    ESC Calibration
    ESCs
    1951
    • dleeD
      dlee
      I am trying to calibrate ESC on VOXL2. I am using 1804-2800kv motors. When I run voxl-esc-calibrate.py for each motors, I got some params.
      # Motor 1
          pwm_vs_rpm_curve_a0 = 112.878194918
          pwm_vs_rpm_curve_a1 = 0.336081465707
          pwm_vs_rpm_curve_a2 = 7.53669159958e-06
      # Motor 2
          pwm_vs_rpm_curve_a0 = 35.6265065345
          pwm_vs_rpm_curve_a1 = 0.37353561309
          pwm_vs_rpm_curve_a2 = 2.9479165331e-06
      # Motor 3
          pwm_vs_rpm_curve_a0 = 132.362831923
          pwm_vs_rpm_curve_a1 = 0.3256003514
          pwm_vs_rpm_curve_a2 = 8.8413818561e-06
      # Motor 4
          pwm_vs_rpm_curve_a0 = -98.2189291548
          pwm_vs_rpm_curve_a1 = 0.405821707061
          pwm_vs_rpm_curve_a2 = 7.1523119742e-07
      But I know that in order to use VOXL-ESC parameters in the XML file, I need to put only one value. I put 4 sets of parameters for each motor, how do I make them into one parameter set?
        Alex Kushleyev ModalAI Team @dlee
        @dlee
        First, please make sure that you are running the calibration with propellers installed (and use safety precautions).
        Next, if you are doing several calibration tests (which sometimes makes sense) and want to use an average value, you have to be a little careful. Keep in mind that you cannot just average four a0 values and use it for a0_average (and so on). Also, even though the a0, a1, a2 numbers may look different, it is difficult to just look at the numbers and see how similar or different the curves are - the answer is to plot them.
        I have written a short script to plot your four results using python. You can run it and take a look (first you may need to install numpy and plotly python packages using pip3 install numpy plotly.
        import numpy as np
        import plotly.graph_objects as go
        rpms = np.arange(0,20000) #rpm range for the quadratic fit
        cals = []
        fits = []
        cals.append([7.53669159958e-06, 0.336081465707, 112.878194918])
        cals.append([2.9479165331e-06,  0.37353561309,  35.6265065345])
        cals.append([8.8413818561e-06,  0.3256003514,   132.362831923])
        cals.append([7.1523119742e-07,  0.405821707061, -98.2189291548])
        fig = go.Figure()
        for idx in range(len(cals)):
            fit = np.polyval(cals[idx], rpms)
            fits.append(fit)
            fig.add_trace(go.Scatter(x=rpms, y=fits[idx], name='Fit %d'%idx))
        fig.update_layout(title='Motor Voltage vs. RPM')
        fig.update_xaxes(title_text="RPM")
        fig.update_yaxes(title_text="Motor Voltage (mV)")
        fig.show()
        The resulting plot looks like below, the four plots are not quite the same. But i have a feeling you might not have used propellers on during calibration? please confirm.
        dleeD 1 Reply Last reply Reply Quote 0
        • dleeD
          dlee @Alex Kushleyev
          It seems that when I run the script once, it only calibrates for one motor. So I ran the script 4 times to calibrate 4 motors. The motors spinned when I ran each script. Is there something I'm doing wrong?
          I ran that script inside the drone, so I commented out the code to draw the plot.
            @dlee , the calibration script indeed only spins one motor at a time, by design. Can you please confirm that you calibrated with propellers on?
            • dleeD
              @Alex-Kushleyev Yes, I calibrated with propellers on.
                @dlee
                Got it. Can you tell me what was the maximum rpm reached during the calibration? I think i may have used too high rpm in the plot.
                • dleeD
                  @Alex-Kushleyev Maximum RPM was reached at 13,000. I am using 2800kv motors.
                    @dlee
                    Thanks. If you look at the plot at 13K rpm, the plots look much closer together. Also please note that there are two curves that are close together and another two that are also close together. I think they may correspond to CW and CCW rotating propellers. Sometimes the CW and CCW propellers are not exactly the same and could result in slightly different calibration..
                    I think for your initial testing you can use either of the calibration curves. However i am wondering whether your propellers are not symmetric CW and CCW.
                    You can also use a calibration that is an average. I will follow up soon how to calculate that.
                    dleeD 2 Replies Last reply Reply Quote 0
                    • dleeD
                      @Alex-Kushleyev I checked that all of propellers spin right side (top-left & bottom-right: CCW; top-right & bottom-left : CW).
                      • dleeD
                        @Alex-Kushleyev Is there any update?
                          @dlee , sorry for the delay.
                          Just to clarify, it is possible that your CW and CCW propellers are not exactly the same, therefore the CW and CCW motors are showing slightly different response to calibration. In this case we can calculate an average for this calibration and use that for all 4 motors. I modified the script to calculate the quadratic fit for all four calibration results together.
                          import numpy as np
                          rpms = np.arange(0,13000) #rpm range for the quadratic fit
                          cals = []
                          fits = []
                          all_fits = []
                          #enter the calibration results from each motor
                          fig = go.Figure()
                              fits.append(fit)
                              fig.add_trace(go.Scatter(x=rpms, y=fits[idx], name='Fit %d'%idx))  #plot each fit
                          #create an array that contains points sampled from each curve
                          #and perform a polynomial fit on all the data to find the average
                          all_data = np.array(fits).flatten('C')
                          all_rpms = np.array([rpms,rpms,rpms,rpms]).flatten('C')
                          #evaluate the average poly fit
                          ply = np.polyfit(all_rpms, all_data, 2)
                          av_fit = np.polyval(ply, rpms)
                          #print the average fit coefficients
                          print('Average Fit coefficients:')
                          print('    pwm_vs_rpm_curve_a0 = ' + str(ply[2]))
                          print('    pwm_vs_rpm_curve_a1 = ' + str(ply[1]))
                          print('    pwm_vs_rpm_curve_a2 = ' + str(ply[0]))
                          #plot the average
                          fig.add_trace(go.Scatter(x=rpms, y=av_fit, name='Average Fit'))
                          #finalize and show the figure
                          fig.show()
                          It results in the following plot and average coefficients. You can enter these coefficients into your custom esc parameters xml file.
                              pwm_vs_rpm_curve_a0 = 45.66215105517507
                              pwm_vs_rpm_curve_a1 = 0.36025978431449995
                              pwm_vs_rpm_curve_a2 = 5.01030529655002e-06
                          • John Nomikos 0J John Nomikos 0 referenced this topic on
                          • Alexander SaundersA Alexander Saunders referenced this topic on
