  3. Probing Intel Realsense LIDAR with voxl-mapper
11 Posts 6 Posters 2.8k Views 1 Watching
  • Zachary Lowell 0Z Offline
    Zachary Lowell 0
    Hi!
    I currently have some code written that pipes some lidar data from an intel realsense to voxl-mapper. AKA all the pipes that the modal TOF camera uses in voxl-camera-server, I am writing to as well. I am able to see the point cloud and tof ir image and depth image in voxl-portal, but when I run voxl-mapper I immediately am hit with:
    ERROR in pipe_server_write_point_cloud, received NULL data pointer
    I am printing data on both ends and what is going from the intel realsense is clearly making it to voxl-mapper, but unsure why I am getting this error since I am writing the point cloud from my custom code. Is voxl-mapper also trying to probe the realsense?
    Zach
    R 1 Reply Last reply
    • adminA Offline
      adminA Offline
      Hey @Zachary-Lowell-0 ,
      So you have a custom driver for realsense going right? We don't have anything going for realsense so we aren't trying to probe anything (assuming you mean access the interface (not sure if it's UART/USB/I2C etc) but portal definitely isn't going to be interacting with devices like that.
      • modaltbM Offline
        modaltbM Offline
        modaltb
        Oops, wrong login on last response 😉
        wilkinsafW 1 Reply Last reply
        • modaltbM modaltb
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          @modaltb Wanted to reply here. We figured out the issue. We needed to pipe over additional information to voxl-mapper. Zach has more details in case anyone is curious
            Hi!
            Zach
            R Offline
            R Offline
            robertshmurda
            @Zachary-Lowell-0 Hi, this is a reply out of nowhere but our project also involves integrating a LiDAR (not the RealSense) with the VOXL2. We have not yet started the process, but I was wondering if your project involved the replacement of the TOF sensors or just piping the LiDAR data to voxl-mapper and bypassing the data sent by the built-in sensors. I also want to ask about the code you used and problems you encountered if it's no trouble to you, it would be substantially helpful for our project.
              Zachary Lowell 0
              @robertshmurda this has been done by myself by piping the point cloud directly into the MPA.
              You can grab the point cloud from whatever api/sdk exists for your lidar and as long as you can get it into the correct struct to pass through the MPA, you can do that and stream it directly to voxl-mapper.
              If you have more questions - feel free to email me zachary.lowell@ascendengineer.com and we can hop on a call or something.
                R Offline
                R Offline
                robertshmurda
                @Zachary-Lowell-0 Thanks Zach, went ahead and sent you an email.
                • K Offline
                  K Offline
                  K.Stute
                  wrote on last edited by K.Stute
                  Hi @Zachary-Lowell-0,
                  sorry to reactivate this old topic but I'm stuck trying to get a real-sense D455 to work over the USB-port of the voxl2. Since apparently the real-sense products are not support by modalai I'd like to know how you got the camera connected and working.
                  Thanks in advance!
                  • K K.Stute
                    Thanks in advance!
                    wilkinsafW Offline
                    wilkinsafW Offline
                    wilkinsaf
                    @K-Stute we had to write a customer driver to handle it
                    K 1 Reply Last reply
                    • wilkinsafW wilkinsaf
                      K Offline
                      K Offline
                      K.Stute
                      @wilkinsaf any chance that this driver is open source? Would save me some time^^
                      • K K.Stute
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        @K-Stute I wish, but it is not.
