  3. Failsafe Landing bug in PX4 1.14?
21 Posts 3 Posters 7.1k Views 2 Watching
    @hmlow Do you have any logs that you can share?
    H Offline
    H Offline
    hmlow
    Yes pls refer to this ulg log:
    horizontal translation while landing
    I did a couple of landings in Land flight mode. The first and second landing was from a positive and negative x position (NED) with respect to the Home location, respectively. You will be able to see that during the descend, the aircraft translates in the x-axis toward the home location without any stick inputs from me. There are local position setpoints generated during the descent/translation, which suggests that it is a programmed behavior.
    I did a couple of more landings at various positions/orientations with respect to the Home location after that.
      H Offline
      H Offline
      hmlow
      Any luck? Does the log make sense to you?
      • H hmlow
        @hmlow We did a quick check with HITL simulation but in that case the landing is perfectly straight down every time. So we need to have our flight team recreate this with a real drone to see if it can be replicated but that will take a few days for them to get to it.
        H 1 Reply Last reply
          H Offline
          H Offline
          hmlow
          @Eric-Katzfey Thanks keep me posted
          • H hmlow
            @hmlow Our flight team was able to recreate the issue today. Now we just need to figure out what is causing that to happen.
            • H hmlow
              @hmlow This seems like a fundamental bug in PX4 when dealing with EV modes so we're working with the PX4 developers to figure out who and how this will be addressed.
              H 2 Replies Last reply
                H Offline
                H Offline
                hmlow
                @Eric-Katzfey thanks for the update. At least the issue has been identified. Looking forward to some fixes in the near future..
                  H Offline
                  H Offline
                  hmlow
                  @Eric-Katzfey hi. Any progress on this?
                  • H hmlow
                    @hmlow Not really. I don't think anyone in the px4 community has time to assist on this so it's going to be up to ModalAI to fix it. Unfortunately, I can't offer any estimate on when we will be able to resolve this yet.
                    • H hmlow
                      @hmlow I have been able to recreate the issue in HITL with the Gazebo simulator so that should help with testing and investigation on this issue.
                        H Offline
                        H Offline
                        hmlow
                        @Eric-Katzfey that's good. Looking forward to the fix
                        • H hmlow
                          @hmlow This fixes it in HITL:
                          diff --git a/src/modules/navigator/mission_block.cpp b/src/modules/navigator/mission_block.cpp
                          index 565b2f2150..ac36732214 100644
                          --- a/src/modules/navigator/mission_block.cpp
                          +++ b/src/modules/navigator/mission_block.cpp
                          @@ -664,8 +664,8 @@ MissionBlock::mission_item_to_position_setpoint(const mission_item_s &item, posi
                                          return false;
                          -       sp->lat = item.lat;
                          -       sp->lon = item.lon;
                          +       sp->lat = static_cast<double>(NAN);
                          +       sp->lon = static_cast<double>(NAN);
                                  sp->alt = get_absolute_altitude_for_item(item);
                                  sp->yaw = item.yaw;
                                  sp->yaw_valid = PX4_ISFINITE(item.yaw);```
                          • H hmlow
                            @hmlow But that probably only works for VIO mode. Not sure what it would do in GPS mode. So it isn't a fix that will be acceptable for general use. So it still needs more work but that is the heart of the issue.
                            S 1 Reply Last reply
                            • Eric KatzfeyE Eric Katzfey referenced this topic on
                            • LaborzaubererTHIL LaborzaubererTHI referenced this topic on
                              S Offline
                              S Offline
                              swickliff
                              @Eric-Katzfey Has any testing been done with this fix in GPS mode?
                              • S swickliff
                                @swickliff No, it hasn't. Supposedly all of this is fixed in latest mainline but we haven't tested it. But we do have a mainline build available to try: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mainline-px4_1.16.0-1.0.0-202502271326_arm64.deb
