  3. Sentinel (VOXL2) not connecting via ADB and not able to boot
16 Posts 2 Posters 2.9k Views 1 Watching
  • J Offline
    J Offline
    JoshRebello
    wrote on last edited by JoshRebello
    Hello Team,
    I'd like assistance with my Sentinel issue, I'm facing the exact same problems as the one in this post - https://forum.modalai.com/topic/2131/sentinel-voxl2-not-booting-not-flashing?_=1700502794310
    I've tried everything suggested in that post, to the dot by the developer team. But I'm facing the exact same issues as outlined there, the only difference being they had the issue immediate next day. I was using my Sentinel drone a few months back and everything worked fine, I was caught up with another project at work and couldn't use it for a few months and now that I'm trying to start it up again, I'm facing this issue where I cannot connect via the adb shell.
    Just wanted to know how this was resolved? Want to avoid the RMA if possible as it will be difficult for us.
    Everything suggested so far in this post has been attempted, still facing the issue. Also the errors are exactly similar to what @Andre-Moura faced in that post. Only using batteries provided by ModalAI as well, tried different cables and computers.
    Hoping to hear from you.
    Kind regards,
    Joshua Rebello.
    • J JoshRebello
      Hello Team,
      Kind regards,
      Joshua Rebello.
      @JoshRebello Copying my response from the other thread. If you run lsusb or sudo dmesg -wH on your host PC do you see the device enumerating when plugged in?
      J 1 Reply Last reply
        J Offline
        J Offline
        JoshRebello
        @tom Nope, I don't see the VOXL2 SN or anything.
        Bus 004 Device 004: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode)
        This is what I get, exactly the same as in the other post.
        • J JoshRebello
          @JoshRebello That's what I meant, it is enumerating but just in QDL mode. You say you already went through the QDL flash is that correct?
          Did you turn the switch back off after QDL was complete?
            J Offline
            J Offline
            JoshRebello
            @tom Oh apologies, my bad. Yes, it is enumerating but just in QDL mode.
            Yes, i tried going through the QDL flash, but got errors - the flash didn't complete. GOt the same errors as posted in the post I've linked up.
            And yes, after trying the QDL flash, I turned the switch back off but the QDL flash did not complete for me.
            • J JoshRebello
              @JoshRebello How did you install qdl?
                J Offline
                J Offline
                JoshRebello
                @tom I couldn't I tried, it was one of the suggestions mentioned if my adb wouldn't connect so I gave it a try.
                I tested 'force fastboot', since that did not work, I followed the VOXL 2 QDL Guide to try and flash the VOXL2 QDL Image 14.1a_1.1.2. What I got was:
                andre@andre:~/1.1.2-M0054-14.1a-FLAT-V3/ufs$ sudo qdl --debug --storage ufs --include . prog_firehose_ddr.elf rawprogram_unsparse0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml patch0.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml
                Waiting for EDL device
                HELLO version: 0x2 compatible: 0x1 max_len: 1024 mode: 0
                READ64 image: 13 offset: 0x0 length: 0x40
                READ64 image: 13 offset: 0x40 length: 0x310
                READ64 image: 13 offset: 0x1000 length: 0x1000
                READ64 image: 13 offset: 0x2000 length: 0xc48
                READ64 image: 13 offset: 0x3000 length: 0x1000
                READ64 image: 13 offset: 0x4000 length: 0x1000
                READ64 image: 13 offset: 0x5000 length: 0x1000
                READ64 image: 13 offset: 0x6000 length: 0x1000
                READ64 image: 13 offset: 0x7000 length: 0x1000
                READ64 image: 13 offset: 0x8000 length: 0x1000
                READ64 image: 13 offset: 0x9000 length: 0x1000
                READ64 image: 13 offset: 0xa000 length: 0x1000
                READ64 image: 13 offset: 0xb000 length: 0x1000
                READ64 image: 13 offset: 0xc000 length: 0x1000
                READ64 image: 13 offset: 0xd000 length: 0x1000
                READ64 image: 13 offset: 0xe000 length: 0x1000
                READ64 image: 13 offset: 0xf000 length: 0x1000
                READ64 image: 13 offset: 0x10000 length: 0x1000
                READ64 image: 13 offset: 0x11000 length: 0x1000
                READ64 image: 13 offset: 0x12000 length: 0x1000
                READ64 image: 13 offset: 0x13000 length: 0x1000
                READ64 image: 13 offset: 0x14000 length: 0x1000
                READ64 image: 13 offset: 0x15000 length: 0x1000
                READ64 image: 13 offset: 0x16000 length: 0x1000
                READ64 image: 13 offset: 0x17000 length: 0x1000
                READ64 image: 13 offset: 0x18000 length: 0x1000
                READ64 image: 13 offset: 0x19000 length: 0x1000
                READ64 image: 13 offset: 0x1a000 length: 0x1000
                READ64 image: 13 offset: 0x1b000 length: 0x1000
                READ64 image: 13 offset: 0x1c000 length: 0x1000
                READ64 image: 13 offset: 0x1d000 length: 0x1000
                READ64 image: 13 offset: 0x1e000 length: 0x1000
                READ64 image: 13 offset: 0x1f000 length: 0x1000
                READ64 image: 13 offset: 0x20000 length: 0x1000
                READ64 image: 13 offset: 0x21000 length: 0x1000
                READ64 image: 13 offset: 0x22000 length: 0x1000
                READ64 image: 13 offset: 0x23000 length: 0x1000
                READ64 image: 13 offset: 0x24000 length: 0x1000
                READ64 image: 13 offset: 0x25000 length: 0x1000
                READ64 image: 13 offset: 0x26000 length: 0x1000
                READ64 image: 13 offset: 0x27000 length: 0x1000
                READ64 image: 13 offset: 0x28000 length: 0x1000
                READ64 image: 13 offset: 0x29000 length: 0x1000
                READ64 image: 13 offset: 0x2a000 length: 0x1000
                READ64 image: 13 offset: 0x2b000 length: 0x1000
                READ64 image: 13 offset: 0x2c000 length: 0x1000
                READ64 image: 13 offset: 0x2d000 length: 0x1000
                READ64 image: 13 offset: 0x2e000 length: 0x1000
                READ64 image: 13 offset: 0x2f000 length: 0x1000
                READ64 image: 13 offset: 0x30000 length: 0x1000
                READ64 image: 13 offset: 0x31000 length: 0x1000
                READ64 image: 13 offset: 0x32000 length: 0x1000
                READ64 image: 13 offset: 0x33000 length: 0x1000
                READ64 image: 13 offset: 0x34000 length: 0x1000
                READ64 image: 13 offset: 0x35000 length: 0x1000
                READ64 image: 13 offset: 0x36000 length: 0x1000
                READ64 image: 13 offset: 0x37000 length: 0x1000
                READ64 image: 13 offset: 0x38000 length: 0x1000
                READ64 image: 13 offset: 0x39000 length: 0x1000
                READ64 image: 13 offset: 0x3a000 length: 0x1000
                READ64 image: 13 offset: 0x3b000 length: 0x1000
                READ64 image: 13 offset: 0x3c000 length: 0x1000
                READ64 image: 13 offset: 0x3d000 length: 0x1000
                READ64 image: 13 offset: 0x3e000 length: 0x1000
                READ64 image: 13 offset: 0x3f000 length: 0x1000
                READ64 image: 13 offset: 0x40000 length: 0x1000
                READ64 image: 13 offset: 0x41000 length: 0x1000
                READ64 image: 13 offset: 0x42000 length: 0x1000
                READ64 image: 13 offset: 0x43000 length: 0x1000
                READ64 image: 13 offset: 0x44000 length: 0x1000
                READ64 image: 13 offset: 0x45000 length: 0x1000
                READ64 image: 13 offset: 0x46000 length: 0x1000
                READ64 image: 13 offset: 0x47000 length: 0x1000
                READ64 image: 13 offset: 0x48000 length: 0x1000
                READ64 image: 13 offset: 0x49000 length: 0x1000
                READ64 image: 13 offset: 0x4a000 length: 0x1000
                READ64 image: 13 offset: 0x4b000 length: 0x1000
                READ64 image: 13 offset: 0x4c000 length: 0x1000
                READ64 image: 13 offset: 0x4d000 length: 0x1000
                READ64 image: 13 offset: 0x4e000 length: 0x1000
                READ64 image: 13 offset: 0x4f000 length: 0x1000
                READ64 image: 13 offset: 0x50000 length: 0x1000
                READ64 image: 13 offset: 0x51000 length: 0x1000
                READ64 image: 13 offset: 0x52000 length: 0x1000
                READ64 image: 13 offset: 0x53000 length: 0x1000
                READ64 image: 13 offset: 0x54000 length: 0x1000
                READ64 image: 13 offset: 0x55000 length: 0x1000
                READ64 image: 13 offset: 0x56000 length: 0x1000
                READ64 image: 13 offset: 0x57000 length: 0x1000
                READ64 image: 13 offset: 0x58000 length: 0x1000
                READ64 image: 13 offset: 0x59000 length: 0x1000
                READ64 image: 13 offset: 0x5a000 length: 0x1000
                READ64 image: 13 offset: 0x5b000 length: 0x1000
                READ64 image: 13 offset: 0x5c000 length: 0x1000
                READ64 image: 13 offset: 0x5d000 length: 0x1000
                READ64 image: 13 offset: 0x5e000 length: 0x1000
                READ64 image: 13 offset: 0x5f000 length: 0x1000
                READ64 image: 13 offset: 0x60000 length: 0x1000
                READ64 image: 13 offset: 0x61000 length: 0x1000
                READ64 image: 13 offset: 0x62000 length: 0x1000
                READ64 image: 13 offset: 0x63000 length: 0x1000
                READ64 image: 13 offset: 0x64000 length: 0x1000
                READ64 image: 13 offset: 0x65000 length: 0x16c
                READ64 image: 13 offset: 0x65170 length: 0x1000
                READ64 image: 13 offset: 0x66170 length: 0x1000
                READ64 image: 13 offset: 0x67170 length: 0x1000
                READ64 image: 13 offset: 0x68170 length: 0x1000
                READ64 image: 13 offset: 0x69170 length: 0x1000
                READ64 image: 13 offset: 0x6a170 length: 0x1000
                READ64 image: 13 offset: 0x6b170 length: 0x1000
                READ64 image: 13 offset: 0x6c170 length: 0x1000
                READ64 image: 13 offset: 0x6d170 length: 0x1000
                READ64 image: 13 offset: 0x6e170 length: 0x1000
                READ64 image: 13 offset: 0x6f170 length: 0x1000
                READ64 image: 13 offset: 0x70170 length: 0x1000
                READ64 image: 13 offset: 0x71170 length: 0x6a0
                READ64 image: 13 offset: 0x71810 length: 0x1000
                READ64 image: 13 offset: 0x72810 length: 0x1000
                READ64 image: 13 offset: 0x73810 length: 0x1000
                READ64 image: 13 offset: 0x74810 length: 0x1000
                READ64 image: 13 offset: 0x75810 length: 0x1000
                READ64 image: 13 offset: 0x76810 length: 0x1000
                READ64 image: 13 offset: 0x77810 length: 0x1000
                READ64 image: 13 offset: 0x78810 length: 0x1000
                READ64 image: 13 offset: 0x79810 length: 0x1000
                READ64 image: 13 offset: 0x7a810 length: 0x1000
                READ64 image: 13 offset: 0x7b810 length: 0x1000
                READ64 image: 13 offset: 0x7c810 length: 0x1000
                READ64 image: 13 offset: 0x7d810 length: 0x1000
                READ64 image: 13 offset: 0x7e810 length: 0x1000
                READ64 image: 13 offset: 0x7f810 length: 0x1000
                READ64 image: 13 offset: 0x80810 length: 0x1000
                READ64 image: 13 offset: 0x81810 length: 0xcc
                READ64 image: 13 offset: 0x818e0 length: 0x84
                READ64 image: 13 offset: 0x81964 length: 0x1000
                READ64 image: 13 offset: 0x82964 length: 0x1000
                READ64 image: 13 offset: 0x83964 length: 0x1000
                READ64 image: 13 offset: 0x84964 length: 0x1000
                READ64 image: 13 offset: 0x85964 length: 0x1000
                READ64 image: 13 offset: 0x86964 length: 0x1000
                READ64 image: 13 offset: 0x87964 length: 0x1000
                READ64 image: 13 offset: 0x88964 length: 0x134
                READ64 image: 13 offset: 0x88a98 length: 0x1000
                READ64 image: 13 offset: 0x89a98 length: 0x1000
                READ64 image: 13 offset: 0x8aa98 length: 0x1000
                READ64 image: 13 offset: 0x8ba98 length: 0x1000
                READ64 image: 13 offset: 0x8ca98 length: 0x1000
                READ64 image: 13 offset: 0x8da98 length: 0x1000
                READ64 image: 13 offset: 0x8ea98 length: 0x3f0
                READ64 image: 13 offset: 0x8ee88 length: 0x1000
                READ64 image: 13 offset: 0x8fe88 length: 0x1000
                READ64 image: 13 offset: 0x90e88 length: 0x1000
                READ64 image: 13 offset: 0x91e88 length: 0x1000
                READ64 image: 13 offset: 0x92e88 length: 0x1000
                READ64 image: 13 offset: 0x93e88 length: 0x1000
                READ64 image: 13 offset: 0x94e88 length: 0x3f0
                READ64 image: 13 offset: 0x95278 length: 0x1000
                READ64 image: 13 offset: 0x96278 length: 0x1000
                READ64 image: 13 offset: 0x97278 length: 0x1000
                READ64 image: 13 offset: 0x98278 length: 0x1000
                READ64 image: 13 offset: 0x99278 length: 0x1000
                READ64 image: 13 offset: 0x9a278 length: 0x1000
                READ64 image: 13 offset: 0x9b278 length: 0x1000
                READ64 image: 13 offset: 0x9c278 length: 0x1000
                READ64 image: 13 offset: 0x9d278 length: 0x1000
                READ64 image: 13 offset: 0x9e278 length: 0x1000
                READ64 image: 13 offset: 0x9f278 length: 0x1000
                READ64 image: 13 offset: 0xa0278 length: 0x1000
                READ64 image: 13 offset: 0xa1278 length: 0x1000
                READ64 image: 13 offset: 0xa2278 length: 0x1000
                READ64 image: 13 offset: 0xa3278 length: 0x1000
                READ64 image: 13 offset: 0xa4278 length: 0x1000
                READ64 image: 13 offset: 0xa5278 length: 0x1000
                READ64 image: 13 offset: 0xa6278 length: 0x1000
                READ64 image: 13 offset: 0xa7278 length: 0x1000
                READ64 image: 13 offset: 0xa8278 length: 0x1000
                READ64 image: 13 offset: 0xa9278 length: 0x1000
                READ64 image: 13 offset: 0xaa278 length: 0x1000
                END OF IMAGE image: 13 status: 0
                DONE status: 1
                <data>
                <log value="INFO: Binary build date: Aug 17 2021 @ 23:37:37" /></data>
                LOG: INFO: Binary build date: Aug 17 2021 @ 23:37:37
                <data>
                " /></data>
                <data>
                <log value="INFO: Chip serial num: 1794324607 (0x6af3387f)" /></data>
                LOG: INFO: Chip serial num: 1794324607 (0x6af3387f)
                <data>
                <log value="INFO: Supported Functions (15):" /></data>
                LOG: INFO: Supported Functions (15):
                <data>
                <log value="INFO: program" /></data>
                LOG: INFO: program
                <data>
                <log value="INFO: read" /></data>
                LOG: INFO: read
                <data>
                <log value="INFO: nop" /></data>
                LOG: INFO: nop
                <data>
                <log value="INFO: patch" /></data>
                LOG: INFO: patch
                <data>
                <log value="INFO: configure" /></data>
                LOG: INFO: configure
                <data>
                <log value="INFO: setbootablestoragedrive" /></data>
                LOG: INFO: setbootablestoragedrive
                <data>
                <log value="INFO: erase" /></data>
                LOG: INFO: erase
                <data>
                <log value="INFO: power" /></data>
                LOG: INFO: power
                <data>
                <log value="INFO: firmwarewrite" /></data>
                LOG: INFO: firmwarewrite
                <data>
                <log value="INFO: getstorageinfo" /></data>
                LOG: INFO: getstorageinfo
                <data>
                <log value="INFO: benchmark" /></data>
                LOG: INFO: benchmark
                <data>
                <log value="INFO: emmc" /></data>
                LOG: INFO: emmc
                <data>
                <log value="INFO: ufs" /></data>
                LOG: INFO: ufs
                <data>
                <log value="INFO: fixgpt" /></data>
                LOG: INFO: fixgpt
                <data>
                <log value="INFO: getsha256digest" /></data>
                LOG: INFO: getsha256digest
                <data>
                <log value="INFO: End of supported functions 15" /></data>
                LOG: INFO: End of supported functions 15
                qdl: firehose operation timed out
                <data><configure MemoryName="ufs" MaxPayloadSizeToTargetInBytes="1048576" verbose="0" ZLPAwareHost="1" SkipStorageInit="0"/></data>
                <data>
                <log value="INFO: Calling handler for configure" /></data>
                LOG: INFO: Calling handler for configure
                <data>
                <log value="INFO: Storage type set to value UFS" /></data>
                LOG: INFO: Storage type set to value UFS
                <data>
                <response value="ACK" MemoryName="UFS" MinVersionSupported="1" Version="1" MaxPayloadSizeToTargetInBytes="1048576" MaxPayloadSizeToTargetInBytesSupported="1048576" MaxXMLSizeInBytes="4096" DateTime="Aug 17 2021 - 23:37:37" /></data>
                [CONFIGURE] max payload size: 1048576
                <data><program SECTOR_SIZE_IN_BYTES="4096" num_partition_sectors="32776" physical_partition_number="0" start_sector="3154440" filename="qti-ubuntu-robotics-image-qrb5165-rb5-sysfs_1.ext4"/></data>
                <data>
                <log value="INFO: Calling handler for program" /></data>
                LOG: INFO: Calling handler for program
                <data>
                <log value="ERROR: Failed to initialize (open whole lun) UFS Device slot 0 partition 0" /></data>
                LOG: ERROR: Failed to initialize (open whole lun) UFS Device slot 0 partition 0
                <data>
                <log value="ERROR: Failed to open the device:3 slot:0 partition:0 error:0" /></data>
                LOG: ERROR: Failed to open the device:3 slot:0 partition:0 error:0
                <data>
                <log value="ERROR: OPEN handle NULL and no error, weird 344489460" /></data>
                LOG: ERROR: OPEN handle NULL and no error, weird 344489460
                <data>
                <log value="ERROR: Failed to open device, type:UFS, slot:0, lun:0 error:3" /></data>
                LOG: ERROR: Failed to open device, type:UFS, slot:0, lun:0 error:3
                <data>
                <response value="NAK" rawmode="false" /></data>
                [PROGRAM] failed to setup programming
                Or sometimes, after this, the command would run instantly but with no console output.
                • J JoshRebello
                  DONE status: 1
                  <data>
                  <data>
                  " /></data>
                  <data>
                  <data>
                  <data>
                  LOG: INFO: program
                  <data>
                  LOG: INFO: read
                  <data>
                  LOG: INFO: nop
                  <data>
                  LOG: INFO: patch
                  <data>
                  <data>
                  <data>
                  LOG: INFO: erase
                  <data>
                  LOG: INFO: power
                  <data>
                  <data>
                  <data>
                  <data>
                  LOG: INFO: emmc
                  <data>
                  LOG: INFO: ufs
                  <data>
                  LOG: INFO: fixgpt
                  <data>
                  <data>
                  <data>
                  <data>
                  <data>
                  <data>
                  <data>
                  <data>
                  <data>
                  <data>
                  <data>
                  @JoshRebello What I'm asking is how did you get the QDL tool itself onto your PC? Did you clone the repo and build it like in this doc?: https://docs.modalai.com/voxl2-unbricking/#flash
                  We've seen qdl failures if it is installed from other sources
                  J 2 Replies Last reply
                    J Offline
                    J Offline
                    JoshRebello
                    #9
                    @tom Yes, that's correct. I got the QDL tool and tried to install as directed in this doc - https://docs.modalai.com/voxl2-unbricking/#flash. It still failed
                      J Offline
                      J Offline
                      JoshRebello
                      Hi @tom
                      Any updates after my reply above? I'd really like to get this issue sorted and start some work on the drone.
                      Cheers,
                      Joshua
                      • J JoshRebello
                        Hi @tom
                        Cheers,
                        Joshua
                        @JoshRebello I'd recommend an RMA: https://www.modalai.com/pages/rma
                          J Offline
                          J Offline
                          JoshRebello
                          @tom Is there no other option other than an RMA? How was the issue solved for the case I refereed to in this support ticket? We're based in the UK and there will be a lot of complication sending the drone over to the US with my company.
                            J Offline
                            J Offline
                            JoshRebello
                            @tom Hello,
                            I haven't heard any response since my last question. Would really appreciate some support on this even if it's virtual support.
                            Hoping to hear from you soon.
                            Kind regards,
                            Joshua Rebello.
                            • J JoshRebello
                              @tom Hello,
                              Kind regards,
                              Joshua Rebello.
                              @JoshRebello QDL is really the last resort effort to recover a bricked board. If that doesn't work there really isn't any other option than an RMA
                                J Offline
                                J Offline
                                JoshRebello
                                @tom Hello,
                                Thanks for getting back to me on this.
                                Thank you for getting back to me on this. Looks like I will have to go through RMA to get the issue resolved.
                                On that note, does your team have an office in the UK that can support this? or is shipping to the US the only option?
                                Regards,
                                Joshua Rebello.
                                • J JoshRebello
                                  @tom Hello,
                                  Regards,
                                  Joshua Rebello.
                                  @JoshRebello Our only office is in San Diego.
