    voxl-camera-server bugs with snapshot capture for mapping
    VOXL SDK
    1437
    • A
      AndriiHlyvko
      Hi. I was evaluating the voxl-camera-server snapshot feature for the purpose of using the images for othromaps and pointcoud generation. I found multiple things which are not working properly. I am using an external px4 (mro-ctrl-zero-h7) which sends an onboard mavlink stream to a serial port on voxl-mini. Timebased snapshot capture was working fine so I moved to an acutal survey mission outdoors, which is when I discovered none of the images were saved on the voxl. I set up a testbench where I am flying SITL missions on my laptop and use Mavproxy to output the SITL mavlink through USB-TTL adapter to VOXL. To check the snapshot timing information I point the IMX214 camera at my screen which shows the SITL QGC simulation. Here are my findings:
      1. If I use the default mavlink datarate and baudrate the snapshot capturing is not reliable. Sometimes no snapshots get captured at all. When I moved to using a custom mavlink stream on px4 which only outputs command messages and GPS info the snapshot feature started working reliably.
      2. I can only reliably capture camera images at most at 1HZ. If I increase the camera capture command frequency beyond 1Hz snapshots get lost.
      3. GPS Exif image data contains wrong GPS seconds data. Degrees and seconds are correct but seconds is wrong. (SITL GPS is in Zurich and VOXL Exif data claims 37 deg 24' 3.85" N, 121 deg 59' 3.11" W which is Santa Clara )
      Here is a link to an archive with the snapshots captured by voxl with the SITL mission file I was running:
      https://drive.google.com/file/d/1vA5-F1MUICMC2DUvb5XdrhR2N_YSinao/view?usp=sharing
        Eric Katzfey ModalAI Team @AndriiHlyvko
        @AndriiHlyvko Snapshots commands are handled by the voxl-mavcam-manager application. It has it's own mavlink connection to QGC. You can enable debug messages in voxl-mavcam-manager by adding the -d option to see what commands it is getting. The images will have timestamps based on the system time at the voxl, not of the external flight controller.
        A 3 Replies Last reply Reply Quote 0
        • A
          AndriiHlyvko @Eric Katzfey
          @Eric-Katzfey do you know if there a way to run a remote gdb server through adb and then just insert breakpoints in the mavcam manager?
          • A
            @Eric-Katzfey I added my own print statements to voxl-camera manager that prints GPS data it grams from mavlink before it inserts the information as exif. It is correct GPS data:
            ANDRII GPS mavlink: lat:37.413543, lon:-121.996550
            Camera: hires taking snapshot (destination: /data/snapshots/hires-2024-05-16_21:18:18.jpg)
            ANDRII grabbed gps: lat:37.413543, lon:-121.996550
            Camera: hires writing snapshot to :"/data/snapshots/hires-2024-05-16_21:18:18.jpg"
            But then when I inspect the snapshot image with exiftool I see the information is not correct:
            ---- ExifTool ----
            ExifTool Version Number         : 12.40
            ---- File ----
            File Name                       : hires-2024-05-16_21:18:18.jpg
            Directory                       : ./snapshots
            File Size                       : 641 KiB
            File Modification Date/Time     : 2024:05:16 14:18:41-07:00
            File Access Date/Time           : 2024:05:16 14:18:41-07:00
            File Inode Change Date/Time     : 2024:05:16 14:18:41-07:00
            File Permissions                : -rw-r--r--
            File Type                       : JPEG
            File Type Extension             : jpg
            MIME Type                       : image/jpeg
            Exif Byte Order                 : Big-endian (Motorola, MM)
            Image Width                     : 4208
            Image Height                    : 3120
            Encoding Process                : Baseline DCT, Huffman coding
            Bits Per Sample                 : 8
            Color Components                : 3
            Y Cb Cr Sub Sampling            : YCbCr4:2:0 (2 2)
            ---- EXIF ----
            Image Width                     : 4208
            Image Height                    : 3120
            Make                            : QTI-AA
            Camera Model Name               : QCAM-AA
            Orientation                     : Horizontal (normal)
            X Resolution                    : 72
            Y Resolution                    : 72
            Resolution Unit                 : inches
            Modify Date                     : 2024:05:16 21:18:18
            Y Cb Cr Positioning             : Centered
            Exposure Time                   : 1/120
            F Number                        : 2.4
            Exposure Program                : Program AE
            ISO                             : 194
            Exif Version                    : 0220
            Date/Time Original              : 2024:05:16 21:18:18
            Create Date                     : 2024:05:16 21:18:18
            Components Configuration        : Y, Cb, Cr, -
            Shutter Speed Value             : 1/120
            Aperture Value                  : 2.4
            Brightness Value                : 3.52
            Exposure Compensation           : 0
            Max Aperture Value              : 2.4
            Metering Mode                   : Average
            Light Source                    : D65
            Flash                           : Off, Did not fire
            Focal Length                    : 2.2 mm
            Sub Sec Time                    : 340360
            Sub Sec Time Original           : 340360
            Sub Sec Time Digitized          : 340360
            Flashpix Version                : 0100
            Color Space                     : sRGB
            Exif Image Width                : 4208
            Exif Image Height               : 3120
            Interoperability Index          : R98 - DCF basic file (sRGB)
            Interoperability Version        : 0100
            Sensing Method                  : Not defined
            Scene Type                      : Directly photographed
            Exposure Mode                   : Auto
            White Balance                   : Auto
            Focal Length In 35mm Format     : 2 mm
            Scene Capture Type              : Standard
            GPS Latitude Ref                : North
            GPS Latitude                    : 37 deg 24' 1.00"
            GPS Longitude Ref               : West
            GPS Longitude                   : 121 deg 59' 1.48"
            GPS Altitude                    : 1 m
            Compression                     : JPEG (old-style)
            X Resolution                    : 72
            Y Resolution                    : 72
            Thumbnail Offset                : 986
            Thumbnail Length                : 15135
            Image Width                     : 4208
            Image Height                    : 3120
            Make                            : QTI-AA
            X Resolution                    : 72
            Y Resolution                    : 72
            F Number                        : 2.4
            ISO                             : 194
            Exif Version                    : 0220
            Light Source                    : D65
            Color Space                     : sRGB
            Exif Image Width                : 320
            Exif Image Height               : 240
            X Resolution                    : 72
            Y Resolution                    : 72
            Thumbnail Offset                : 17013
            Thumbnail Image                 : (Binary data 15135 bytes, use -b option to extract)
            ---- Composite ----
            Aperture                        : 2.4
            Image Size                      : 4208x3120
            Megapixels                      : 13.1
            Scale Factor To 35 mm Equivalent: 0.9
            Shutter Speed                   : 1/120
            Create Date                     : 2024:05:16 21:18:18.340360
            Date/Time Original              : 2024:05:16 21:18:18.340360
            Modify Date                     : 2024:05:16 21:18:18.340360
            GPS Latitude                    : 37 deg 24' 1.00" N
            GPS Longitude                   : 121 deg 59' 1.48" W
            Circle Of Confusion             : 0.033 mm
            Field Of View                   : 167.3 deg
            Focal Length                    : 2.2 mm (35 mm equivalent: 2.0 mm)
            GPS Position                    : 37 deg 24' 1.00" N, 121 deg 59' 1.48" W
            Hyperfocal Distance             : 0.06 m
            Light Value                     : 8.5
            • A
              AndriiHlyvko @AndriiHlyvko
              @AndriiHlyvko lat:37.413543, lon:-121.996550 is 37°24'48.8"N 121°59'47.6"W and not 37 deg 24' 1.00" N, 121 deg 59' 1.48" W
              • A
                @Eric-Katzfey Idk if you are still interested but I fixed the bug in the voxl-camera-server. It turnes out whoever wrote it didn't do research on how exif format works. The exif data that was being appended to the image was written in intel byteorder while the camera uses motorolla byteorder. I think your HAL driver needs to check the byteordering when the camera is being set up. But here is the fix that works for the IMX214 camera:
                    // degrees, min, seconds is each a Radional
                    // a rational is two uint32 numbers
                    entry = create_tag(exif, EXIF_IFD_GPS, (ExifTag)EXIF_TAG_GPS_LATITUDE, 3*sizeof(ExifRational));
                    entry->format = EXIF_FORMAT_RATIONAL;
                    entry->components = 3;
                    ExifLong degrees_lat = static_cast<ExifLong>(gps_grabbed_info.latitude);
                    double fractional = (gps_grabbed_info.latitude - degrees_lat);
                    ExifLong minutes_lat = static_cast<ExifLong>(fractional*60);
                    fractional = (fractional*60) - minutes_lat;
                    double seconds = (fractional * 60);
                    ExifRational degrees_r = { degrees_lat*10, 10 };
                    ExifRational minutes_r = { minutes_lat, 1 };
                    ExifRational seconds_r = { static_cast<ExifLong>(seconds * 1000000), 1000000 }; // Increased precision for seconds
                    //ExifRational seconds_r = { static_cast<ExifLong>(seconds), 1 };
                    //ExifRational seconds_r = { 3375UL, 100UL };
                    printf("Seconds int:%u\n", seconds_r.numerator);
                    printf("Seconds double:%lf\n", seconds);
                    exif_set_rational(entry->data, EXIF_BYTE_ORDER_MOTOROLA, degrees_r);
                    exif_set_rational(entry->data + sizeof(ExifRational), EXIF_BYTE_ORDER_MOTOROLA, minutes_r);
                    exif_set_rational(entry->data + 2 * sizeof(ExifRational), EXIF_BYTE_ORDER_MOTOROLA, seconds_r);
                • ModeratorM
                  Moderator ModalAI Team @AndriiHlyvko
                  @AndriiHlyvko thanks! Feel free to submit a merge request. Otherwise, we'll look to pull in manually
                  • A
                    AndriiHlyvko @Moderator
                    @Moderator sounds good I will try to create a merge request for this sometime early next week
                    • A
                      @Moderator Whats the procedure for creating merge requests that are from someone outside of ModalAI? The repo doesn't allow pushing a new branch. I also tried to send an email a link generated by gitlab and that didn't work.
                        tom admin @AndriiHlyvko
                        @AndriiHlyvko Can you try forking the repo, pushing your changes to your fork, then opening a merge request from your fork into the dev branch?
                        • A
                          AndriiHlyvko @tom
                          @tom cool. I created an MR with wrong source branch by mistake so just delete that one. But this one is the right one: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/merge_requests/42
