    failed to compile voxl-dfs-server ver 0.2.0
    FAQs
    1936
    • S
      shlee853
      I download voxl-dfs-server from gitlab as a master.
      Then I compiled as stable dependency. but failed on processing.
      maybe opencl library is not included.
      swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-dfs-server$ voxl-docker -i voxl-cross
           launching image: voxl-cross with the following command:
           docker run --rm -it --net=host --privileged -w /home/swift --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/swift/git/voxl-dfs-server:/home/root:rw -w /home/root voxl-cross /bin/bash
           root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root#
           root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# ls
           CHANGELOG  CMakeLists.txt  LICENSE  README.md  bash_completions  build.sh  build_utils  clean.sh  clients  config  install_build_deps.sh  install_on_voxl.sh  ipk  make_package.sh  server  service
           root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# ./clean.sh
           root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# ./install_build_deps.sh stable
           using stable repository
           Downloading http://voxl-packages.modalai.com/stable/Packages.gz.
           Updated source 'stable'.
           Installing libmodal_pipe (2.0.7) on root.
           Downloading http://voxl-packages.modalai.com/stable/libmodal_pipe_2.0.7.ipk.
           Configuring libmodal_pipe.
           Done installing libmodal_pipe
           Installing libmodal_json (0.3.5) on root.
           Downloading http://voxl-packages.modalai.com/stable/libmodal_json_0.3.5.ipk.
           Configuring libmodal_json.
           Done installing libmodal_json
           Installing opencv (4.5.2) on root.
           Downloading http://voxl-packages.modalai.com/stable/opencv_4.5.2-1.ipk.
           Configuring opencv.
           done installing opencv
           root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# ./build.sh
           -- The C compiler identification is GNU 5.4.0
           -- The CXX compiler identification is GNU 5.4.0
           -- Check for working C compiler: /usr/bin/cc
           -- Check for working C compiler: /usr/bin/cc -- works
           -- Check for working CXX compiler: /usr/bin/c++
           -- Check for working CXX compiler: /usr/bin/c++ -- works
           -- Configuring done
           -- Generating done
           -- Build files have been written to: /home/root/build_utils/build
           Scanning dependencies of target embedfile
           [ 50%] Building C object CMakeFiles/embedfile.dir/src/embedfile.c.o
           [100%] Linking C executable embedfile
           [100%] Built target embedfile
           -- The C compiler identification is GNU 4.9.3
           -- The CXX compiler identification is GNU 4.9.3
           -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9
           -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9 -- works
           -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9
           -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9 -- works
           -- Configuring done
           -- Generating done
           -- Build files have been written to: /home/root/build64
           [ 10%] Generating blur_kernel_code.c
           [ 10%] Generating disparity_kernel_code.c
           [ 15%] Generating sobel_filter_kernel_code.c
           [ 21%] Generating compute_dsi_kernel_code.c
           [ 26%] Generating sparse_census_transform_kernel_code.c
           Scanning dependencies of target voxl-dfs-server
           [ 36%] Building C object server/CMakeFiles/voxl-dfs-server.dir/undistort.c.o
           [ 36%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/sad_disparity_estimation.cpp.o
           [ 42%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o
           [ 47%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/box_filter_blur.cpp.o
           In file included from /home/root/server/opencl_kernel.h:38:0,
                            from /home/root/server/box_filter_blur.h:38,
                            from /home/root/server/box_filter_blur.cpp:35:
           /home/root/server/opencl_manager.h:39:21: fatal error: CL/cl.hpp: No such file or directory
            #include <CL/cl.hpp>
           compilation terminated.
           In file included from /home/root/server/opencl_manager.cpp:35:0:
                            from /home/root/server/sad_disparity_estimation.h:38,
                            from /home/root/server/sad_disparity_estimation.cpp:35:
           server/CMakeFiles/voxl-dfs-server.dir/build.make:154: recipe for target 'server/CMakeFiles/voxl-dfs-server.dir/box_filter_blur.cpp.o' failed
           make[2]: *** [server/CMakeFiles/voxl-dfs-server.dir/box_filter_blur.cpp.o] Error 1
           make[2]: *** Waiting for unfinished jobs....
           server/CMakeFiles/voxl-dfs-server.dir/build.make:130: recipe for target 'server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o' failed
           make[2]: *** [server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o] Error 1
           server/CMakeFiles/voxl-dfs-server.dir/build.make:106: recipe for target 'server/CMakeFiles/voxl-dfs-server.dir/sad_disparity_estimation.cpp.o' failed
           make[2]: *** [server/CMakeFiles/voxl-dfs-server.dir/sad_disparity_estimation.cpp.o] Error 1
           CMakeFiles/Makefile2:85: recipe for target 'server/CMakeFiles/voxl-dfs-server.dir/all' failed
           make[1]: *** [server/CMakeFiles/voxl-dfs-server.dir/all] Error 2
           Makefile:127: recipe for target 'all' failed
           make: *** [all] Error 2
           root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# cmake CMakeLists.txt
           -- Configuring done
           -- Generating done
           -- Configuring done
           -- Generating done
           -- Configuring done
           -- Generating done
           CMake Warning:
             Manually-specified variables were not used by the project:
               CMAKE_TOOLCHAIN_FILE
           make: *** No targets specified and no makefile found.  Stop.
      1. could you please check?
      2. also I want to see dfs image result using client pipeline as voxl-cam-logger.
        It also cannot compiled on this version.
        could you please let me know to resolve it?
      • Chad SweetC
        Chad Sweet ModalAI Team
        You need to use the latest version of voxl-docker from developer.modalai.com
        • S
          shlee853
          I downloaded latest sw in gitlab. as I know, ver.0.2.0 is latest one.
            Alex Kushleyev ModalAI Team
            voxl-emulator and voxl-cross are docker images that contain the voxl system headers and libraries for cross-compilation (voxl-cross is used in this example). voxl-docker is a script which launches voxl-cross docker image. The docker image has been updated to include opencl stuff. Make sure you download the latest voxl-emulator and voxl-cross docker images from https://developer.modalai.com/asset.
            S 2 Replies Last reply Reply Quote 0
            • S
              shlee853 @Alex Kushleyev
              @Alex-Kushleyev okay Thanks buddy
              • S
                @Alex-Kushleyev Can I ask something?
                Can I get disparity image in real-time using stereo camera?
                obstable distance is not reliable on 0 degree for my voxl flight.
                • Chad SweetC
                  If the data is not very accurate, it is likely you need to recalibrate the stereo sensors. Instructions are here
                  Otherwise, the data is published here disparity and point cloud. We provide the code so you can change how you see fit for your application
                    • S
                      shlee853 @Chad Sweet
                      @Chad-Sweet could you please try compile voxl-dfs-server 0.2.0 and client?
                      I need to modify application but it failed even the voxl-cross version is newest.
                        Hi shlee,
                        Here is a copy of my device cloning a fresh copy of dfs-server and building it successfully in voxl-cross, if you could let us know exactly what errors you're encountering when trying to build that'd be helpful.
                        Alex:~/tmp$ git clone git@gitlab.com:voxl-public/modal-pipe-architecture/voxl-dfs-server.git
                        Cloning into 'voxl-dfs-server'...
                        remote: Enumerating objects: 525, done.
                        remote: Counting objects: 100% (266/266), done.
                        remote: Compressing objects: 100% (139/139), done.
                        remote: Total 525 (delta 173), reused 197 (delta 121), pack-reused 259
                        Receiving objects: 100% (525/525), 200.24 KiB | 1.16 MiB/s, done.
                        Resolving deltas: 100% (297/297), done.
                        Alex:~/tmp$ cd voxl-dfs-server/
                        Alex:~/tmp/voxl-dfs-server(master)$ voxl-docker -i voxl-cross
                        docker run --rm -it --net=host --privileged -w /home/alex --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/alex/tmp/voxl-dfs-server:/home/root:rw -w /home/root voxl-cross /bin/bash -l
                        voxl-cross:~$ ./install_build_deps.sh stable
                        Configuring opencv.
                        voxl-cross:~$ ./build.sh
                        -- Configuring done
                        -- Generating done
                        -- Configuring done
                        -- Generating done
                        [ 10%] Generating sobel_filter_kernel_code.c
                        [ 21%] Generating disparity_kernel_code.c
                        [ 31%] Building C object server/CMakeFiles/voxl-dfs-server.dir/undistort.c.o
                        [ 36%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/dfs_processing_engine.cpp.o
                        [ 42%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/sad_disparity_estimation.cpp.o
                        [ 52%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_kernel.cpp.o
                        [ 57%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/main.cpp.o
                        [ 63%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o
                        [ 68%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/sobel_filter.cpp.o
                        [ 73%] Building C object server/CMakeFiles/voxl-dfs-server.dir/blur_kernel_code.c.o
                        [ 78%] Building C object server/CMakeFiles/voxl-dfs-server.dir/disparity_kernel_code.c.o
                        [ 84%] Building C object server/CMakeFiles/voxl-dfs-server.dir/compute_dsi_kernel_code.c.o
                        [ 89%] Building C object server/CMakeFiles/voxl-dfs-server.dir/sparse_census_transform_kernel_code.c.o
                        [ 94%] Building C object server/CMakeFiles/voxl-dfs-server.dir/sobel_filter_kernel_code.c.o
                        [100%] Linking CXX executable voxl-dfs-server
                        [100%] Built target voxl-dfs-server
                        voxl-cross:~$ ./make_package.sh
                        Package Name:  voxl-dfs-server
                        version Number:  0.2.0
                        Install the project...
                        -- Install configuration: "Release"
                        -- Installing: ../ipk/data/etc/systemd/system/voxl-dfs-server.service
                        -- Installing: ../ipk/data/usr/bin/voxl-dfs-server
                        /home/root
                        ar: creating voxl-dfs-server_0.2.0.ipk
                        DONE
                        voxl-cross:~$
                        • S
                          shlee853 @Guest
                          @Alex-Gardner are you using a version 1.1 for voxl-cross?
                          You can find my compilation result at the first comment in this thread.
                          The errors are related with obsolete opencl lib.
                          • S
                            shlee853 @Guest
                            @Alex-Gardner Thanks for your supports.
                            I realized voxl-docker s/w was updated 1 month ago.
                            I resolved this problem using newest voxl-docker.
                            swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git$ cd voxl-dfs-server
                            swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-dfs-server$ ls
                            bash_completions  clean.sh        install_build_deps.sh  make_package.sh
                            build.sh          clients         install_on_voxl.sh     README.md
                            build_utils       CMakeLists.txt  ipk                    server
                            CHANGELOG         config          LICENSE                service
                            docker run --rm -it --net=host --privileged -w /home/swift --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/swift/git/voxl-dfs-server:/home/root:rw -w /home/root voxl-cross /bin/bash -l
                            voxl-cross:~$
                            voxl-cross:~$
                            Configuring opencv.
                            -- Configuring done
                            -- Generating done
                            -- Configuring done
                            -- Generating done
                            [ 15%] Generating disparity_kernel_code.c
                            [ 15%] Generating compute_dsi_kernel_code.c
                            [ 21%] Generating blur_kernel_code.c
                            [ 36%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o
                            [ 52%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/dfs_processing_engine.cpp.o
                            [ 63%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_kernel.cpp.o
                            voxl-cross:~$
                            voxl-cross:~$
                            voxl-cross:~$
                            /home/root
                            DONE
                            voxl-cross:~$
                            Here is myvoxl-docker images
                            swift@swift-HP-Pavilion-dv6-Notebook-PC:~$ voxl-docker -l | grep "voxl"
                            voxl-cross       V1.1      77af6063e492   14 minutes ago   999MB
                            voxl-cross       latest    77af6063e492   14 minutes ago   999MB
                            voxl-emulator    V1.7      55d4f01b7bcd   7 weeks ago      3.33GB
                            voxl-emulator    latest    55d4f01b7bcd   7 weeks ago      3.33GB
                            voxl-hexagon     latest    8509f4e31f56   2 months ago     5.24GB
                            voxl-emulator    V1.5      323601eb49d7   4 months ago     3.2GB
