  3. Cannot communicate over adb/fastboot after flashing image
20 Posts 3 Posters 4.8k Views 2 Watching
  • Kashish Garg 0K Kashish Garg 0
    @Alex-Kushleyev I was able to turn off SW2, but I was unable to log into the board using adb. I tried reinstalling adb on my machine, I tried multiple machines and multiple usb-c cables. We have another, working, starling and we are able to log into adb there, so we are pretty sure it has to do with this voxl2 specifically.
    @Kashish-Garg-0 , thanks for clarifying. Was this board working originally and then something happened or was it "dead" when you received it?
    Kashish Garg 0K 1 Reply Last reply
      Kashish Garg 0K Offline
      Kashish Garg 0
      @Alex-Kushleyev it was working and we accidentally removed glibc in an attempt to upgrade it. Meaning we couldn't access the shell anymore.
        @Kashish-Garg-0 , I understand.
        Can you try this procedure to force into fastboot and then perform SDK install?
        https://docs.modalai.com/voxl2-voxl2-mini-system-image/#force-voxl-2-into-fastboot
          Kashish Garg 0
          @Alex-Kushleyev Hey Alex, we have gone through this procedure a few times, even had a partner to make sure the button was being pressed appropriately. When running fastboot devices, no device gets identified.
          Alex KushleyevA tomT 2 Replies Last reply
            @Kashish-Garg-0 , I understand, thanks for clarifying.
            My colleague, who has more experience with this, was out of office last week, coming back tomorrow. I will make sure he takes a look at your post, he may have some suggestions. @tom
              @Kashish-Garg-0 With your device plugged in to your host pc via usb, what do you see with lsusb on your host PC?
                Kashish Garg 0
                Bus 005 Device 008: ID 05c6:900e Qualcomm, Inc.
                Thanks for your help!
                  @Kashish-Garg-0 Okay so the device is booting into EDL mode, which is what is used for QDL flashing. Can you confirm that the EDL switch is turned off?
                    Kashish Garg 0
                    wrote on last edited by Kashish Garg 0
                    #14
                    @tom Yes the EDL Switch is turned OFF, pointing away from the Processor
                      @Kashish-Garg-0 And when you went through the QDL process did the QDL flashing complete as expected? Should take around 10 minutes to complete
                        Kashish Garg 0
                        @tom I just re ran it and it took around 7 minutes or so and gave the appropriate output:
                        <data>
                        <log value="INFO: Calling handler for setbootablestoragedrive" /></data>
                        <data>
                        <log value="INFO: Using scheme of value= 1" /></data>
                        <data>
                        <data>
                        <data>
                          <data>
                          <data>
                          <data>
                          <data>
                          <data>
                          @Kashish-Garg-0 And then if you remove and replace both power and usb is it still booting to that same mode?
                            Kashish Garg 0
                            @tom You mean is it going to EDL mode after replacing power/usb and moving the EDL Switch to off?
                            Bus 005 Device 011: ID 05c6:900e Qualcomm, Inc. USB2.0 Hub
                            Is what is being printed with lsusb now
                              @Kashish-Garg-0 Sounds like we'll have get an RMA going for this one: https://www.modalai.com/pages/rma
                                @Kashish-Garg-0 It's possible your board has a QSM8250 (M0054-2) instead of a QRB5165 (M0054-1), see here for the diffs: https://docs.modalai.com/m0054-versions/#m0054-1-and-m0054-2
                                If that is the case then you will have to QDL using a different build, which you can download from downloads.modalai.com, look for M0054-2 Starling QDL Image 1.7.4 2024-02-09-1.7.4-M0054-2.zip under the "All" category
