  3. Unable to use Arducam B0205 with VOXL (not VOXL2) - USB Camera
usbcameradrivers
7 Posts 2 Posters 2.3k Views 2 Watching
  • D Offline
    D Offline
    dbrophy
    Description of Problem:
    I have a ModalAI M500 with an Arducam B0205 (link) connected to it. Although the camera shows up with lsusb, I cannot use it inside my docker container. Other USB cameras work fine. This Arducam camera works fine on my laptop, which runs Linux Mint.
    I commonly get the error message that the camera is in use, but lsof shows it is not used by the container nor any process inside Yocto.
    Output of uname -a and ls /dev | grep video :
    voxl:~$ uname -a
    Linux apq8096 3.18.71-perf #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 aarch64 GNU/Linux
    voxl:~$ ls /dev | grep video
    video0
    video1
    video2
    video3
    video32
    video33
    video4
    The camera is confirmed to be /dev/video2.
    Output of lsof, lsusb, ffmpeg, and related debugging commands:
    Commands run on Yocto:
    voxl:~$ ./lsof | grep /dev/video2
    voxl:~$ lsusb
    Bus 001 Device 030: ID 0c45:6369 Microdia
    Bus 001 Device 006: ID 1f94:3002
    Bus 001 Device 004: ID 0424:7500 Standard Microsystems Corp. LAN7500 Ethernet 10/100/1000 Adapter
    Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
    voxl:~$ ffmpeg -i /dev/video2
    ffmpeg version n4.2.2 Copyright (c) 2000-2019 the FFmpeg developers
      built with gcc 4.9.3 (GCC)
      configuration: --arch=arm --prefix=/builds/voxl-public/voxl-ffmpeg/ipk/data/usr/local --enable-omx
      libavutil      56. 31.100 / 56. 31.100
      libavcodec     58. 54.100 / 58. 54.100
      libavformat    58. 29.100 / 58. 29.100
      libavdevice    58.  8.100 / 58.  8.100
      libavfilter     7. 57.100 /  7. 57.100
      libswscale      5.  5.100 /  5.  5.100
      libswresample   3.  5.100 /  3.  5.100
    [video4linux2,v4l2 @ 0x1761120] Cannot open video device /dev/video2: Device or resource busy
    voxl:~$
    Yes, I have verified that my lsof binary works. The camera is the 0c45:6369 Microdia device listed in lsusb. Strangely, even though the camera is not in use, ffmpeg reports "/dev/video2: Device or resource busy".
    Commands run inside my roskinetic container:
    roskinetic:~$ v4l2-ctl --device=/dev/video2 -D --list-formats
    Failed to open /dev/video2: Device or resource busy
    roskinetic:~$ python3
    Python 3.9.0 (default, Sep  2 2022, 14:09:47)
    [GCC 5.4.0 20160609] on linux
    Type "help", "copyright", "credits" or "license" for more information.
    >>> import cv2
    >>> cam = cap.open('/dev/video2', cv2.CAP_ANY)
    Traceback (most recent call last):
      File "<stdin>", line 1, in <module>
    NameError: name 'cap' is not defined
    >>> cap = cv2.VideoCapture('/dev/video2', cv2.CAP_ANY)
    [ WARN:0@27.752] global /io/opencv/modules/imgcodecs/src/loadsave.cpp (239) findDecoder imread_('/dev/video2'): can't open/read file: check file path/integrity
    >>> exit()
    roskinetic:~$ ls -al /dev | grep video2
    crw-rw----.  1 root video    81,  20 Jan  1  1970 video2
    roskinetic:~$ lsof
    COMMAND  PID USER   FD   TYPE DEVICE SIZE/OFF    NODE NAME
    bash       1 root  cwd    DIR   0,31     4096   31256 /root
    bash       1 root  rtd    DIR   0,31     4096   29395 /
    bash       1 root  txt    REG  179,1   925744 6305171 /bin/bash
    bash       1 root  mem    REG  179,1    39272 1197209 /lib/aarch64-linux-gnu/libnss_files-2.23.so
    bash       1 root  mem    REG  179,1    39312 1197211 /lib/aarch64-linux-gnu/libnss_nis-2.23.so
    bash       1 root  mem    REG  179,1    76632 1197206 /lib/aarch64-linux-gnu/libnsl-2.23.so
    bash       1 root  mem    REG  179,1    31408 1197207 /lib/aarch64-linux-gnu/libnss_compat-2.23.so
    bash       1 root  mem    REG  179,1  1261896 1197197 /lib/aarch64-linux-gnu/libc-2.23.so
    bash       1 root  mem    REG  179,1    10400 1197201 /lib/aarch64-linux-gnu/libdl-2.23.so
    bash       1 root  mem    REG  179,1   154784 6292046 /lib/aarch64-linux-gnu/libtinfo.so.5.9
    bash       1 root  mem    REG  179,1   125776 1197193 /lib/aarch64-linux-gnu/ld-2.23.so
    bash       1 root    0u   CHR  136,0      0t0       3 /0
    bash       1 root    1u   CHR  136,0      0t0       3 /0
    bash       1 root    2u   CHR  136,0      0t0       3 /0
    bash       1 root  255u   CHR  136,0      0t0       3 /0
    lsof    7819 root  cwd    DIR   0,31     4096   31256 /root
    lsof    7819 root  rtd    DIR   0,31     4096   29395 /
    lsof    7819 root  txt    REG  179,1   171304 7235192 /usr/bin/lsof
    lsof    7819 root  mem    REG  179,1   139560 1197214 /lib/aarch64-linux-gnu/libpthread-2.23.so
    lsof    7819 root  mem    REG  179,1    10400 1197201 /lib/aarch64-linux-gnu/libdl-2.23.so
    lsof    7819 root  mem    REG  179,1   395104 6292022 /lib/aarch64-linux-gnu/libpcre.so.3.13.2
    lsof    7819 root  mem    REG  179,1  1261896 1197197 /lib/aarch64-linux-gnu/libc-2.23.so
    lsof    7819 root  mem    REG  179,1   109656 6292035 /lib/aarch64-linux-gnu/libselinux.so.1
    lsof    7819 root  mem    REG  179,1   125776 1197193 /lib/aarch64-linux-gnu/ld-2.23.so
    lsof    7819 root    0u   CHR  136,0      0t0       3 /0
    lsof    7819 root    1u   CHR  136,0      0t0       3 /0
    lsof    7819 root    2u   CHR  136,0      0t0       3 /0
    lsof    7819 root    3r   DIR   0,34        0       1 /proc
    lsof    7819 root    4r   DIR   0,34        0  770582 /proc/7819/fd
    lsof    7819 root    5w  FIFO    0,9      0t0  770586 pipe
    lsof    7819 root    6r  FIFO    0,9      0t0  770587 pipe
    lsof    7820 root  cwd    DIR   0,31     4096   31256 /root
    lsof    7820 root  rtd    DIR   0,31     4096   29395 /
    lsof    7820 root  txt    REG  179,1   171304 7235192 /usr/bin/lsof
    lsof    7820 root  mem    REG  179,1   139560 1197214 /lib/aarch64-linux-gnu/libpthread-2.23.so
    lsof    7820 root  mem    REG  179,1    10400 1197201 /lib/aarch64-linux-gnu/libdl-2.23.so
    lsof    7820 root  mem    REG  179,1   395104 6292022 /lib/aarch64-linux-gnu/libpcre.so.3.13.2
    lsof    7820 root  mem    REG  179,1  1261896 1197197 /lib/aarch64-linux-gnu/libc-2.23.so
    lsof    7820 root  mem    REG  179,1   109656 6292035 /lib/aarch64-linux-gnu/libselinux.so.1
    lsof    7820 root  mem    REG  179,1   125776 1197193 /lib/aarch64-linux-gnu/ld-2.23.so
    lsof    7820 root    4r  FIFO    0,9      0t0  770586 pipe
    lsof    7820 root    7w  FIFO    0,9      0t0  770587 pipe
    roskinetic:~$ ffmpeg -f v4l2 -video_size 720x480 -i /dev/video2 -q:v 16 -r:v 5 -y test.mjpg
    ffmpeg version 2.8.17-0ubuntu0.1 Copyright (c) 2000-2020 the FFmpeg developers
      built with gcc 5.4.0 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.12) 20160609
      configuration: --prefix=/usr --extra-version=0ubuntu0.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv
      libavutil      54. 31.100 / 54. 31.100
      libavcodec     56. 60.100 / 56. 60.100
      libavformat    56. 40.101 / 56. 40.101
      libavdevice    56.  4.100 / 56.  4.100
      libavfilter     5. 40.101 /  5. 40.101
      libavresample   2.  1.  0 /  2.  1.  0
      libswscale      3.  1.101 /  3.  1.101
      libswresample   1.  2.101 /  1.  2.101
      libpostproc    53.  3.100 / 53.  3.100
    [video4linux2,v4l2 @ 0x47df00] Cannot open video device /dev/video2: Device or resource busy
    roskinetic:~$
    Essentially, information inside the container mirrors what I see in Yocto. OpenCV also cannot open the camera. Keep in mind that I can open another (cheaper) USB camera just fine.
    Anyone have ideas on why this might be failing?
    My application/implementation
    I have software set up to analyze the images. This is written in Python, and it is set up to use OpenCV to open /dev/video2. It worked decently with the previous camera, but I needed a higher quality camera with a better FoV. This camera works great when I test the software on my laptop, but there is some issue with it on the VOXL.
    Here is uname from my laptop, if anyone is curious:
    Linux forcyte-xenon 5.15.0-71-generic #78~20.04.1-Ubuntu SMP Wed Apr 19 11:26:48 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
    I've spent most of today trying to figure this out, I've found some resources online but none of them have really helped. If anyone has ideas on this, it would be greatly appreciated.
    • D dbrophy
      voxl:~$ uname -a
      video0
      video1
      video2
      video3
      video32
      video33
      video4
      voxl:~$ lsusb
      voxl:~$
      >>> import cv2
      >>> exit()
      roskinetic:~$ lsof
      roskinetic:~$
      @dbrophy What output do you get if you run this script: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/scripts/show-video-device-info.sh?
      • D Offline
        D Offline
        dbrophy
        Thanks. Here's the output of your command (I ran it both inside and outside container):
        voxl:~$ ./show-video-device-info.sh
        /dev/video2: USB 2.0 Camera 0c45:6369
        voxl:~$ docker attach ff
        roskinetic:~$ cd yoctohome/
        roskinetic:yoctohome$ ./show-video-device-info.sh
        • D dbrophy
          @dbrophy Have you tried using it outside of the Docker? Perhaps with voxl-uvc-server?
          D 1 Reply Last reply
            D Offline
            D Offline
            dbrophy
            @Eric-Katzfey Yes, I've tried both inside and outside Docker. The command outputs are detailed in my original post, except for voxl-uvc-server. I tried that too, but I forget what went wrong, I will try again and put the output in the next paragraph of this post.
            The terminal output of voxl-uvc-server -l is extremely long (hundreds if not a few thousand lines). I have cut most of it out, as the same lines repeated over and over:
            voxl:~$ voxl-uvc-server -l
            loading config file
            *** START DEVICE LIST ***
            Found device 0
            Got device descriptor for 0c45:6369 (null)
            Found device 0c45:6369
            uvc_open failed, Return code: No such device (-4)
            Found device 0
            uvc_find_device failed, Return code: No such device (-4)
            Found device 0
            [... snipped repeating text ...]
            Found device 0
            Found device 0
            Found device 0
            Found device 0
            DEVICE CONFIGURATION (0c45:6369/[none]) ---
            Status: idle
            VideoControl:
            	bcdUVC: 0x0100
            VideoStreaming(1):
            	bEndpointAddress: 129
            	Formats:
            	MJPEGFormat(1)
            		  bits per pixel: 0
            		  GUID: 4d4a5047000000000000000000000000 (MJPG)
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 00
            			  bit rate: 995469360-995469360
            			  max frame size: 4147789
            			  default interval: 1/30
            			  interval[0]: 1/30
            			FrameDescriptor(2)
            			  capabilities: 00
            			  bit rate: 147597360-147597360
            			  max frame size: 614989
            			  interval[0]: 1/30
            			FrameDescriptor(3)
            			  capabilities: 00
            			  bit rate: 442509360-442509360
            			  max frame size: 1843789
            			  interval[0]: 1/30
            			FrameDescriptor(4)
            			  capabilities: 00
            			  bit rate: 110733360-110733360
            			  max frame size: 461389
            			  interval[0]: 1/30
            			FrameDescriptor(5)
            			  capabilities: 00
            			  bit rate: 37005360-37005360
            			  max frame size: 154189
            			  interval[0]: 1/30
            			FrameDescriptor(6)
            			  capabilities: 00
            			  bit rate: 230541360-230541360
            			  max frame size: 960589
            			  interval[0]: 1/30
            			FrameDescriptor(7)
            			  capabilities: 00
            			  bit rate: 331917360-331917360
            			  max frame size: 1382989
            			  interval[0]: 1/30
            			FrameDescriptor(8)
            			  capabilities: 00
            			  bit rate: 48801840-48801840
            			  max frame size: 203341
            			  interval[0]: 1/30
            			FrameDescriptor(9)
            			  capabilities: 00
            			  bit rate: 49907760-49907760
            			  max frame size: 207949
            			  interval[0]: 1/30
            			FrameDescriptor(10)
            			  capabilities: 00
            			  bit rate: 28403760-28403760
            			  max frame size: 118349
            			  interval[0]: 1/30
            			FrameDescriptor(11)
            			  capabilities: 00
            			  bit rate: 12306480-12306480
            			  max frame size: 51277
            			  interval[0]: 1/30
            			FrameDescriptor(12)
            			  capabilities: 00
            			  bit rate: 589965360-589965360
            			  max frame size: 2458189
            			  interval[0]: 1/30
            			FrameDescriptor(13)
            			  capabilities: 00
            			  bit rate: 629286960-629286960
            			  max frame size: 2622029
            			  interval[0]: 1/30
            			FrameDescriptor(14)
            			  capabilities: 00
            			  bit rate: 377628720-377628720
            			  max frame size: 1573453
            			  interval[0]: 1/30
            	UncompressedFormat(2)
            		  bits per pixel: 16
            		  GUID: 5955593200001000800000aa00389b71 (YUY2)
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 00
            			  bit rate: 165888000-165888000
            			  max frame size: 4147200
            			  default interval: 1/5
            			  interval[0]: 1/5
            			FrameDescriptor(2)
            			  capabilities: 00
            			  bit rate: 147456000-147456000
            			  max frame size: 614400
            			  interval[0]: 1/30
            			FrameDescriptor(3)
            			  capabilities: 00
            			  max frame size: 1843200
            			  default interval: 1/10
            			  interval[0]: 1/10
            			FrameDescriptor(4)
            			  capabilities: 00
            			  bit rate: 49766400-49766400
            			  max frame size: 207360
            			  interval[0]: 1/30
            			FrameDescriptor(5)
            			  capabilities: 00
            			  bit rate: 125829120-125829120
            			  max frame size: 1572864
            			  interval[0]: 1/10
            			FrameDescriptor(6)
            			  capabilities: 00
            			  bit rate: 48660480-48660480
            			  max frame size: 202752
            			  interval[0]: 1/30
            			FrameDescriptor(7)
            			  capabilities: 00
            			  bit rate: 36864000-36864000
            			  max frame size: 153600
            			  interval[0]: 1/30
            			FrameDescriptor(8)
            			  capabilities: 00
            			  bit rate: 12165120-12165120
            			  max frame size: 50688
            			  interval[0]: 1/30
            			FrameDescriptor(9)
            			  capabilities: 00
            			  bit rate: 9216000-9216000
            			  max frame size: 38400
            			  interval[0]: 1/30
            			FrameDescriptor(10)
            			  capabilities: 00
            			  bit rate: 153600000-153600000
            			  max frame size: 960000
            			  default interval: 1/20
            			  interval[0]: 1/20
            			FrameDescriptor(11)
            			  capabilities: 00
            			  bit rate: 73728000-147456000
            			  interval[0]: 1/10
            			  interval[1]: 1/5
            			FrameDescriptor(12)
            			  capabilities: 00
            			  max frame size: 1382400
            			  default interval: 1/15
            			  interval[0]: 1/15
            			FrameDescriptor(13)
            			  capabilities: 00
            			  bit rate: 98304000-98304000
            			  max frame size: 2457600
            			  interval[0]: 1/5
            			FrameDescriptor(14)
            			  capabilities: 00
            			  bit rate: 104857600-104857600
            			  max frame size: 2621440
            			  interval[0]: 1/5
            END DEVICE CONFIGURATION
            *** END DEVICE LIST ***
            voxl:~$
            Here I try to open the camera with voxl-uvc-server:
            voxl:~$ voxl-uvc-server -v 0c45 -d
            loading config file
            Enabling debug messages
            width:                            640
            height:                           480
            fps:                              30
            pipe_name:                        uvc
            voxl-uvc-server starting
            Image resolution 640x480, 30 fps chosen
            Vendor ID 0x0c45 chosen
            UVC initialized
            Device 0c45:0000 found
            uvc_open failed
            UVC exited
            voxl-uvc-server ending
            voxl:~$
            I've also tried the camera on BeagleBone black, it works fine out-of-the-box. It seems this is just a problem with VOXL. My hypothesis is that the kernel on the Yocto side is too far out of date, or at least that updating it would fix it. See my original post for the output of uname -a. Do you think this my be correct?
            • D dbrophy
              loading config file
              Found device 0
              Found device 0
              Found device 0
              Found device 0
              Found device 0
              Found device 0
              Found device 0
              Status: idle
              VideoControl:
              	bcdUVC: 0x0100
              VideoStreaming(1):
              	Formats:
              	MJPEGFormat(1)
              		  bits per pixel: 0
              		  default frame: 1
              		  aspect ratio: 0x0
              		  interlace flags: 00
              		  copy protect: 00
              			FrameDescriptor(1)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(2)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(3)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(4)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(5)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(6)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(7)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(8)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(9)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(10)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(11)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(12)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(13)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(14)
              			  capabilities: 00
              			  interval[0]: 1/30
              		  bits per pixel: 16
              		  default frame: 1
              		  aspect ratio: 0x0
              		  interlace flags: 00
              		  copy protect: 00
              			FrameDescriptor(1)
              			  capabilities: 00
              			  interval[0]: 1/5
              			FrameDescriptor(2)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(3)
              			  capabilities: 00
              			  interval[0]: 1/10
              			FrameDescriptor(4)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(5)
              			  capabilities: 00
              			  interval[0]: 1/10
              			FrameDescriptor(6)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(7)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(8)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(9)
              			  capabilities: 00
              			  interval[0]: 1/30
              			FrameDescriptor(10)
              			  capabilities: 00
              			  interval[0]: 1/20
              			FrameDescriptor(11)
              			  capabilities: 00
              			  interval[0]: 1/10
              			  interval[1]: 1/5
              			FrameDescriptor(12)
              			  capabilities: 00
              			  interval[0]: 1/15
              			FrameDescriptor(13)
              			  capabilities: 00
              			  interval[0]: 1/5
              			FrameDescriptor(14)
              			  capabilities: 00
              			  interval[0]: 1/5
              voxl:~$
              loading config file
              width:                            640
              height:                           480
              fps:                              30
              pipe_name:                        uvc
              UVC initialized
              uvc_open failed
              UVC exited
              voxl:~$
              @dbrophy It's hard to say. Most cameras I have tried on VOXL with UVC didn't immediately work. I had to debug and make some tweaks to get it to work. That's why we list the specific cameras we have tested with in our voxl-uvc-server documentation.
              • D Offline
                D Offline
                dbrophy
                Yes, I saw one camera you mentioned on there, but the SKU was wrong, so it is impossible for me to know which camera you are referring to. To quote the documentation:
                You can find the Arducam Specs and Selection guide by going here.
                The Arducam B0229 is an excellent choice.
                The B0229 is not an Arducam camera. It is a camera cable for Raspberry Pi. I would use some webcam listed on your UVC page, but I need a wide viewing angle and preferably IR support. Refresh rates less than 24Hz aren't really acceptable. They just don't really fit the bill.
                Maybe you know of a camera that would work? I'd prefer to get what I bought working, but I can get something different if necessary.
