<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[April tag detection position on Starling]]></title><description><![CDATA[<p dir="auto">Hi, How do I get the voxl_mpa_to_ros node to stream the 6-DOF pose of the april tag, currently in my starling when I run the tag detector service and the voxl_mpa_to_ros node it only streams the /tracking_tag_overlay topic of type sensor_msgs/Image. I can see the position of the tag if I do voxl-inspect-tags</p>
]]></description><link>https://forum.modalai.com/topic/3238/april-tag-detection-position-on-starling</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 03:11:45 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3238.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Mar 2024 23:16:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to April tag detection position on Starling on Tue, 19 Mar 2024 23:29:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/1516">@Darshit-Desai</a> Hi Darshit, you will need to modify <a href="https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros/-/tree/master/catkin_ws/src/src/interfaces?ref_type=heads" rel="nofollow ugc">the code</a> to support what you would like to achieve. If you'd like to mainline, we accept merge requests</p>
]]></description><link>https://forum.modalai.com/post/15519</link><guid isPermaLink="true">https://forum.modalai.com/post/15519</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Tue, 19 Mar 2024 23:29:03 GMT</pubDate></item></channel></rss>
