Starling drone, nothing shows up in voxl-suite upon checking for version of sdk
Title describes the problem, I noticed this when I was following instructions of upgrading the sdk, the starling was bought back in Nov 23 and since then no sdk update has happened on it, this is the first time I have noticed it, is it safe to install the sdk using the process mentioned here (https://docs.modalai.com/flash-system-image/), knowing now that it didn't have any in the first place
I have tried to upgrade the sdk with one of the nightly builds which was suggested by @thomas for updating buggy tflite server, but it shows an error of px4 parameter update at the end, I have attached the terminal history of the sdk upgrade in the drive link below,
Page Not Found
Web word processing, presentations and spreadsheets
(drive.google.com)
Page Not Found
(drive.google.com)
I was able to recover my drone by after falling back and installing sdk 1.0 in the starling but as mentioned in the issue here I need to install the nightly build to get the tflite server working, is there some way without wrecking the starling functionality?
Can anyone recommend a Tflite Colab Notebook for VOXL2 Training
@sansoy Here's the one from last night: https://console.cloud.google.com/storage/browser/_details/platform-nightlies/voxl2/voxl2_SDK_nightly_20240117.tar.gz?...
ModalAI Forum (forum.modalai.com)
@Darshit-Desai update the full platform to the latest SDK, then just update the tflite server from dev.
@Moderator Hi I was able to update the sdk yesterday till version 1.1.2, Can you tell me the method of just updating the tflite-server with the changes that @thomas did?
@Moderator do I need to use voxl-cross to build the modified tflite server? Is voxl-cross supposed to be installed on my desktop or the drone and at the end when I get the ipk file how do I install it?
Glad you were able to install SDK 1.1.2. However my
voxl-tflite-serverfixes aren't on that SDK release, they're only present in the nightlies which you can find here.voxl-tflite-serverdoes come installed by default and you can run it by just callingvoxl-tflite-serverfrom within ADB.Hope this helps!
Thomas Patton
@Moderator said in Starling drone, nothing shows up in voxl-suite upon checking for version of sdk:
@thomas Actually I wanted to know what does this mean? Does it mean specifically building the voxl-tflite-server and then upgrading only that component? Since I cannot use the nightly build because of the px4 params error which keeps on coming up as described here https://forum.modalai.com/post/14348
Specifically this version of the sdk which was uploaded in another thread and said to contain the tflite changes, this has bugs which cause the sdk update to fail yesterday:
https://console.cloud.google.com/storage/browser/_details/platform-nightlies/voxl2/voxl2_SDK_nightly_20240117.tar.gz;tab=live_object?pageState=("StorageObjectListTable":("s":[("i":"objectListDisplayFields%2FtimeLastModified","s":"1"),(%22i%22:%22displayName%22,%22s%22:%220%22 -
https://console.cloud.google.com/storage/browser/_details/platform-nightlies/voxl2/voxl2_SDK_nightly_20240117.tar.gz;tab=live_object?pageState=("StorageObjectListTable":("s":[("i":"objectListDisplayFields%2FtimeLastModified","s":"1"),(%22i%22:%22displayName%22,%22s%22:%220%22So yes, if you install the nightly you're saying you'll still get your PX4 error, I see. In that case, you're going to need to build
voxl-tflite-serverfrom source. The instructions for that are:- Clone the repo onto your local machine, the source code is here. Make sure to check out the
devbranch so you can get my most recent changes with fixes. - Set up
voxl-crossandvoxl-dockeron your machine. We have a nice docs page for how to do that here. Most important will be the ability to spin up thevoxl-crossimage using Docker. - Spin up the
voxl-crossimage in Docker. Make sure to do so either from thevoxl-tflite-serverdirectory or a directory that contains it. cdintovoxl-tflite-serverand then run./install_build_deps qrb5165 staging && ./build.sh qrb5165 && ./make_package. This will build the most recent.debfile forvoxl-tflite-server.- Now inside of your local machine (not
voxl-cross) with your drone powered on and connected via usb, run the./deploy_to_voxlscript to deploy the updated debian
Now you'll have the latest
.debforvoxl-tflite-serverwith the changes!Hope this helps,
Thomas Patton
Thomas Patton
@thomas I wanted to ask about the instructions, it makes me uninstall/remove docker.io and other things but I have in my desktop pc docker containers. Will that be affected?
file:///home/swarm_researchers/Pictures/Screenshots/Screenshot%20from%202024-01-29%2015-31-13.png - Clone the repo onto your local machine, the source code is here. Make sure to check out the
file:///home/swarm_researchers/Pictures/Screenshots/Screenshot%20from%202024-01-29%2015-31-13.pngThose instructions seem outdated, follow the ones on the official Docker page here.
Thomas
Thomas
@thomas Thank you the update procedure worked and the results I posted in this thread
