  3. Position mode works, but offboard mode don't
33 Posts 4 Posters 11.1k Views 2 Watching
  • Dawid MościckiD Dawid Mościcki
    @Zachary-Lowell-0 what do You mean by SDK ? Is this guide that i should follow, but without full wipe ? https://docs.modalai.com/sentinel-factory-reset/
    @Dawid-Mościcki https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release
    Dawid MościckiD 4 Replies Last reply
      Dawid MościckiD Offline
      Dawid Mościcki
      @tom after flashing, i've got problem with calibrating IMU, btw should 2 imu be present ? because i can see only one :
      voxl-calibrate-imu-temp
      voxl-imu-server currently has no calibration file
      Server has IMU0 enabled and available for temperature calibration
      WARNING, voxl-fan utility missing, can't turn on fan
      We're now starting the COLD stage of the calibration.
      Please stop all unnecessary services in another terminal, and try your best
      to cool the PCB with a fan. Alternatively, start this process on a cold PCB.
      We will be measuring the static gyro and accel offset as the board heats up.
      VOXL must remain completely still through this entire process!
      The IMU temperatures will be printed here continuously.
      Press ENTER to start the heating process when you are happy that the IMUs
      are cold enough for the lower bound. 25-35C is a reasonable goal for this.
      CPU: 36.3C IMU0: 30.4C ^M
      WARNING, voxl-fan utility missing, can't turn off fan
      We're now starting the HOT stage of the calibration. We just turned off
      the fan, and started stressing the CPU to heat up the PCB.
      This will run automatically for a while collecting data points until enough
      data has been collected, something gets too hot, or the timeout is reached.
      CPU: 57.1C IMU0: 34.9C all imus reached steady state, finishing test
      taking sample #2
      not enough samples, need at least 3
        Dawid Mościcki
        @tom i created backup from /data folder on my pc, but i don't know if this could be helpful
        Dawid MościckiD 1 Reply Last reply
          Dawid Mościcki
          @Dawid-Mościcki after importing parameters for vio-indoor without gps from https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/EKF2_helpers/indoor_vio_missing_gps.params
          i only armed vehicle to see vibrations : https://review.px4.io/plot_app?log=c70ab712-72c1-4abf-b954-edda6316bf05
          What could I do next ?
            Dawid Mościcki
            @tom this is my second try https://review.px4.io/plot_app?log=cba05321-9bb5-42f2-a766-ecfa6ee01f80
              Dawid Mościcki
              @tom this is my dump from /data folder : https://drive.google.com/drive/folders/1ZJXCvCcAg81zJolngtlS-Y_re2BjY2pz?usp=sharing
                #29
                @Dawid-Mościcki , the gyro / accel noise in your logs is very high.
                This looks like the flight board is loose something is causing it to vibrate during flight (any wires or anything connected to VOXL2 that might be flopping around?).
                Actuator controls FFT shows
                shows noise at about 80 hz (4800rpm) whch maches the average commanded / actual rpm:
                This confirms that the oscillations are coming from propeller vibrations and not oscillations due to high attitude control gains (which would be much lower frequency in the range of 15-20hz).
                Dawid MościckiD 2 Replies Last reply
                  Dawid Mościcki
                  @Alex-Kushleyev Thanks for help, after changing propellers everything seems to work normal, but somehow RC apparatus stopped working. When i'm trying to set up bind mode nothing happens. I was following this guide :
                  https://docs.modalai.com/sentinel-user-guide-pre-flight-setup/
                  Led is blinking always slowly on blue....
                  What can i do about it ?
                    Dawid Mościcki
                    @Alex-Kushleyev for some reason CPU load on qvio-server is very high. We also have problem with Alfa wifi modem - every few minutes it's turning off and restarting ... Led isnt blinking for few seconds then network start working again . While this is happening Qgroundcontrol is crashing (as every time when drone is reconnected)
                    Output from voxl-inspect-services
                    modallink-relink | Disabled | Not Running |
                    voxl-camera-server | Enabled | Running | 71.0%
                    voxl-cpu-monitor | Enabled | Running | 0.6%
                    voxl-feature-tracker | Disabled | Not Running |
                    voxl-flow-server | Disabled | Not Running |
                    voxl-imu-server | Enabled | Running | 5.4%
                    voxl-lepton-server | Disabled | Not Running |
                    voxl-mavcam-manager | Enabled | Running | 0.0%
                    voxl-mavlink-server | Enabled | Running | 3.5%
                    voxl-modem | Disabled | Not Running |
                    voxl-neopixel-manager | Disabled | Not Running |
                    voxl-open-vins-server | Disabled | Not Running |
                    voxl-portal | Enabled | Running | 0.2%
                    voxl-px4 | Enabled | Running | 57.1%
                    voxl-qvio-server | Enabled | Not Running |
                    voxl-rangefinder-server | Disabled | Not Running |
                    voxl-remote-id | Disabled | Not Running |
                    voxl-softap | Enabled | Completed |
                    voxl-streamer | Enabled | Running | 0.0%
                    voxl-tflite-server | Disabled | Not Running |
                    voxl-uvc-server | Disabled | Not Running |
                    voxl-vision-hub | Enabled | Running | 1.9%
                    • Dawid MościckiD Offline
                      Dawid Mościcki
                      this is output from journalctl :
                      Mar 02 13:11:37 m0054 dhcpcd[1694]: wlan0: carrier acquired
                      Mar 02 13:11:37 m0054 dhcpcd[1694]: wlan0: IAID ca:b5:ab:b9
                      Mar 02 13:11:37 m0054 dhcpcd[1694]: wlan0: adding address fe80::76d9:b52b:91ff:9629
                      Mar 02 13:11:37 m0054 dhcpcd[1694]: wlan0: rebinding lease of 192.168.88.243
                      Mar 02 13:11:38 m0054 dhcpcd[1694]: wlan0: soliciting an IPv6 router
                      Mar 02 13:11:41 m0054 dhcpcd[1694]: wlan0: probing address 192.168.88.243/24
                      Mar 02 13:11:46 m0054 dhcpcd[1694]: wlan0: leased 192.168.88.243 for 600 seconds
                      Mar 02 13:11:46 m0054 dhcpcd[1694]: wlan0: adding route to 192.168.88.0/24
                      Mar 02 13:11:46 m0054 dhcpcd[1694]: wlan0: adding default route via 192.168.88.1
                      Mar 02 13:11:51 m0054 dhcpcd[1694]: wlan0: no IPv6 Routers available
                      Mar 02 13:12:28 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-DISCONNECTED bssid=18:fd:74:f3:01:e1 reason=0 locally_generated=1
                      Mar 02 13:12:28 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-ASSOC-REJECT status_code=1
                      Mar 02 13:12:28 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
                      Mar 02 13:12:28 m0054 dhcpcd[1694]: wlan0: carrier lost
                      Mar 02 13:12:29 m0054 dhcpcd[1694]: wlan0: deleting address fe80::76d9:b52b:91ff:9629
                      Mar 02 13:12:29 m0054 dhcpcd[1694]: wlan0: deleting default route via 192.168.88.1
                      Mar 02 13:12:29 m0054 dhcpcd[1694]: wlan0: deleting route to 192.168.88.0/24
                      Mar 02 13:12:32 m0054 wpa_supplicant[2278]: wlan0: Trying to associate with 18:fd:74:f3:01:e1 (SSID='autonomy_lab' freq=2452 MHz)
                      Mar 02 13:12:32 m0054 wpa_supplicant[2278]: wlan0: Associated with 18:fd:74:f3:01:e1
                      Mar 02 13:12:32 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
                      Mar 02 13:12:33 m0054 wpa_supplicant[2278]: wlan0: WPA: Key negotiation completed with 18:fd:74:f3:01:e1 [PTK=CCMP GTK=CCMP]
                      Mar 02 13:12:33 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-CONNECTED - Connection to 18:fd:74:f3:01:e1 completed [id=0 id_str=]
                      Mar 02 13:12:33 m0054 dhcpcd[1694]: wlan0: carrier acquired
                      Mar 02 13:12:33 m0054 dhcpcd[1694]: wlan0: IAID ca:b5:ab:b9
                      Mar 02 13:12:33 m0054 dhcpcd[1694]: wlan0: adding address fe80::76d9:b52b:91ff:9629
                      Mar 02 13:12:33 m0054 dhcpcd[1694]: wlan0: soliciting an IPv6 router
                      Mar 02 13:12:34 m0054 dhcpcd[1694]: wlan0: rebinding lease of 192.168.88.243
                      Mar 02 13:12:39 m0054 dhcpcd[1694]: wlan0: probing address 192.168.88.243/24
                      Mar 02 13:12:44 m0054 dhcpcd[1694]: wlan0: leased 192.168.88.243 for 600 seconds
                      Mar 02 13:12:44 m0054 dhcpcd[1694]: wlan0: adding route to 192.168.88.0/24
                      Mar 02 13:12:44 m0054 dhcpcd[1694]: wlan0: adding default route via 192.168.88.1
                      Mar 02 13:12:46 m0054 dhcpcd[1694]: wlan0: no IPv6 Routers available
                      Mar 02 13:13:34 m0054 dhcpcd[1694]: wlan0: carrier lost
                      Mar 02 13:13:34 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-DISCONNECTED bssid=18:fd:74:f3:01:e1 reason=0 locally_generated=1
                      Mar 02 13:13:34 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-ASSOC-REJECT status_code=1
                      Mar 02 13:13:34 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
                      Mar 02 13:13:34 m0054 dhcpcd[1694]: wlan0: deleting address fe80::76d9:b52b:91ff:9629
                      Mar 02 13:13:34 m0054 dhcpcd[1694]: wlan0: deleting default route via 192.168.88.1
                      Mar 02 13:13:34 m0054 dhcpcd[1694]: wlan0: deleting route to 192.168.88.0/24
                      Mar 02 13:13:38 m0054 wpa_supplicant[2278]: wlan0: Trying to associate with 18:fd:74:f3:01:e1 (SSID='autonomy_lab' freq=2452 MHz)
                      Mar 02 13:13:38 m0054 wpa_supplicant[2278]: wlan0: Associated with 18:fd:74:f3:01:e1
                      Mar 02 13:13:38 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
                      Mar 02 13:13:39 m0054 wpa_supplicant[2278]: wlan0: WPA: Key negotiation completed with 18:fd:74:f3:01:e1 [PTK=CCMP GTK=CCMP]
                      Mar 02 13:13:39 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-CONNECTED - Connection to 18:fd:74:f3:01:e1 completed [id=0 id_str=]
                      Mar 02 13:13:39 m0054 dhcpcd[1694]: wlan0: carrier acquired
                      Mar 02 13:13:39 m0054 dhcpcd[1694]: wlan0: IAID ca:b5:ab:b9
                      Mar 02 13:13:39 m0054 dhcpcd[1694]: wlan0: adding address fe80::76d9:b52b:91ff:9629
                      Mar 02 13:13:39 m0054 dhcpcd[1694]: wlan0: soliciting an IPv6 router
                      Mar 02 13:13:40 m0054 dhcpcd[1694]: wlan0: rebinding lease of 192.168.88.243
                      Mar 02 13:13:43 m0054 dhcpcd[1694]: wlan0: probing address 192.168.88.243/24
                      Mar 02 13:13:48 m0054 dhcpcd[1694]: wlan0: leased 192.168.88.243 for 600 seconds
                      Mar 02 13:13:48 m0054 dhcpcd[1694]: wlan0: adding route to 192.168.88.0/24
                      Mar 02 13:13:48 m0054 dhcpcd[1694]: wlan0: adding default route via 192.168.88.1
                      Mar 02 13:13:53 m0054 dhcpcd[1694]: wlan0: no IPv6 Routers available
                      Idk wifi keeps disconnecting. Could You please help me ? And every time when wifi is disconnecting and connecting again, QGC is crashing 😕 This behavior could be caused by px4 modules shipped with Your forked version of px4 ...
                        Dawid Mościcki
                        I will close this ticket and make a new ones. This conversations is too long, sorry for that 😕 Thanks for help so far !
