<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[voxl-dfs-server stack smashing]]></title><description><![CDATA[<p dir="auto">Hey guys,</p>
<p dir="auto">I've recently been having trouble with the voxl-dfs-server. I'm running voxl-suite 1.0 on Sentinel. I've recalibrated the stereo cameras and enabled the server, but it isn't running. When I try to run I get a "stack smashing" error. Has anyone else encountered this issue? Any recommendations to fix? Code is below, all inputs are appreciated!</p>
<pre><code>                                                         ▂▂▂▂▂▂▂▂▂▂▂▂▂
system-image: 1.6.2-M0054-14.1a-perf
kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
hw version:   M0054
voxl-suite:
current IP: wlan0: 192.168.8.1
voxl2:/$ voxl-inspect-services
Scanning services...
 docker-autorun       | Disabled  | Not Running |
 docker-daemon        | Disabled  | Not Running |
 voxl-camera-server   |  Enabled  |   Running   |    71.8%
 voxl-cpu-monitor     |  Enabled  |   Running   |     0.5%
 voxl-dfs-server      |  Enabled  | Not Running |
 voxl-imu-server      |  Enabled  |   Running   |     5.3%
 voxl-lepton-server   | Disabled  | Not Running |
 voxl-mavcam-manager  |  Enabled  |   Running   |     0.0%
 voxl-mavlink-server  |  Enabled  |   Running   |     2.5%
 voxl-portal          |  Enabled  |   Running   |     0.2%
 voxl-px4-imu-server  | Disabled  | Not Running |
 voxl-px4             |  Enabled  |   Running   |    33.0%
 voxl-qvio-server     |  Enabled  |   Running   |    37.6%
 voxl-remote-id       | Disabled  | Not Running |
 voxl-softap          |  Enabled  |  Completed  |
 voxl-static-ip       | Disabled  | Not Running |
 voxl-streamer        |  Enabled  |   Running   |     0.0%
 voxl-tag-detector    |  Enabled  |   Running   |    18.5%
 voxl-tflite-server   |  Enabled  |   Running   |     0.9%
 voxl-uvc-server      | Disabled  | Not Running |
 voxl-vision-hub      |  Enabled  |   Running   |     2.3%
voxl2:/$ voxl-configure-dfs-server
bash: voxl-configure-dfs-server: command not found
voxl2:/$ voxl-configure-dfs-server enable
voxl2:/$ systemctl enable voxl-dfs-server
voxl2:/$
voxl2:/$ voxl-dfs-server
min_disparity:   4
max_disparity:   64
min_threshold:   10
cost_threshold:  10
width:           640
height:          480
pc_skip_n_lines: 4
dfs pair #0
    enable:             1
    input_pipe:         stereo_front
    skip_n_frames:      1
    blur_size:          0
    post_median_size:   0
    intrinsics_file:    /data/modalai/opencv_stereo_front_intrinsics.yml
    extrinsics_file:    /data/modalai/opencv_stereo_front_extrinsics.yml
dfs pair #1
    enable:             1
    input_pipe:         stereo_rear
    skip_n_frames:      1
    blur_size:          0
    post_median_size:   0
    intrinsics_file:    /data/modalai/opencv_stereo_rear_intrinsics.yml
    extrinsics_file:    /data/modalai/opencv_stereo_rear_extrinsics.yml
loading calibration files
for Pair #0, loaded these lens params:
f:  476.498688
cx: 337.858215
cy: 244.905640
baseline_m: 0.080362
for Pair #1, loaded these lens params:
f:  501.284851
cx: 323.020020
cy: 223.681076
baseline_m: 0.079995
initializing dfs module
opening cameras paused
client voxl-vision-hub0 connected to ch 2
client voxl-vision-hub0 connected to ch 5
connected to pipe stereo_front
connected to pipe stereo_rear
*** stack smashing detected ***: &lt;unknown&gt; terminated
Aborted
]]></description><link>https://forum.modalai.com/topic/2963/voxl-dfs-server-stack-smashing</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 01:32:31 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2963.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Dec 2023 04:46:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to voxl-dfs-server stack smashing on Mon, 18 Dec 2023 00:28:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/taylor-presley" aria-label="Profile: Taylor-Presley">@<bdi>Taylor-Presley</bdi></a> Please upgrade to the latest SDK, it should be resolved</p>
]]></description><link>https://forum.modalai.com/post/13634</link><guid isPermaLink="true">https://forum.modalai.com/post/13634</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Mon, 18 Dec 2023 00:28:09 GMT</pubDate></item></channel></rss>
