Dawid MościckiD
Dawid Mościcki
@Dawid Mościcki
  • QGC keeps crashing when sentinel drone is reconnected
    Dawid MościckiD Dawid Mościcki
    @Zachary-Lowell-0 This could be probably caused by missing sdlog_mode parameter. Maybe it was introduced in one of the commits that modified logger.cpp in src/modules/logger ?
  • Sentinel drone AWUS wifi problem
    I reflashed firmware and reconfigured drone manually (not using automatic scripts which platform detection) and problem vanished. Probably there is something wrong with detecting actual drone version in those automated scripts.
  • Sentinel drone radio stopped working
    If any1 will have similar problems in future don't follow guide : https://docs.modalai.com/sentinel-user-guide-pre-flight-setup/
    See those docs : https://docs.modalai.com/voxl-elrs/
    All You need to do is voxl-elrs -b, then on aperture go to ExpressLRS and choose bind 🙂
    Can be closed.
  • Strange Turbulent Flight Behavior when transitioning into Offboard Mode (Please Help!!)
    In my case similar behavior was fixed by :
    "The thing that is most likely the issue I believe is voxl-vision-hub. There is a program in vision-hub that will automatically do a figure 8 in offboard when it gets kicked off programatically and this is most likely conflicting with your takeoff. The parameters you needs to disable in /etc/modalai/voxl-vision-hub.conf are:
    offboard_mode: off"
    Hi, I'm using Sentinel drone. For some reason RC apparatus stopped working and i can't bind it again.
    When i'm trying to set up bind mode nothing happens. I was following this guide :
    Led is blinking always slowly on blue....
    What can i do about it ?
    I'm using out-of-the-box commando8 (included with Sentinel drone).
    Why this could happen ?
    Thanks for help
  • Sentinel drone voxl qvio server high cpu usage
    For some reason CPU load on qvio-server is very high.
    Output from voxl-inspect-services
    docker-autorun | Disabled | Not Running |
    modallink-relink | Disabled | Not Running |
    voxl-camera-server | Enabled | Running | 71.0%
    voxl-cpu-monitor | Enabled | Running | 0.6%
    voxl-dfs-server | Disabled | Not Running |
    voxl-feature-tracker | Disabled | Not Running |
    voxl-flow-server | Disabled | Not Running |
    voxl-imu-server | Enabled | Running | 5.4%
    voxl-lepton-server | Disabled | Not Running |
    voxl-mavcam-manager | Enabled | Running | 0.0%
    voxl-mavlink-server | Enabled | Running | 3.5%
    voxl-modem | Disabled | Not Running |
    voxl-neopixel-manager | Disabled | Not Running |
    voxl-open-vins-server | Disabled | Not Running |
    voxl-portal | Enabled | Running | 0.2%
    voxl-px4-imu-server | Disabled | Not Running |for some reason CPU load on qvio-server is very high. We also have problem with Alfa wifi modem - every few minutes it's turning off and restarting ... Led isnt blinking for few seconds then network start working again . While this is happening Qgroundcontrol is crashing (as every time when drone is reconnected)
    voxl-px4 | Enabled | Running | 57.1%
    voxl-qvio-server | Enabled | Not Running |
    voxl-rangefinder-server | Disabled | Not Running |
    voxl-remote-id | Disabled | Not Running |
    voxl-softap | Enabled | Completed |
    voxl-static-ip | Disabled | Not Running |
    voxl-streamer | Enabled | Running | 0.0%
    voxl-tag-detector | Disabled | Not Running |
    voxl-tflite-server | Disabled | Not Running |
    voxl-time-sync | Disabled | Not Running |
    voxl-uvc-server | Disabled | Not Running |
    voxl-vision-hub | Enabled | Running | 1.9%
    voxl-wait-for-fs | Enabled | Completed |
    What can I do in order to debug this issue further ? This wasn't an issue until last week (normally it ran at much lower cpu % usage).
    Hi, I' using Sentinel drone. Wifi was working very well untill last week. For some reason now it keeps disconnecting every 1-2 minutes.
    Output from journalctl -xe |grep wlan
    Mar 02 13:11:37 m0054 dhcpcd[1694]: wlan0: carrier acquired
    Mar 02 13:11:37 m0054 dhcpcd[1694]: wlan0: IAID ca:b5:ab:b9
    Mar 02 13:11:37 m0054 dhcpcd[1694]: wlan0: adding address fe80::76d9:b52b:91ff:9629
    Mar 02 13:11:37 m0054 dhcpcd[1694]: wlan0: rebinding lease of 192.168.88.243
    Mar 02 13:11:38 m0054 dhcpcd[1694]: wlan0: soliciting an IPv6 router
    Mar 02 13:11:41 m0054 dhcpcd[1694]: wlan0: probing address 192.168.88.243/24
    Mar 02 13:11:46 m0054 dhcpcd[1694]: wlan0: leased 192.168.88.243 for 600 seconds
    Mar 02 13:11:46 m0054 dhcpcd[1694]: wlan0: adding route to 192.168.88.0/24
    Mar 02 13:11:46 m0054 dhcpcd[1694]: wlan0: adding default route via 192.168.88.1
    Mar 02 13:11:51 m0054 dhcpcd[1694]: wlan0: no IPv6 Routers available
    Mar 02 13:12:28 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-DISCONNECTED bssid=18:fd:74:f3:01:e1 reason=0 locally_generated=1
    Mar 02 13:12:28 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-ASSOC-REJECT status_code=1
    Mar 02 13:12:28 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
    Mar 02 13:12:28 m0054 dhcpcd[1694]: wlan0: carrier lost
    Mar 02 13:12:29 m0054 dhcpcd[1694]: wlan0: deleting address fe80::76d9:b52b:91ff:9629
    Mar 02 13:12:29 m0054 dhcpcd[1694]: wlan0: deleting default route via 192.168.88.1
    Mar 02 13:12:29 m0054 dhcpcd[1694]: wlan0: deleting route to 192.168.88.0/24
    Mar 02 13:12:32 m0054 wpa_supplicant[2278]: wlan0: Trying to associate with 18:fd:74:f3:01:e1 (SSID='autonomy_lab' freq=2452 MHz)
    Mar 02 13:12:32 m0054 wpa_supplicant[2278]: wlan0: Associated with 18:fd:74:f3:01:e1
    Mar 02 13:12:32 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    Mar 02 13:12:33 m0054 wpa_supplicant[2278]: wlan0: WPA: Key negotiation completed with 18:fd:74:f3:01:e1 [PTK=CCMP GTK=CCMP]
    Mar 02 13:12:33 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-CONNECTED - Connection to 18:fd:74:f3:01:e1 completed [id=0 id_str=]
    Mar 02 13:12:33 m0054 dhcpcd[1694]: wlan0: carrier acquired
    Mar 02 13:12:33 m0054 dhcpcd[1694]: wlan0: IAID ca:b5:ab:b9
    Mar 02 13:12:33 m0054 dhcpcd[1694]: wlan0: adding address fe80::76d9:b52b:91ff:9629
    Mar 02 13:12:33 m0054 dhcpcd[1694]: wlan0: soliciting an IPv6 router
    Mar 02 13:12:34 m0054 dhcpcd[1694]: wlan0: rebinding lease of 192.168.88.243
    Mar 02 13:12:39 m0054 dhcpcd[1694]: wlan0: probing address 192.168.88.243/24
    Mar 02 13:12:44 m0054 dhcpcd[1694]: wlan0: leased 192.168.88.243 for 600 seconds
    Mar 02 13:12:44 m0054 dhcpcd[1694]: wlan0: adding route to 192.168.88.0/24
    Mar 02 13:12:44 m0054 dhcpcd[1694]: wlan0: adding default route via 192.168.88.1
    Mar 02 13:12:46 m0054 dhcpcd[1694]: wlan0: no IPv6 Routers available
    Mar 02 13:13:34 m0054 dhcpcd[1694]: wlan0: carrier lost
    Mar 02 13:13:34 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-DISCONNECTED bssid=18:fd:74:f3:01:e1 reason=0 locally_generated=1
    Mar 02 13:13:34 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-ASSOC-REJECT status_code=1
    Mar 02 13:13:34 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
    Mar 02 13:13:34 m0054 dhcpcd[1694]: wlan0: deleting address fe80::76d9:b52b:91ff:9629
    Mar 02 13:13:34 m0054 dhcpcd[1694]: wlan0: deleting default route via 192.168.88.1
    Mar 02 13:13:34 m0054 dhcpcd[1694]: wlan0: deleting route to 192.168.88.0/24
    Mar 02 13:13:38 m0054 wpa_supplicant[2278]: wlan0: Trying to associate with 18:fd:74:f3:01:e1 (SSID='autonomy_lab' freq=2452 MHz)
    Mar 02 13:13:38 m0054 wpa_supplicant[2278]: wlan0: Associated with 18:fd:74:f3:01:e1
    Mar 02 13:13:38 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    Mar 02 13:13:39 m0054 wpa_supplicant[2278]: wlan0: WPA: Key negotiation completed with 18:fd:74:f3:01:e1 [PTK=CCMP GTK=CCMP]
    Mar 02 13:13:39 m0054 wpa_supplicant[2278]: wlan0: CTRL-EVENT-CONNECTED - Connection to 18:fd:74:f3:01:e1 completed [id=0 id_str=]
    Mar 02 13:13:39 m0054 dhcpcd[1694]: wlan0: carrier acquired
    Mar 02 13:13:39 m0054 dhcpcd[1694]: wlan0: IAID ca:b5:ab:b9
    Mar 02 13:13:39 m0054 dhcpcd[1694]: wlan0: adding address fe80::76d9:b52b:91ff:9629
    Mar 02 13:13:39 m0054 dhcpcd[1694]: wlan0: soliciting an IPv6 router
    Mar 02 13:13:40 m0054 dhcpcd[1694]: wlan0: rebinding lease of 192.168.88.243
    Mar 02 13:13:43 m0054 dhcpcd[1694]: wlan0: probing address 192.168.88.243/24
    Mar 02 13:13:48 m0054 dhcpcd[1694]: wlan0: leased 192.168.88.243 for 600 seconds
    Mar 02 13:13:48 m0054 dhcpcd[1694]: wlan0: adding route to 192.168.88.0/24
    Mar 02 13:13:48 m0054 dhcpcd[1694]: wlan0: adding default route via 192.168.88.1
    Mar 02 13:13:53 m0054 dhcpcd[1694]: wlan0: no IPv6 Routers available
    Could You please provide help ? I have no idea how to fix this issue. This issue keeps happening even when drone is stationary on ground.
  • Position mode works, but offboard mode don't
    I will close this ticket and make a new ones. This conversations is too long, sorry for that 😕 Thanks for help so far !
    Hi, Im using sentinel drone.
    When drone is connected for the first time to QGC everything works. After lost of signal and reconnection or just powering off drone then powering up QGC is crashing.
    Output :
    Settings location "/home/autonomylab/.config/QGroundControl.org/QGroundControl.ini" Is writable?: true
    Filter rules "*Log.debug=false\nGStreamerAPILog.debug=true\nqt.qml.connections=false"
    System reported locale: QLocale(English, Latin, United States) ; Name "en_US" ; Preffered (used in maps): "en-US"
    MAVLinkLogManagerLog: MAVLink logs directory: "/home/autonomylab/Documents/QGroundControl/Logs"
    Map Cache in: "/home/autonomylab/.cache/QGCMapCache300" / "qgcMapCache.db"
    qml: QGCCorePlugin(0x5559f952fc80) []
    setCurrentPlanViewSeqNum
    _recalcFlightPathSegments homePositionValid false
    "v4.3.0"
    Adding target QHostAddress("192.168.88.243") 14550
    ParameterManagerLog: Attemping load from cache
    ParameterManagerLog: Parameters cache match failed /home/autonomylab/.config/QGroundControl.org/ParamCache/1_1.v2
    QCoreApplication::postEvent: Unexpected null receiver
    VideoReceiverLog: Stop called on empty URI
    corrupted size vs. prev_size while consolidating
    Aborted (core dumped)
    In my other project this type is behavior was caused by my custom px4 module with new set of parameters. Maybe it's possible in Your software as well?
    this is output from journalctl :
    Idk wifi keeps disconnecting. Could You please help me ? And every time when wifi is disconnecting and connecting again, QGC is crashing 😕 This behavior could be caused by px4 modules shipped with Your forked version of px4 ...
    @Alex-Kushleyev for some reason CPU load on qvio-server is very high. We also have problem with Alfa wifi modem - every few minutes it's turning off and restarting ... Led isnt blinking for few seconds then network start working again . While this is happening Qgroundcontrol is crashing (as every time when drone is reconnected)
    @Alex-Kushleyev Thanks for help, after changing propellers everything seems to work normal, but somehow RC apparatus stopped working. When i'm trying to set up bind mode nothing happens. I was following this guide :
    @tom this is my dump from /data folder : https://drive.google.com/drive/folders/1ZJXCvCcAg81zJolngtlS-Y_re2BjY2pz?usp=sharing
    @tom this is my second try https://review.px4.io/plot_app?log=cba05321-9bb5-42f2-a766-ecfa6ee01f80
    @Dawid-Mościcki after importing parameters for vio-indoor without gps from https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/EKF2_helpers/indoor_vio_missing_gps.params
    i only armed vehicle to see vibrations : https://review.px4.io/plot_app?log=c70ab712-72c1-4abf-b954-edda6316bf05
    What could I do next ?
    @tom i created backup from /data folder on my pc, but i don't know if this could be helpful
    @tom after flashing, i've got problem with calibrating IMU, btw should 2 imu be present ? because i can see only one :
    voxl-calibrate-imu-temp
    voxl-imu-server currently has no calibration file
    Server has IMU0 enabled and available for temperature calibration
    WARNING, voxl-fan utility missing, can't turn on fan
    We're now starting the COLD stage of the calibration.
    Please stop all unnecessary services in another terminal, and try your best
    to cool the PCB with a fan. Alternatively, start this process on a cold PCB.
    We will be measuring the static gyro and accel offset as the board heats up.
    VOXL must remain completely still through this entire process!
    The IMU temperatures will be printed here continuously.
    Press ENTER to start the heating process when you are happy that the IMUs
    are cold enough for the lower bound. 25-35C is a reasonable goal for this.
    CPU: 36.3C IMU0: 30.4C ^M
    WARNING, voxl-fan utility missing, can't turn off fan
    We're now starting the HOT stage of the calibration. We just turned off
    the fan, and started stressing the CPU to heat up the PCB.
    This will run automatically for a while collecting data points until enough
    data has been collected, something gets too hot, or the timeout is reached.
    CPU: 57.1C IMU0: 34.9C all imus reached steady state, finishing test
    taking sample #2
    not enough samples, need at least 3
    @Zachary-Lowell-0 what do You mean by SDK ? Is this guide that i should follow, but without full wipe ? https://docs.modalai.com/sentinel-factory-reset/
    @Dawid-Mościcki i don't even know how's that possible https://review.px4.io/plot_app?log=973783b8-6262-46e3-8214-602dce495131
    look at actuator FFT
    @Dawid-Mościcki Any 3D files for this drone are available for download ? For example landing skid ?
