2 Software version: OpenCL 2.0 QUALCOMM build: commit # changeid # Date: 11/10/21 Wed Local Branch:  Remote Branch:  Compiler E031.37.12.01
         1.3 OpenCL C version: OpenCL C 2.0 Adreno(TM) 650
         1.4 Parallel compute units: 3
        I also verified that a simple matrix multiplication app also worked (not provided here)
        @eric , can you please let me know if this works for you?
          apt-get update
          E Offline
          E Offline
          eric
          OMG IT WORKS!!
          I was able to extract all these libraries from the host and directly install them inside the docker, and now the pcol-opencl-icd installation isn't needed.
          This is really important for us, since it allows us to build external dependencies that rely on OpenCL in our pipeline directly without bind mounts (outside the host environment).
          Really, really appreciate all your help!
          FROM arm64v8/ubuntu:22.04
          # Install necessary dependencies
          RUN apt-get update && \
              apt-get install -y \
              cmake \
              build-essential \
              libglib2.0-0
          # Copy Adreno GPU dependencies
          # - libcutils0_0-r1_arm64.deb
          # - libsync_1.0-r1_arm64.deb
          # - qti-libion_0-r1_arm64.deb
          # - liblog0_1.0-r1_arm64.deb
          # - qti-adreno_1.0-r0_arm64.deb
          COPY dep /root/dep
          # Create required directory for qti-adreno install
          RUN mkdir /usr/include/KHR && dpkg -i /root/dep/*.deb
          # Copy and build test script
          COPY ./hellocl /root/hellocl
          RUN cd /root/hellocl && mkdir build && cd build && cmake .. && make
          CMD ["bash"]
          voxl2:~/opencl$ docker run -it --rm --privileged opencl:latest ./root/hellocl/build/hellocl
          Platform Information:
          Platform Name: QUALCOMM Snapdragon(TM)
          Platform Vendor: QUALCOMM
          Platform Version: OpenCL 2.0 QUALCOMM build: commit # changeid # Date: 11/10/21 Wed Local Branch:  Remote Branch:
          Platform Profile: FULL_PROFILE
          Platform Extensions:
          Device Information:
          Device Name: QUALCOMM Adreno(TM)
          Device Vendor: QUALCOMM
          Driver Version: OpenCL 2.0 QUALCOMM build: commit # changeid # Date: 11/10/21 Wed Local Branch:  Remote Branch:  Compiler E031.37.12.01
          Device Version: OpenCL 2.0 Adreno(TM) 650
          Device OpenCL C Version: OpenCL C 2.0 Adreno(TM) 650
          Device Max Compute Units: 3
          This should be three: 3
          • E eric
            OMG IT WORKS!!
                cmake \
                build-essential \
                libglib2.0-0
            COPY dep /root/dep
            CMD ["bash"]
            Device Information:
            hi @eric ,
            Nice! very clean.
            Did you use dpkg-repack to create debs of installed packages, such as:
            apt-get install dpkg-repack
            dpkg-repack qti-adreno
            Cool trick!
            I will test this out and add to our docs.
              hi @eric ,
              Nice! very clean.
              Cool trick!
              E Offline
              E Offline
              eric
              wrote on last edited by eric
              #14
              @Alex-Kushleyev Yes, dpkg -S <file path> to figure out which debs installed which libraries (ie, dpkg -S /usr/lib/libOpenCL.so), apt-cache show to see the source (ubuntu ppa vs modalai), then dpkg-repack to repack the modalai debs.
              Thanks again!
              • E eric
                Thanks again!
                @eric , thanks again for your input on this, i have posted a complete tutorial how to enable OpenCL in Docker on VOXL2 : https://docs.modalai.com/voxl-2-opencl-in-docker/
                  E Offline
                  E Offline
                  eric
                  @Alex-Kushleyev Awesome! Thanks again for all your help with this!
                  Peter MilaniP 1 Reply Last reply
                  • E eric
                    Peter MilaniP Offline
                    Peter Milani
                    @Alex-Kushleyev @eric I've implemented your solution and get the same result.
                    I did get a bit confused as running clinfo only returned a single device of type CPU and without the name "Adreno".
                    However I added to your test script a query on the device_type and it returned GPU so I guess its only finding the GPU. I would have expected it to return a few more devices as the [Qualcomm OpenCL guide] (https://docs.qualcomm.com/bundle/publicresource/80-NB295-11_REV_C_Qualcomm_Snapdragon_Mobile_Platform_Opencl_General_Programming_and_Optimization.pdf) suggests that the dsp and CPU could have been returned as well, so I'm not sure what is happening there. I didn't have to link devices only shared the volumes to the relevant libraries. I would have expected the CPU to be returned a a matter of course as that is what happens with the intel implementation.
                    My additional lines to the script (given for info is):
                      cl_device_type device_type;
                      clGetDeviceInfo(devices[j], CL_DEVICE_TYPE, sizeof(cl_device_type), &device_type, NULL);
                      printf("Device type: ");
                      if (device_type & CL_DEVICE_TYPE_CPU)
                          printf("CPU ");
                      if (device_type & CL_DEVICE_TYPE_GPU)
                          printf("GPU ");
                      if (device_type & CL_DEVICE_TYPE_ACCELERATOR)
                          printf("ACCELERATOR ");
                      if (device_type & CL_DEVICE_TYPE_DEFAULT)
                          printf("DEFAULT ");
                      printf("\n");
                    Which returns
                    OpenCL platform count: 1
                    OpenCL device count: 1
                    Device type: GPU
                    • Peter MilaniP Peter Milani
                            printf("CPU ");
                            printf("GPU ");
                            printf("DEFAULT ");
                        printf("\n");
                      Which returns
                      Device type: GPU
                      @Peter-Milani , it looks like Qualcomm CPU device is not supported by OpenCL library from Qualcomm.
                      clinfo may be confused, but installing and running clinfo natively on voxl2 does not return any platforms - the opencl libraries that may get installed by apt are most likely not compatible with the VOXL2 GPU.
                        Peter Milani
                        @Alex-Kushleyev I was able to get the following when running opencl within the docker instance:
                         clinfo
                        Number of platforms                               1
                          Platform Name                                   Portable Computing Language
                          Platform Vendor                                 The pocl project
                          Platform Version                                OpenCL 1.2 pocl 1.4, None+Asserts, LLVM 9.0.1, RELOC, SLEEF, POCL_DEBUG
                          Platform Profile                                FULL_PROFILE
                          Platform Extensions                             cl_khr_icd
                          Platform Extensions function suffix             POCL
                        Number of devices                                 1
                          Device Name                                     pthread-0x805
                          Device Vendor                                   Qualcomm
                          Device Vendor ID                                0x13b5
                          Device Version                                  OpenCL 1.2 pocl HSTR: pthread-aarch64-unknown-linux-gnu-GENERIC
                          Driver Version                                  1.4
                          Device OpenCL C Version                         OpenCL C 1.2 pocl
                          Device Type                                     CPU
                          Device Profile                                  FULL_PROFILE
                          Device Available                                Yes
                          Compiler Available                              Yes
                          Linker Available                                Yes
                          Max compute units                               8
                          Max clock frequency                             1804MHz
                          Device Partition                                (core)
                            Max number of sub-devices                     8
                            Supported partition types                     equally, by counts
                            Supported affinity domains                    (n/a)
                          Max work item dimensions                        3
                          Max work item sizes                             4096x4096x4096
                          Max work group size                             4096
                          Preferred work group size multiple              8
                          Preferred / native vector sizes
                            char                                                16 / 16
                            short                                                8 / 8
                            int                                                  4 / 4
                            long                                                 2 / 2
                            half                                                 0 / 0        (n/a)
                            float                                                4 / 4
                            double                                               2 / 2        (cl_khr_fp64)
                          Half-precision Floating-point support           (n/a)
                          Single-precision Floating-point support         (core)
                            Denormals                                     No
                            Infinity and NANs                             Yes
                            Round to nearest                              Yes
                            Round to zero                                 No
                            Round to infinity                             No
                            IEEE754-2008 fused multiply-add               No
                            Support is emulated in software               No
                            Correctly-rounded divide and sqrt operations  No
                          Double-precision Floating-point support         (cl_khr_fp64)
                            Denormals                                     Yes
                            Round to zero                                 Yes
                            Round to infinity                             Yes
                            IEEE754-2008 fused multiply-add               Yes
                          Address bits                                    64, Little-Endian
                          Global memory size                              5896568832 (5.492GiB)
                          Error Correction support                        No
                          Max memory allocation                           2147483648 (2GiB)
                          Unified memory for Host and Device              Yes
                          Minimum alignment for any data type             128 bytes
                          Alignment of base address                       1024 bits (128 bytes)
                          Global Memory cache type                        None
                          Image support                                   Yes
                            Max number of samplers per kernel             16
                            Max size for 1D images from buffer            134217728 pixels
                            Max 1D or 2D image array size                 2048 images
                            Max 2D image size                             8192x8192 pixels
                            Max 3D image size                             2048x2048x2048 pixels
                            Max number of read image args                 128
                            Max number of write image args                128
                          Local memory type                               Global
                          Local memory size                               33554432 (32MiB)
                          Max number of constant args                     8
                          Max constant buffer size                        33554432 (32MiB)
                          Max size of kernel argument                     1024
                          Queue properties
                            Out-of-order execution                        Yes
                            Profiling                                     Yes
                          Prefer user sync for interop                    Yes
                          Profiling timer resolution                      1ns
                          Execution capabilities
                            Run OpenCL kernels                            Yes
                            Run native kernels                            Yes
                          printf() buffer size                            16777216 (16MiB)
                          Built-in kernels                                (n/a)
                          Device Extensions                               cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr_fp64
                        NULL platform behavior
                          clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  Portable Computing Language
                          clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [POCL]
                          clCreateContext(NULL, ...) [default]            Success [POCL]
                          clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
                          clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  Success (1)
                          clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No devices found in platform
                          clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
                          clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
                          clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
                        ICD loader properties
                          ICD loader Name                                 OpenCL ICD Loader
                          ICD loader Vendor                               OCL Icd free software
                          ICD loader Version                              2.2.11
                          ICD loader Profile                              OpenCL 2.1
                        but after installing:
                        apt install -y -qq pocl-opencl-icd;
                           clinfo
                          Number of devices                                 1
                            Driver Version                                  1.4
                            Device Type                                     CPU
                            Max compute units                               8
                              char                                                16 / 16
                              short                                                8 / 8
                              int                                                  4 / 4
                              long                                                 2 / 2
                              half                                                 0 / 0        (n/a)
                              float                                                4 / 4
                              Denormals                                     No
                              Round to zero                                 No
                              Denormals                                     Yes
                              Round to zero                                 Yes
                            Image support                                   Yes
                            Queue properties
                              Profiling                                     Yes
                          @Peter-Milani , I see. this looks like a generic implementation of OpenCL for ARM from 3rd party (not Qualcomm), and i think it also overwrites the proprietary opencl libraries, disabling the GPU opencl support. However, you could make two separate docker images, one for each use case (cpu and gpu)
