    Problem contacting ESC
    1469
    • Riccardo FranceschiniR
      Hi we are trying to configure the flight deck voxl2 board with the sdk 1.1.1 recently flashed.
      We are encountering problems detecting the ESC in particular while running
      voxl-esc
      with the option 1 (scan), the output is the following
      VOXL Platform: M0054
      terminate called after throwing an instance of 'qmi_error'
        what():  qmi_client_send_msg_sync() failed, (client_id=)0, result=0: qmi service error (-2)
      /usr/bin/voxl-esc: line 133:  4321 Aborted                 python3 voxl-esc-scan.py
      FAILED to ping ESCs
      disabling bridge
      bridge disabled
      DONE
      while running the option detect (2)
      enabling bridge
      bridge enabled
      Couldn't configure flight_controller sensor
      ERROR:   fc_sensor_initialize failed
      ERROR:   Failed to initialize slpi
      ERROR:   Encountered error while initializing bus 12
      ERROR:   voxl_uart_flush: Bus '12' is not initialized
      ERROR:   voxl_uart_read_bytes: Bus '12' is not initialized
      ERROR:   voxl_uart_write: Bus '12' is not initialized
      ERROR:   voxl_uart_close: Bus '12' is not initialized
      Do you have any idea of why we are encountering this error?
      • E
        ejohnson01
        I'm not 100% that this is your issue, but I think I have seen this when voxl-px4 is running in the background. Make sure to run systemctl stop voxl-px4 before running voxl-esc
        • S
          smilon
          I am facing a similar-natured issue after upgrading to SDK 1.1.2. While everything from voxl-esc tool works fine in my case (scan, spin). I am getting px4 warnings that arming is denied and failsafe triggered when I try to arm. Then when I run:
          ./voxl-esc-verify-params.py
          ./voxl-esc-scan.py
          ./voxl-esc-calibrate.py
          etc.
          I get:
          [GCC 8.4.0]
          • S smilon referenced this topic on
            Alex Kushleyev ModalAI Team @Riccardo Franceschini
            @Riccardo-Franceschini , can you please try to manually stop px4 before running any ESC scripts and let us know if the issue persists. If PX4 is running, it will interfere with proper operation of voxl-esc tools because they may be trying to use the same UART port.
            Riccardo FranceschiniR 1 Reply Last reply Reply Quote 0
              Riccardo Franceschini @Alex Kushleyev
              Hi, the voxl-px4 was not affecting the problem. It seems to be solved by performing a new factory reset, as explained here. However, we have now lost the calibration files. How can those be retrieved? We encountered a similar problem on two boards with serials M2100000J2R and M22000003EV.
                @Riccardo-Franceschini , can you please clarify which calibration files you need?
                  @Alex-Kushleyev sure are those :
                  Calibration File Status:
                  Missing /data/modalai/voxl-imu-server.cal
                  Missing /data/modalai/opencv_tracking_intrinsics.yml
                  Missing /data/modalai/opencv_stereo_front_intrinsics.yml
                  Missing /data/modalai/opencv_stereo_front_extrinsics.yml
                  Missing /data/modalai/opencv_stereo_rear_intrinsics.yml
                  Missing /data/modalai/opencv_stereo_rear_extrinsics.yml
                  Missing /data/px4/param/parameters_gyro.cal
                  Missing /data/px4/param/parameters_acc.cal
                  Missing /data/px4/param/parameters_level.cal
                  Missing /data/px4/param/parameters_mag.ca
                  The camera ones and the IMU I can recover them by using the calibration tools but I haven't found a solution for the px4 ones
                    Eric Katzfey ModalAI Team @Riccardo Franceschini
                    @Riccardo-Franceschini Can you just do the PX4 sensor calibrations to get new files? They only take a couple of minutes.
                      Riccardo Franceschini @Eric Katzfey
                      Hi Eric, I tried using QGroundControl. The accelerometer and gyro have been successfully calibrated, but I encountered an error stating "no mags" when attempting to calibrate the compass and then nothing happen. Do you have any ideas about what could be causing this issue?
                        @Riccardo-Franceschini Can you provide some more details about your system? For example, what kind of magnetometer do you have?
                          Hi @Eric-Katzfey eventually we managed to solve the problem by resetting to default the parameter of px4 and performing the calibration from qgc
