Prasanth Kumar DubaP
Prasanth Kumar Duba
@Prasanth Kumar Duba
  • VOXL Mapper
    Prasanth Kumar DubaP Prasanth Kumar Duba
    Dear Team,
    Voxl mapper is not visible in opkg-directory and also install_on_voxl.sh is not available in git repository hence it's throwing a error.
    Please check and let me know.
    Regards
    Prasanth Kumar Duba
    Ph.D Research Scholar
    TiHAN-IIT Hyderabad
  • VOXL_Flight Deck : Issue in Viewing Point Cloud from TOF Sensor/ tracking image sensors
    I would like to view the point cloud data from TOF , tracking image and stereo image sensors data in ROS platform. After gone through the steps, identified the tof and stereo are not advertising. Please check the console output and help me in this regard.
    roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    ... logging to /home/root/.ros/log/e9401558-1dd3-11b2-8acb-18473db1c7ad/roslaunch-apq8096-3329.log
    Checking log directory for disk usage. This may take awhile.
    Press Ctrl-C to interrupt
    started roslaunch server http://192.168.8.1:45675/
    SUMMARY
    PARAMETERS
    • /mpa/voxl_mpa_to_ros_node/image0_pipe: tracking
    • /mpa/voxl_mpa_to_ros_node/image0_publish: True
    • /mpa/voxl_mpa_to_ros_node/image1_pipe: hires_preview
    • /mpa/voxl_mpa_to_ros_node/image1_publish: True
    • /mpa/voxl_mpa_to_ros_node/image2_pipe: qvio_overlay
    • /mpa/voxl_mpa_to_ros_node/image2_publish: True
    • /mpa/voxl_mpa_to_ros_node/image3_pipe:
    • /mpa/voxl_mpa_to_ros_node/image3_publish: False
    • /mpa/voxl_mpa_to_ros_node/image4_pipe:
    • /mpa/voxl_mpa_to_ros_node/image4_publish: False
    • /mpa/voxl_mpa_to_ros_node/image5_pipe:
    • /mpa/voxl_mpa_to_ros_node/image5_publish: False
    • /mpa/voxl_mpa_to_ros_node/imu0_pipe: imu0
    • /mpa/voxl_mpa_to_ros_node/imu0_publish: True
    • /mpa/voxl_mpa_to_ros_node/imu1_pipe: imu1
    • /mpa/voxl_mpa_to_ros_node/imu1_publish: True
    • /mpa/voxl_mpa_to_ros_node/stereo_pipe: stereo
    • /mpa/voxl_mpa_to_ros_node/stereo_publish: True
    • /mpa/voxl_mpa_to_ros_node/tof_cutoff: 100
    • /mpa/voxl_mpa_to_ros_node/tof_pipe: tof
    • /mpa/voxl_mpa_to_ros_node/tof_publish: True
    • /mpa/voxl_mpa_to_ros_node/vio0_pipe: qvio
    • /mpa/voxl_mpa_to_ros_node/vio0_publish: True
    • /mpa/voxl_mpa_to_ros_node/vio1_pipe:
    • /mpa/voxl_mpa_to_ros_node/vio1_publish: False
    • /rosdistro: indigo
    • /rosversion: 1.11.21
    NODES
    /mpa/
    auto-starting new master
    process[master]: started with pid [3348]
    ROS_MASTER_URI=http://localhost:11311/
    setting /run_id to e9401558-1dd3-11b2-8acb-18473db1c7ad
    process[rosout-1]: started with pid [3361]
    process[mpa/voxl_mpa_to_ros_node-2]: started with pid [3375]
    Param: "image3_publish" set to false, not publishing associated interface
    Param: "image4_publish" set to false, not publishing associated interface
    Param: "image5_publish" set to false, not publishing associated interface
    Param: "vio1_publish" set to false, not publishing associated interface
    Starting Manager Thread with 8 interfaces
    MPA to ROS app is now running
    Did not find pipe for interface: tracking,
    interface will be idle until its pipe appears
    Did not find pipe for interface: hires_preview,
    Did not find pipe for interface: qvio_overlay,
    Did not find pipe for interface: stereo,
    Found pipe for interface: tof, now advertising
    Found pipe for interface: imu0, now advertising
    Found pipe for interface: imu1, now advertising
    Found pipe for interface: qvio, now advertising
    Thanks & Regards
    Prasanth Kumar Duba
    IIT Hyderabad
  • Receiver compatible issue with flight deck
    Dear Team,
    Flight deck is not compatible with flysky fs-ia6b and spectrum AR8020T receivers. According to user guide it has to compatible with any 8-channel receiver but it's couldn't happen.
    Kindly check and correct me if i'm wrong in this regard.
  • Integration with Spectrum AR8020T receiver
    @Chad-Sweet I have tried with flysky receiver also but it's not working. Please suggest the receiver which is compatiable with flight deck.
    Dear Team,
    I have connected the AR8020T receiver with the flight deck, but there is an issue with radio calibration in QGround Control software.
    Would you please check the attached image and help me in this regard?
    Regards
    Prasanth Kumar
  • FlightDeck not compatible with Frsky?
    @Mark-Sears
    I have also got the flight deck only. Now, I would like to connect to FS-iA6B receiver. For that given cable is not suitable. Could you please suggest me in this regard.
    Thanks
  • Integration of VOXL on Quadcopter
    I have done Wifi setup, SSH and Installation of software with voxl flight deck using voxl quick starts manual. But, I am unable to find the how to connect my quad copter to voxl. Could you please help me in this regard.
    Thanks and Regards,
    Prasanth Kumar
    Development Drones m500
