Tips to increase cable length of Time of flight camera
Hello community,
I am using VOXL2 with latest SDK 1.1.2. In mu UAV, due to size restrictions I want to extend tracking and TOF camera cable lengths atleast near to 20 cms. I am aware of this Y flex cable which can extend both these cameras. Can this cable also be used to extend TOF camera cable length further?Second query, Is this new tracking camera fully compatible and supported on SDK 1.1.2 for QVIO purpose? Any hurdles please let me know.
Hello community,
@Aaky 20cm is starting to push on the maximum length for MIPI. You can use the M0036 extension flex, but at some point it will not work any longer.
Yes, the new M0149 tracking sensor can be used for VIO. You will need to calibrate the intrinsics though
Hello community,
Hi @Aaky
ToF is also a very high current sensor, so using lengths beyond what we support may lead to failure, or severely reduced image quality.
20cms is VERY long for MIPI and most often will fail at those lengths without a re-driver/Re-timer circuit you will need to add in your system.Hope this helps.
Hi @Aaky
@Vinny @Moderator Thanks for the input.
So, Will M0084 support new tracking camera MSU-M0149-1 and TOF camera together in new SDK 1.1.2?
I connected M0084 to J7 over VOXL2, on JU of M0084 I have connected TOF and over JL tracking camera (OV7251) is connected as per your defined configuration over here. But this isn't spawning up TOF camera. Following are the logs with Verbosity enabled on voxl-camera-server.
voxl2:/$ voxl-camera-server -d 0 ================================================================= configuration for 2 cameras: cam #0 name: tof sensor type: pmd-tof isEnabled: 1 camId: 0 camId2: -1 fps: 5 en_rotate: 0 en_rotate2: 0 en_preview: 1 pre_width: 224 pre_height: 1557 en_raw_preview: 1 en_small_video: 0 small_video_width: -1 small_video_height: -1 en_large_video: 0 large_video_width: -1 large_video_height: -1 en_snapshot: 0 snap_width: -1 snap_height: -1 ae_mode: off standby_enabled: 0 decimator: 5 independent_exposure:0 cam #1 name: tracking sensor type: ov7251 isEnabled: 1 camId: 1 camId2: -1 fps: 30 en_rotate: 0 en_rotate2: 0 en_preview: 1 pre_width: 640 pre_height: 480 en_raw_preview: 1 en_small_video: 0 small_video_width: -1 small_video_height: -1 en_large_video: 0 large_video_width: -1 large_video_height: -1 en_snapshot: 0 snap_width: -1 snap_height: -1 ae_mode: lme_msv standby_enabled: 0 decimator: 1 independent_exposure:0 ================================================================= DEBUG: Attempting to open the hal module DEBUG: SUCCESS: Camera module opened on attempt 0 DEBUG: ----------- Number of cameras: 1 DEBUG: Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750 GPS server Connected DEBUG: Connected to cpu-monitor DEBUG: ------ voxl-camera-server: Starting 2 cameras Starting Camera: tof (id #0) DEBUG: Checking Gain limits for Camera: tof Using gain limits min: 54 max: 3451 DEBUG: cam ID 0 checking for fmt: 38 w: 224 h: 1557 o: 0 DEBUG: i: 0 fmt: 34 w: 640 h: 480 o:0 DEBUG: i: 4 fmt: 34 w: 640 h: 480 o:1 DEBUG: i: 8 fmt: 35 w: 640 h: 480 o:0 DEBUG: i: 12 fmt: 35 w: 640 h: 480 o:1 DEBUG: i: 16 fmt: 33 w: 640 h: 480 o:0 DEBUG: i: 20 fmt: 34 w: 640 h: 400 o:0 DEBUG: i: 24 fmt: 34 w: 640 h: 400 o:1 DEBUG: i: 28 fmt: 35 w: 640 h: 400 o:0 DEBUG: i: 32 fmt: 35 w: 640 h: 400 o:1 DEBUG: i: 36 fmt: 33 w: 640 h: 400 o:0 DEBUG: i: 40 fmt: 34 w: 640 h: 360 o:0 DEBUG: i: 44 fmt: 34 w: 640 h: 360 o:1 DEBUG: i: 48 fmt: 35 w: 640 h: 360 o:0 DEBUG: i: 52 fmt: 35 w: 640 h: 360 o:1 DEBUG: i: 56 fmt: 33 w: 640 h: 360 o:0 DEBUG: i: 60 fmt: 34 w: 352 h: 288 o:0 DEBUG: i: 64 fmt: 34 w: 352 h: 288 o:1 DEBUG: i: 68 fmt: 35 w: 352 h: 288 o:0 DEBUG: i: 72 fmt: 35 w: 352 h: 288 o:1 DEBUG: i: 76 fmt: 33 w: 352 h: 288 o:0 DEBUG: i: 80 fmt: 34 w: 320 h: 240 o:0 DEBUG: i: 84 fmt: 34 w: 320 h: 240 o:1 DEBUG: i: 88 fmt: 35 w: 320 h: 240 o:0 DEBUG: i: 92 fmt: 35 w: 320 h: 240 o:1 DEBUG: i: 96 fmt: 33 w: 320 h: 240 o:0 DEBUG: i:100 fmt: 34 w: 240 h: 320 o:0 DEBUG: i:104 fmt: 34 w: 240 h: 320 o:1 DEBUG: i:108 fmt: 35 w: 240 h: 320 o:0 DEBUG: i:112 fmt: 35 w: 240 h: 320 o:1 DEBUG: i:116 fmt: 33 w: 240 h: 320 o:0 DEBUG: i:120 fmt: 34 w: 176 h: 144 o:0 DEBUG: i:124 fmt: 34 w: 176 h: 144 o:1 DEBUG: i:128 fmt: 35 w: 176 h: 144 o:0 DEBUG: i:132 fmt: 35 w: 176 h: 144 o:1 DEBUG: i:136 fmt: 33 w: 176 h: 144 o:0 DEBUG: i:140 fmt: 37 w: 640 h: 480 o:0 DEBUG: i:144 fmt: 38 w: 640 h: 480 o:0 DEBUG: i:148 fmt: 32 w: 640 h: 480 o:0 DEBUG: i:152 fmt: 36 w: 640 h: 480 o:0 ERROR: Camera 0 failed to find supported preview config: 224x1557 WARNING: Failed to start cam tof due to invalid resolution WARNING: assuming cam is missing and trying to compensate Starting Camera: tracking (originally id #1) with id offset: 1 DEBUG: Checking Gain limits for Camera: tracking Using gain limits min: 54 max: 3451 DEBUG: cam ID 0 checking for fmt: 37 w: 640 h: 480 o: 0 DEBUG: i: 0 fmt: 34 w: 640 h: 480 o:0 DEBUG: i: 4 fmt: 34 w: 640 h: 480 o:1 DEBUG: i: 8 fmt: 35 w: 640 h: 480 o:0 DEBUG: i: 12 fmt: 35 w: 640 h: 480 o:1 DEBUG: i: 16 fmt: 33 w: 640 h: 480 o:0 DEBUG: i: 20 fmt: 34 w: 640 h: 400 o:0 DEBUG: i: 24 fmt: 34 w: 640 h: 400 o:1 DEBUG: i: 28 fmt: 35 w: 640 h: 400 o:0 DEBUG: i: 32 fmt: 35 w: 640 h: 400 o:1 DEBUG: i: 36 fmt: 33 w: 640 h: 400 o:0 DEBUG: i: 40 fmt: 34 w: 640 h: 360 o:0 DEBUG: i: 44 fmt: 34 w: 640 h: 360 o:1 DEBUG: i: 48 fmt: 35 w: 640 h: 360 o:0 DEBUG: i: 52 fmt: 35 w: 640 h: 360 o:1 DEBUG: i: 56 fmt: 33 w: 640 h: 360 o:0 DEBUG: i: 60 fmt: 34 w: 352 h: 288 o:0 DEBUG: i: 64 fmt: 34 w: 352 h: 288 o:1 DEBUG: i: 68 fmt: 35 w: 352 h: 288 o:0 DEBUG: i: 72 fmt: 35 w: 352 h: 288 o:1 DEBUG: i: 76 fmt: 33 w: 352 h: 288 o:0 DEBUG: i: 80 fmt: 34 w: 320 h: 240 o:0 DEBUG: i: 84 fmt: 34 w: 320 h: 240 o:1 DEBUG: i: 88 fmt: 35 w: 320 h: 240 o:0 DEBUG: i: 92 fmt: 35 w: 320 h: 240 o:1 DEBUG: i: 96 fmt: 33 w: 320 h: 240 o:0 DEBUG: i:100 fmt: 34 w: 240 h: 320 o:0 DEBUG: i:104 fmt: 34 w: 240 h: 320 o:1 DEBUG: i:108 fmt: 35 w: 240 h: 320 o:0 DEBUG: i:112 fmt: 35 w: 240 h: 320 o:1 DEBUG: i:116 fmt: 33 w: 240 h: 320 o:0 DEBUG: i:120 fmt: 34 w: 176 h: 144 o:0 DEBUG: i:124 fmt: 34 w: 176 h: 144 o:1 DEBUG: i:128 fmt: 35 w: 176 h: 144 o:0 DEBUG: i:132 fmt: 35 w: 176 h: 144 o:1 DEBUG: i:136 fmt: 33 w: 176 h: 144 o:0 DEBUG: i:140 fmt: 37 w: 640 h: 480 o:0 DEBUG: i:144 fmt: 38 w: 640 h: 480 o:0 DEBUG: i:148 fmt: 32 w: 640 h: 480 o:0 DEBUG: i:152 fmt: 36 w: 640 h: 480 o:0 VERBOSE: Successfully found configuration match for camera 0: 640x480 VERBOSE: Adding preview stream for camera: 0 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI VERBOSE: Opened GBM fd gbm_create_device(156): Info: backend name is: msm_drm VERBOSE: Created GBM device DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Successfully set up pipeline for stream: PREVIEW setting ov7251 BLC register for cam id 0 VERBOSE: sid: 0x00E2, addr: 0x4005, data: 0x0002 VERBOSE: sid: 0x00E2, addr: 0x3820, data: 0x0000 VERBOSE: sid: 0x00E2, addr: 0x3821, data: 0x0000 VERBOSE: Entered thread: cam0-request(tid: 2370) VERBOSE: Entered thread: cam0-result(tid: 2371) DEBUG: Started Camera: tracking ------ voxl-camera-server: Started 1 of 2 cameras ------ voxl-camera-server: Camera server is now running VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 0 for camera tracking for 1 streams VERBOSE: Received result from HAl3 for frame number 0 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: finished sending request for frame 0 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 1 for camera tracking for 1 streams VERBOSE: finished sending request for frame 1 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 2 for camera tracking for 1 streams VERBOSE: finished sending request for frame 2 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Received result from HAl3 for frame number 1 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Sending request for frame 3 for camera tracking for 1 streams VERBOSE: Received result from HAl3 for frame number 2 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: finished sending request for frame 3 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 4 for camera tracking for 1 streams VERBOSE: finished sending request for frame 4 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 5 for camera tracking for 1 streams VERBOSE: Received result from HAl3 for frame number 3 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 4 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 0 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 0 from camera tracking VERBOSE: Timestamp: 96792200134 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 0 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 0 from camera tracking VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame DEBUG: setting thread affinity for cam tracking preview VERBOSE: finished sending request for frame 5 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 6 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 6 for camera tracking for 1 streams VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: Received result from HAl3 for frame number 5 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 1 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 1 from camera tracking VERBOSE: Timestamp: 96858901957 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 1 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 1 from camera tracking VERBOSE: finished sending request for frame 6 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 7 for camera tracking VERBOSE: setting hal3 exposure for tracking 24503468 799 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 7 for camera tracking for 1 streams VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame DEBUG: tracking checking to see if it is raw8 or raw 10 DEBUG: Frame was actually 8 bit, sending as is VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: Received result from HAl3 for frame number 6 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 2 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 2 from camera tracking VERBOSE: Timestamp: 96892174613 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 2 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 2 from camera tracking VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: finished sending request for frame 7 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 8 for camera tracking VERBOSE: setting hal3 exposure for tracking 26995516 1634 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 8 for camera tracking for 1 streams VERBOSE: Received result from HAl3 for frame number 7 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 3 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 3 from camera tracking VERBOSE: Timestamp: 96925509613 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 3 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 3 from camera tracking VERBOSE: finished sending request for frame 8 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 9 for camera tracking VERBOSE: setting hal3 exposure for tracking 26995516 1634 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 9 for camera tracking for 1 streams VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: Received result from HAl3 for frame number 8 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 4 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 4 from camera tracking VERBOSE: Timestamp: 96958834926 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 4 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 4 from camera tracking VERBOSE: finished sending request for frame 9 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 10 for camera tracking VERBOSE: setting hal3 exposure for tracking 27581204 1648 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 10 for camera tracking for 1 streams VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: Received result from HAl3 for frame number 9 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 5 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 5 from camera tracking VERBOSE: Timestamp: 96992163051 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 5 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 5 from camera tracking VERBOSE: finished sending request for frame 10 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 11 for camera tracking VERBOSE: setting hal3 exposure for tracking 27892654 1655 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 11 for camera tracking for 1 streams VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: Received result from HAl3 for frame number 10 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 6 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 6 from camera tracking VERBOSE: Timestamp: 97025491696 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 6 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 6 from camera tracking VERBOSE: finished sending request for frame 11 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 12 for camera tracking VERBOSE: setting hal3 exposure for tracking 28544998 1659 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 12 for camera tracking for 1 streams VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: Received result from HAl3 for frame number 11 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 7 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 7 from camera tracking VERBOSE: Timestamp: 97039590700 VERBOSE: Gain: 799 VERBOSE: Exposure: 24503468 VERBOSE: Received result from HAl3 for frame number 7 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 7 from camera tracking VERBOSE: finished sending request for frame 12 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 13 for camera tracking VERBOSE: setting hal3 exposure for tracking 28519818 1667 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 13 for camera tracking for 1 streams VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: Received result from HAl3 for frame number 12 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 8 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 8 from camera tracking VERBOSE: Timestamp: 97070415475 VERBOSE: Gain: 1632 VERBOSE: Exposure: 26995516 VERBOSE: Received result from HAl3 for frame number 8 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 8 from camera tracking VERBOSE: finished sending request for frame 13 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 14 for camera tracking VERBOSE: setting hal3 exposure for tracking 33000000 1666 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 14 for camera tracking for 1 streams VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frameIt seems to be TOF camera resolution problem. But I dont know where exactly to look for to set appropriate resolution since voxl-camera-server.conf dosent have TOF camera resolution mentioned.
Please help on above both queries. -
Please help on above both queries.@Aaky , if you connected TOF to JU of M0084 and M0084 is connected to J7 of VOXL, then TOF will be in camera slot #3. This means that you need to place
com.qti.sensormodule.irs1645_3.bin(note3at the end) in/usr/lib/camera/. You can find allsensormodulefiles in/usr/share/modalai/chi-cdk/Your log shows that your OV7251 camera has been found in camera slot #2, which is correct because it is connected to M0084 JL .
JL stands for
lowerand JU stands foruppercamera slot. -
JL stands for
lowerand JU stands foruppercamera slot.@Alex-Kushleyev Thanks for your input.
I followed your instructions to place "com.qti.sensormodule.irs1645_3.bin" in "/usr/lib/camera/". After this there was slight improvement I guess where voxl-camera-server was able to detect two cameras but still it fails to start TOF camera due to resolution problem. Please help ahead. I have connected JU of M0084 to TOF and JL to tracking camera.Logs :
voxl2:/$ voxl-camera-server -d 0 ================================================================= configuration for 2 cameras: cam #0 name: tof sensor type: pmd-tof isEnabled: 1 camId: 0 camId2: -1 fps: 5 en_rotate: 0 en_rotate2: 0 en_preview: 1 pre_width: 224 pre_height: 1557 en_raw_preview: 1 en_small_video: 0 small_video_width: -1 small_video_height: -1 en_large_video: 0 large_video_width: -1 large_video_height: -1 en_snapshot: 0 snap_width: -1 snap_height: -1 ae_mode: off standby_enabled: 0 decimator: 5 independent_exposure:0 cam #1 name: tracking sensor type: ov7251 isEnabled: 1 camId: 1 camId2: -1 fps: 30 en_rotate: 0 en_rotate2: 0 en_preview: 1 pre_width: 640 pre_height: 480 en_raw_preview: 1 en_small_video: 0 small_video_width: -1 small_video_height: -1 en_large_video: 0 large_video_width: -1 large_video_height: -1 en_snapshot: 0 snap_width: -1 snap_height: -1 ae_mode: lme_msv standby_enabled: 0 decimator: 1 independent_exposure:0 ================================================================= DEBUG: Attempting to open the hal module DEBUG: SUCCESS: Camera module opened on attempt 0 DEBUG: ----------- Number of cameras: 2 DEBUG: Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750 DEBUG: Cam idx: 1, Cam slot: 3, Slave Address: 0x007A, Sensor Id: 0x003D GPS server Connected DEBUG: Connected to cpu-monitor DEBUG: ------ voxl-camera-server: Starting 2 cameras Starting Camera: tof (id #0) DEBUG: Checking Gain limits for Camera: tof Using gain limits min: 54 max: 3451 DEBUG: cam ID 0 checking for fmt: 38 w: 224 h: 1557 o: 0 DEBUG: i: 0 fmt: 34 w: 640 h: 480 o:0 DEBUG: i: 4 fmt: 34 w: 640 h: 480 o:1 DEBUG: i: 8 fmt: 35 w: 640 h: 480 o:0 DEBUG: i: 12 fmt: 35 w: 640 h: 480 o:1 DEBUG: i: 16 fmt: 33 w: 640 h: 480 o:0 DEBUG: i: 20 fmt: 34 w: 640 h: 400 o:0 DEBUG: i: 24 fmt: 34 w: 640 h: 400 o:1 DEBUG: i: 28 fmt: 35 w: 640 h: 400 o:0 DEBUG: i: 32 fmt: 35 w: 640 h: 400 o:1 DEBUG: i: 36 fmt: 33 w: 640 h: 400 o:0 DEBUG: i: 40 fmt: 34 w: 640 h: 360 o:0 DEBUG: i: 44 fmt: 34 w: 640 h: 360 o:1 DEBUG: i: 48 fmt: 35 w: 640 h: 360 o:0 DEBUG: i: 52 fmt: 35 w: 640 h: 360 o:1 DEBUG: i: 56 fmt: 33 w: 640 h: 360 o:0 DEBUG: i: 60 fmt: 34 w: 352 h: 288 o:0 DEBUG: i: 64 fmt: 34 w: 352 h: 288 o:1 DEBUG: i: 68 fmt: 35 w: 352 h: 288 o:0 DEBUG: i: 72 fmt: 35 w: 352 h: 288 o:1 DEBUG: i: 76 fmt: 33 w: 352 h: 288 o:0 DEBUG: i: 80 fmt: 34 w: 320 h: 240 o:0 DEBUG: i: 84 fmt: 34 w: 320 h: 240 o:1 DEBUG: i: 88 fmt: 35 w: 320 h: 240 o:0 DEBUG: i: 92 fmt: 35 w: 320 h: 240 o:1 DEBUG: i: 96 fmt: 33 w: 320 h: 240 o:0 DEBUG: i:100 fmt: 34 w: 240 h: 320 o:0 DEBUG: i:104 fmt: 34 w: 240 h: 320 o:1 DEBUG: i:108 fmt: 35 w: 240 h: 320 o:0 DEBUG: i:112 fmt: 35 w: 240 h: 320 o:1 DEBUG: i:116 fmt: 33 w: 240 h: 320 o:0 DEBUG: i:120 fmt: 34 w: 176 h: 144 o:0 DEBUG: i:124 fmt: 34 w: 176 h: 144 o:1 DEBUG: i:128 fmt: 35 w: 176 h: 144 o:0 DEBUG: i:132 fmt: 35 w: 176 h: 144 o:1 DEBUG: i:136 fmt: 33 w: 176 h: 144 o:0 DEBUG: i:140 fmt: 37 w: 640 h: 480 o:0 DEBUG: i:144 fmt: 38 w: 640 h: 480 o:0 DEBUG: i:148 fmt: 32 w: 640 h: 480 o:0 DEBUG: i:152 fmt: 36 w: 640 h: 480 o:0 ERROR: Camera 0 failed to find supported preview config: 224x1557 WARNING: Failed to start cam tof due to invalid resolution WARNING: assuming cam is missing and trying to compensate Starting Camera: tracking (originally id #1) with id offset: 1 DEBUG: Checking Gain limits for Camera: tracking Using gain limits min: 54 max: 3451 DEBUG: cam ID 0 checking for fmt: 37 w: 640 h: 480 o: 0 DEBUG: i: 0 fmt: 34 w: 640 h: 480 o:0 DEBUG: i: 4 fmt: 34 w: 640 h: 480 o:1 DEBUG: i: 8 fmt: 35 w: 640 h: 480 o:0 DEBUG: i: 12 fmt: 35 w: 640 h: 480 o:1 DEBUG: i: 16 fmt: 33 w: 640 h: 480 o:0 DEBUG: i: 20 fmt: 34 w: 640 h: 400 o:0 DEBUG: i: 24 fmt: 34 w: 640 h: 400 o:1 DEBUG: i: 28 fmt: 35 w: 640 h: 400 o:0 DEBUG: i: 32 fmt: 35 w: 640 h: 400 o:1 DEBUG: i: 36 fmt: 33 w: 640 h: 400 o:0 DEBUG: i: 40 fmt: 34 w: 640 h: 360 o:0 DEBUG: i: 44 fmt: 34 w: 640 h: 360 o:1 DEBUG: i: 48 fmt: 35 w: 640 h: 360 o:0 DEBUG: i: 52 fmt: 35 w: 640 h: 360 o:1 DEBUG: i: 56 fmt: 33 w: 640 h: 360 o:0 DEBUG: i: 60 fmt: 34 w: 352 h: 288 o:0 DEBUG: i: 64 fmt: 34 w: 352 h: 288 o:1 DEBUG: i: 68 fmt: 35 w: 352 h: 288 o:0 DEBUG: i: 72 fmt: 35 w: 352 h: 288 o:1 DEBUG: i: 76 fmt: 33 w: 352 h: 288 o:0 DEBUG: i: 80 fmt: 34 w: 320 h: 240 o:0 DEBUG: i: 84 fmt: 34 w: 320 h: 240 o:1 DEBUG: i: 88 fmt: 35 w: 320 h: 240 o:0 DEBUG: i: 92 fmt: 35 w: 320 h: 240 o:1 DEBUG: i: 96 fmt: 33 w: 320 h: 240 o:0 DEBUG: i:100 fmt: 34 w: 240 h: 320 o:0 DEBUG: i:104 fmt: 34 w: 240 h: 320 o:1 DEBUG: i:108 fmt: 35 w: 240 h: 320 o:0 DEBUG: i:112 fmt: 35 w: 240 h: 320 o:1 DEBUG: i:116 fmt: 33 w: 240 h: 320 o:0 DEBUG: i:120 fmt: 34 w: 176 h: 144 o:0 DEBUG: i:124 fmt: 34 w: 176 h: 144 o:1 DEBUG: i:128 fmt: 35 w: 176 h: 144 o:0 DEBUG: i:132 fmt: 35 w: 176 h: 144 o:1 DEBUG: i:136 fmt: 33 w: 176 h: 144 o:0 DEBUG: i:140 fmt: 37 w: 640 h: 480 o:0 DEBUG: i:144 fmt: 38 w: 640 h: 480 o:0 DEBUG: i:148 fmt: 32 w: 640 h: 480 o:0 DEBUG: i:152 fmt: 36 w: 640 h: 480 o:0 VERBOSE: Successfully found configuration match for camera 0: 640x480 VERBOSE: Adding preview stream for camera: 0 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI VERBOSE: Opened GBM fd gbm_create_device(156): Info: backend name is: msm_drm VERBOSE: Created GBM device DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000 VERBOSE: Dumping GBM flags DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI DEBUG: Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10 DEBUG: Successfully set up pipeline for stream: PREVIEW setting ov7251 BLC register for cam id 0 VERBOSE: sid: 0x00E2, addr: 0x4005, data: 0x0002 VERBOSE: sid: 0x00E2, addr: 0x3820, data: 0x0000 VERBOSE: sid: 0x00E2, addr: 0x3821, data: 0x0000 VERBOSE: Entered thread: cam0-request(tid: 2236) VERBOSE: Entered thread: cam0-result(tid: 2237) DEBUG: Started Camera: tracking ------ voxl-camera-server: Started 1 of 2 cameras ------ voxl-camera-server: Camera server is now running VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 0 for camera tracking for 1 streams VERBOSE: Received result from HAl3 for frame number 0 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: finished sending request for frame 0 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 1 for camera tracking for 1 streams VERBOSE: finished sending request for frame 1 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 2 for camera tracking for 1 streams VERBOSE: finished sending request for frame 2 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 3 for camera tracking for 1 streams VERBOSE: Received result from HAl3 for frame number 1 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 2 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: finished sending request for frame 3 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 4 for camera tracking for 1 streams VERBOSE: finished sending request for frame 4 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 5 for camera tracking for 1 streams VERBOSE: Received result from HAl3 for frame number 3 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 4 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 0 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 0 from camera tracking VERBOSE: Timestamp: 63336924366 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 0 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 0 from camera tracking VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame DEBUG: setting thread affinity for cam tracking preview VERBOSE: finished sending request for frame 5 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 6 for camera tracking VERBOSE: setting hal3 exposure for tracking 5259763 800 VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: added request for preview stream VERBOSE: Sending request for frame 6 for camera tracking for 1 streams VERBOSE: Received result from HAl3 for frame number 5 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 1 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 1 from camera tracking VERBOSE: Timestamp: 63403592491 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 1 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 1 from camera tracking VERBOSE: finished sending request for frame 6 for camera tracking VERBOSE: returning from SendOneCaptureRequest for frame 7 for camera tracking VERBOSE: setting hal3 exposure for tracking 24428958 799 VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frame DEBUG: tracking checking to see if it is raw8 or raw 10 VERBOSE: added request for preview stream VERBOSE: Sending request for frame 7 for camera tracking for 1 streams DEBUG: Frame was actually 8 bit, sending as is VERBOSE: publishing raw preview frame for mono camera tracking VERBOSE: Received result from HAl3 for frame number 6 VERBOSE: Received 0 buffers from camera tracking, partial result:1 VERBOSE: Received result from HAl3 for frame number 2 VERBOSE: Received 0 buffers from camera tracking, partial result:2 VERBOSE: Received metadata for frame 2 from camera tracking VERBOSE: Timestamp: 63437223220 VERBOSE: Gain: 799 VERBOSE: Exposure: 5259763 VERBOSE: Received result from HAl3 for frame number 2 VERBOSE: Received 1 buffers from camera tracking, partial result:0 VERBOSE: Received output buffer 2 from camera tracking VERBOSE: tracking procesing new buffer VERBOSE: Camera: tracking processing preview frameSetup pic :
Screenshot of /usr/lib/camera:
@Alex-Kushleyev Any update on how to solve this issue?
@Aaky , since your ov7251 camera has a lower slot id (2), it was mapped to canera id 0. And TOF was mapped to camera id 1. So you should swap the camera ids in your camera config file and it should work!
@Alex-Kushleyev Thank you for the input. It works perfectly now. I hope if I plug in M0149 tracking sensor in JL port instead of OV7251 it would also work in similar fashion.
@Aaky, yes if you change the camera configuration, just follow the same process:
- copy correct sensorbin (with correct slot id) to /usr/lib/camera/ as previously discussed
- confirm the camera is detected using voxl-camera-server -l
- update camera config xml with correct camera ids - the camera id’s will start with zero and increment by 1 for each camera. The camera id assignment happens in order of the camera slot id. Slot id is mapped to the physical connector.
You may want to remove unused sensorbins from /usr/lib/camera just to avoid any confusion. You can always get them back from /usr/share/modalai/chi-cdk
