  3. voxl-dfs-server stack smashing
2 Posts 2 Posters 712 Views
  • Taylor PresleyT Offline
    Taylor Presley
    Hey guys,
    I've recently been having trouble with the voxl-dfs-server. I'm running voxl-suite 1.0 on Sentinel. I've recalibrated the stereo cameras and enabled the server, but it isn't running. When I try to run I get a "stack smashing" error. Has anyone else encountered this issue? Any recommendations to fix? Code is below, all inputs are appreciated!
    system-image: 1.6.2-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:
    current IP: wlan0: 192.168.8.1
    Scanning services...
     modallink-relink     | Disabled  | Not Running |
     voxl-camera-server   |  Enabled  |   Running   |    71.8%
     voxl-cpu-monitor     |  Enabled  |   Running   |     0.5%
     voxl-dfs-server      |  Enabled  | Not Running |
     voxl-imu-server      |  Enabled  |   Running   |     5.3%
     voxl-lepton-server   | Disabled  | Not Running |
     voxl-mavcam-manager  |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server  |  Enabled  |   Running   |     2.5%
     voxl-portal          |  Enabled  |   Running   |     0.2%
     voxl-px4-imu-server  | Disabled  | Not Running |
     voxl-px4             |  Enabled  |   Running   |    33.0%
     voxl-qvio-server     |  Enabled  |   Running   |    37.6%
     voxl-remote-id       | Disabled  | Not Running |
     voxl-softap          |  Enabled  |  Completed  |
     voxl-static-ip       | Disabled  | Not Running |
     voxl-streamer        |  Enabled  |   Running   |     0.0%
     voxl-tag-detector    |  Enabled  |   Running   |    18.5%
     voxl-tflite-server   |  Enabled  |   Running   |     0.9%
     voxl-uvc-server      | Disabled  | Not Running |
     voxl-vision-hub      |  Enabled  |   Running   |     2.3%
    voxl2:/$ voxl-configure-dfs-server
    bash: voxl-configure-dfs-server: command not found
    voxl2:/$ voxl-configure-dfs-server enable
    voxl2:/$ systemctl enable voxl-dfs-server
    voxl2:/$
    voxl2:/$ voxl-dfs-server
    min_disparity:   4
    max_disparity:   64
    min_threshold:   10
    cost_threshold:  10
    width:           640
    height:          480
    pc_skip_n_lines: 4
    dfs pair #0
        enable:             1
        input_pipe:         stereo_front
        skip_n_frames:      1
        blur_size:          0
        post_median_size:   0
        intrinsics_file:    /data/modalai/opencv_stereo_front_intrinsics.yml
        extrinsics_file:    /data/modalai/opencv_stereo_front_extrinsics.yml
    dfs pair #1
        enable:             1
        input_pipe:         stereo_rear
        skip_n_frames:      1
        blur_size:          0
        post_median_size:   0
        intrinsics_file:    /data/modalai/opencv_stereo_rear_intrinsics.yml
        extrinsics_file:    /data/modalai/opencv_stereo_rear_extrinsics.yml
    loading calibration files
    for Pair #0, loaded these lens params:
    f:  476.498688
    cx: 337.858215
    cy: 244.905640
    baseline_m: 0.080362
    for Pair #1, loaded these lens params:
    f:  501.284851
    cx: 323.020020
    cy: 223.681076
    baseline_m: 0.079995
    initializing dfs module
    opening cameras paused
    client voxl-vision-hub0 connected to ch 2
    client voxl-vision-hub0 connected to ch 5
    connected to pipe stereo_front
    connected to pipe stereo_rear
    *** stack smashing detected ***: <unknown> terminated
    Aborted
    ModeratorM 1 Reply Last reply
    • Taylor PresleyT Taylor Presley
      Hey guys,
      hw version:   M0054
      voxl-suite:
      voxl2:/$
      min_disparity:   4
      max_disparity:   64
      min_threshold:   10
      cost_threshold:  10
      width:           640
      height:          480
      pc_skip_n_lines: 4
      dfs pair #0
          enable:             1
          skip_n_frames:      1
          blur_size:          0
          post_median_size:   0
      dfs pair #1
          enable:             1
          skip_n_frames:      1
          blur_size:          0
          post_median_size:   0
      f:  476.498688
      cx: 337.858215
      cy: 244.905640
      f:  501.284851
      cx: 323.020020
      cy: 223.681076
      Aborted
      @Taylor-Presley Please upgrade to the latest SDK, it should be resolved
