  2. FAQs
  3. failed to compile voxl-dfs-server ver 0.2.0
Scheduled Pinned Locked Moved Unsolved FAQs
12 Posts 4 Posters 3.3k Views 3 Watching
  • S Offline
    S Offline
    shlee853
    wrote on last edited by shlee853
    I download voxl-dfs-server from gitlab as a master.
    Then I compiled as stable dependency. but failed on processing.
    maybe opencl library is not included.
    swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-dfs-server$ voxl-docker -i voxl-cross
         launching image: voxl-cross with the following command:
         docker run --rm -it --net=host --privileged -w /home/swift --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/swift/git/voxl-dfs-server:/home/root:rw -w /home/root voxl-cross /bin/bash
         root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root#
         root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# ls
         CHANGELOG  CMakeLists.txt  LICENSE  README.md  bash_completions  build.sh  build_utils  clean.sh  clients  config  install_build_deps.sh  install_on_voxl.sh  ipk  make_package.sh  server  service
         root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# ./clean.sh
         root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# ./install_build_deps.sh stable
         using stable repository
         Downloading http://voxl-packages.modalai.com/stable/Packages.gz.
         Updated source 'stable'.
         Installing libmodal_pipe (2.0.7) on root.
         Downloading http://voxl-packages.modalai.com/stable/libmodal_pipe_2.0.7.ipk.
         Configuring libmodal_pipe.
         Done installing libmodal_pipe
         Installing libmodal_json (0.3.5) on root.
         Downloading http://voxl-packages.modalai.com/stable/libmodal_json_0.3.5.ipk.
         Configuring libmodal_json.
         Done installing libmodal_json
         Installing opencv (4.5.2) on root.
         Downloading http://voxl-packages.modalai.com/stable/opencv_4.5.2-1.ipk.
         Configuring opencv.
         done installing opencv
         root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# ./build.sh
         -- The C compiler identification is GNU 5.4.0
         -- The CXX compiler identification is GNU 5.4.0
         -- Check for working C compiler: /usr/bin/cc
         -- Check for working C compiler: /usr/bin/cc -- works
         -- Check for working CXX compiler: /usr/bin/c++
         -- Check for working CXX compiler: /usr/bin/c++ -- works
         -- Configuring done
         -- Generating done
         -- Build files have been written to: /home/root/build_utils/build
         Scanning dependencies of target embedfile
         [ 50%] Building C object CMakeFiles/embedfile.dir/src/embedfile.c.o
         [100%] Linking C executable embedfile
         [100%] Built target embedfile
         -- The C compiler identification is GNU 4.9.3
         -- The CXX compiler identification is GNU 4.9.3
         -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9
         -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9 -- works
         -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9
         -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9 -- works
         -- Configuring done
         -- Generating done
         -- Build files have been written to: /home/root/build64
         [ 10%] Generating blur_kernel_code.c
         [ 10%] Generating disparity_kernel_code.c
         [ 15%] Generating sobel_filter_kernel_code.c
         [ 21%] Generating compute_dsi_kernel_code.c
         [ 26%] Generating sparse_census_transform_kernel_code.c
         Scanning dependencies of target voxl-dfs-server
         [ 36%] Building C object server/CMakeFiles/voxl-dfs-server.dir/undistort.c.o
         [ 36%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/sad_disparity_estimation.cpp.o
         [ 42%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o
         [ 47%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/box_filter_blur.cpp.o
         In file included from /home/root/server/opencl_kernel.h:38:0,
                          from /home/root/server/box_filter_blur.h:38,
                          from /home/root/server/box_filter_blur.cpp:35:
         /home/root/server/opencl_manager.h:39:21: fatal error: CL/cl.hpp: No such file or directory
          #include <CL/cl.hpp>
         compilation terminated.
         In file included from /home/root/server/opencl_manager.cpp:35:0:
                          from /home/root/server/sad_disparity_estimation.h:38,
                          from /home/root/server/sad_disparity_estimation.cpp:35:
         server/CMakeFiles/voxl-dfs-server.dir/build.make:154: recipe for target 'server/CMakeFiles/voxl-dfs-server.dir/box_filter_blur.cpp.o' failed
         make[2]: *** [server/CMakeFiles/voxl-dfs-server.dir/box_filter_blur.cpp.o] Error 1
         make[2]: *** Waiting for unfinished jobs....
         server/CMakeFiles/voxl-dfs-server.dir/build.make:130: recipe for target 'server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o' failed
         make[2]: *** [server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o] Error 1
         server/CMakeFiles/voxl-dfs-server.dir/build.make:106: recipe for target 'server/CMakeFiles/voxl-dfs-server.dir/sad_disparity_estimation.cpp.o' failed
         make[2]: *** [server/CMakeFiles/voxl-dfs-server.dir/sad_disparity_estimation.cpp.o] Error 1
         CMakeFiles/Makefile2:85: recipe for target 'server/CMakeFiles/voxl-dfs-server.dir/all' failed
         make[1]: *** [server/CMakeFiles/voxl-dfs-server.dir/all] Error 2
         Makefile:127: recipe for target 'all' failed
         make: *** [all] Error 2
         root@swift-HP-Pavilion-dv6-Notebook-PC:/home/root# cmake CMakeLists.txt
         -- Configuring done
         -- Generating done
         -- Configuring done
         -- Generating done
         -- Configuring done
         -- Generating done
         CMake Warning:
           Manually-specified variables were not used by the project:
             CMAKE_TOOLCHAIN_FILE
         make: *** No targets specified and no makefile found.  Stop.
    1. could you please check?
    2. also I want to see dfs image result using client pipeline as voxl-cam-logger.
      It also cannot compiled on this version.
      could you please let me know to resolve it?
      You need to use the latest version of voxl-docker from developer.modalai.com
      • S Offline
        S Offline
        shlee853
        I downloaded latest sw in gitlab. as I know, ver.0.2.0 is latest one.
        • Alex KushleyevA Offline
          voxl-emulator and voxl-cross are docker images that contain the voxl system headers and libraries for cross-compilation (voxl-cross is used in this example). voxl-docker is a script which launches voxl-cross docker image. The docker image has been updated to include opencl stuff. Make sure you download the latest voxl-emulator and voxl-cross docker images from https://developer.modalai.com/asset.
          S 2 Replies Last reply
            S Offline
            S Offline
            shlee853
            @Alex-Kushleyev okay Thanks buddy
              S Offline
              S Offline
              shlee853
              @Alex-Kushleyev Can I ask something?
              Can I get disparity image in real-time using stereo camera?
              obstable distance is not reliable on 0 degree for my voxl flight.
                If the data is not very accurate, it is likely you need to recalibrate the stereo sensors. Instructions are here
                Otherwise, the data is published here disparity and point cloud. We provide the code so you can change how you see fit for your application
                S 1 Reply Last reply
                • ? Offline
                  • Chad SweetC Chad Sweet
                    S Offline
                    S Offline
                    shlee853
                    @Chad-Sweet could you please try compile voxl-dfs-server 0.2.0 and client?
                    I need to modify application but it failed even the voxl-cross version is newest.
                    • ? Offline
                      Hi shlee,
                      Here is a copy of my device cloning a fresh copy of dfs-server and building it successfully in voxl-cross, if you could let us know exactly what errors you're encountering when trying to build that'd be helpful.
                      Alex:~/tmp$ git clone git@gitlab.com:voxl-public/modal-pipe-architecture/voxl-dfs-server.git
                      Cloning into 'voxl-dfs-server'...
                      remote: Enumerating objects: 525, done.
                      remote: Counting objects: 100% (266/266), done.
                      remote: Compressing objects: 100% (139/139), done.
                      remote: Total 525 (delta 173), reused 197 (delta 121), pack-reused 259
                      Receiving objects: 100% (525/525), 200.24 KiB | 1.16 MiB/s, done.
                      Resolving deltas: 100% (297/297), done.
                      Alex:~/tmp$ cd voxl-dfs-server/
                      Alex:~/tmp/voxl-dfs-server(master)$ voxl-docker -i voxl-cross
                      docker run --rm -it --net=host --privileged -w /home/alex --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/alex/tmp/voxl-dfs-server:/home/root:rw -w /home/root voxl-cross /bin/bash -l
                      voxl-cross:~$ ./install_build_deps.sh stable
                      Configuring opencv.
                      voxl-cross:~$ ./build.sh
                      -- Configuring done
                      -- Generating done
                      -- Configuring done
                      -- Generating done
                      [ 10%] Generating sobel_filter_kernel_code.c
                      [ 21%] Generating disparity_kernel_code.c
                      [ 31%] Building C object server/CMakeFiles/voxl-dfs-server.dir/undistort.c.o
                      [ 36%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/dfs_processing_engine.cpp.o
                      [ 42%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/sad_disparity_estimation.cpp.o
                      [ 52%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_kernel.cpp.o
                      [ 57%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/main.cpp.o
                      [ 63%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o
                      [ 68%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/sobel_filter.cpp.o
                      [ 73%] Building C object server/CMakeFiles/voxl-dfs-server.dir/blur_kernel_code.c.o
                      [ 78%] Building C object server/CMakeFiles/voxl-dfs-server.dir/disparity_kernel_code.c.o
                      [ 84%] Building C object server/CMakeFiles/voxl-dfs-server.dir/compute_dsi_kernel_code.c.o
                      [ 89%] Building C object server/CMakeFiles/voxl-dfs-server.dir/sparse_census_transform_kernel_code.c.o
                      [ 94%] Building C object server/CMakeFiles/voxl-dfs-server.dir/sobel_filter_kernel_code.c.o
                      [100%] Linking CXX executable voxl-dfs-server
                      [100%] Built target voxl-dfs-server
                      voxl-cross:~$ ./make_package.sh
                      Package Name:  voxl-dfs-server
                      version Number:  0.2.0
                      Install the project...
                      -- Install configuration: "Release"
                      -- Installing: ../ipk/data/etc/systemd/system/voxl-dfs-server.service
                      -- Installing: ../ipk/data/usr/bin/voxl-dfs-server
                      /home/root
                      ar: creating voxl-dfs-server_0.2.0.ipk
                      DONE
                      voxl-cross:~$
                      • ? A Former User
                        Hi shlee,
                        Configuring opencv.
                        -- Configuring done
                        -- Generating done
                        -- Configuring done
                        -- Generating done
                        /home/root
                        DONE
                        voxl-cross:~$
                        S Offline
                        S Offline
                        shlee853
                        @Alex-Gardner are you using a version 1.1 for voxl-cross?
                        You can find my compilation result at the first comment in this thread.
                        The errors are related with obsolete opencl lib.
                        • ? A Former User
                          Hi shlee,
                          Configuring opencv.
                          -- Configuring done
                          -- Generating done
                          -- Configuring done
                          -- Generating done
                          /home/root
                          DONE
                          voxl-cross:~$
                          S Offline
                          S Offline
                          shlee853
                          @Alex-Gardner Thanks for your supports.
                          I realized voxl-docker s/w was updated 1 month ago.
                          I resolved this problem using newest voxl-docker.
                          swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git$ cd voxl-dfs-server
                          swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-dfs-server$ ls
                          bash_completions  clean.sh        install_build_deps.sh  make_package.sh
                          build.sh          clients         install_on_voxl.sh     README.md
                          build_utils       CMakeLists.txt  ipk                    server
                          CHANGELOG         config          LICENSE                service
                          docker run --rm -it --net=host --privileged -w /home/swift --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/swift/git/voxl-dfs-server:/home/root:rw -w /home/root voxl-cross /bin/bash -l
                          voxl-cross:~$
                          voxl-cross:~$
                          Configuring opencv.
                          -- Configuring done
                          -- Generating done
                          -- Configuring done
                          -- Generating done
                          [ 15%] Generating disparity_kernel_code.c
                          [ 15%] Generating compute_dsi_kernel_code.c
                          [ 21%] Generating blur_kernel_code.c
                          [ 36%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_manager.cpp.o
                          [ 52%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/dfs_processing_engine.cpp.o
                          [ 63%] Building CXX object server/CMakeFiles/voxl-dfs-server.dir/opencl_kernel.cpp.o
                          voxl-cross:~$
                          voxl-cross:~$
                          voxl-cross:~$
                          /home/root
                          DONE
                          voxl-cross:~$
                          Here is myvoxl-docker images
                          swift@swift-HP-Pavilion-dv6-Notebook-PC:~$ voxl-docker -l | grep "voxl"
                          voxl-cross       V1.1      77af6063e492   14 minutes ago   999MB
                          voxl-cross       latest    77af6063e492   14 minutes ago   999MB
                          voxl-emulator    V1.7      55d4f01b7bcd   7 weeks ago      3.33GB
                          voxl-emulator    latest    55d4f01b7bcd   7 weeks ago      3.33GB
                          voxl-hexagon     latest    8509f4e31f56   2 months ago     5.24GB
                          voxl-emulator    V1.5      323601eb49d7   4 months ago     3.2GB
