  2. VOXL Dev Drones
  3. Starling & Starling 2
  4. Starling drone, nothing shows up in voxl-suite upon checking for version of sdk
12 Posts 3 Posters 1.9k Views 2 Watching
  • Darshit DesaiD Offline
    Darshit Desai
    Title describes the problem, I noticed this when I was following instructions of upgrading the sdk, the starling was bought back in Nov 23 and since then no sdk update has happened on it, this is the first time I have noticed it, is it safe to install the sdk using the process mentioned here (https://docs.modalai.com/flash-system-image/), knowing now that it didn't have any in the first place
      Darshit Desai
      I have tried to upgrade the sdk with one of the nightly builds which was suggested by @thomas for updating buggy tflite server, but it shows an error of px4 parameter update at the end, I have attached the terminal history of the sdk upgrade in the drive link below,
      Page Not Found
      Web word processing, presentations and spreadsheets
      favicon
      (drive.google.com)
        Page Not Found
        favicon
        (drive.google.com)
        Darshit Desai
        I was able to recover my drone by after falling back and installing sdk 1.0 in the starling but as mentioned in the issue here I need to install the nightly build to get the tflite server working, is there some way without wrecking the starling functionality?
        Link Preview Image
        Can anyone recommend a Tflite Colab Notebook for VOXL2 Training
        @sansoy Here's the one from last night: https://console.cloud.google.com/storage/browser/_details/platform-nightlies/voxl2/voxl2_SDK_nightly_20240117.tar.gz?...
        favicon
        ModalAI Forum (forum.modalai.com)
        ModeratorM 1 Reply Last reply
          Link Preview Image
          favicon
          @Darshit-Desai update the full platform to the latest SDK, then just update the tflite server from dev.
          Darshit DesaiD 2 Replies Last reply
          • ModeratorM Moderator
            Darshit Desai
            @Moderator Hi I was able to update the sdk yesterday till version 1.1.2, Can you tell me the method of just updating the tflite-server with the changes that @thomas did?
              Darshit Desai
              @Moderator do I need to use voxl-cross to build the modified tflite server? Is voxl-cross supposed to be installed on my desktop or the drone and at the end when I get the ipk file how do I install it?
              ? 1 Reply Last reply
                @Darshit-Desai
                Glad you were able to install SDK 1.1.2. However my voxl-tflite-server fixes aren't on that SDK release, they're only present in the nightlies which you can find here. voxl-tflite-server does come installed by default and you can run it by just calling voxl-tflite-server from within ADB.
                Hope this helps!
                Thomas Patton
                  Darshit Desai
                  @Moderator said in Starling drone, nothing shows up in voxl-suite upon checking for version of sdk:
                  @thomas Actually I wanted to know what does this mean? Does it mean specifically building the voxl-tflite-server and then upgrading only that component? Since I cannot use the nightly build because of the px4 params error which keeps on coming up as described here https://forum.modalai.com/post/14348
                  Specifically this version of the sdk which was uploaded in another thread and said to contain the tflite changes, this has bugs which cause the sdk update to fail yesterday:
                  https://console.cloud.google.com/storage/browser/_details/platform-nightlies/voxl2/voxl2_SDK_nightly_20240117.tar.gz;tab=live_object?pageState=("StorageObjectListTable":("s":[("i":"objectListDisplayFields%2FtimeLastModified","s":"1"),(%22i%22:%22displayName%22,%22s%22:%220%22
                    @Darshit-Desai
                    So yes, if you install the nightly you're saying you'll still get your PX4 error, I see. In that case, you're going to need to build voxl-tflite-server from source. The instructions for that are:
                    • Clone the repo onto your local machine, the source code is here. Make sure to check out the dev branch so you can get my most recent changes with fixes.
                    • Set up voxl-cross and voxl-docker on your machine. We have a nice docs page for how to do that here. Most important will be the ability to spin up the voxl-cross image using Docker.
                    • Spin up the voxl-cross image in Docker. Make sure to do so either from the voxl-tflite-server directory or a directory that contains it.
                    • cd into voxl-tflite-server and then run ./install_build_deps qrb5165 staging && ./build.sh qrb5165 && ./make_package. This will build the most recent .deb file for voxl-tflite-server.
                    • Now inside of your local machine (not voxl-cross) with your drone powered on and connected via usb, run the ./deploy_to_voxl script to deploy the updated debian
                    Now you'll have the latest .deb for voxl-tflite-server with the changes!
                    Hope this helps,
                    Thomas Patton
                    • ? A Former User
                      @Darshit-Desai
                      Hope this helps,
                      Thomas Patton
                      Darshit Desai
                      @thomas I wanted to ask about the instructions, it makes me uninstall/remove docker.io and other things but I have in my desktop pc docker containers. Will that be affected?
                      990781d7-99ad-4e25-9bf6-1486dd9f5255-Screenshot from 2024-01-29 15-31-13.png file:///home/swarm_researchers/Pictures/Screenshots/Screenshot%20from%202024-01-29%2015-31-13.png
                        @Darshit-Desai
                        Those instructions seem outdated, follow the ones on the official Docker page here.
                        Thomas
                        • ? A Former User
                          @Darshit-Desai
                          Thomas
                          Darshit Desai
                          @thomas Thank you the update procedure worked and the results I posted in this thread
                          Link Preview Image
                          favicon
