    Voxl Streamer Config
    377
    • B
      bendraper
      I'm trying to get an RTSP stream to start at a certain port and using the qvio overlay pipe on bootup, but it always defaults to hires pipe at the default 8900 port. I've edited the /etc/modal/voxl_streamer.config file to reflect my changes but they never take when I just run voxl-streamer afterwards. I also tried to run the voxl-configure-streamer command but it will overwrite the config to the defaults. Even when I add arguments to the voxl-configure-streamer command, if I then go run voxl-streamer, they will use default arguments. The only way to open the custom stream is to do voxl-streamer command but with arguments but I'd like this to happen by default on boot. Any thoughts??
      tomT B 2 Replies Last reply Reply Quote 0
        tom admin @bendraper
        @bendraper That doesn't sound like things are working as expected.
        What software release are you using? Can you post the output of voxl-version?
        Can we also see your full voxl-streamer conf file:
        cat /etc/modalai/voxl-streamer.conf
        • B
          bendraper @tom
          Output of voxl-version
          kernel:       #1 SMP PREEMPT Thu Oct 13 17:48:16 UTC 2022 4.19.125
          hw version:   M0054
          voxl-suite:   0.9.4
          Packages:
          Last Updated: 2022-09-06 03:18:50
          List:
                  libmodal-cv              0.2.3
                  libmodal-exposure        0.0.7
                  libmodal-journal         0.2.1
                  libmodal-json            0.4.3
                  libmodal-pipe            2.6.0
                  libqrb5165-io            0.1.0
                  libvoxl-cci-direct       0.1.5
                  libvoxl-cutils           0.1.1
                  mv-voxl                  0.1-r0
                  qrb5165-bind             0.1-r0
                  qrb5165-dfs-server       0.1.0
                  qrb5165-imu-server       0.5.0
                  qrb5165-slpi-test-sig    01-r0
                  qrb5165-system-tweaks    0.1.5
                  qrb5165-tflite           2.8.0-2
                  voxl-bind                0.0.1
                  voxl-camera-calibration  0.2.3
                  voxl-camera-server       1.3.5
                  voxl-cpu-monitor         0.3.0
                  voxl-docker-support      1.2.4
                  voxl-gphoto2-server      0.0.10
                  voxl-jpeg-turbo          2.1.3-4
                  voxl-libgphoto2          0.0.4
                  voxl-libuvc              1.0.7
                  voxl-logger              0.3.4
                  voxl-mavlink             0.1.0
                  voxl-mavlink-server      0.2.0
                  voxl-modem               0.16.1
                  voxl-mongoose            7.7.0-1
                  voxl-mpa-to-ros          0.3.6
                  voxl-mpa-tools           0.7.6
                  voxl-opencv              4.5.5-1
                  voxl-portal              0.4.2
                  voxl-px4                 1.12.31
                  voxl-px4-imu-server      0.1.2
                  voxl-qvio-server         0.8.2
                  voxl-remote-id           0.0.5
                  voxl-streamer            0.4.1
                  voxl-suite               0.9.4
                  voxl-tag-detector        0.0.4
                  voxl-tflite-server       0.3.1
                  voxl-utils               1.2.2
                  voxl-uvc-server          0.1.3
                  voxl-vision-px4          1.4.0
                  voxl2-system-image       1.4.1-r0
                  voxl2-wlan               1.0-r0
          and voxl-streamer.config
                  "input-pipe":   "qvio_overlay",
                  "bitrate":      1000000,
                  "decimator":    2,
                  "port": 554,
                  "rotation":     0
          • B
            bendraper @bendraper
            @bendraper On reboot the contents of the config file actually persist, but I know its not taking because if I run voxl-streamer with no args, it says opening stream at port 8900 and not 554
              @bendraper Well we could dig into this further but I'm actually going to recommend that you upgrade to VOXL SDK 1.0.0 (released yesterday).
              This will be a massive upgrade from your current release and will be much easier to work with.
              See here for the download: https://developer.modalai.com/asset/2
              Release notes here: https://docs.modalai.com/sdk-1.0-release-notes/
              I do know that voxl-streamer is one of the many services that gets big updates in this release
              • B
                bendraper @tom
                @tom Will give this a try, thanks Tom
                • B
                  bendraper @tom
                  @tom Do you know if its possible to do an SDK update on windows or wsl?
                    @bendraper As long as bash / adb / fastboot are available then I would think it's possible. Although it's not something we've tried / officially support so I can't say that I would recommend it.
                    Wouldn't hurt to try though if it saves you some time
                    • B
                      bendraper @tom
                      @tom Hey Tom. So I tried doing it in WSL but I can only get as far as this screen
                      After hitting that last prompt, it just hangs there indefinitely. Obviously since you haven't tried this method I don't expect there to be a solution, but I was wondering if this is a symptom of something you've seen before that may help in debugging further. If I cancel the flash the Voxl does not get bricked and I can use it as normal on the old SDK. There's also no LED indicators that may suggest its getting flash and obviously no visual indicators in the console that it's getting flashed so I don't think its getting very far in the flash process.
