  3. UAV climbs out of control in POSITION mode (All QVIO sensors successfully calibrated)
px4-dev-kit
19 Posts 4 Posters 6.0k Views 2 Watching
  • ModeratorM Moderator
    @rdjarvis Have you gone through the steps in the VIO troubleshooting guide? https://docs.modalai.com/flying-with-vio/#troubleshooting-vio
    Screen record the qvio overlay, you should see what is causing your issue
    rdjarvisR Offline
    rdjarvisR Offline
    rdjarvis
    @Moderator We have followed the QVIO trouble shooting steps.
    I will post a screenshot of voxl-logger --preset_odometry and a short video clip of the QVIO overlay.
    -Ryan
    Stefan AmundarainS 1 Reply Last reply
    • rdjarvisR rdjarvis
      -Ryan
      Stefan AmundarainS Offline
      Stefan Amundarain
      @rdjarvis @Moderator
      Flight log from second flight:https://logs.px4.io/plot_app?log=4bb1781f-abc9-49bc-a713-e03a7629b074
      a few screenshots from qvio logger while on the bench. Can get some from the air potentially. Screenshot 2024-05-17 121123.png Screenshot 2024-05-17 121105.png
      video of QVIO Overly from web portal. This was two flights, one in manual, the second in position. drone becomes uncontrollable in position mode and keeps attempting to climb with no throttle input or extremely little
      (https://drive.google.com/file/d/1fBXyT1QNDqnYAGuz7ahqJcGqRUeZFnU-/view?usp=sharing)
      • Stefan AmundarainS Stefan Amundarain
        @Stefan-Amundarain ,
        Is your vehicle in standard configuration that is offered in our dev kits (specifically, orientation between the camera and the VIO IMU?)
        This looks like you may have an incorrect transform between the VIO IMU and camera.
        Before attempting to fly using VIO after making changes or initial bring up, always verify VIO operation by doing handheld tests that would simulate flight (propellers off, disarmed, etc).
        You can look at the qvio overlay to make sure features are tracked and quality is good, otherwise you most likely have an issue with the IMU to camera transform.
          rdjarvisR Offline
          rdjarvisR Offline
          rdjarvis
          Hello Alex,
          1. Yes, vehicle is in standard configuration for C11 DevKit
          2. Extrinsic have been set for the placement of IMU and VIO
          3. If this is an incorrect transform between the VIO IMU (IMU Apps) and Camera, how do we correct it other than adjusting extrinsics.conf file?
          4. When hand flying VIO quality fluctuates through the entire range -1 - 100%, in a multiple indoor, highly lite conditions.
          5. As you can see in the video link posted, points are tracked, and stay tracked as the VIO quality drops to 0 after takeoff.
          Any suggestions?
          RDJ
            rdjarvisR Offline
            rdjarvisR Offline
            rdjarvis
            @Alex-Kushleyev was the issue referenced at the start of this post from March ever resolved? It seems they had the same issues with a Starling UAV.
            ModeratorM 1 Reply Last reply
              @rdjarvis was the camera orientation changed? That does not look like the standard C11 orientation
              rdjarvisR 1 Reply Last reply
                rdjarvisR Offline
                rdjarvisR Offline
                rdjarvis
                @Moderator Yes, as per ModalAI documentation, is says putting the camera in a vertical plane is ideal for indoor only operations.
                We modified camera t wrt body from 45 to 0 for the vertical placement of camera.
                UAV had identical unstable flight before this value and camera position was modified.
                  #10
                  @rdjarvis ,
                  the RPY between imu_apps and tracking frames is not correct. Please review the following documentation : https://docs.modalai.com/configure-extrinsics/
                  The IMU has z axis "into the pcb" = down, if you look at the VOXL2 board from top. You have specified rotation 0,0,90, which is just yaw 90 degrees (around z axis). However, the camera is looking straight out, which means the camera's Z axis is where IMU's X axis is.
                  The RPY should be 0, 90, 90 - please make sure you understand how to calculate it based on the documentation. Let me know if that fixes your issue.
                  Regarding VIO initialization, it is a bit tricky. When the vehicle initially is not moving, there is no way for VIO to initialize scale (disatance) of all the features for monocular VIO. In order to fully initialize, VIO needs to start moving. Also only when it starts moving, if there are errors in reference frames, they will result in inconsistencies within VIO and it will blow up.
                  When vio reports quality and features before you start moving, it can be a bit misleading -- VIO is only using partial information to report its state. But it needs to report some "good news", otherwise you would not even take off until your VIO has converged (chicken and egg problem - you need VIO to be converged before you take off, but in order to for vio to converge, it needs to take off..). So, vio evaluates initial quality based on the availability of features that are being tracked without fully localizing them until there is sufficient motion.
                    @rdjarvis ,
                    rdjarvisR Offline
                    rdjarvisR Offline
                    rdjarvis
                    Thank you for explaining this. We will review, test and get back to you.
                    Thanks again,
                    RDJ
                      @rdjarvis ,
                      rdjarvisR Offline
                      rdjarvisR Offline
                      rdjarvis
                      @Alex-Kushleyev You are correct. After reviewing, studying and having a better understanding of the relationship between imu_apps and tracking we have achieved stable indoor flight in POSTION with QVIO.
                      Thank you for all you have done!
                      RDJ
                        RDJ
                        @rdjarvis , very good! I am glad you got it working.
                          rdjarvisR Offline
                          rdjarvisR Offline
                          rdjarvis
                          @Alex-Kushleyev After logging 10 flights indoors/position we've noticed the Camera server is running at 100+%, and VIO around 30-40%. We disabled front and rear stereo for troubling shooting the tracking camera. Camera server dropped to 30-40% while running, but flight still tends to be erratic, but not uncontrollable.
                          Flight in Altitude and Manual are great, and honestly rather enjoyable.
                          Where should we start to optimize the tracking camera/VIO to keep dialing this in?
                            rdjarvisR Offline
                            rdjarvisR Offline
                            rdjarvis
                            @Alex-Kushleyev When the UAV is stationary on the deck, looking at the same objects the VIO quality fluctuates, randomly from 0-100%. Occasionally (bad camera calibration/Not stationary/no position estimate) errors are sent. Is this a result of the camera server being overloaded, or are there any other issues we can investigate?
                            RDJ
                              RDJ
                              @rdjarvis , the cpu (by default) will run in auto mode, meaning it will slow down under light load. Can you try to set the cpu to performance mode using voxl-set-cpu-mode perf and see if your performance inproves?
                              For front and rear stereo, which outputs for those cameras do you use? The code does debayering to mono and color for each camera, so disabling unneeded debayering can help.
                                rdjarvisR Offline
                                rdjarvisR Offline
                                rdjarvis
                                @Alex-Kushleyev As always, thanks Alex. I will plug away at it today and get back to you.
                                FYI FPV 4n1 ESC will be sent to you this week so you can evaluate when you get the time.
                                THanks,
                                RDJ
                                  THanks,
                                  RDJ
                                  Stefan Amundarain
                                  We applied the changed to the CPU and that seems to be working slightly better. The drone no longer climbs out of control and seems to maintain VIO with between 20-45%, however, the drone continuously goes nose down and to the left like the front left motor is not working hard enough.
                                  steps we have taken include calibrating level and doing an accelerometer calibration as well; however, the issue still persists.
                                  We have recalibrated the cameras as well and double checked our extrinsic values to make sure those are correct as well.
                                  we have double checked the weight and balance of the drone as well and these are not causing the issue in our opinion.
                                  what are other steps we can take to try and correct this issue?
                                    @Stefan-Amundarain what do the flight logs tell you?
