  2. ESCs
  3. ESC Calibration
ESC Calibration
Scheduled Pinned Locked Moved ESCs
11 Posts 2 Posters 3.7k Views 1 Watching
  • dleeD dlee
    I am trying to calibrate ESC on VOXL2. I am using 1804-2800kv motors. When I run voxl-esc-calibrate.py for each motors, I got some params.
    # Motor 1
        pwm_vs_rpm_curve_a0 = 112.878194918
        pwm_vs_rpm_curve_a1 = 0.336081465707
        pwm_vs_rpm_curve_a2 = 7.53669159958e-06
    # Motor 2
        pwm_vs_rpm_curve_a0 = 35.6265065345
        pwm_vs_rpm_curve_a1 = 0.37353561309
        pwm_vs_rpm_curve_a2 = 2.9479165331e-06
    # Motor 3
        pwm_vs_rpm_curve_a0 = 132.362831923
        pwm_vs_rpm_curve_a1 = 0.3256003514
        pwm_vs_rpm_curve_a2 = 8.8413818561e-06
    # Motor 4
        pwm_vs_rpm_curve_a0 = -98.2189291548
        pwm_vs_rpm_curve_a1 = 0.405821707061
        pwm_vs_rpm_curve_a2 = 7.1523119742e-07
    But I know that in order to use VOXL-ESC parameters in the XML file, I need to put only one value. I put 4 sets of parameters for each motor, how do I make them into one parameter set?
    @dlee
    First, please make sure that you are running the calibration with propellers installed (and use safety precautions).
    Next, if you are doing several calibration tests (which sometimes makes sense) and want to use an average value, you have to be a little careful. Keep in mind that you cannot just average four a0 values and use it for a0_average (and so on). Also, even though the a0, a1, a2 numbers may look different, it is difficult to just look at the numbers and see how similar or different the curves are - the answer is to plot them.
    I have written a short script to plot your four results using python. You can run it and take a look (first you may need to install numpy and plotly python packages using pip3 install numpy plotly.
    import numpy as np
    import plotly.graph_objects as go
    rpms = np.arange(0,20000) #rpm range for the quadratic fit
    cals = []
    fits = []
    cals.append([7.53669159958e-06, 0.336081465707, 112.878194918])
    cals.append([2.9479165331e-06,  0.37353561309,  35.6265065345])
    cals.append([8.8413818561e-06,  0.3256003514,   132.362831923])
    cals.append([7.1523119742e-07,  0.405821707061, -98.2189291548])
    fig = go.Figure()
    for idx in range(len(cals)):
        fit = np.polyval(cals[idx], rpms)
        fits.append(fit)
        fig.add_trace(go.Scatter(x=rpms, y=fits[idx], name='Fit %d'%idx))
    fig.update_layout(title='Motor Voltage vs. RPM')
    fig.update_xaxes(title_text="RPM")
    fig.update_yaxes(title_text="Motor Voltage (mV)")
    fig.show()
    The resulting plot looks like below, the four plots are not quite the same. But i have a feeling you might not have used propellers on during calibration? please confirm.
    dleeD 1 Reply Last reply
      @dlee
      import numpy as np
      cals = []
      fits = []
      fig = go.Figure()
          fits.append(fit)
      fig.show()
      dleeD Offline
      dleeD Offline
      dlee
      It seems that when I run the script once, it only calibrates for one motor. So I ran the script 4 times to calibrate 4 motors. The motors spinned when I ran each script. Is there something I'm doing wrong?
      I ran that script inside the drone, so I commented out the code to draw the plot.
      • dleeD dlee
        @dlee , the calibration script indeed only spins one motor at a time, by design. Can you please confirm that you calibrated with propellers on?
          dleeD Offline
          dleeD Offline
          dlee
          @Alex-Kushleyev Yes, I calibrated with propellers on.
          • dleeD dlee
            @dlee
            Got it. Can you tell me what was the maximum rpm reached during the calibration? I think i may have used too high rpm in the plot.
              @dlee
              dleeD Offline
              dleeD Offline
              dlee
              @Alex-Kushleyev Maximum RPM was reached at 13,000. I am using 2800kv motors.
              • dleeD dlee
                @dlee
                Thanks. If you look at the plot at 13K rpm, the plots look much closer together. Also please note that there are two curves that are close together and another two that are also close together. I think they may correspond to CW and CCW rotating propellers. Sometimes the CW and CCW propellers are not exactly the same and could result in slightly different calibration..
                I think for your initial testing you can use either of the calibration curves. However i am wondering whether your propellers are not symmetric CW and CCW.
                You can also use a calibration that is an average. I will follow up soon how to calculate that.
                dleeD 2 Replies Last reply
                  @dlee
                  dleeD Offline
                  dleeD Offline
                  dlee
                  @Alex-Kushleyev I checked that all of propellers spin right side (top-left & bottom-right: CCW; top-right & bottom-left : CW).
                    @dlee
                    dleeD Offline
                    dleeD Offline
                    dlee
                    @Alex-Kushleyev Is there any update?
                    • dleeD dlee
                      @dlee , sorry for the delay.
                      Just to clarify, it is possible that your CW and CCW propellers are not exactly the same, therefore the CW and CCW motors are showing slightly different response to calibration. In this case we can calculate an average for this calibration and use that for all 4 motors. I modified the script to calculate the quadratic fit for all four calibration results together.
                      import numpy as np
                      rpms = np.arange(0,13000) #rpm range for the quadratic fit
                      cals = []
                      fits = []
                      all_fits = []
                      #enter the calibration results from each motor
                      fig = go.Figure()
                          fits.append(fit)
                          fig.add_trace(go.Scatter(x=rpms, y=fits[idx], name='Fit %d'%idx))  #plot each fit
                      #create an array that contains points sampled from each curve
                      #and perform a polynomial fit on all the data to find the average
                      all_data = np.array(fits).flatten('C')
                      all_rpms = np.array([rpms,rpms,rpms,rpms]).flatten('C')
                      #evaluate the average poly fit
                      ply = np.polyfit(all_rpms, all_data, 2)
                      av_fit = np.polyval(ply, rpms)
                      #print the average fit coefficients
                      print('Average Fit coefficients:')
                      print('    pwm_vs_rpm_curve_a0 = ' + str(ply[2]))
                      print('    pwm_vs_rpm_curve_a1 = ' + str(ply[1]))
                      print('    pwm_vs_rpm_curve_a2 = ' + str(ply[0]))
                      #plot the average
                      fig.add_trace(go.Scatter(x=rpms, y=av_fit, name='Average Fit'))
                      #finalize and show the figure
                      fig.show()
                      It results in the following plot and average coefficients. You can enter these coefficients into your custom esc parameters xml file.
                          pwm_vs_rpm_curve_a0 = 45.66215105517507
                          pwm_vs_rpm_curve_a1 = 0.36025978431449995
                          pwm_vs_rpm_curve_a2 = 5.01030529655002e-06
                      • John Nomikos 0J John Nomikos 0 referenced this topic on
                      • Alexander SaundersA Alexander Saunders referenced this topic on
