  3. Qualcomm RB5 - Remote ID
17 Posts 3 Posters 2.9k Views 3 Watching
  • D Offline
    D Offline
    doe43john77
    Good afternoon, I have been trying to get the remote ID to work on RB5. I followed the steps in the technical document, and everything was working well until I had to check voxl-remote-id status. I end up getting something like this which is in the technical document. My device is already in SoftAP mode.
    voxl:/$ systemctl status voxl-remote-id
    voxl-remote-id.service - voxl-remote-id
    Loaded: loaded (/usr/bin/voxl-remote-id; enabled; vendor preset: enabled)
    Active: active (running) since Thu 1970-01-01 02:19:30 UTC; 52 years 9 months ago
    Main PID: 2447 (voxl-remote-id)
    CGroup: /system.slice/voxl-remote-id.service
    └─2447 /usr/bin/voxl-remote-id
    Jan 01 02:19:30 apq8096 systemd[1]: Started voxl-remote-id.
    Jan 01 02:19:31 apq8096 voxl-remote-id[2447]: INFO: Remote ID SN: 1814C4056553343
    Jan 01 02:19:31 apq8096 voxl-remote-id[2447]: INFO: Attempting to Connect to hostapd: /data/misc/wifi/hostapd/(null)
    • D Offline
      D Offline
      doe43john77
      Is there any solution or feedback to the above problem.
      • D doe43john77
        @doe43john77 It's acting like the softap mode didn't get setup correctly. Are you able to connect to the drone over WiFi? Is there anything in the directory /data/misc/wifi/hostapd?
        D 3 Replies Last reply
          D Offline
          D Offline
          doe43john77
          @Eric-Katzfey Yes, I am able to connect the drone over WiFi.
            D Offline
            D Offline
            doe43john77
            @Eric-Katzfey Also isn't hostapd a conf. file
            • D doe43john77
              @doe43john77 Here's what I have:
              voxl2-mini:/$ cd /data/misc/wifi/
              voxl2-mini:/data/misc/wifi$ ls
              hostapd  hostapd.conf  wlan_mode  wpa_supplicant.conf
              voxl2-mini:/data/misc/wifi$ ls -l
              total 80
              drwxr-x--- 2 root root  4096 Jun 29 15:56 hostapd
              -rw-r--r-- 1 root root 66860 Jun 29 15:56 hostapd.conf
              -rw-rw-rw- 1 root root     8 Jun 29 16:18 wlan_mode
              -rw-r--r-- 1 root root   444 Jun 29 16:18 wpa_supplicant.conf
              voxl2-mini:/data/misc/wifi$ cd hostapd
              voxl2-mini:/data/misc/wifi/hostapd$ ls
              wlan0
              voxl2-mini:/data/misc/wifi/hostapd$ ls -l
              total 0
              srwxrwx--- 1 root root 0 Jun 29 15:56 wlan0
                D Offline
                D Offline
                doe43john77
                @Eric-Katzfey This is what i have when I do what you did above. I add the hostapd into the directory and copied the hostapd.conf into the hostapd directory.
                rb5:~$ cd /data/misc/wifi/
                rb5:/data/misc/wifi$ ls
                hostapd hostapd.conf wpa_supplicant.conf
                hostapd-wlan1.conf sta_mode_hostapd.conf
                hostapd-wlan2.conf wlan_mode
                rb5:/data/misc/wifi$ ls -l
                total 284
                drwxr-xr-x 2 root root 4096 Jun 30 16:23 hostapd
                -rw-r--r-- 1 root root 66929 Oct 13 2022 hostapd-wlan1.conf
                -rw-r--r-- 1 root root 66929 Oct 13 2022 hostapd-wlan2.conf
                -rw-r--r-- 1 root root 66928 Jun 30 18:31 hostapd.conf
                -rw-r--r-- 1 root root 66927 Oct 13 2022 sta_mode_hostapd.conf
                -rw-rw-rw- 1 root root 7 Jun 30 18:31 wlan_mode
                -rw-r--r-- 1 root root 234 Jun 30 18:31 wpa_supplicant.conf
                rb5:/data/misc/wifi$ cd hostapd
                rb5:/data/misc/wifi/hostapd$ ls
                hostapd.conf
                rb5:/data/misc/wifi/hostapd$ ls -l
                total 68
                -rw-r--r-- 1 root root 66928 Jun 30 16:11 hostapd.conf
                D 2 Replies Last reply
                • D doe43john77
                  total 284
                  hostapd.conf
                  total 68
                  D Offline
                  D Offline
                  doe43john77
                  @doe43john77 Checking for an update
                  • D doe43john77
                    total 284
                    hostapd.conf
                    total 68
                    D Offline
                    D Offline
                    doe43john77
                    @Eric-Katzfey what needs to be contained in the wlan0 file
                    • D doe43john77
                      @doe43john77 I was able to recreate the issue and we are working on a solution
                      D 1 Reply Last reply
                        D Offline
                        D Offline
                        doe43john77
                        @tom Good morning, is there an update on the solution.
                        • D doe43john77
                          @doe43john77 It's on our list, but no movement yet
                            D Offline
                            D Offline
                            doe43john77
                            @tom Good morning any updates on the Remote ID
                            • D doe43john77
                              @doe43john77 It's probably going to be a couple of weeks before we can provide something.
                                D Offline
                                D Offline
                                doe43john77
                                @Eric-Katzfey Good morning, Is there any update on Remote ID? Thank you!
                                Eric KatzfeyE tomT 2 Replies Last reply
                                • D doe43john77
                                  @doe43john77 No, sorry, it's on our list for the next release but we haven't had a chance to look at it yet
                                  • D doe43john77
                                    @doe43john77 A fix has been put in place in voxl-remote-id v0.0.9
