  2. VOXL Dev Drones
  3. Qualcomm Flight RB5 5G Drone
  4. RB5 drone goes to a different height than I input
Scheduled Pinned Locked Moved Qualcomm Flight RB5 5G Drone
12 Posts 3 Posters 1.9k Views 2 Watching
  • A Offline
    Advait Pandit
    When I give a takeoff command to RB5 drone using QGC and set a particular height (in meters), it does not go to the set height but always ends up going to what I am assuming is the default height. This causes major issues as I my lab is underground and the drone has hit the top of the the safety net and dropped a couple of times. Can you please advise me on this.
    Thank you!
    Advait P
    • A Advait Pandit
      Thank you!
      Advait P
      Eric KatzfeyE Online
      @Advait-Pandit I'm guessing that this could be more of a PX4 issue than an RB5 issue so I would recommend also posting this on the PX4 forum to see if you can get some feedback there. Also, I would recommend trying your scenario using HITL testing first to make sure everything works as expected. If it works fine in HITL but not during an actual flight then perhaps there is an RB5 issue. https://docs.modalai.com/voxl2-PX4-hitl/
      A 1 Reply Last reply
        Advait Pandit
        Thank you Eric, I will also post this on the PX4 forum. Would you suggest putting the mavsdk script directly onto the drone to avoid errors/latency issues due to a udp/tcp connection? Is there a way to execute a script on the drone without connecting it with a usb cable. Thanks!
        Kind regards,
        Advait P
        • A Advait Pandit
          Kind regards,
          Advait P
          @Advait-Pandit You can certainly run mavsdk directly on the drone.
            Advait Pandit
            Great, so how can I remotely trigger this script on the drone? I successfully pushed the script using 'adb push' onto the drone's file system but this obviously required a usb connection. Given that the drone needs to run a good distance away, I would need a way to 'adb shell' onto the drone without a usb cable, how could I do that?
            Advait P
            tomT Eric KatzfeyE 2 Replies Last reply
            • A Advait Pandit
              Advait P
              @Advait-Pandit If you have a network connection i.e. WiFi you can ssh onto the drone
              • A Advait Pandit
                Advait P
                @Advait-Pandit I would very strongly recommend testing all this with HITL first. Then try it on a real flight when it is working as expected.
                  Advait Pandit
                  Thank you, I was able to ssh onto the drone via wifi. There is an issue with packages when trying to work with python scripts. I can't download python packages using pip even after creating a virtual environment. I get the error: -bash: pip: command not found
                  Kind regards,
                  Advait P
                  tomT Eric KatzfeyE 3 Replies Last reply
                  • A Advait Pandit
                    Kind regards,
                    Advait P
                    @Advait-Pandit I think we only use pip3. I can't speak on venvs
                    • A Advait Pandit
                      Kind regards,
                      Advait P
                      @Advait-Pandit It's much easier to use mavsdk inside a docker container where you can configure the proper environment.
                      • A Advait Pandit
                        Kind regards,
                        Advait P
                        @Advait-Pandit Here is some documentation: https://docs.modalai.com/mavsdk/
                          Advait Pandit
                          Thank you for the advise, I will take a look!
