Qin YangQ
Qin Yang
@Qin Yang
  • Issues about ssh RB5
    Qin YangQ Qin Yang
    @Alex-Kushleyev Thank you very much for the solution, I fix it and it works. : )
    Development Drones rb5
    Qin YangQ Qin Yang
    @tom Thank you very much, I got it.
    Qin YangQ Qin Yang
    @tom The serial number is M22000006H2, please check the picture for more details. By the way, this rb5 bought in Sep. 29, 2023.
    Qin YangQ Qin Yang
    @Moderator Thank you very much for your suggestions. Currently, I install the latest version 1.1.2. And everything looks back in normal.
    However, in the process of installation, I met some errors and I did not know whether it is a big issue.
    Also, I found my original file miss some file : "opencv_stereo_intrinsics.yml" and "opencv_stereo_extrinsics.yml", can you send them to me.
    Please check the pictures for more details:
    Qin YangQ Qin Yang
    @tom Thank you very much for your guiding. It works.
    However, I got another issues about the camera. I follow the instruction How to Connect VOXL to QGroundControl over WiFi
    , but my rb5 did not have any video showing in the QGC. And I run the voxl-inspect-services and found voxl-streamer did not run. Moreover, my rb5 software might be an old version since I can not find the command like: voxl-inspect-mavlink. Can you give me some suggestions?
    please check the below picture:
    Thank you very much for your help and support.
    Qin YangQ Qin Yang
    @tom Yes, the macbook and rb5 both connected to the hostpot. By the way, I installed the macbook with Ubuntu 22.04 not MAC OS.
    I did not use the voxl-wifi station SSID PASS on the rb5. I just follow the link text.
    Can you guide me how to do that?
    Thanks.
    Qin YangQ Qin Yang
    @tom So, what should I do for the next?
    How to setup it?
    The network I used is TModile 5G in the Ipad and I turn on the hotspot to connect the rb5 and the host PC.
    Qin YangQ Qin Yang
    @tom Sorry, I want to update something.
    I can ping 127.0.0.1, but I can not ssh it. please check the picture:
    Thanks.
    Qin YangQ Qin Yang
    @tom My host PC system is ubuntu 22.04, is that an issue? since I looked at the instruction which suggest 18.04.
    Thanks
    Qin YangQ Qin Yang
    @tom Thank you for your reply.
    I list the full output of ifconfig, can you help me figure out which IP I need to use in the ssh? I tried 127.0.0.1, it also did not work.
    Qin YangQ Qin Yang
    Hi Everyone,
    I bought a Rb5. Currently, I follow the instructions to connect my PC to rb5, but I met some setup issues.
    The problem is that my host PC and the RB5 are in the same 5G network. My rb5 can ping my host PC and google.com, but my host PC can not ssh the rb5.
    Please check the pictures.
    I did not know what is going on here, can you help me solve it?
