  3. Propeller Coefficients for Starling V2
starlingv2propellers
2 Posts 2 Posters 1.6k Views 1 Watching
  • Kashish Garg 0K Offline
    Kashish Garg 0
    wrote on last edited by Kashish Garg 0
    We were curious if anyone (either as users or from the ModalAI team) has been able to ascertain the propeller coefficients (thrust vs rpm / rpm vs throttle) for the props that come with the Starling V2? We are looking for coefficients specifically to be used for SO3 Control
    • Kashish Garg 0K Kashish Garg 0
      Hello @Kashish-Garg-0
      we have a curve that is "motor voltage vs rpm", meaning that for a desired RPM, it tells the ESC what average motor voltage should be applied. The average motor voltage is defined as battery_voltage * motor_pmw_duty_cycle. The battery voltage in this curve is in millivolts. Since you are typically controlling the desired RPM, as a user you do not need to worry about what "throttle" or voltage to apply - the ESC does this automatically in order to achieve the desired RPM. this calibration curve is used as a feed-forward term in the RPM controller. The ESC does support an "open loop" type of control where you specify the power from 0 to 100%, which is similar to a standard ESC, but PX4 does not use that ESC control mode.
      By the way, you can test the ESC directly (not using PX4) using our voxl-esc tools (https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/master/voxl-esc-tools) which works directly on VOXL2 or a standalone linux PC (or mac). voxl-esc-spin.py has a --power argument where you specify the power from 0 to 100, which translates directly to the average duty cycle applied to the motor.
      Here is the calibration for the Starling V2 motor / propeller that we use:
      https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-params/mavic_mini_2/mavic_mini_2.xml?ref_type=heads#L63
      Also, you can take a look at this post to see how to interpret those parameters a0, a1, a2 : https://forum.modalai.com/topic/2522/esc-calibration/2
      We also have some dyno tests for this motor / propeller : https://gitlab.com/voxl-public/flight-core-px4/dyno_data/-/blob/master/data/mavic_mini2_timing_test/mavic_mini2_modal_esc_pusher_7.4V_timing0.csv . We are not sure how accurate that is, but it can be used as a starting point. @James-Strawson can you please confirm that is the correct dyno data for the Starling V2 motors?
      • Neelay JoglekarN Neelay Joglekar referenced this topic on
