    Voxl 2 DFS Server failed
    • C
      cch
      Hi, I'm using voxl2 SDK 0.9.5. Follow these steps:
      1.Use exit to get out of the shell and adb reboot to restart your VOXL2
      2.Once the device restarts, use adb shell to access the terminal and then use voxl-camera-server to start the camera server manually
      3.In a web browser access VOXL Portal as you have been. You should be able to see the stereo camera output.
      4.In another terminal, use adb shell to access the terminal and then use voxl-dfs-server to launch the DFS Server.
      I can't see 'stereo front disparity', 'stereo front disparity scaled' or 'pointcloud pc' from voxl-portal:
      ![alt text](voxl-portal2.png voxl-portal.png image url)
      Terminal output:
      Terminal 1:
       modallink-relink     | Disabled  | Not Running |
       voxl-camera-server   |  Enabled  | Not Running |
       voxl-cpu-monitor     | Disabled  | Not Running |
       voxl-dfs-server      |  Enabled  |   Running   |     0.0
       voxl-imu-server      |  Enabled  |   Running   |     0.0
       voxl-mavlink-server  | Disabled  | Not Running |
       voxl-portal          |  Enabled  |   Running   |     0.0
       voxl-px4-imu-server  | Disabled  | Not Running |
       voxl-px4             |  Enabled  |   Running   |     0.0
       voxl-qvio-server     | Disabled  | Not Running |
       voxl-remote-id       | Disabled  | Not Running |
       voxl-softap          | Disabled  | Not Running |
       voxl-static-ip       | Disabled  | Not Running |
       voxl-streamer        | Disabled  | Not Running |
       voxl-tag-detector    | Disabled  | Not Running |
       voxl-tflite-server   | Disabled  | Not Running |
       voxl-vision-px4      | Disabled  | Not Running |
      voxl2:/$ voxl-camera-server
      WARNING: Camera stereo recieved much newer master than child (33), discarding child and trying again
      Terminal 2:
      system-image: 1.5.5-M0054-14.1a-perf
      kernel:       #1 SMP PREEMPT Fri Mar 24 00:48:55 UTC 2023 4.19.125
      hw version:   M0054
      voxl-suite:   0.9.5
      voxl2:/$ voxl-dfs-server
      min_disparity:   4
      max_disparity:   64
      min_threshold:   10
      cost_threshold:  10
      width:           640
      height:          480
      pc_skip_n_lines: 4
      dfs pair #0
          enable:             1
          input_pipe:         stereo_front
          skip_n_frames:      1
          blur_size:          0
          post_median_size:   0
          intrinsics_file:    /data/modalai/opencv_stereo_front_intrinsics.yml
          extrinsics_file:    /data/modalai/opencv_stereo_front_extrinsics.yml
      dfs pair #1
          enable:             0
          input_pipe:         stereo_rear
          skip_n_frames:      1
          blur_size:          0
          post_median_size:   0
          intrinsics_file:    /data/modalai/opencv_stereo_rear_intrinsics.yml
          extrinsics_file:    /data/modalai/opencv_stereo_rear_extrinsics.yml
      existing instance of voxl-dfs-server found, attempting to stop it
      loading calibration files
      for Pair #0, loaded these lens params:
      f:  508.425964
      cx: 337.120087
      cy: 280.774963
      baseline_m: 0.037456
      initializing dfs module
      opening cameras paused
      client voxl-portal0 connected to ch 1
      client voxl-portal0 connected to ch 0
      client voxl-portal0 connected to ch 2
      Terminal 3:
       voxl-dfs-server      |  Enabled  | Not Running |
       voxl-portal          |  Enabled  |   Running   |    30.0
        Eric Katzfey ModalAI Team @cch
        @cch Why are you starting it from the command line in terminal 2? It is already running so you don't need to run it again.
        • C
          cch @Eric Katzfey
          @Eric-Katzfey Thanks. I tried again but got the same result, could you please help me check out if there are other problems? Here are the steps I followed:
          1. power up the voxl2
          2. open up a terminal and check 'voxl-inspect-services':
           voxl-camera-server   |  Enabled  |   Running   |    36.4
          1. open up a web and check the output of voxl-portal:
          2. check 'voxl-inspect-services' again:
           voxl-camera-server   |  Enabled  |   Running   |    47.6
          I'm so confused because there is no error showing up from anywhere.
            tom admin @cch
            @cch What do you see with systemctl status voxl-dfs-server
            • C
              cch @tom
              @tom Here are the full outputs:
              hw version:   M0054
              voxl-suite:   0.9.5
               voxl-camera-server   |  Enabled  |   Running   |    55.0
              voxl2:/$ systemctl status voxl-dfs-server
              ● voxl-dfs-server.service - voxl-dfs-server
                 Loaded: loaded (/usr/bin/voxl-dfs-server; enabled; vendor preset: enabled)
                 Active: active (running) since Thu 2023-11-02 13:19:52 UTC; 18h ago
               Main PID: 1425 (voxl-dfs-server)
                  Tasks: 14 (limit: 4915)
                 CGroup: /system.slice/voxl-dfs-server.service
                         └─1425 /usr/bin/voxl-dfs-server
              Nov 02 13:19:52 m0054 systemd[1]: Started voxl-dfs-server.
              • C
                cch @cch
                Can anybody find out the problems? Many thanks.
                • C cch referenced this topic on
