  3. VOXL no ADB access
VOXL no ADB access
8 Posts 3 Posters 1.6k Views 1 Watching
  • SHofmeesterS Offline
    SHofmeester
    On one of our VOXLs I tried to access it using adb shell, but it couldn't find the device. It also doesn't show up when I use adb devices.
    When I used this procedure (that has worked on another device before), it keeps saying Waiting for fastboot....
    Is there another method?
    Thanks in advance!
    • SHofmeesterS SHofmeester
      Thanks in advance!
      tomT Online
      tomT Online
      @SHofmeester What does the device enumerate as with lsusb?
      SHofmeesterS 1 Reply Last reply
        SHofmeester
        Hi @tom,
        I tried lsusb both regularly and with the fastboot method from the unbricking procedure. But it didn't recognize the device. The result of lsusb was the same when it was plugged in and when it wasn't plugged in. I tried with another VOXL and it did recognize it.
          Hi @tom,
          tomT Online
          tomT Online
          @SHofmeester Interesting, can you try with a different USB cable / port? How are you powering your VOXL?
            SHofmeester
            I'm powering the VOXL with the standard power module delivered with the VOXL.
            I have tried different cables and ports, but the results are the same. Those are cables and ports do work with another VOXL we have.
            Is there a specific location on the board we can measure with a multimeter to see if the VOXL is still functioning correctly on a hardware level? Or is that too difficult or dangerous?
              tomT Online
              tomT Online
              @SHofmeester I would recommend submitting an RMA: https://www.modalai.com/pages/rma
              • M Offline
                M Offline
                majjam
                I had the exact same problem on my Ubuntu 18.04 machine with the VOXL 2.
                To fix this, I had to restart the adb server with sudoers permissions. Maybe this will help:
                adb kill-server
                sudo adb start-server
                • M majjam
                  adb kill-server
                  tomT Online
                  tomT Online
                  wrote on last edited by tom
                  @SHofmeester Another thing I just thought to try::
                  run sudo dmesg -wH and see if you see the VOXL enumerate when you plug it in to your machine
