  3. April tag detection position on Starling
2 Posts 2 Posters 602 Views 1 Watching
  • Darshit DesaiD Offline
    Darshit Desai
    Hi, How do I get the voxl_mpa_to_ros node to stream the 6-DOF pose of the april tag, currently in my starling when I run the tag detector service and the voxl_mpa_to_ros node it only streams the /tracking_tag_overlay topic of type sensor_msgs/Image. I can see the position of the tag if I do voxl-inspect-tags
    ModeratorM 1 Reply Last reply
      @Darshit-Desai Hi Darshit, you will need to modify the code to support what you would like to achieve. If you'd like to mainline, we accept merge requests
