  2. VOXL Dev Drones
  3. Sentinel
  4. Need Assistance Connecting Pure Thermal Mini 2 Pro to Sentinel
Scheduled Pinned Locked Moved Sentinel
14 Posts 3 Posters 2.4k Views 1 Watching
  • A EvansA Offline
    A EvansA Offline
    A Evans
    I recently procured a Pure Thermal Mini 2 Pro (https://www.sparkfun.com/products/17544) and attempted to connect it using a JST to USB cable via a USB A to USB C adapter. The setup worked flawlessly when I tested it on another device.
    However, when trying to connect via the ADB port using the same cable configuration, I've been unsuccessful. I stumbled upon this thread discussing a similar issue, and it seems that this bug might still be unresolved.
    I'm curious about the potential solutions.
    • Do I require any additional equipment? (if so what?)
    • is there an alternate port on the Sentinel that I could utilize?
    • A workaround for the ADB port would be ideal.
    Upon reviewing the specifications, I noticed there doesn't appear to be an unused USB or JST port that could potentially accommodate the thermal camera.
    Any advice or suggestions would be greatly appreciated.
    Thank you in advance for your assistance.
    • A EvansA Offline
      A EvansA Offline
      A Evans
      The topic I was referring too : https://forum.modalai.com/topic/933/cannot-connect-usb-camera-over-usb-c-adb-port?_=1683736009350
        VOXL 2 J9 cannot be used as a host at this time, so what you are trying will not work
        • A EvansA Offline
          A EvansA Offline
          A Evans
          Could you provide a solution happy to buy any addition boards.
          VinnyV 1 Reply Last reply
          • A EvansA A Evans
            Hi @A-Evans
            Several of our plug-in boards expose USB host ports, such as this:
            https://www.modalai.com/products/m0125?variant=40740708876339
            or this:
            https://www.modalai.com/products/m0078
            or our 5G modem product (you do not need a modem to get the USB hub features).
            https://www.modalai.com/products/mdk-m0090?variant=40594936463411
            Please check our cables page to see what option will work best for you based on what HW you have, such as:
            https://www.modalai.com/collections/cables-1/products/mcbl-00009
            or https://www.modalai.com/collections/cables-1/products/mcbl-00022
            all cable specs are here (updated often) and you might find some other options that can help: https://docs.modalai.com/cable-datasheets/
            Hope this helped!
            A EvansA 1 Reply Last reply
            • VinnyV Vinny
              Hi @A-Evans
              or this:
              Hope this helped!
              A EvansA Offline
              A EvansA Offline
              A Evans
              @Vinny Thanks for this vinny, appologies for the late reply been on holiday, what is the difference between each suggested?
              • A EvansA A Evans
                Hi @A-Evans
                The main difference between this board:
                and this board:
                is the UART on the smaller board is not present on the "L" board.
                The "L Board" only gives USB2, but has the option to select a high current VBUS option bypassing our USB power switches.
                Either one will work for a Pure Thermal Lepton over USB2. The "L" board might be better for drones with high vibe since it can be secured with additional mounting holes.
                Hope this helps!
                • A EvansA Offline
                  A EvansA Offline
                  A Evans
                  Cheers Vinny appreciate the detail will get finance to put an order in now.
                  • VinnyV Vinny
                    Hi @A-Evans
                    and this board:
                    Hope this helps!
                    A EvansA Offline
                    A EvansA Offline
                    A Evans
                    @Vinny I've received the parts, and not think I may be missing some pieces, the sentinel comes with the VOXL 2 USB board, but there isn't anyway to connect both these board, I'm assuming the uart on 3.0 can't be used to connect the camera or wifi? or do I need a specific cable for connecting the pure thermal to the uart?
                    apologies I'm a software man not a hardware man.
                    • A EvansA A Evans
                      Hi @A-Evans
                      In your original post, you wanted to connect Pure Thermal Lepton USB board to Voxl2, correct?
                      Either of those boards, even if Sentinel came with the USB+ UART adapter, all work to expose a USB2 host which should be suitable for connecting to Lepton.
                      The originla board you posted from Sparkfun uses a 1mm JST SR connector, so you can make any simple adapter to our USB plug, or you can check out some of our cables as a starting point:
                      https://docs.modalai.com/cable-datasheets/#mcbl-00071
                      https://docs.modalai.com/cable-datasheets/#mcbl-00080
                      Generally speaking, yes, you can only have 1 plug-in board at a time connected to J3/J5 on Voxl2. That is why we have so many options of boards for different use cases.
                      If you need additional USB ports, UARTs, etc, for more expansion support, you might need to consider something like our 5G modem board (you do not need to have a modem for the bulk of it to work).
                      It exposes multiple USB ports and other UART/I2C ports as well.
                      However, if all you want is to add Lepton over USB, the Voxl2 USB board should be all you need.
                      • VinnyV Vinny
                        Hi @A-Evans
                        A EvansA Offline
                        A EvansA Offline
                        A Evans
                        @Vinny I think there has been a misunderstanding I need to connect the camera while also having the wifi adapter plugged in, are you saying there is no way to utilise the uart connector on the VOXL2 USB3.0 / UART expansion Adapter, and the only board that is currently on offer with more than one usb connector is the 5g modem?
                        • A EvansA A Evans
                          Hi @A-Evans
                          OK, yes, I see. WiFi was not mentioned in the original post, so thanks for clarifying.
                          Yes, in order to have more than 1 USB port, you need to have one of our Microhard or 5G modem boards to expose multiple USB ports. Those boards all have USB hubs on them to enable this. Whereas our very simple plug-in boards only expose the one port direct from Voxl2.
                          For either 4G/5G Modem or Microhard boards, you do not need to have the module installed. The USB hub portions of the design work with or without wireless modules installed.
                          Hope that clarifies things.
                          • VinnyV Vinny
                            Hi @A-Evans
                            A EvansA Offline
                            A EvansA Offline
                            A Evans
                            @Vinny ah could you provide me a parts list, I may have to return the others, shipping is heafty to the UK too. are there any third party board that would work?
                            • A EvansA A Evans
                              Hi @A-Evans
                              This is our current WiFi solution for Voxl2, or any ModalAI board with a standard USB2 4-position JST GH port.
                              https://www.modalai.com/products/wifi-usb-cable-add-on?_fid=da227b041&_pos=1&_ss=c
                              If you want to use our 10-pin USB3 format connector for the Alpha USB Dongle, then you can also consider using this cable: https://www.modalai.com/products/mcbl-00022
                              Note: We use Alpha WiFi since it's NDAA compliant 🙂
                              You are free to use any WiFI USB dongle sourced at the UK, and make your own cables for USB2 (not too hard for proto-type builds).
