VOXL no ADB access
On one of our VOXLs I tried to access it using
adb shell, but it couldn't find the device. It also doesn't show up when I useadb devices.
When I used this procedure (that has worked on another device before), it keeps sayingWaiting for fastboot....Is there another method?
Thanks in advance!
Thanks in advance!
@SHofmeester What does the device enumerate as with
lsusb?Hi @tom,
I tried
lsusbboth regularly and with the fastboot method from the unbricking procedure. But it didn't recognize the device. The result oflsusbwas the same when it was plugged in and when it wasn't plugged in. I tried with another VOXL and it did recognize it. -
Hi @tom,
I tried
@SHofmeester Interesting, can you try with a different USB cable / port? How are you powering your VOXL?
I'm powering the VOXL with the standard power module delivered with the VOXL.I have tried different cables and ports, but the results are the same. Those are cables and ports do work with another VOXL we have.
Is there a specific location on the board we can measure with a multimeter to see if the VOXL is still functioning correctly on a hardware level? Or is that too difficult or dangerous?
@SHofmeester I would recommend submitting an RMA: https://www.modalai.com/pages/rma
I had the exact same problem on my Ubuntu 18.04 machine with the VOXL 2.
To fix this, I had to restart the adb server with sudoers permissions. Maybe this will help:
adb kill-server sudo adb start-server -
