  3. Unbrick Voxl2
Unbrick Voxl2
24 Posts 5 Posters 8.0k Views 2 Watching
  • C Offline
    C Offline
    CJ
    I'm unable to adb shell into the drone (Voxl2 Starling). So I've tried to flash the drone using fastboot. The flashing is successful but it cannot adb into the drone after restart the drone. The error is no devices/emulators found.
    Then, I try the qdl method and the following error is shown. Pls advise how to unbrick the drone.
    C 1 Reply Last reply
    • C CJ
      C Offline
      C Offline
      CJ
      Hi ModalAI team,
      Any help?
      • C CJ
        Hi ModalAI team,
        Any help?
        @CJ I haven't seen that I/O error before, perhaps try a different USB port / cable?
        C 2 Replies Last reply
        • wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          Did you install QDL from the snap store? if so, this might be your issue
            C Offline
            C Offline
            CJ
            @tom I've tried with different usb cables. But the same error message appears.
            • wilkinsafW wilkinsaf
              C Offline
              C Offline
              CJ
                C Offline
                C Offline
                CJ
                @wilkinsaf Yes, I've download from snap store. Thanks for your tips. I'll try to download using git clone.
                • C CJ
                  C Offline
                  C Offline
                  CJ
                  @CJ said in Unbrick Voxl2:
                  The git clone version works but still unable to adb to the drone after successfully flashed.
                    C Offline
                    C Offline
                    CJ
                    wrote on last edited by CJ
                    #9
                    @tom After I've flashed the drone, I'm not able to adb.
                    The usb connection shows as fastboot (see image below) instead of
                    Bus 001 Device 022: ID 05c6:901d Qualcomm, Inc. KONA-QRD _SN:21217FEB
                    Can you advise how to fix this?
                    C tomT 2 Replies Last reply
                    • C CJ
                      C Offline
                      C Offline
                      CJ
                      • C CJ
                        @CJ That may be okay, I would try forcing the voxl2 into fastboot using the SW2 button as seen here: https://www.youtube.com/watch?v=IM3PnW7cipQ
                        then flashing the latest SDK release
                          C Offline
                          C Offline
                          CJ
                          #12
                          @tom Hi, I've completed the flashing of latest SDK release. But I'm not able to adb shell into the drone.
                          The condition remains the same even after I did a power cycle, adb kill-server and adb start-server. Pls help.
                          • C CJ
                            @CJ What operating system are you running? Are you using a virtual machine? I haven't seen this error before myself
                              C Offline
                              C Offline
                              CJ
                              @tom Hi Tom,
                              The OS is ubuntu 22.04 and not on virtual machine.
                              It seems like it cannot come out of fastboot mode and waiting for adb connection.
                              • C CJ
                                @tom Hi Tom,
                                @CJ After rebooting, what do you see with lsusb?
                                  C Offline
                                  C Offline
                                  CJ
                                  #16
                                  @tom Pls see the image below. The Google Inc.... (fastboot) is the drone usb.
                                  • C CJ
                                    @CJ If another QDL flash doesn't solve it, this might require an RMA for us to investigate: https://www.modalai.com/pages/rma
                                      C Offline
                                      C Offline
                                      CJ
                                      @tom What will be the likely cause for the drone not getting out of fastboot mode?
                                      • C CJ
                                        @CJ Unkown. Were you ever able to QDL successfully?
                                          C Offline
                                          C Offline
                                          CJ
                                          #20
                                          @tom Yes, the QDL is successful.
                                          And installing the SDK is also successful but it just wait for adb interface to be up, which the usb is still in fastboot mode after power cycle.
