    Tips to increase cable length of Time of flight camera
    Image Sensors
    1009
    • A
      Aaky
      Hello community,
      I am using VOXL2 with latest SDK 1.1.2. In mu UAV, due to size restrictions I want to extend tracking and TOF camera cable lengths atleast near to 20 cms. I am aware of this Y flex cable which can extend both these cameras. Can this cable also be used to extend TOF camera cable length further?
      Second query, Is this new tracking camera fully compatible and supported on SDK 1.1.2 for QVIO purpose? Any hurdles please let me know.
      ModeratorM VinnyV 2 Replies Last reply Reply Quote 0
      • ModeratorM
        Moderator ModalAI Team @Aaky
        @Aaky 20cm is starting to push on the maximum length for MIPI. You can use the M0036 extension flex, but at some point it will not work any longer.
        Yes, the new M0149 tracking sensor can be used for VIO. You will need to calibrate the intrinsics though
        • VinnyV
          Vinny ModalAI Team @Aaky
          Hi @Aaky
          ToF is also a very high current sensor, so using lengths beyond what we support may lead to failure, or severely reduced image quality.
          20cms is VERY long for MIPI and most often will fail at those lengths without a re-driver/Re-timer circuit you will need to add in your system.
          Hope this helps.
          • A
            Aaky @Vinny
            @Vinny @Moderator Thanks for the input.
            So, Will M0084 support new tracking camera MSU-M0149-1 and TOF camera together in new SDK 1.1.2?
            I connected M0084 to J7 over VOXL2, on JU of M0084 I have connected TOF and over JL tracking camera (OV7251) is connected as per your defined configuration over here. But this isn't spawning up TOF camera. Following are the logs with Verbosity enabled on voxl-camera-server.
            voxl2:/$ voxl-camera-server -d 0
            configuration for 2 cameras:
            cam #0
                sensor type:         pmd-tof
                isEnabled:           1
                camId:               0
                camId2:              -1
                fps:                 5
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           224
                pre_height:          1557
                en_raw_preview:      1
                en_small_video:      0
                small_video_width:   -1
                small_video_height:  -1
                en_large_video:      0
                large_video_width:   -1
                large_video_height:  -1
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             off
                standby_enabled:     0
                decimator:           5
                independent_exposure:0
            cam #1
                sensor type:         ov7251
                isEnabled:           1
                camId:               1
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           640
                pre_height:          480
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                standby_enabled:     0
                decimator:           1
            DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
            GPS server Connected
            DEBUG:   Connected to cpu-monitor
            DEBUG:   ------ voxl-camera-server: Starting 2 cameras
            Starting Camera: tof (id #0)
            DEBUG:   Checking Gain limits for Camera: tof
            Using gain limits min: 54 max: 3451
            DEBUG:   cam ID 0 checking for fmt:   38  w:  224 h: 1557 o:   0
            DEBUG:   i:  0 fmt: 34 w: 640 h: 480 o:0
            DEBUG:   i:  4 fmt: 34 w: 640 h: 480 o:1
            DEBUG:   i:  8 fmt: 35 w: 640 h: 480 o:0
            DEBUG:   i: 12 fmt: 35 w: 640 h: 480 o:1
            DEBUG:   i: 16 fmt: 33 w: 640 h: 480 o:0
            DEBUG:   i: 20 fmt: 34 w: 640 h: 400 o:0
            DEBUG:   i: 24 fmt: 34 w: 640 h: 400 o:1
            DEBUG:   i: 28 fmt: 35 w: 640 h: 400 o:0
            DEBUG:   i: 32 fmt: 35 w: 640 h: 400 o:1
            DEBUG:   i: 36 fmt: 33 w: 640 h: 400 o:0
            DEBUG:   i: 40 fmt: 34 w: 640 h: 360 o:0
            DEBUG:   i: 44 fmt: 34 w: 640 h: 360 o:1
            DEBUG:   i: 48 fmt: 35 w: 640 h: 360 o:0
            DEBUG:   i: 52 fmt: 35 w: 640 h: 360 o:1
            DEBUG:   i: 56 fmt: 33 w: 640 h: 360 o:0
            DEBUG:   i: 60 fmt: 34 w: 352 h: 288 o:0
            DEBUG:   i: 64 fmt: 34 w: 352 h: 288 o:1
            DEBUG:   i: 68 fmt: 35 w: 352 h: 288 o:0
            DEBUG:   i: 72 fmt: 35 w: 352 h: 288 o:1
            DEBUG:   i: 76 fmt: 33 w: 352 h: 288 o:0
            DEBUG:   i: 80 fmt: 34 w: 320 h: 240 o:0
            DEBUG:   i: 84 fmt: 34 w: 320 h: 240 o:1
            DEBUG:   i: 88 fmt: 35 w: 320 h: 240 o:0
            DEBUG:   i: 92 fmt: 35 w: 320 h: 240 o:1
            DEBUG:   i: 96 fmt: 33 w: 320 h: 240 o:0
            DEBUG:   i:100 fmt: 34 w: 240 h: 320 o:0
            DEBUG:   i:104 fmt: 34 w: 240 h: 320 o:1
            DEBUG:   i:108 fmt: 35 w: 240 h: 320 o:0
            DEBUG:   i:112 fmt: 35 w: 240 h: 320 o:1
            DEBUG:   i:116 fmt: 33 w: 240 h: 320 o:0
            DEBUG:   i:120 fmt: 34 w: 176 h: 144 o:0
            DEBUG:   i:124 fmt: 34 w: 176 h: 144 o:1
            DEBUG:   i:128 fmt: 35 w: 176 h: 144 o:0
            DEBUG:   i:132 fmt: 35 w: 176 h: 144 o:1
            DEBUG:   i:136 fmt: 33 w: 176 h: 144 o:0
            DEBUG:   i:140 fmt: 37 w: 640 h: 480 o:0
            DEBUG:   i:144 fmt: 38 w: 640 h: 480 o:0
            DEBUG:   i:148 fmt: 32 w: 640 h: 480 o:0
            DEBUG:   i:152 fmt: 36 w: 640 h: 480 o:0
            ERROR:   Camera 0 failed to find supported preview config: 224x1557
            WARNING: Failed to start cam tof due to invalid resolution
            WARNING: assuming cam is missing and trying to compensate
            Starting Camera: tracking (originally id #1) with id offset: 1
            DEBUG:   Checking Gain limits for Camera: tracking
            DEBUG:   cam ID 0 checking for fmt:   37  w:  640 h:  480 o:   0
            VERBOSE: Successfully found configuration match for camera 0: 640x480
            DEBUG:   Converted gralloc flags 0x20900 to GBM flags 0x1400000
            VERBOSE: Dumping GBM flags
            DEBUG:   	Found flag GBM_BO_USAGE_HW_COMPOSER_QTI
            VERBOSE: Opened GBM fd
            VERBOSE: Created GBM device
            DEBUG:   Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10
            setting ov7251 BLC register for cam id 0
            VERBOSE: sid: 0x00E2, addr: 0x4005, data: 0x0002
            VERBOSE: sid: 0x00E2, addr: 0x3820, data: 0x0000
            VERBOSE: sid: 0x00E2, addr: 0x3821, data: 0x0000
            VERBOSE: Entered thread: cam0-request(tid: 2370)
            VERBOSE: Entered thread: cam0-result(tid: 2371)
            DEBUG:   Started Camera: tracking
            ------ voxl-camera-server: Started 1 of 2 cameras
            VERBOSE: setting hal3 exposure for tracking     5259763   800
            VERBOSE: added request for preview stream
            VERBOSE: Sending request for frame 0 for camera tracking for 1 streams
            VERBOSE: Received 0 buffers from camera tracking, partial result:1
            VERBOSE: finished sending request for frame 0 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tracking
            VERBOSE: Sending request for frame 1 for camera tracking for 1 streams
            VERBOSE: finished sending request for frame 1 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera tracking
            VERBOSE: Sending request for frame 2 for camera tracking for 1 streams
            VERBOSE: finished sending request for frame 2 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera tracking
            VERBOSE: Sending request for frame 3 for camera tracking for 1 streams
            VERBOSE: Received result from HAl3 for frame number 2
            VERBOSE: finished sending request for frame 3 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera tracking
            VERBOSE: Sending request for frame 4 for camera tracking for 1 streams
            VERBOSE: finished sending request for frame 4 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera tracking
            VERBOSE: Sending request for frame 5 for camera tracking for 1 streams
            VERBOSE: Received result from HAl3 for frame number 3
            VERBOSE: Received result from HAl3 for frame number 4
            VERBOSE: Received 0 buffers from camera tracking, partial result:2
            VERBOSE: Received metadata for frame 0 from camera tracking
            VERBOSE: 	Timestamp: 96792200134
            VERBOSE: 	Gain: 799
            VERBOSE: 	Exposure: 5259763
            VERBOSE: Received 1 buffers from camera tracking, partial result:0
            VERBOSE: Received output buffer 0 from camera tracking
            VERBOSE: tracking procesing new buffer
            VERBOSE: Camera: tracking processing preview frame
            DEBUG:   setting thread affinity for cam tracking preview
            VERBOSE: finished sending request for frame 5 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 6 for camera tracking
            VERBOSE: Sending request for frame 6 for camera tracking for 1 streams
            VERBOSE: publishing raw preview frame for mono camera tracking
            VERBOSE: Received result from HAl3 for frame number 5
            VERBOSE: Received metadata for frame 1 from camera tracking
            VERBOSE: 	Timestamp: 96858901957
            VERBOSE: 	Gain: 799
            VERBOSE: Received output buffer 1 from camera tracking
            VERBOSE: finished sending request for frame 6 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 7 for camera tracking
            VERBOSE: setting hal3 exposure for tracking    24503468   799
            VERBOSE: Sending request for frame 7 for camera tracking for 1 streams
            DEBUG:   tracking checking to see if it is raw8 or raw 10
            DEBUG:   Frame was actually 8 bit, sending as is
            VERBOSE: Received result from HAl3 for frame number 6
            VERBOSE: Received metadata for frame 2 from camera tracking
            VERBOSE: 	Timestamp: 96892174613
            VERBOSE: 	Gain: 799
            VERBOSE: Received output buffer 2 from camera tracking
            VERBOSE: finished sending request for frame 7 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 8 for camera tracking
            VERBOSE: setting hal3 exposure for tracking    26995516  1634
            VERBOSE: Sending request for frame 8 for camera tracking for 1 streams
            VERBOSE: Received result from HAl3 for frame number 7
            VERBOSE: Received metadata for frame 3 from camera tracking
            VERBOSE: 	Timestamp: 96925509613
            VERBOSE: 	Gain: 799
            VERBOSE: Received output buffer 3 from camera tracking
            VERBOSE: finished sending request for frame 8 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 9 for camera tracking
            VERBOSE: Sending request for frame 9 for camera tracking for 1 streams
            VERBOSE: Received result from HAl3 for frame number 8
            VERBOSE: Received metadata for frame 4 from camera tracking
            VERBOSE: 	Timestamp: 96958834926
            VERBOSE: 	Gain: 799
            VERBOSE: Received output buffer 4 from camera tracking
            VERBOSE: finished sending request for frame 9 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 10 for camera tracking
            VERBOSE: setting hal3 exposure for tracking    27581204  1648
            VERBOSE: Sending request for frame 10 for camera tracking for 1 streams
            VERBOSE: Received result from HAl3 for frame number 9
            VERBOSE: Received metadata for frame 5 from camera tracking
            VERBOSE: 	Timestamp: 96992163051
            VERBOSE: 	Gain: 799
            VERBOSE: Received output buffer 5 from camera tracking
            VERBOSE: finished sending request for frame 10 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 11 for camera tracking
            VERBOSE: setting hal3 exposure for tracking    27892654  1655
            VERBOSE: Sending request for frame 11 for camera tracking for 1 streams
            VERBOSE: Received result from HAl3 for frame number 10
            VERBOSE: Received metadata for frame 6 from camera tracking
            VERBOSE: 	Timestamp: 97025491696
            VERBOSE: 	Gain: 799
            VERBOSE: Received output buffer 6 from camera tracking
            VERBOSE: finished sending request for frame 11 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 12 for camera tracking
            VERBOSE: setting hal3 exposure for tracking    28544998  1659
            VERBOSE: Sending request for frame 12 for camera tracking for 1 streams
            VERBOSE: Received result from HAl3 for frame number 11
            VERBOSE: Received metadata for frame 7 from camera tracking
            VERBOSE: 	Timestamp: 97039590700
            VERBOSE: 	Gain: 799
            VERBOSE: 	Exposure: 24503468
            VERBOSE: Received output buffer 7 from camera tracking
            VERBOSE: finished sending request for frame 12 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 13 for camera tracking
            VERBOSE: setting hal3 exposure for tracking    28519818  1667
            VERBOSE: Sending request for frame 13 for camera tracking for 1 streams
            VERBOSE: Received result from HAl3 for frame number 12
            VERBOSE: Received metadata for frame 8 from camera tracking
            VERBOSE: 	Timestamp: 97070415475
            VERBOSE: 	Gain: 1632
            VERBOSE: 	Exposure: 26995516
            VERBOSE: Received output buffer 8 from camera tracking
            VERBOSE: finished sending request for frame 13 for camera tracking
            VERBOSE: returning from SendOneCaptureRequest for frame 14 for camera tracking
            VERBOSE: setting hal3 exposure for tracking    33000000  1666
            VERBOSE: Sending request for frame 14 for camera tracking for 1 streams
            It seems to be TOF camera resolution problem. But I dont know where exactly to look for to set appropriate resolution since voxl-camera-server.conf dosent have TOF camera resolution mentioned.
            Please help on above both queries.
              Alex Kushleyev ModalAI Team @Aaky
              @Aaky , if you connected TOF to JU of M0084 and M0084 is connected to J7 of VOXL, then TOF will be in camera slot #3. This means that you need to place com.qti.sensormodule.irs1645_3.bin (note 3 at the end) in /usr/lib/camera/ . You can find all sensormodule files in /usr/share/modalai/chi-cdk/
              Your log shows that your OV7251 camera has been found in camera slot #2, which is correct because it is connected to M0084 JL .
              JL stands for lower and JU stands for upper camera slot.
              • A
                Aaky @Alex Kushleyev
                @Alex-Kushleyev Thanks for your input.
                I followed your instructions to place "com.qti.sensormodule.irs1645_3.bin" in "/usr/lib/camera/". After this there was slight improvement I guess where voxl-camera-server was able to detect two cameras but still it fails to start TOF camera due to resolution problem. Please help ahead. I have connected JU of M0084 to TOF and JL to tracking camera.
                Logs :
                cam #0
                    isEnabled:           1
                    camId:               0
                    camId2:              -1
                    fps:                 5
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           224
                    pre_height:          1557
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             off
                    standby_enabled:     0
                    decimator:           5
                cam #1
                    sensor type:         ov7251
                    isEnabled:           1
                    camId:               1
                    camId2:              -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             lme_msv
                    standby_enabled:     0
                    decimator:           1
                DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x007A, Sensor Id: 0x003D
                VERBOSE: Entered thread: cam0-request(tid: 2236)
                VERBOSE: Entered thread: cam0-result(tid: 2237)
                VERBOSE: 	Timestamp: 63336924366
                VERBOSE: 	Gain: 799
                VERBOSE: 	Timestamp: 63403592491
                VERBOSE: 	Gain: 799
                VERBOSE: setting hal3 exposure for tracking    24428958   799
                VERBOSE: 	Timestamp: 63437223220
                VERBOSE: 	Gain: 799
                Setup pic :
                Screenshot of /usr/lib/camera:
                • A
                  Aaky @Aaky
                  @Alex-Kushleyev Any update on how to solve this issue?
                    @Aaky , since your ov7251 camera has a lower slot id (2), it was mapped to canera id 0. And TOF was mapped to camera id 1. So you should swap the camera ids in your camera config file and it should work!
                    • A
                      @Alex-Kushleyev Thank you for the input. It works perfectly now. I hope if I plug in M0149 tracking sensor in JL port instead of OV7251 it would also work in similar fashion.
                        @Aaky, yes if you change the camera configuration, just follow the same process:
                        • copy correct sensorbin (with correct slot id) to /usr/lib/camera/ as previously discussed
                        • confirm the camera is detected using voxl-camera-server -l
                        • update camera config xml with correct camera ids - the camera id’s will start with zero and increment by 1 for each camera. The camera id assignment happens in order of the camera slot id. Slot id is mapped to the physical connector.
                        You may want to remove unused sensorbins from /usr/lib/camera just to avoid any confusion. You can always get them back from /usr/share/modalai/chi-cdk
